EAGLE User Support (English) Circle command at the commnd line
  • Subscribers 178 subscribers
  • Views 1105 views
Former Member over 15 years ago
I am having a problem obtining a circle of a specified diameter with the
circle command.  I am moving objects from one library to another by using
scripts, and have keepouts over through hole pads to keep surface mount
devices with IPC standard courtyards in the keepout layer a sufficient
distance away.
The example given in the help files
circle (0 0) (1 0)
produces a circle of diameter 1 and centre the origin.
If, however, I move the center of the circle to, say (5 5) and execute the
command
circle (5 5) (1 0)
Eagle draws a circle of radius 6.403122 at (5 5) .
On further experimentation I discovered that the command
circle (x y) (r 0)
produces a circle with centre (x y) and radius (y2 + (x-r)2)^0.5 .
I tested this on Eagle 4.16r2 with the same result.
What gives?
Cheers
    "John Chapple" <jrchapple@sympatico.ca> wrote in message
    news:i03mbq$u47$1@cheetah.cadsoft.de...
    >distance away.
    circle (0 0) (1 0)
    command
    circle (5 5) (1 0)
    circle (x y) (r 0)
    What gives?
    Cheers
    Hi John,
    The first point is the centre of the circle and the second is a point on the
    circumference.
    The comand to draw a circle of radius 1 at 5 5 is: circle (5 5) (6 5);
    regards
    Former Member over 15 years ago in reply to Former Member
    Thanks very much, Greg.
    Cheers
    "Greg Erskine" <gerskine@tpg.com.au> wrote in message
    news:i041p9$s09$1@cheetah.cadsoft.de...
    >>distance away.
    >> circle (0 0) (1 0)
    >> the command
    >> circle (5 5) (1 0)
    >> circle (x y) (r 0)
    >> What gives?
    >> Cheers
    >> John
    Hi John,
    the circumference.
    regards
    John Chapple wrote on Fri, 25 June 2010 21:49
    circle (0 0) (1 0)
    It shouldn't.  The diameter should be 2, not 1.
    Quote:
    circle (5 5) (1 0)
    Sounds right.  What's the problem?
    Quote:
    On further experimentation I discovered that ...
    Here's a heretical thought, READ THE MANUAL instead of poking around in the
    dark guessing what the command does.
    Quote:
    What gives?
    Apparently your unwillingness to read the documentation.  If you had
    bothered, you'd know that the two points you specify are the center and a
    point on the circle.  So
    CIRCLE (3 2) (4 2)
    will produce a circle centered at 3,2 with a radius of 1.
