EAGLE User Support (English) Numberous DRC Overlap errors!
  • Replies 12 replies
  • Views 26356 views
This is my first Eagle project, and also my first post to the forum.
Help would be appreciated!
I am using Windows version 5.10.0
After manually drawing wires for my power buses, I did an error check. Got
a substantial list!
I learned that the newly added wires where all misnamed, and just because
they touched the pads from component to component they did not replace the
approbate air wires.
So I discovered the need to Name them. And this really helped...!
Now I have eliminated all the errors except the 15 overlap errors.
I can't figure it out...
So I'll attach a zip file with the schematic and board included.
Please advise, as I am truly baffled, and stuck. I need to fix these before
I allow Eagle to auto route the rest.
Thanks, in advance.
Jack
begin 644 v3_2.zip
M4$L#!!0``@`(`!BOW#SKA(9M,DP``#TV`0`3````1&EG:5-L:61E<E]6,RXR
MG-C:.U]"7R5Q;G^G"0L`81`")SC$)02'*6G"185$+"IBPQP4!%D0`!<H40
M0U#0WB:M.ZV66FNQ?VO1+MK-2ZVUUI]5VGJMM;9:VTNM56I[NWB]:E$1E.7,
M?YZ9[_V^]YOSG7-"J*WUBC\<YCGOO#/O,OM\,P7=$?'P0"'Z#,B;+L2\G$_M
MF+CN[3MG?'BHV!*=>?H.5_[>4&]T\AAO((^^<P(61("/'Y6_'G:V==,?R>
M.7^X_JS"L604$$H3SA_%F]L-_\H%!,0J$0X3,W=G9NW*#Q(4.'AG((KV]>
MO<FA[S=LF(<WM3:[>&%AJ"_AY[5U;-S<V;(:?(8/#PTAO*YU0TO;IM:-;0HO
M&A'J1WAG_?KF52V:SXDCBCQ\I8</.7&DQZ=S44?KVM:V3:`?>:*'K_3P(:-&
M,_XFS>T;#\1X]B_#U\R)BQC+ZI>?UF_*#HQXYA]!X^<-SX7(^^L=-HM%`4
MCA_7UZ/W\($3PGD>?6U'2[/1<V%X0A^/WL-S3RK.=?79.;NUK773.DU??%)?
M%U_IX;DGG\+XSU'%=,ISRLF,OX?WFSB)R;NX95.GP4<-)')Z&Y)9,'NO[3
M>4Y2[NR,/A/AGH^L]*#
]];0!'GV#XM/1NJI3T9]VZ@"/WL-SITP9X/K5
MI0R?.M4K3UU'Z_KUQEZYI:4>/G?C>FU&V&L)1^`)%WMJV5LM;7N[1VAI
MWK2YHP5^TB\28?PWKMJL/!3E[Q>->GA#RYJ6CI:V52V*?[R"Z0T)'+U5Q)G>
M/'S(LF5>?5G8TDGU9<@%%[!ZMWG3)L</<R\D-4[+)#OWRY5W\;MVY8N7&]
M]L,A%UWDY4ON#'S%"@\GMP7>W.SA\]K6;"3*U=Z]7?.YM;5VD&=X?$X`%"
M?-0MJN@2K_P@KZA;M54J,E[]C0`<H4`5GJAPA$3>=9+!JQ0?)=75\VH!)A38
M-16_5"H\)/BE;.KJTFV1O6_Z=T3)Y441V.33SUMRM32LO*>.2DDT\1HK3;
M8?B%Q)S3HGJ?X]4^#B>[R3[S@Q5NPZ5'.TOL\?M5C\7F2J.-C5.[=XN=
M7\T3=Y\:$I\67><;:B&`K_CP8=G^&-K8KG4<!_V+GPR)SXB&FDAYS<((PT?N
M,WA4X5'&!WBAZ-IL\P<?A5]OXRB/PK]@XTOW)*7"OVWCX4T:?]C&7QJB\2=L
M?-<WCP)_UI8&=$UY]M''P4_KJ-(U%)VT<Y53XB%<M'/I4^.17K?@WT6B
M2=O<X#,T_OAM4FI\1M3'!W\^YKJZA@]<-!KW$O[HXO7U>;)[;,.RIW/'18
M(MS7S^`41UC?F",XCCC2<9SBQ`]XM#MT$>A?N2I'/%@<5CF>N;!FP2S@*[9/
MD[^62D=O*EF_GFS0']55:[(ZYRT7'`C0S`_U1T1#)<ZV*4\N=R[L^51G/C
M19D8>OE_XH'%%BCP,;&1?6QR)1N$7KX!BG7=$CY=_YJ`I:$<"[_+A,<O
MV>W#XX2__%L?7D'XPC=]>(+P>P<)P?!*PD=,\N%5A%]E@O)GSO4A\^C?"9
M'3X\&F'XYV\0@O`HX\/Q&,N7XW%63HY7:/^)%&V_6,KVSZN_-PN!\.U<@U,<
MX7;52G(<<:0C?%+WOOB3UTA9N4;*73<K&79([?/`RW<:O/`>/_Z9[QO\LI_X
M\8//&/QWKQ9:\8Q#?OP1U4`#_UADHWA)T\P>]2/WY]M<$WS/;CKYYK
M\%]>Y,?/O=C@B:U^?)'"(ZK/C2O\B5N-_PWW,-M1%?OS::H-?/-N/GS!
MX/U+/9S\C=LKP?R3XY7,GSE>Q?R?X]6LOG!\FH.C?C$\%G'N;N/>>7"_WE
MOU#9!7B-L@O'WWG&X"\Z,<_WV#;_V)'X_N-'C1/7[\Y]<8_-LW>[AJ3T;=
MMTS2Y1__FD:D_RW'9IS/#?",%PW2XI/F.MM;00[Y/M1@Z-\7J5!U_>(%
MU7-V;7G5[=\7\G;IVE?=_GV"%U5J\%;%*C_Y?3OOC_12'F%ZM'#A,!?RK-
M.,&B3V2DSTVAK\Q(GV?1)[P[Y-"GYE_WQ3ZJHST_5HJS/2]T^AGY:1/M\/
MQ<H2Y;%,]`-2Z2LRT0],I4]DHA42E9B?X$BSY6'HUDHA^<2A_-1#\DA3ZS
M?0M2Z#/;=V@?6;[6C_$JK4OS"5/IZ)?G@J?49[%:725V6B'Y%"'\MHKQ-3
MZ#/[\T@_%,]6_E&I]-,RT8].H<]<_C%^2-6NLHSE&6O3QT5&><>ET&?F/]ZF
MK\A,/\&F3V0N3SB%/C/_DVSZJK,[4^Q'ZI2[4-&?SXYE3YC>W5*GW&\D],
MI<_87DVR_'EJHC1M3/-9_-Y/_N35YWY;'Q2VY/K@T-TC_5NO,@$U:O$F)/
M*.KR)!QSDJ90S,4G=4>6[]QEYBDK5$<_^14:OQD<?X%O>=3@Q=UB.4+,LQ#B
M]T,Y'DY_P`<XYC77?4B(/ZK&V)X?`>^8ZY\?8;[SO$I'NNO:0_.=8>)P\ANR
M3^@.!?X9XXIH9&:%.*T[1\L$VF<+IYQ&\QW@F&LR/$;CHL&72SE3E?87(R>[
MY5'ESITI92WJ=0(0>O,[\9`]H\_@O'29><H+_OJX8>(=$#__7-)E_"'?T4
M41SAZE](2?13+W;HKO33N_$K_?0O#C4V";\F!$*B?SL4$M`I0I29<-#!3DC'
M[%74/YF4H$.(=)P>?(F?PK=P/A[_\!6<C\<_?#GA2$_E57RV&CO>JNRX2]GQ
MA->,'1.]LB/H3]EP;':\Y;OO3NBGD*O"D=2?_<7J!#O4,ZA-R.H$/(_8'X
M$C]N1Z3W^'MV)#\Q_#T[(CV5U[/CU<J.CV(=S[%C9:_M>*3[V.R(<KZ7[%AP
MF;$C0FY'TCW%CV76?TC)#;$70(N3\07^+'[8CT'G_/CN0GAK]G1Z2G\I(=
M;U/U<77H?F7'"[4=$TY]7/B[9`=[STE%&A'T,^SALSF;?S8]#>PEX.[MH+
M=H>]R%](GQ1'R/5\]@6&'B&GISA"FQXX],3M2/RA!XZ?OL+4$X2\WJV<;_1[
MW>2OGKWV!=-?4'(ZQWHH&>DXW:D..5#=B37K[&CL3?R]?8D?*C?#P[7JWL
M^(2R8[=CQ\I>VQ'U\5_9CJ1G;B_H&?4!>N/U#OH$'4)N+]"AGB`=K]<4IWRX
M'<'7R]>S(_D/KX4'7CV;%#V7&OLN.7'#M6]=J.:/N"[(@V[U_!CJ1G;B_H
M>>1FHT^$W(Z@0\CM!;J7MAD[(N1\$*=\N!W!U\O7LR/YC\G7LR/24SZ>'9<K
M.[ZA[/B88\?J7MOQFW<'VQ%^]:]@1](SMQ?T/*/9Z!,AMR/H$')[@6[W[<:.
M"#D?Q"D?;D?P]?U[$C^8_U[(CTE(]GQT7*CJJ3[?H?QX[3>FW'&[_WKVU'
MK"\CQ'H_U__R!J-/A-R.H$.(=-R.=W[V!$AYX,XY</M"Y>OIX=$??R]>R(
M])2/L>-P<;OLDB^(CZKZ..AORHZQLD1I#/:"3K2\0VHF<#O>YDR?'3SFS'^+
MOOX-H>FQ4+34/D1!R_\CI!PS#5WE0B!$/-LPA^0TK@"#E.?"D=Z8'H*7_(
MQ?/U!O]$%O/%H_<9+KCX/]=J?X_E^G.(('QTGQ(&\5'SZ'Z4D?/@![&$
M@1"_<UR?)5"A30]\_.L?XM3G.SCK">,PEP<\TH7T`]`O[\3?YY@;'[&F7W
MSRF[Q\CN%;VU[=;>R.D-L+\TK\CI#;_:,SC!U1-FYWX`@Y3GPI';<[XI0_
MMSOR\_A[=D?<*\_[QZ0.<CN:$-3[;Y$/BNJNS>1'9/]-;N\S]L[(Z0VPOC
M*/R.D-L=XW.$?!X!NP!'R''B2FXW1&G_+G=D9_'W[,[XEYYWA]V_2#9MW!
