EAGLE User Support (English) SO8 powerpak eagle package (Vishay SI7288-T1)
  • Subscribers 179 subscribers
  • Views 784 views
hisham.i
hisham.i over 10 years ago
I am not able to find SO8-powerpak eagle package in the eagle library for mosfet SI7288-T1.
Please share if available.
Thanks.
  • hisham.i
    Any update on this request please.
    autodeskguest over 10 years ago in reply to hisham.i
    You could have created one yourself in the time it took to post the
    original request. Even if you're a total beginner without a clue, you
    could have learned how to create one yourself, done so, checked it,
    played around, made a new and improved one and posted it up on the
    Cadsoft user contributions area... in the time you've apparently been
    waiting around. Why didn't you?
    Hisham Issa wrote on Fri, 25 December 2015 09:29
    Nope, nobody has come forward in the last 7 days to save you from this 15
    minutes of work.  Your project could be on hold indefinitely.  Or, you
    could just do it yourself.
    Nah, silly me, what was I thinking.  Nevermind.  It's much better to spend
    over 600 times longer waiting for someone else to do your job for you.
    Hello Hisham,
    I hope you're doing well. As Olin and Rob have said in less amicable
    terms, usually the best way to get a part made is by making it yourself.
    You can search for components on schematicpal.com or look through
    Newark's libraries for pre-existing parts but once you know how to make
    a part in EAGLE, you might find it faster to just make the part yourself.
    hth,
    Jorge Garcia