MMCMPS-53[7Z#;`]=HNQ.=F]LK=VQWP6D;([85V!K\CY'9'.1'R>0?L`APA
MQXDOI>-V1YSRYW9'?AY_SZ(>5Y?]B];)TIAVUWM&F0V6_W86+_T:ER4$Z5
M&J?=I>S>=;OZG[;OY;-IG*8UXMK]FN_3.$WCKMW?&)"4%SPMQ."W0@(AZ>E:!#B'2$#WLGJ=MQA'R<1G&$D-%9
M[QJ%\L]]#NOG?CU@G`:[.[@[;L39!'R/E3'"'QI)#3I/_)#D\N0U_D9R
M>?*:<1?)2?HCOWW[&B]?[F\D;_M(=</C1V+E1UKE!WWP(X_/QX[0F0`R&W
M(]8B$4*'W(X/3#1R(>1V!!U"I#L>.U;\Z=VU(0D;@=(8\GKV='Q#UY/3LB
M/>FO]W:\6MD1ZQAYY0=CQR/'3&_AAQ\7@]YT$XBY.TJZ#!/1SJ;@"Y0(>0
MK_/TQHY8'WLW[0@Y23YN1\CCR>O9$7%/7L^.2$_ZZ[T=.Y0=L8X1A1U/W7<<
M=L3\&G+P>3WD(7FYO4"'>3K2\74#R`4ZA-P?>F-'K(^]FW:$G"0?MR/D\>3U
M[$AR]>72$[27_MN%C9L4"UJ\MAQZ;CL2/6HR`'0FY'Z!,AQF7<CHN7&+D0
M<CN"#B'2'8\==]S[[MH1<I)\W(Z0QY/7LR/BGKR>'9&>]-=;.WY6]8\7Z_[Q
MD[#CE63'ZI>.:OIS3[SJ#&['QT\T)D<W+4CSGJC?<>99MX_3EYK@^$O'\$
M'?H)I./]X[,[3#"\'CZ1Y3_W>P?24Z2CQ(<GGR&CN27)Z\QHXD)^F/['CC
M],QV[/BQ;<?#R8MS6I4=?P`[WG<\=L0>(.1`R.V(M3V$6,OC=L1>(-(AY'8$
M'4*D.QX[_FE@Z%VU(0D;@=(8\GKV='Q#UY/3LB/>FO]W;\E;+CIY4=7X,=
M_WP\=L1W'Y`#(;?CTT5&WLC+29\=44:D0\CM"#J$2'<\=KPY_N[:$7*2?-R.
MH/7D]>R(N">O9T>D)_WUWHZ[E!V_H^PXX75EQQ&O'X<=L68-.1!R.VZK-O)>
M^A._';%6C70(N1U!AQ#ICL>."YO>73M"3I/VQ'R>/)Z=D3<D]>S(]3_GIO
MQW9EQ_W*CO6PXYSCL2.^SX(D)_WUUHY/'?E5,IJ+_G$7['@7V?'QDXP=GQSEMV/U7F-'
M!W?M..,O1W3[OGM4KJ]_W%&:J_L/A+Q_!!W*B'2\?USWS!'=CR`\GOX1Y7\W
MT>2D0C.Y)<GKS&CB27)ZQ(\E)B,[OG+CT8QV''Y)CF7'7<J.#R@[_AYV
MW',\=M1[]DH.WC]"'K3_"'G_"#J]5Z_2\?X1<H$.X?'TCRA_W;)WUXZ0D^3C
M=H0\GKR>'1'WY/7LB/2DO][;L5W9$?WCX#>4'?N\<1QV1/L..7C_"'G0_B/D
M_2/HT$\@'>\?(1?H$!Y/_XCRI^L?_UYVA)PD'[<CY/'D]>R(N">O9T>D)_WU
MUHX;9)?\A3[/4*%,6)N8&2M+0`_8`PS:'P=N[X]KN]\6O"&M<.@?;&1\%#
M"(3`]O?Q</W-@@IC?Y72QND;`G>]:!#**,1?G`_!B)[B"#D?PB$;YU/<;LY%
M(.3G*`GC#VE-ZXV>TN$[_V4.2>!T#E?8=:UKC;GI".G^L@G-%O(1Q\B1_9
MG<I!9/=J9R,_U9CQ\WR07&=LN,%QHYQQY573IGI=H1.-8)WX]VA%X0<GM!
M7\@3N;?-4#OI'_;7N"-=/R[!L(9O6M'\"5W(Z(4_[<CN0G#G_'CA<K.]ZD
M[/AQQXYEB6.U"]D=^_Y!=L?]`/:Y]_>B'8$AY/:"OK!G#WTCY'8D_=OV@O\C
M'4(;9_2N'<&7^'$[(D[Y<SN2GSC\'3LN47;$N9&[C1TKCMV.[S6[D%\%G:,`
M;I^C(/W`#Q'R\RIT?ACZYN=>H'?0(>3GX4&'\RM(Q\_/$,[H73N"+_'C=D2<
M\N=V1'K&W['C3<J.^,[H:6/'A#-/?!_8T?[NB>P(O039$7I!R.U%YTZA;[Y_
M"KV3_FU[04=(Q_=/"6?TKAW!E_AQ.R).^7,[DI_P[QHVR$\I.SZH['C`L>/[
MISYB7^]8[`C9$/KVNR\WXSKHFY]'@MY)_[:]X#](Q
U$<[H73N"+_'C=D2<
M\N=V)#^A\TO&CAODE\4?E!W'OZGM6%46ZXT=R1ZGO.:W"\41XMP0C=LYCO-(
MA.\M,.>+]CH?\G,\J%\C'"'Q(3MBG<2V([X3^\L-P7:$3A%"1]R._#=N1_R&
M$+]Q>_'?;)S1NW8$7TK#[8@XY<_MB#2,O[9CI1JO/J''J[-AQZHR-=*!O>B[
MN>>')B9R.]+W=P[NCG-`'S2^!6Z/;U$>K)G!)CA[Q,<)_)P\'S>"#KZ"='P<
M@KT[T"'DXT;BS_`MA",]I2.]47Z4#F-RL/*J>=WSQ9ZWV9SOR+_IVOW?7)
M5S!G]7#R3XHCG/V"Y\_@#WKA^-F'U\(HC=V;%9VO$W9\6R8T5O[8AV.\B.
M.,<09$?TU]`/'R=`;_`'A'Q\"#KTTC'QR&P!@0\O$A\6>X:T>DIW3U(YQ1Q/I';ZYG/&1SG,#E.Y_4))[M0G,[G$XY_@Y[RX3B=DR1Z
MV#$J%\BG]#AG.]DQT5L[!HTK@&-]V+;CY3\TOGS-F?[QP.<KC#\@Y.,-T,'7
MD8[W7VM9L8'"/EX@_@S?`OA2$_IR(Z4'5#=J3RL'*1UXI3PL\#WU=\F.
ME;VQ(]IM^WMJV!%U'[(%V1'C$.B'GZ>"WN`/"/FX`G1HGY&.G]>"/4"'D(\K
MB#_#73LB/:7C=D2<\N%V1'I6SO>@'7'?+-\0?>/S[WIG#/]_;\.?H/G/OF
M_1WBZ&_P.7<"Z<OAOB2#.2@-'R''B2GX7/2#_*%/OW?^G+Y[8OW@
M^)[DZ#Q"7![?()[TG!?UE#GKI9-F]O;UV-ZGO24'RZFXSP*N<^M#D+ZY2?
M))6?Z'^)RNZ4JV%2@+NAZ&;78A/_11<EEX_P=Y4Q)-/>:3DX;/O@L>'3PE
M&FOJ*9]<EP_NJRD(D'><0JZ65\M/"W-?C9'6?U_-LRYJ[I/!VCO^C35ZLB_N
MC4';;M;SO7MCQHD\<9;<GSQ;7&#N!]1:\/B#?JF+&O[P3\J#^8][CPW\`;_S
M?#$FT/GF4;Y]_?EJK:7DZZ#'GB_18SZ)W_!O3D_M$G[/5,Y1EAW)G1_ZHD
M['9I:4?VH#[>PDW]_>&KCW]TY6_E95/7_ITJ#[_;2?3.\N'#:T!_<=<?\Y
M(2#?<60$V6)G\5NE;_5%6M,G7T3/LE0\6\A?9]1_CM7.97P+$'BC^WB$7G
M6;^`)WA\:'")UV?CG%$<)/.8XX?N,XQ8D?W1.+?R/OH'MBP<N^)Q9C49SK
M,/?!&AF`XUM7V-O@1F;@6)/P<",;[#XD0)_CE<5OD@_*6T/;<'^L:T=_/Z63
M:$;`J2XZN"Z0O_\R=TDO-.6)HRR8CYAVLM2]E[+O1\SZB=VN`D?>_O%)I*CL
M'HGO&\6\/TAQPRHQ67/'P/T'C1YY.XYI<_?UC`>&GW6.?W1PI[%)V]
M0TKT`?OO,B'A@Y::ON^M29T\B3G_C>>($P!_PA%^8*D,V4<Q')%2?]&WR>
M>W_F)X2Q09.J4!TMFUHW=6[L0/W:QNQ"..K7=:I^->C+K\Y7=FDH/:_QHJ#Z
MU1"IB,2F=P=6KZ#[,QLBE9%X)OI<F[XZDLA$;]V?V76%*FTF>NO^S(9H)#/_
MOC9]%)Y#/=G=GT\2WGZI_#'?9IZ:W[,[NNS\+?NCS(1;)S-Z/[-K>Q;^
M@U+Y9_0'Z_[,KL]EX3_8YI_(S-Z/[/K]BS\K?LS&*Q:&4F>NN'KJ]DX3\L
MA7\LH[]9]V=V?3,?OS(9$)#-_Z_[,KN]DX6_=G]E0&8]GU]U?V;7@UGX
M6_=GLA6WZW[,Q>8^IB>?K1-7Y&9WKH_<T$V?QYKT\<CTS16_=G+LCF;^-M
MD1F>NOS`6):;&,[:UU?V;7#[/8R[H_LOQ+/36_9E=3V6AM[/[/I-%GKK
M_LRNWV>AM^[/[/IK%GKK_LRNOV6A+['H#V:AGVS1)[/0GVK1]WTK,_UI%OW@
M/13/H16>BG6O3CL]"76O23LM"76?1E6>C+?K*/01B_[,+/11BWYV%OJ8
M1;\P"WW<HF_*0E]AT2_/0IPZ-=DH:TZ-NRT%=9])=FH:VZ#:A7Z:17]-
M%OK3+?H;LM!_R`]%IL5B39GHIUO\=V3A?X9%?V<6C/M\4`6K,LONST,P
MZ'=GH:^QZ)_(0C_3HO]U%OI:B_YW6>CK/K_SD"?Z7[CP0'SH'%JMH]N5:V
MAW:8P8^:!='\G>X1O87=8XSY+];)MYV>>L\P<)R;XO-K\*%[KD:P>Y(Q?Z?]
M.QGXKR>>==#+<XUCAQOH]PBF-]G=-3''-*3D]QK(-R>HKC+Z>G..X`XO04
MQ]X&IZ<X[3,"QSK`>6K"5F?I>;S2\W_*VV2?T`IEP9>5!?6T4K]S<=M?C!Z^
M><+-0P5[1V:U,Q!T<%JOCK<IN7:K2=5-:J*$D-97$9]Q4$K\CA`XWJVXX&4I
M<<8"KAV(-U'O2\=H`YB_%K-6`F'.L&9FT#ZP8^^XX!;NZ##?-]C9)+'Y-R
MKYH$;%,-%\*D*6<)Q1$6ORHEQQ%'.HY3G/@E=3G%R=&WI;QHGY1/J8GG'<[D
MA_1Y6+0H?>8<@#[5M%N7'_Y@UD/"*?LR=OFAYR?W&OU?5_B1(J[_"F<@Z.`Q
MHS<1Q[F$XK])7#8.],`?.;O5?G_9OX2#KN$57SD&U*J#"$9"_$7U*31?R.
MT,&U'M9,,GI#R/5&^.=_Z]<GXDC'<8H3OVSZ_+:\28K0ORE]CM;Z5-,4P?6S
M>I3_G2/2CX.[V+8"T!]<7(G3[]`S?G;3S]0V]8S_K>GZ2L4P._M6,\?2[>
M(R7P!Y1"(?>COS-G"_**S#K6Z1/X/!1X`A)GZ_=:0?ML"O3XHCY'JC.-)Q
MG.$C^OSLE>,/J\OY/K\G*KOT&>,]F$ZI?13VK]0MOWC]0/[#CW=\:^
M5\CMX`S\7!P:G_:?KTVL_SH4\L:_T#VD^1IOT4_U+MY]S]1I\/#/3TB?N[
M_BHVGUV:'W&(I5:;Y]T!K@S)E2=+-C[99V/&ST[>)3TB5WQ&2].?\YI;<7
MO?8-&XU60>.D/39YV$I_U.UQ3]3(>*/7V"'OAA-0`C'/IL^ZF47YV:JD_@
MYGXJOS[7?-'XT=7/V3X@BY'U(<Z3A.<>)'^H0N[T:]4[I<.L;3YQ>4/E_0
MMQ&EQ"YM!Y0<>4/ZBIN>5'I6=A5#UY[>0`_]/*5^+V9Z0U\'O)\:IQ!.
M?'8K>X#/[A>]M[QG\ZYII/;33UY49G(N'@;GW_9^GS=GFY?$5<J?1YK]%G
M-++6?]3\L.'GCY=U62WVK<[8^PUX$QG*U_X.;<H$__<>CM=C7)OD>U?PBY
M_O_ZI-'_I3%/_PHV@"\C_);PHG/RJ>E!!$U!]!_M>F&;TAY'HC?-AC?GTB
MCG0<ISCQX_K\[?-&GR4G<_^D>UF?('TN\=_S&4YSSV>J?_X=]%/TS]"/W_\G
MGQSL_Y-/9N,]K<]'7C3ZK)E`APL+E/^5/MGV]`G]AVT'P*OD[\_?ZY[SSB
M[_DG_&2XTMN=$2%>43Z*D/3YZ.U2KE-Z.ZA?R7NZ1.#/S;S2I-W/.WP;NE
M7/Z4\FFE9X1TO@)CBB#_!Q[@_R5-6XROGZM7_\41\CU3'&DXSC%B9#%_WQ
M-T;>\9,]>8$__ZPI/\9&5/[Q8I#6\Z/:;P<<=/2\1)\S^?OHK2B=WC!6#:H7
MP/_1>H/_//@5XU<%)7Z_G7VD<7!8ZGC9BCM]AQCN?#_R?&\R<>D?3TGY
M/VHO_%$__S(C.?/)GUF'<__H_7S7AS/!MSB%@EV^5WQ0T8?VI])I1_0I\X
M3XCS#[8^@>.LOSU_WWD3M;?=9W)Y5VR@]E;C;GO[T)>DQ!CZS`O-V)K:C2,?
ME_+R'TM9_F4I/S/=L\OL"X0`OO7?A2"<&"L#3X(R3]_L5KA2D>Q_Z?P!9X
M8YPV[V>WBB.=!RG./$C?6)NM$^UE9@;%91X[1C`'FN.MV3BW#\!4[EA#^O
ME)OE+GU<AOI7_LSGQS'LO?#F/)Y_//!WTF=1D#YAQQ=OI'8O[U1NW_`E
MU.YIW/7G?X;?.I>Z%/;'OV9OX2#QK\>]_O;?&_?ZQBW'.E^(!\T7_MGS
MJ3]J?3Y!M3B77@('T"_V`E7D]5<S7C7ZC"5Z-9"WP:-)X&_7=3J._0
M)Z_O7]#ZU./2MQU]B']!(T;TCG_1\*E6?0]A\*@9]XIC/!_.I/."3..!
M9Y\W>H#V^3SKF1>,7,6G\'G6"<X\"_H_F_3_#YMG!>GS7V&>E7X\8,:WN\SX
M%OK$L3)!XZN@\:W-N>#\>W?=7S[#3.)?WK]AD%32!?[!#;]!;SWP,"
M\]][E3[U,4;MS]@##YK_`K?GO]GFFSV=5V:8G\8?'V/FR=5_,O-FFB\#QSP9
M.)\O_DY6@9,8'K?Q$6@9,8&/JQM^8WA4_EG*Q]G\_8G1)L][)@O!<+W_
M@ODO]E_X>LM\CKYBNA4^OPE]*GW7VB]&F?]@]:K<68B:\C7?_>TWX\PW@@
MCK$V]KK/_Y79\R9]`L>>-W"$J?,4[3T!XTF-N_J\Y@=2SE5]U=)?JS'!R9X^
M[YXB!/#+9PK!\#3KL4/$-G?_99_69X6CSV/<?RG9^PGC9\6=?O]$''Z&W[E_
M4IS2<7KBP_US1]Q\=X<^$B'I$SC6U(`C)'WN^('1Y](Q_OYHG7/PR,%=?=[T
M/6./-3\W]B+
S%CK[:YQIXBPWP![17\&>6#G[-R:ASE`T[E]+</0]Y1^M?K
MC1^T#[UM'X:(>MFEQ@\8CY5I?<8CT]SQ0]!X"7C`?DW)['--/7_P'G_[@#CJ
M.7[G[0/%*1VG)SZ\?<!WJE\N57/BG5(B)'T"O`94\<0DCZ_N9W6)Q/<7TN
MWDCKDQIW]8D>:4:+SYTIYHG13Q]UJE%+A^$]3#TXX?H#.4[ZJ'?>74.,J'
M]H#*Z6?%T#_[GK.!WS\;;/Z[4$]$/VN>>M,\XJX7V&6>U>M\\_;D$]`_
M/IOXH#WYA[4G(\4F^6EY@UBI]/]UI?](%)1;MVO98Z\I-[I`-W_>WV;YO\
M/ESH_Z[S[F]*>;:NSHX?=<9)SXK%GG?]P.G?'$FB>%%.X2_2+64[$6:NXE
M,#CZ1>`X2VGN'X@48:T<<RI3)PH,CO1FKD7W'D3<[SHI'_HE/)#.KD
MJW&T7_!O&Z=R`#?E\>CA]S:.-@9\T'9S/H13/AP'']#;?(!3/H23O#9_TH_%
M)T[Z8OK1YW)A#YPU@W[H3@;@H`,..Q(.OYHI_TL+-8JOWJ&_JWV=BQ7=
M9V+V[I9STJNU7(DY\1G=POQ)QRA?S:8;K^Y>@7XSYG/M=MQ).
M>\G._:[Z'A)^OMKHV=R#`1SI@3OVVL+Y4#Y4'RD_?.O/[Z&%?F$G&Z=R`.?W
MW((>]K-QV`5\L*;#^1!.^7`<?$!O\P%.^1!.\MK\23\V'](7TP_\1^/P']B+
M541[`0<>N-52"?EOOTG;>(;PK]XYS?[7[;K7E5_2]@.U7:&#[DF]R[
M?;?G5\0'=[WASTL#C5]1OK@CB>%%6#.#?B$'ZB;Y%7#H$3CJJOL^5(>IZ_@.
MWFG'KB`<Z8$[]MK"5`[OV$3G[0FY.O[[UI&Z=R`#?E\>AA/QNG=ZEA-\Z'
M<,J'XU1?;#[`[?>O25Z;/G'YD/Z8OI!_ZAQG(/]T1>,39QL^C,E>;<+/3V
MDGON=S8FWQ:%H>VK]P]*#SE^M;]?L%\->CO8K\#WILI4OT+]Q=C']BOB
M@S<SN5]1OGAC\P._M?T*!X@Q[X\J?\]'=&##WN\R"\V$/:&>0&>W,_#;
M;RF_;=1NP9NYS\ENY%L?V6[C\Y7K\E/G@[B_LMY8NWMC[PV_>*W^Y+X[?[
MTOBMPG]OZ`)D(KTQJA%_7X+B"_!5VJW:+67-<HP^MW8+_/9&\EOK
M_IF`>]+\?IN7I'4\O]]J_&Z_WTYD][:!'[O_,TXXW0=&Y:=[PV@,0GY.]YA1
MN8!/9'SH6SXSS\H7K?)S\G7]7=CCD'<WR7NL\RS8VKM7QY,7N/E.QR\O\2=Y
MCX2<=44'AZ]P>3%&0_S1<7YY'RSVWU]*\A(?O[P8_S\M'Q5HE_8=TN/_JMZ/
M_].U2U-?3KDOR!WGX]Y:K_R1-.U/)$W[$TG3_D32M#1>'#[$TG3_D32M#1
M-.U/)$W[$TG3_D32M#1-.U/)$W[$TG3_D32M#1>)KV)PY[V.T,Z''',/Z0
M_?$;Z*F]PN_>.`WC_QJ\3_VKXL/JWHTG`OQ_]G7T#[W:GW-J?V=Y%XQUS#
MG_(AO\(=7:A7:-\Q(-CK8`N'<O8J0([2/B>`/6NT?1X$@/W+N/,1(G/I0/
MZ9_R\[]S$2G"M\ZH+S9.Y?#>L_#H<0;(QG&'*/C0NQDV3OEP''S\[W1X..5#
M.,EK\R?]6'SBI"F'TGZ
Q?@7]<+\BN]_X/;]?(3WH;[[/[U=[DS]4XW_X
M50/\ZNS#O1S_'YM?>>-_J\]_O?[FTCC;R-OXDT_B;2)O'Q]O(HV_B33^
M)MXFTCC;R*-OXDT_B;2)M(XV\BC;)-/XFBH]S>#PGW5/^,?S.Q*I?FC\
MZEOKY0?G4U_.K?;;]Z?FBP7SFXZU?P`[31ME-[@Q>KR`^#?_EW</_>J>
MTTSHX/H;:P-(\1:,>D!]8?NTW;P70_-NC1O)[LT%/]VR;_>\>[:1'O3\
M/FWB#SOP\"?N-6L=DX\0?.[P,'/=;`;QRC:F/\$?.AW#*A/@`WJ;#W#*
MA]];#KE('X23G':^I"_.'_[SU3(I,?8$'QI;3G+L`OS\7WIWZ<*OOJ7\JE'[
MU0/PJUV'K7F?[5<T7SM.O_K`3_Z)?L+GUU2/J5Y3?2<[`?DW/4\Q_@R9Q4
M?\,\Y6QY@^P?PG[H'Y1+12JBT2;?/,7V*YK_V'Z%]PG,_JG?KT[[7]H_];=7
M?!Y%Y>?S%B&Z2?D1\9G'XG>3L?,W+AWE62*],\Y5O)NU4]NDO)._R(JD>#
MCECUR'D_(:4>.;@K]X8KUR=*B_Z@[_R;Y^@G%$T/J)@Q>!/_SOR3%2XBYN
MJA?`X6?`,?CH6W]!''&^?&#TW]`H[TP!U_WL+Y4#[DAY0?[EUW\G7?98`]
M;)S`=R4Q_^.@XW3>PVX#Y[S2?=.!+WC`'J;#W#O'0>#D[PV?]/S8?TQ?2C
M_0KQ\#[E0TEWS=QH>H1<.CMQ2%>/9HE/R4'A]J57YUQ1->C"G\]LOVYM6V
M7\&7L:]JQ7P![4ZE?$YZ9*X?,KRK?MI]YXEM<OZ(;TPL+ZC#-R`OS@=`
M7NS)>?.%5<DKY97A]2@J&L#ZE$+U:.'OAQ<C_#F:I"\W3]RGW7I,H+_9JS
M47YYB?_=]_CKR_HGDWK/?-+?DKYW#?">)MX1L''08T\(.'_7`/0X;V#CK_4-
MZ?<,GBL("<Z'<,J'X`#>IL/<,J'<PM#XV?!(;_/9]H.D?M\!(5L_C"..
M]L["BSB.MQ/H_/#.>Y/:OM<]G'3]69]GGAD2X(^0\T<<?"R\B..<_Y::D*Y'
MQ:$!.,?7WJN\0?R"[(CE8_L2>T>Z8?QW\+U0/:D]I#T1G@/43[/U+Y[4O:
M;W?";W>0WUY5$RW'WDXV&1;Y#?HI\-:O]/:S/\*1\N+]F1]/9_T9^YOS'_
M2KN,/X)_?!V&'3`]][@]RNRUYY/]\RO,OE/D+\%U6)97R\K0%EI60_W65\B_GP=G8OHR;_\A&]D%^L1Y,N@3Y\M(
MGGZA?%BMI'9ZMZ-"`DN@ZC'KW9VWJ$MY;?MS>D1\[OF?QQ%3:<[Z]?
MX(\U&H3W?\GSPYR/)_4[]A/G/?N-8Y!7-&P<]WLL';M[-]@QYK-QM&_@
M@_:-\R&<\N$X(#>Y@.<\B$\>&K\T?.-+;?/#V-/2`D/2`]GGA:903\
M_2>]D=Q4TB/I#^J1Y0OY4/C3RHGRW?)*<\R/?7-X5\XZNI&U++H^\K<.CO
MNS,D+AKAIJ_%.KYRZ2C/\BK5Q4OWM2;>H=]GZ#Y"_"@4MOQUTX+T/O7O'Q
M5<_J'?9_OZ3F]]4\BY1\G8M/-K0OJU]36X/ETB+*#=#IJ_H'_A]0[\
M,8Y_>9#W3BOA&*\#Y^^ZCGC3G,G"O)6_`PL<Z8'S=V.)\Y\'?$\&X4QK4V
M3OD!Y^4@1[S`1O'.U7@@W,:G`_AE`_'P0?T-A_@E`_A))?-G_3`<#_3WO5
MU`OHC]<+Z`7XGF&^?K`(.-9S/'T:>W&<?7=01/JU<;(70G;_21QQT%EX$<=I
M'C=>C%]Q3K57_P5RG`;[N/]K*_N/F!I+SORZE^"_L&]1<5K<'CKMN_D]1K
MT@CY.YN8CV!OZO0_FY!P^/=+VU)QT&,/$CA"3H_W$&T<]0=\'AL=$IP/X90/
MQ\$']#8?X)2/6YXS#%^;/W"DM_FLG!_2:_D(F1[<?O;)6_SC*-(7Z8GJ->F3
M]$'UFLK#&_AY:'\4=_QK@K61W`F3]LQU(=K3M).@R]1?(WL7!H@[E+\=
M$#N4O]VGP7%J(GO&]K1N,EV]\PQS'?64Q.6S?:C;[DWP\1G^H
M7R`ZZ(CLI>6ZV/0+;,])]PM$S
SJ/(4C=V?U/7MV4(<&C=Z&R\*Q-[D]V1Q
MZ'.X@1_U[O>H=_2N'_9%L.Y([Z'3.BKB6"?A[ZT#QYE0X/R]=?!!''SX>^O$
ME_CQ]P3!E]+Q]5ND]_AX[PF"WLM7/93;#O2NBBW8]#"-G%WA\!#KO3.E?0
MYCV.ODDIYRP5].O_.M%7Y]J[`AGG\6B"N2V^35(;S_.#JI[#(LZ=@%\RCL
MM6->A9#T$'DYJ??>$?+W-$&',P1(AY#PIXM">JR#D.CY^LRY)P:OSSBXJS?"
M,>\AO4(_\+>@=R>Q'ABD'Y0#:\2WEX7<-VMUO?YE4@*'7(0C7\S'\&^^GD1Z
M@#R>O,;?2%\D-_DMZ<?3@_%;TB?IV[QW/$C<(+OD(_K[E-G*)$V)6&5IY%C/
M=$Y<R'H`]WZNE6.B^-./)VUJ6W$(X\@#OGSZ\@/O2-HK.?>SGGP_B[YZ[I
MO(=]GASI*1_'C&=2Z'U'-@78U[S/8[?OL#-]SB>?<>+?N)!5GYBE`3Y:XK
MX<\=\.<IW:O=9ZS&3AP[T?LN9G6!A?ONR<0=K$'?M95_#?GN=/.=S.Z97\T>
MK$$[2?_&K3?M)[IX11"._N)*-9_-#]VORO]%573]'('(U%^DFT?`ES]2DZHW
MX*]LZ_D\@O+EYZ=X?X$Y%<W[>']AS2-<>JQMT_HV]1?Z'4;37RAYH8?^S(Z_
MA1U_:NPH0KC'0Y\3R]>:=K]OFNQ\<^?@;KN!;Y6V*)GQK1)"Y[[Z.,41X@8X
MCB..=!RG./$#?JQ^XI=KDE1RC9".7/1=[0,#_7+1=[4._IZ5Z]NN7)=`KF:2
M:YUS'\[.(?[OA7<X]$X>*_JG?X.\0=2;G])2GQ?B)#DHCA"U".(XYT'*S\B3G&$!=Y[$W&*
M(QW'4[\2ZU2JX'M5Q-D&NVI\N?_OGG?:KS"_7]A:GO2OSRX6R!\E%[\#
M8^4:)[Z5O%HVZOV"3RN1&NKFED<3O5EOP3@S:\@W7XQ\4<[;>\8]T6ZPE\
M71WC2WJ_F.@QWHU<+[>#GKTXS:.<2SX8-V"\R&<\N$XO0-N\Z%WO?F`/95
MZ7UPSA\XO0_.^6`=`>OL"/D^%.(8MUAX$<?Y/M3PM\T
4BNE/8Z"?@CY/P1
M!Q\++(XYY]WQ(S_7GGWX_XT\"0[YP&7Q]#>K(GC0])/XS_%JX'LJ>['NOH
MC>2@>33&!M<]1/-HY;?"U-,=\M/R"8%]ZN\K?\9WFDV].H>/[WR#]JGI^U_;
MG_DY?#I?S\_/XPPG1_FN'D[UKNW><!A[_UOXC->#!2?4OU%B?ZX+\A5SPR
MK7=R@5_0]P7`[_E:^G,LOQC)SYV..CI708ZX\_1\"<EIU+C-.;S_0[\0$.
M/J/?]']GA#APY,/XNWK#>7[Z[A+OTF*HBZL`/H?'"ELWZ5$GWJ7%NY/T5BOA
MYMUG<95YZ6E:27G$?6_#.\^![_3BG>@1NXB<B+N;YWH/S\OZ]8U];4B\!W
M;!W/7EG*L?'/T$KCH;3L<U3Y\W.<\N>F7_A\*(10>]>6>_>ED^Z/(,
M'S&TL"AS>7=-[Q(WD9=GGT_C*@9GYEI#[HG=QCD+=/L#Z-4J_;^-S`H'=U
MCX%_GN_=KIH`/\$[[.?*_<G_$(82E1561J-5U?CO2WJK]>(E/H[3_@F',0
M'G7G:Z'E1#]YMA#XB_H-G.@Y/DX,%Y](XAWV=NV.M:7U+G\Z(S:;O8!(.,[&
M/<9>7L0[8H]],2EQ1LV\HVWJ>W%W?#D_:X:YFZFG<?W%*$F_?9#3WBJ-,<
M!SW:!O/M,;WG'E].<828^W%ZQ"D=YT]S1,C!RT,XYT/Q(/[XYH?DX#CB"+'G
MQ7'$P8?C%+?EI3A"Y,-QRI?C-W[?G*.KVVM"DNO??B;E0UJSOHS;SR#='W
M)1])'@U-UW:OG[=P;FQI7-FW1MLOC"O1P)G-YMOX6]$$GT^CTX]A(DT>OW
MYMBCT2/OR/8RXY$#_P6]H(CWF7#>`]S;ZR?\??E*8X0:3F..-)QG.$C]Z7
M1QS?X-GOWP''V)&_?S=.Y(O]R1ME64Z[+E_3177S%M7-$E1/C1YJ?/6%UB5N
M82\%(E_@SPU+S1<X^GV>;W%W9#GZ(T1$_FP_]9MJ'
M(6)[<KUL#YVG_:2QWK,SOJA3\5:"$#1RRG.$(O7X-K__FN\2_"B0_"('K8
M#'\)ISALR''BR_&IW3.8'W_G>&]8RC\[QB2O:C\SKAB.<6I7)0OV9W3_04
MY_+2>XM80P]Z;]%\`?9'>\/WJ)B?:W8KQJDXOE<OFXV$?]U'3TRZJ%V<
MN7I*Z6L;$0G2MI'F?P_BHU\-I5-%QZ]58]W-?Y'RA4U2_NQ'?OJIJKVX
MM<J$A".]%HUOYMN0L(OF"1EQ0VX4]:$'*_Q.`(.?^SKI$2X65WI);3YD_E
ML/E0OI0/YP.Q(]PA_)03CTDG]'2GGBUZZ0\J0]4O[RBDO/N3ASY\LQ'?
M2\I):D)P]!V&GR]$/Z7/6)40%WKZC%]PNQ#7GBK$`UN%^.
3_\_4O/W6]6@
MLN\GA'AANH<3'?$CG/C=(2ONE_<]7`@NQ).)5[PYU2]AOIT5/\VS^1\IPS
M/S?[Z1\2Y63-GV@IZV7N/9B*D/UN?EK\541SA\[?[;QP>C_(O_U+;4
M?$%W]A>#9!_XG>;#43E._I*X/S9?4(^OR)TN<7'#U/>#LW_#''+F.579H=
M>PTG7-GQ2\J.264OJ>P5(ESI=ZC2+]EE(/#35'W_R1>D'C7X;&TM^99X7$
MV&8AU$_2X*8QPSR(Z']QMOF+<@(G>HYC7M8Z6TK<E<#7A7"?V#HIY!U"37Z[
MYF.<7X?V!/EZWUGK+YFGI'YGK?%26@=`&X8V$NT>PBO8_@B-0=''7)'CW9^0
M_V#P=W_AJ=^ETUM->WS7N%\S[AVD*H7/S2\<\_TU@WPAWB/WO.US['*8X0
MZ3B.*UOG&*(P0_CA-_CA-_TA_A]GE"<Z[C%+%$GBEW8/S?=8-2?6QI)`X]
MF_3HCWU,=(C7Q\#3F,!!X]SG-%7D+W0[CO'*Z4OOU08)0W_QZ'XNBS.3W&
MV%0F3D_\$?+O(]SXE<8O"<X]9N\/(@C?\Z'XOJN3T9/<7TW,,ICG(&\;'E
M)3HN%]83L!:',3C=T7GB(#3?N5U'_.%V&,#QSK##8./L")#^H%](-ON7F]
M(G,^JT07/]D/[(;[5.3SAR[)WC]9?Y02?Y`<D)FSA]E01QUD@_-"XBG.)(
MQW&@P_7/\4Y?WVNTKDO"VNE7&_`H3?@I#?%^6D\CK[=/J\`>Z"X?H&0G_NB.-)QG.)N_6/M),XD
M45VB[[/,W?GF#!S.,9*?0";#"N3QDHOK/RN_6=RFG74XJ;,SI>.2ENR\7/
M,/)RXOL:T"%.Y21_85)\3?;KRB.D.=<;N<>CY5$']FLICSIZ8>V
AC?
MP!S/;E?I&T&[_01?AB=H_1!VP5_8A<;\I`?@*`?'@>&,#.CI;@3X,W#$Z=T)
MPL$'./@P7/,''",CY87=)"7YPL<],!YOL`1!T[\45\P)S9%89?N?NDQ;)8
M[A4?4O6E>E'=0/!GT6XCM]O5C>SAWW)?U<.;)?2F<=_^%.9!=K\?6\?\
M.:#?G_N<^>NL;[NX?8X+]<)[EV$U9=`'.<N;I:/R=-"K:K_W?S2_HTU-3%
MIB8@E[7N74MR6>O>-2071D/W3O++Q=>KL8;$O\>G-><1;_GN*XA;YA</.B
M':Q+]]=R"'&"?J=??-69UVZGPI#[OOU!J_JQJIDSE7GZ*GC(;1[;2XZ])=
M-4G&>M<Q:?5!BP-.W0W\WHYY=JI.*@BQ+HKSY[!]GDH98SC-Q[%B2C-R
MK)>.TXB__%B'V9[<GVP/F0;H/#:OI_6!6\2BE/D^\!&BT8?3&*U)U+-U@,AR
M]!^@AZ]XZPR1Y>AG-?_O>NL,M)YC]E]T_U)?T[!8TY-OXG?4;,>UP<<?PU
MZU0>/?TQZS##Q!JY/3DQZS3GC.EU%VOH/Z#_M*Z!&\_(0/'J;_F.(W'B!M
MG]`9S";?.O`,=_UT#UL'+G;DXFLBM!Y"<2H7Y<O'PFP\L)SB5"Y'SRN@&[15
M?)T$@>.\OCU;]9A:#S#1-.Y>+K3GRMAW",,;"/B#59]GW9<JS!HCP(<1\`
MX:#'/B+HS7ZB$%C/&110'['O]EQRNIRDSS$K*I376-TEM-]C/MX<V^[\=#
M^GPFPRLY#AT[>!7A:#<8'HT(CS_'8\;_B_;M3<IU:CI2<%)((#3SWT@1Q1'N
MF$'S8H,CCG0<ISCQHWDH?,KTX3LE;_!.<3)-D7[1OV3-"B#$>3=5Z>;G'0
MON4Q?7:M-CCMXYRKP4TC"V,3XM4I-]WPS<>//OXX3$G*C7+@WE^5YO\ATG
M"L2RY/;DM\2U^J>%]0O==6!W?3@T,V5]6->OW%DIN*Y?.=ZZL>JOE]/=KN@7
MJ-[0NJ4YA;;#UV.,\,8)]/<FW`%<XQ2F=TY]>A.(L/=NKUL"9_6.]G.7
M3YZNQN6[I.RO''[%XQY_E`UG'S%1TCUB+(%^>6":<XTF%.13C%44<Y3G&D
MP_<6P%'O"KF]=AA[C5<>]5GYHPUA'<![E@XD738H'[VK[Q(?+@]T!^-Q
M&@^8.5SJ.`>X&5-/YNU8W)SY)?H8]4=%9?=(W/<ASMDAL5\T_HH<\3'@3ES,
MX,4-ZP2@PG_GAH,?%+9)?GZGM""@@OO\?<H^'@\@KGGJB#=YG]J5_N-Z&#
M@[.T$$UWY0+-_17C4A/_[EH?'B<Z^IUPI]P"Y55A#LH)/6`<;,X#3"9U
M0F]Q&L,;W!AIM&I5E;]JV_+/SYSHVQC$11;LX+.OR\E_S'/\<XINWX!W
MKGI=/C"&\#DZQS\MD6OR\7/A%P^9>]+BLNRG7PQL[FCDZ-[W[H=?GLC3D.
M?GZ]4TZ=K[?.7]<H&']\9V+P;/J2@WZ(=>E^:.:0>?8G`,]/#-HI/O_'EU
MVG6#1_NJQ^Z6@OGCS/GG?%,[[H.G$U[7<H3PAX!7Z_90_1<2\VJ5*KL>
M-?4BPMI`4VM:7IXRLUNUJ2(P-"9"+LFAXPYK5AK[_R_W%W?[&'HU&-U_
M,'=0M3XGH/DK148=;1IZG&585YOG\C]RI$]^M3EO8,JC##5_057U_$C"I7_@
MEKXN_>NO#SG!SS_FX[_CY/YBWTV'I,W?HX_[Z`OZOJ/W!6WZ/HJ^-B0:(&_7
MKSW]3#YP2';'G?(H\/#^/H,YO?:SZD@X[-#OOO>`;K==_1P>U(?3P\.[_N#Q
M?WK"D8S\,:'O>LVCWSO:$9Z3%B[#GOTW4^DY&4@\2SG'O_.LMV7UD3?3
MEK_HN]_Y9&,]-46O=Y?3J'/4?,79:\<<4Y4UZ+HK-)HK`GTSY\6#Y[Y]N2
MRG]P?_X@X`4'Y+0M90Y&E=\AG(,8O/VT4'`_G4O_)6`)^0*IKVGW/U9%:/
M*DSYP<<M?X'J?_<//H'3QRQZE#\3?=RBUOG`?2>/U?X_!GN73C&P'^GP/Z
MBE*@"F))J\;CTH48>)_IV#N;G5MR+YE[,.J=2]'E2;PI=W[5J;^JCS]X
MJ&]?'WTLE7[WJ-ST]/%4>LP5T])7I-[[540?25'F.7M/25J?0S_G(D@%[K
M$\V5,*>OC#Y1]H(-?5Q]4GO8%Q8(B;/KT=[V[^/61[17N[YYU/7#`P<'%OCL
M%?/;"[::?&&_`'OE@;X1_,WJC%'VW;QPZX_-_:W\.Y.=QIA%CWHW\OI4EQX*,H?U[UODV#EX>TSE=_SYX3/GR'OL_E]
M?/W%A.Y3A>R27:);Z)$ZT8<5EW#_-P^5]%]PE(_GS]#SB)0Y@!J'A)9!_VA#
M$:N8QZAEY_2#GKIO@7B*?>V"PO/#PGS8/[O9<`GC?P'S%,K0#ER6RI.-
MPY=1'/T2X<1_:!HPJGW;]I&<4Y_Q&G]:7B`_EAQ!G#HD/Q1&BWR81!_$
M!W3;GWG#I8>>$2<Q+$\>=\SM#G*E/.,FI\9(`P\KQ_N/`4V<(9>_:=,/
M#>!3W)V[3/?JFYK?:C0E#-W&<7U?-3!P6=8`!]7GXK.KP>/#T(3GR&!Y3_
M##U/2>4?5KW7]:&/YO7/NZ2/39\7*%?.,HR7T/X@1#M->J:XK>?<-.49F\9O
MT;ZA/B(D_H0CSO,-JQR>NKR=;5*?FJOR<'X!.Z_GX'1./H95[?I27GNR
MI/\9,J@^#@DH/\J&\UT84RD\E,<(6S/<<31/GAXSC(T1_PMN-OSEC[/R
MCSWR:_DK8=5SNI]LEA!@34CVB.,KEX::<A//R0`#`_1`=-"'7?Y4_>=;
MY4X]>[-0]\__&B_YY)!A^8IKU"?X=Z@9"W5X3O>.BP#T=\WSM]!<<ICM"S
M8\XRBD-/'F[T1K@M;TZ*O`,M>2L=>0>(3QUJ.KRMO[\^ZGQ5GP;9GKZFOQ[C
M4;X41PA[<KODI-$/QL20VSNG:O1`..HW\>F7A@^5!R'G0W'.OX3QM]L'Z*=/
MBGY??JA\4E83%;]8WMR6_]M_6U_Z)>F/4&L)FVLZI+5![,4Q"WQ?@H??
M20\#T[1C`]D"UN`#_7]E"_%[7Q1M_A8@?0)''SH=RI/?@9Y0<?SW'.IX3A
MO#PEK#QV.3$6PQH?0LZ?XACO<YSB_O+DN'I`.\'IT?:CWP=NCT\*T[2W>C\K
MOP\_5[F,XL2/Y*6X+1?X:)S14[[#`R>%S!HW:/RH^_5$\I#OZ$ESCT&K?Z
M=]+GX_0]1WM"T(^KJ,XUUL)X]=[XK2^`_L!5[<CB7,CK;>,/8@?Z#S&.`_
M*DU]07WOFS(.R15_[?9OJ_U/]HWJ!]/:7$6(9Q.V1#B/JA\]5KKT']RR"K
MO:UV\AVHVI,?BZJ^J>,?<"E(XV]HQ[#&P=L]BB/$?)3CB,/?.4YQK']PG.((
ML2Y.AR0IAT&'[37G'\)X^WEQDG@Z_-?V1@/V7WR]/<?OFI-ZX/77@X56\#
MTXRK0P%VI_X(8SNT#PA=O:DXY$)XW?TY/AQQ/[V1BW"B+V'TMO^?&"CO`'L<
M&#'RYFMY?]TGV$]RT_@)RH>U2RX7Q1&^_9%<'XXXVEW"J9T/LCOHH!].CW:5
MXM`'YW-B0+V@=AYT7#\3NOO;>HC3?&'@4?V_[`_0?L\<EUBP[H>3WF/0BI
M/H;3C,.'!NE-Y.AYT]T_VI_"IT"W!GM`.CH+]&7.#CBF>65Y-<GSKTR/[Q
MA_URT;PL-V!AWX3Y42(MH_WLX@C1!E(_T."RN,EXB>^)0P/CZ_57]/ZMG\
MI9+&_[GOO//FA8=3Q\^#TO@5YLM8<T&(=4%>[PA'R'&,>^EWPE&O":=Q,M67
M_BGE[VN7O\J4OXJ=[\]V'C@VB-V.:$;K`4C7/?\09=_01JYB`Y2O3P6^*#
MH*0(P);!]2REGME?.M^\XFHN5)"F?4!_BO5AA#1NV&XO]W.649T"<?
MYX\)](>4CN-_!SZO.5083*EO5+]P=S6=R3"EX8DF=F'_]#C["OIT_C#X2#
M'\>)OX?G+*/\(!?/=W2@_OO8<D6-7'FB4CZR_PRY[ZV@=8@HNY->HOPOL>
M=.JO:C<HCA!KE=3^3`@LCUWO8E&J=[./OO-F5=_"P'GK"6GZ"\B/\0+I@<8/
MA//Y.,7A"QRG.$JO\CWA!Z57V]CZO)//?3.F]M#P>4?D8?1SG1!O#R4QPA
MU2_"$4=?R'&*(3E'QQ8_C'>:(IOBK_:.7GQ6\]F/-(7[N<[1?MUVT&0FJ?
M"4<<(<;H7GN2$^C_U-=Q/B6,CSU.)KXTQZ!\,3;!.!;RNN-\8?3`YQ)4GKPT
MXW8='S!<H7]8O-2->(#H@\I/>J-^EG#$\9O;_S)ZN_\*!XT/A5D/#!KG
MZ[%AW?$J:?H/XQ)V`='NT/RH.VQVO%1^4WFI70(..W)Z\!\2X`\EC(]_
MO)'2/L2I?CWUQA??WAW0P])TU]@0K]`D+:1R`<<?1K'*<X0KY17'X`^7
M1P?V(W9_5R6HO[OT8'ORPL,[`]=%\P/6C=$Z/5`U=[S];':?H7HD/(Y[D4
M1W]((3N7*N<%4XYTZP/..ZH/GI"8%ZL/E'$]GX#TW#?U"/^,<BV?@7IN$_
M.)!_GLW?G7<_]<:MJM=,M6/_-.T,D3H'?[#UTE&]:"_IGTZTU\/.WB&C!R
M^:/?Q9XWPIOG'/3URX@CI'$F]<M!\XOB`QPV*VC2D<),7'VQ(7E$QO)M9.
M;,BG?XCZ>;71RMG5U8V-0?\4TV>>N6!>;<.BVD4+%S<LFC]_5L/T\IEG3F\_
MDU,WU%25+VJLC9;7SC]GGHHERA?4SF\H;ZJO5Y%8><W"6'EM4\.LV>7X7ZG"
MX@J+Z]B4\MKHHO,6*ZQ"817EBR.UY\PKKXUI;&:D?-["Q>6UM?51%8F6-];-
M4W]KU]C*EQ4WK"TO`YD\?Z.0N(K*\L?8<]7>^^G>BO+&Q?/'2\MIS512
M99!0E7EBZ/G-BY2_Z]%:6=6;Q2X746=2(\E="FABD6<3%G[RS,9U':UM
M%X<;-S2O7Q]>M+ES?6M;2[B^>=7%S6M;II>OA&(&M)MHN'-K>TM8)5O5K)#6
MSHT=I9>U;FBVHTK!M37U-;7S%B\BU0YH:][0VK;V]/#:CM;5X=(P,;RL=77G
MNNSL%IS36`%.4\/1>%E%>$NX(KQAPU3#+!HIBU:J:"!=HH=TE5GIJBUNB6"2
MRNPD5=E)JK.33`LFB1F2A**(E;'RJDA%(%5%#VAZPJ<RE:8VIOXU,QKQESY6
MI:BC$49N"DKDT2#R:#KRR@#JRG3$50'$5>F(JP.(JX.(JP)*'8^65=KEKO(E
MB`<GB*=-D`A.D$B;H"HX056Z!%(8()8)%V":8'TTP(XUR">H>(F:5/XG
MGQ9$/BT=.97>1\[+3N0^SP5FU91$6:0Z#5V\1U05/:/J89X]I.HAMZJR6#JZ
MN-.X1/R"5I55QH)GI"E.@)464Z(M:^Q`/:(-5YG5=?/__#X<8/+YBY:#YZ
MJV,#FQ;-7UPS9U:X8=:<\^;7Z.XJXP\SSVR8U3BOT>G7IH9K-K1TM*YJ;@MO
MVKIAY<;UHB%2'4DL$0W1612!]&("F(1"F(($CJ(QZ5.H@A02*B@\IX7/V&
MN^+$R:H$OJ%;]6(FC#FA`D3JF&8#A-.J,CCD6F:7(>O"(:]<*$">--""N<
M>(5.7AE5;*M,&(N9$/BT6,R)QQVZN$Y7[=`AK&H23;%X!?)180)\S(7.8L&L
M;.5&:I>X_&]Q_3'_4G(VN/]RL2H7JU*:T==!&I5`9@C7!$-Y]C`CE57K
M6MO_7OC4\&7-E[:$-VUX7O!G?_GAF$U$HV$EV3X.9;(',T
MEOGGXV)^?'FG2ZUG&CFU$<Y#7TV.J=SI\8R0XHJ=YSO)8CU$',2Y#H48($
MT<>:>D(?8S(D>I0BFW:J+.TX?4/:%.IW5SLN?:Q']%1XI[M)FT3]'I@DT:,D
MF07V".-EU5&'=T46WA4]Y>US2>HNT]*KWXDQ:=_I67N0A"87/2`UK)U..BV]
MKWGK..<=3UU#U($'525&<1MKG@GJDE65Q34H#C71)\OE830FR9`DX1FK
MJCI3B<RXQE]C%\Q;..\B-&RESE!')5[0VM8:-HV=PL(U6UJ;U]/H,IN-JH+8
M-B!E[:S:VG!CZ^4MX08U2XU&P2'<T)F_<;PHW4GX#EIHV;.U:UA&>V;-VT
M:MWZYK46LR5IF2U!U]1C5GKH9K&5T43O2J7'OVE8W:LY:I*5=E-!;O9;FJ
MEJ1EUH-RI;.X&M3VK.WQNKELU<5KD!U*^D)%Q$KK-VYJ[6S=V!:NKPW/W-C<
ML3J\N5C0VN;\LN9#6<.T/]K:%[=NC'<NYYU<4>2#S":LK7WMJRJF53N;-^
MY]',VM*\JG/]UO#ZUHM;PLWA^G4;6]I:MX0W;%S=HMF+6>M;5G5V;%R_M;-U
M5;B65OC"I>'ZC>LW=BBEKIZ^LD,58./F-BP0QC=L"*]N;=[0TMG2H7]0$]?6
MME7KPIN04HV9<"5I72DN)57*4)'PW%DU=;/<"5QC_:R:<V:1=I2!8)/3PS,W
MMW1<OZUS?TR)5H5FQ:IJA2S$E,CI:IK=(JY=7VKKYRZ"-G*!"R@-BJ"[<9
M9RLGII>Z4+1F2GG1A'=J-*6#E6LYO761%A_KG;:6>!7UUC:,&MS8<;PW/G
MS9F">^LA8WS%L]KFJ6<!()-X5GPXG/:Y@S2[OOPIK6QC`R6S)O\=S&Q34+
MZ8MG!.&\]<L/J\!$V#%3`M+*ES7V=E>GGY99==5K:AY;+2ELT=&]M;RE9M
MW%!>5A8.M[1=M'K319712"1Q4202B9:UKUXCHF6)/='8GEC%GOB>BNH]B3V5
M>Z;M28/V4H9W6X3.CN:V3:V;L"C=UMYF1U6A%]8O#"]V46W/K&D6+PI/BVG2
MQKGG+5X\J\$-:8F>UNDKJLX)1\NKU<2ALU-_%9DA4N9$ZCLVKNUHWA">V]*L
M&B<AGOK1,[<F"?"TW$!7,N:YLWK._5FRDFU+=>*'O[YV\_<?V!'1N^##YZ
MYRS4"P;K\Y\2H.<7C`8]YM/`:YO6!P8]$M(9=!7B\8G'7[9SP&?7K!(/*1
M"SP&?7O!X)(#1Z#?KU@T/#?7Q'#"OJ&ARH3QB*Q_&A/%)1'8GD5U7&U/^C
ML2KW_V<Y_RFGS/=MC.6K/\KI*E3B4B=U^I1-C8WY<Q;6I28IC24J(L>0+GM.
M=77Y4Q)-*2FR9>0E]\59SUZJ_J#&XO/U!+`P04``(`"`#6MMP\W)\L`?X7
M``!/P``$P```$1I9VE3;&ED97)?5C,N,BYB<F2<FFET5%6V@/>]MX:D`JD
M22!,H0B"""2I(4.A="`D`<*0!`)YV`Y0"44HR8"5BH`@B:T-:,,"-?)`Q8XH
MW<]NVZD;GK+>:L?5SHB]G)X*VOW6<D)]41`!@?O.ON?N>T]5ZO:/E[5JG3K?
MW;7//OOLL
^=\73ZX-:&<#NLLV`I7_-.'M@UM5;:CTLF"#=U__JF/ON5Q
MFU\!LL2.\'48@"H!P-O';LM:=MNQBOOV:7\SL\$M>20;Z'].]?Q]DPSB-)
M$O'9G?%X9[O&W5E9DDR\(;RJ2Y=W#QMF\J9HV.#9V9#^+.6&=W/+(*>4Z.
MY"9>'6V/='1%.SL8SQTN.8G'&]K"+1%NS_!/'B/(-X7;NO$!DQ\S6I`WN3(V7S'E
M&/<H]F0G3_68<J;7!GGM9GR5;%(F/LYVSO.;LJ;7!E?H!CC,^)=D2[UFCR
M!>,=!F\VN3A,D'_7&:F;L]E$P3])E<F3AFNS32%=?E)TT4YFMR]^63,XSX
MB2(1-:Q%4;_3+X\PXB?9I.[KYCB,N67,#VQ:$N<R4YPF7F]P]=:K+BN;
M3Y,FV;:4QV+MK7IZU58:/)YG6W:,N\BHHDA?@B)A[M:-5X<;$IOR@2[NJ.
M1;0X\?D$_9TMW2Q"-?O]?I,OB:R.Q"(=+1'&@R6"W_`'CXJ"0I,WGF-=>8
MZ4N$J?]DGGMM<*Z^[JTN-0ONXZ8=]A+.ORUU]O[M_&C>W-G6U:'&:N6&&.
M2&,?.5*DU/8(@'35[;L;J3]#<WF_MW;G=TE18GHR$-7E??52\?^J/M!]8O
M8Y\OV&=DT`Q:VD&/6<SX^CU?"B"/5!/0DY,O0H[KC2V%C?$/!-[07IKSM5
M=75,58\Y%XYEHG[\'?*"WR?P`/&MSR?P(/&O_SN!EQ"O.Y7`2XD_/01`X&7$
MAT]X.7$;YZ9P$/$3RQ/X-.)SXXE<+]/X/?M!"#N%_2(/"",_@8?(<<(%
MO;[<W6M5==U][-,'@.U9A7/J8[N;K:(L8^_(SZI=R#XYE955NMJD_VL3GL
M556<%_B?LZS'T_D]SS?I7$OE/??\X
2^37?<#[S?")_SLX6@_&'L]G<
M!#YA'.?.PD11XCS]CF)_-O%G+S(I$O7LMYZ<9$7LXC6$(..O[^/QB_SD
M8L[?7I'(MX4X7SLGD5\VCO.T0I-3O(GK52K$I\C+A'@6>;D0_R(/"?M%Y--U
MCOMX`&?;N?S=F[G(]F)]E_'U@5Y)5L7D9_[.^?'/TOD]S[^<97$KF_G_/<
MQQ/Y6ULY?ZK/Y/Y>:>1?KE'5&UE\'LWS`M@JZBH7U2`?G?,!@,";*A<NJV%Z
M1C_:RN5Q?KLB7`_FGVPQ_USIUO//,&A7N]5[8#N#M0Q6E<X.\G%??4!5XS4`
M1_,F,TES7.0#VW%<C6OC3NF5`3GJ_LQ=.8[R%?)0"Q]3YUJ^*NB%W+S3J`,`
M6V2G[2;'/K:!+U0UF6]XF;?G9<X_'X(V`F`KZJ$^MJ(>XMNOXBWI*5BGJ@\P
MJ[%==515B6?>K*HXY@^_YF,3/[$`.6PQ=\11SG4C;_#-ID\AN(HU[2=U[V
M;B)[L$_C,WZS:*>@?R.NK_C7U;UN7=M&O[;N;F'=;RJ,15JU=<^$N]4CZB'I
M3K;NG6S=RT,+ER_7U@O'Y.NE_:1V5*COAWPWR#SZVKYOP!/ZTO/R/K>-P&
MT>='"BA"HUX=FSFZY4<5\AQ;#&N,`\7/:["KYY3H?8?*NQL@4PVWUN1_U<
MV'>PV'J?Y2'VW$-\"MM7K*_J7%\O7Y\EM-RSK`X#UOB0]AYPOV#[?R5N=!
M?3SXSWS`5D;].*\=1WA<<COK:5Y!G)/):XU]ER[XG]50T:YX9RR?U0E[U;O4
M%F#E;L]VYG]?P%?2E,K_QCY\G.`_/D?CZGJ(X6#_8G
,%D?T
0]).^;YB!
M$P6.:X8?](/(9H!7-+WKMGSL_83#TXWQO9=[M14'9INS?K7!>KWZ*@Q0
M!GH:,U!!;S"W?X:J7MFLJI4OL0*QF<YESM/8KY%7M="Y'`QN^W=5[?Y<58]W
MJ>H;+R;3UL/L^<M\2QOWP;`#['EOBUDU2UA.7_`S[>BKSA1LZQ%?7/9#D:
MV_4/#;8S63_9D:R'QJ5Q1#VHE_01)_MH'L31+^D/#;(GN&VEJHY_GYWOMZOJ
MVO,F_V0"P)_?4]5)\P`NGA/X+P&<S)\!=I!>9_HS>.V#`-NN`'B&G?O_8S/]
M_R([4_:-`'#\AIUY,TQ.<J2/.(U'OR/><EA5%[-`H?4D3G:W'V`U39XI3_VG
MV'FZX!<F=WZLJC\R.TE?\GJAGS9N-=>+N2_9'\FQ5LN];']Y,%$_3T<__/
M3-(_K6/PN"@W_[>I]5!\XO-D/31.JG&O;$X]KK"/T)^O,'_NU_T\[JSBO55?
MES%L7<Z>N409^OX,%O'2VR]59>$G'FWRSF7UJ7#.13V'Y_9;^J9K`=O6JD
MYW)6W>GY2H(Q80#V2.6<YRN63W))_NA\_D$[D9.\R#&_1>>HZH$_8>[Q&ODM
MGYUJ:U10]\)%EDI>9*FDYPCF$QS7K$,PB\'4P76(Q@NI#CE_FZKBN;;G$&\W
MZ><UZL'?8(NY$CG:@_I1P;G6^37Y"3F6YP7G<GO]O$/ZL%ZKY75(1=?XJ5
M"BZ#?F-CU05]@*]4F0^MCB[T2._7VG$CGUL45](B?](B?]Y#_B=$Z0_Y#G
MPWAPJR<NG88[)>C)\##_*Q[-_[P.G,;N3!]FF<4A,9AC/$VRI+J(/_O-
M>HGZ^#N14Y_TG1?6ZR./9*S7/S/1SZS>V\GE__!'5?W=-.NOGX)MU-;[VN
MICI'L^$["<[4;<XO6Q%>VD?O*\4!_:26<PV9G_/9?#/ME)<2O84T;VT+@8
M4Z(]U,=6')?ZR7:B?K0'6]&>IJ5<;E1,M(?'QVFG88]1GVBUM\F#HOT"+^7W
M';XN,%U07N)HQ0HQTB1_;X%"X?FV?P('+L(\?OQ%$/<M0C<$T_ZD$NZ-'F
MBW(X7W%<Y"B/7!P7.?:1DW[,`Q6?4LR:]S*L]PK4`O4$7,7VRUBV52H7EOD:
M-']FL[R!B_IAMK;3C/QYFM7#["JHZMRH]]#_0\X.SC^!-4(\I\@_\S[B'[VN
M,SAJI_LTY.P+S(,W4VF_I.3YX&0V_DW=!5&6AZ>Q>2VIK`Y,*\5Y)=6Q
M532OI#JVDN:%6?GI28GSFJCO.Y2YNXQ_*&Z_S.!ZAO_(GV-?S%=ZO!F<].#Z
M$\=Z=4A"?=X6WJC-*P,^NC1#G22]S.858?.J;O37Z.OBY'[NRQ+C7P)<$X&7
MB1SWGL[+B:,]`M?>@Y%^D0?T]U<#)RZI:YX#\(R7`%MZ3T5];/?.,M]K41]_
M)WJDSXZ9W=/IQS6KXIQA1QC3N=:7`UZGW#!8[Q/N)?=[=<08SLN*TOKI
M@93WEX2\(=PK`\23XB?X_[D_TCW4E`_HYZQYKURP5\5[7_XF_?ZH]XW[)G&\
M!)]\QW]ODF\6]OZES=I-\??]OF><YJW.4;_6I^?$2:XX@]]#B:?K]]-#
MK0D\2'+T?)/%O763?F_%_,CO<9/)G=J]E7([YWZJ0W(H/^SNSS#>*Q3TRCG4
MQ];WF:)S*4?LFYSKH3[]3>[E]01>BL&\[.;E4%\2\R+'FRGB(6F;9N&QS9
M[-O$K9O>1_SSK2BGMKJ_@,>_*RXLH@>=2/OV#I&G[^V6XO[M7%H<CO;5^]
M2I2_E]6DZ\+L=_HNN'`QTX[Z>80M7%0>6N@K%?4ODN$XD[>3_(4,6W'O$EU_
M2?D"K[\XY%T?CL>Y_/YJ.Q0ER"LH']`KF)#/ZTVP_]G;;;!FY2#]05W>EZQ_
MUJL'!\L7V(EOR-=`<=@TL%2)1_@PXX-0R19"WH7R99]H_SZ'`[[:"?
MEUO)'V7R_0>D9/F0E?R%[YV0WR:S$TO2DOZY,TY7<>\"W?^8WPO]@293_I,M
MZ:GD`U;R3[SF@"_9?-/T>&/K-;2X=[&N/U`7G.XK$>V1F7S\%CE9/F`EO_15
M!SQ4$J6#UK)YPU(VKGCT/US[KR3Q7]5'3<H4%Y6Z`&0J8\QGXJ^8"%_(?I
M]I3R00OY9_8X4LJ76,COG9"64K[40G[#D^DIY<LLY">_SNYBOY&9O*RM[]F?
MTW"_Z_ZOJFR`Q'SRXK8,S:<.4#3Y,V>',OWS&[@_&V*=K;%PNW=>)+PJ$D/Y
MGF4R/'</ZK?Q^#GG<A;W-NKRO/X3];L5!]1]A?+\[=F%2W86S]5Z_#2MJ*ZM
MKZX1Y-.=#G@I:Y!\()7\&!BAM0]E_$,Q7M[B*<GR)V:\Y#_D.-/4W)Z29UGH
MR3:JA$2>"4I*[K;@'@LPF+<O!1VCM<9F'`B56!YU<#]S_A8>>:9P=S49SE
MQ/Z]&5H[X'3C>>>A/K8#3M`Y>,P"%SV4!_US?J0]$@>ZM,XNAXIVX;//^`
M#&-Y"W6.R)??9<-+MB&)SZKQPQ.<Y73N%G5E)GD]X'93NT_4'SE80<^VEW
MF>,2G_$A/P=)/_(QS/=?`/2=?FF#=97XA'C(M_"^GM.>&Q0X]I(,W_W@
MTO:3J;]1WNTZH>L/"OJ'6NBW6>HO.2[#X5TN:&B4#?VRO5$Y?(H7'IH-]E
MH3U/]%O%]R*9KIWPZCY;"TV[5!M[],T&]+J=]FL2_R4NP[&O>1]7Q>G^V0
MC/5:,YK7%?2<VY,-FZ`/3KENT>8[M;1)&#?U?DFSX$X[K#,&QX[D[)%0L_
MY%CZ)W4>D"WBK:?$`9R<P'72_3;LL.\7J+GQ#\YQLB>DY
E6\_J'GQ/NW
M</_3<^(8A[B_DN61XSZDY\3?S.+[CIX3/[>)UYDT#L7;'J4/UMHIWD*"G[,L
MUE&RR,^I_?;('FXWVD-QA?ST#7:XD?F+GI,]'\A]H-AK='NF"W$E6<1#ZO@9
M9F%/S@E%&Q?C_)-JTYZ!#V3-[_2<[!G%_/41O9HUVM]W&R>)8L[$F=!\8V
M\OA`_XCV/#=T>)GG-[,J#$$9=.IVW7\X_V[RJ:_E&IYLO.E[PZ!^P?)D/_
MR33(8"V>*=JYH_=_8NT;NR2#M0ZX='#,AP\[H`1A4$'LV6@9XCY^=OZOD.
MM?`_Z<4Z]_9M.`U5F\?2WC=0L)D_TT/O&TK]-@6%PR[$?.\_-+\C%[$_FG
MS%PO9TH[T_]%?L;SY9=OV[7[!^7_%<?Y@BI+_<G&_J>F:XA1_ZLEQ:G#V9
M[8(IJTS]=>FHOUO2]8=,_8J%_M3VSZQU^(']:.?2/_M:7VP<VP?SKI&6)A
M?ZZ%_7^Y/4VS_]C6M`3[E\D?2*\YLDB_WZR[4L?)2`O[#[&Z]S%VS.)]9?X'
MXOF67[/_I.'P-<WV'I-3OLM"/VWO&1DNOFO7[HOF^7Y`>M_0K[TVT_6G
MI]2?8:$_\)Y=NU=B'.$XI/\%)_J?UC<0-/VO6/@_M?X5+SBU]47_B^LKV\-2
MCIWJGW(A3Z:EU&WT"]E\_<&:#_6090/0XYNN<>Q5==?(M3;LH7_44EQ7/O
M`G;O8/?6\S?P5LLS;-R]6_A]ECCM]](0O]?3[_A^MT/`4:?T.E92O)6:]P+9
M8KGMB<GZH"[6-IHG`HG]3#'MJ>OA]G)Z3/7<''L)DB=[0H[[I2V.QVA]
M?6;\RQ;QD\H>V7-KJP/]C"K!QH<$'M8,NSYA9?Z?G9,\-(?X>@2Y/0ZX
MR=X'9QUM9(P.SN4MTAPQRX[?!2F\T(V/Z/';#\(!AV4O_=
MGQSZ><KMG'X3CRO2PT<"1U0!K:,G7J=:8PK;=Y@ARX6HR-/NZ#X(ACW%HO
M.^6"T6LE@[__-<"O,R48O07@_<Q$[AQ@3']._(>3S,8YG./S9)[[O01CYYF<
M^GYVYY@IV$-]LI?XT!X9CMHE&-UUT"-<<Y$UB=MYOQX)4VI-/NL\RZ&,
MO\GJ/7<5<4ER';!(<$M:R>;XRY2-!!SQ[".`%H][TDRNU-M@*"O;VX(V
MVS9O/<A__A!&>@Y\:H"O3\5H8C=3;X[D&Z/TK2C<R/V]T2?'X+V^.S]'FQ
M=20YTF?4G[K=I(\XV4_S(TY2.;D+_(/<?(S94XV4GK3IS\0NM"=52(U5%K
MG'OTO!$,4;QEL#JCF(5A[`2K.W8HAC^1/W-*!GI.]8_;XEP;8K&_1J?<7Y)T
MY'HGK&#US],KG'!P)ZVC(GT[QP$K&:?GM+^H3W89]XOKG-IY0'J(XWM"SQ.#
MY0&/L?>L[](X':H_9`VC_$3A5?T/)SO!]H!B?`ZNR<.I#VCZ/(:OX)
M?]O`;&'[_#%V_1Y(J`\EBWN<8O%>*+7\J%3G%\M7$YM8A>Y7X$_;[#"NS%A'
M#_4_WVJ'MX5Z-2==EA4H;NPW9H/&ERQUV:&+&7;$#K.R3.X[#I#_G0P_
MUDMPY7<&E_J9S\<"_#T'1(<6&GF`>KO9KGJJK!DO&\983&OT99QE6J7L_P
M[7;(9_/"]ONG%/W_5WT>ZJ^]UIG`J?_&5VD"]WBH_Q9K[]]L<I*_A[6O;2(.
MGB\72_!BIP3?)%@:X"X#TE2["-G0O_)9@=HN9-T@OUN^\;N3G`JTS8,X
M9_6BSB-1M,G.-[".P'(_N)TWK0[VA?M/Z[25AW4F>YI,L[_4WZ]I
MWL0_9?&`=1K%!7&*FV3[\7WRGQFG^").\9GLGZYW[-J]B>(6>?:P?2/][&M#
M;96_;$XHU-@(,YHK&M?$HAUKO8WMX;8V;WUWO"W:$?$VA%O6AELC,XJ;*V:L
MJW"MXUUO?..ZB)?]K"7,2#3>&2M<'VT/PXS9%8L6-`9F%,^NF.8M+RKU;O`&
MO>WMT[RML>@J;VF1\1Z.%93_<*EE7-KO$MJYBY;6FT?@D.@`^6U#36-NI]
M'%`;"/]K5=<18$J9"G]Y8JOO`QJ2J?Y"MFENZ8MTA*/=6YLB\:C=XJLFI&
M<ZS"%6QO]ZZAMLC\0@'10%OM-EC;<+I3I:D4%@N2]8/-V')C34UGGGU516
MUQA&-3;45"Z@[NP[94WSA$-),UH68DVUYLB,69$N,VTN$2?=75CX9:A957
M-WKGU<Z=M_!J;V--76/MTMJF&N__E6X^KTT$41R?:%-U09"">!+>1?Q!L]F(
M+5B"(;2Q!C1"DE84L4RS;Y/5S>QV?[A6/"M>/"A(3Y[JR8MG\59O(O;FI8>"
M?X">Q)/ZWF[3I/Y`&P>6V=F=^;R9[[R=V61G"A.&`?-P?GH:&G/UV0K;@EK9
M;K"-*]7FA4:S7)NIUF;A4K563?GZBP>L9(6-=S(;^$4=,0F\KGXSC6NQCG
M,/)=#_66V\WK.@"J!3-8F"P8QL2"81@%W3,M$?I2I:N%<\I37,OF93A[.FEK
MSS]Z3B(>C[Y]<VA$P-B($"9:,G)"472D:D?L%":>H^*5\NS%"LQ@8+<5U",'
M`V9IW(X9FYPFE,J4OIE+<22'!#8RH3`A3;&:ZL=)QP'4P9\&<%:>T#R8S0
M1:HGBBK&)49J3:=>Y0-E0X-UW%"!+OCD
Z,F3?U18Q<)6)=
FL+->GL[10
M1RZB&H?01\NB9(/8S$BN!=+SJ$&DBL"':Z2IY!H[&1(WTB,U'KRN649]I6LJDN
M!!^7(MM'WG@7C'/?>`[*@'I!WJ+GOX.:PA8&@?2709HWHR!,<H)DB9BTS)9:
M=-WMVG?1U%)+X&\I13J#))%B4"31H#RDB#A1.%68/"GNS)\9V_GQX
'#VTO
MCZ<3WN>!_W)XP?CZ$2&*]WL3XV8IC==W'3.%_S\'.]P9@7NPS&WP?"5@U+
MO?IQGJ^_OM/\)FR6F,6+$'JVD[F>WZ4RF8.F>8-2_W.L3`FQD>6M2KN/5UYM
M?-N?=:X=H]&A/JC0_(Y;!H?B'\,G]Z]>/AEI;OG.177F8(@'/@O=@&[!D"
M</3#4AP=PC`H\-/,]N`D2$`I6=/H#L$`#CWO4^8'0(P%*VW@?L&P)0__A<
M\#9W3O\`4$L!`A0`%``"``@`&*_</.N$AFTR3```/38!`!,````````````@
M`````````$1I9VE3;&ED97)?5C,N,BYS8VA02P$"%``4``(`"`#6MMP\W)\L
M`?X7``!*/P``$P```````````"````!C3```1&EG:5-L:61E<E]6,RXR+F)R
79%!+!08``````@`"`((```"29```````
end
    e14 Contributor over 16 years ago in reply to e14 Contributor
    Drill size in the error window implies there's a drill diameter violation in pads, vias and holes. This value is defined in the Design Rules Sizes tab, Minimum Drill.
    Change the diameters of the Drills on the board to a suitable value higher than the minimum value specified in the Design Rules.
    This should make all the Drill Size errors to go away.
    Jaya
    Jack Edin schrieb:
    Not certain about the zip file, but it might have something to do with the
    chosen method of accessing this forum.
    If you, like me, use a web based viewer the attached file's access could
    act differently? Just a guess...
    It's your decision to choose one of the access methods. Just keep in
    mind that the web-interface to the forums on eaglecentral.ca has a few
    bugs, one of them being the incorrect handling of attachments.
    It may appear fine in the forum, but in the newsgroups there is no
    (MIME) attachment. Instead, FUDforum puts the UUencoded file into the
    message body.
    If you want to provide files, it's better to upload them anywhere and
    post a link, anyway. This also keeps the sizes of the posts small.
    I think the Net command trick will serve me well in the future.
    That Wire tool is just dangerous, huh!??
    It's just not intended for /routing/.
    Maybe you should really have a look at manual and tutorial... I strongly
    recommend to work through them before starting any real work.
    Tilmann
    Jack Edin schrieb:
    I did a Ripup of every offending wire, and replaced them using the Route
    tool successfully!
    Next time you'll surely use the route command right from the start... image
    Now my troubles are the 29 Vias. Each has an error about Drill Size!!
    Which size are your vias? Did you choose any size when placing them?
    If they are too small, you can easily change their size all at once:
    - DISPLAY only the vias layer
    - then GROUP everything
    - use CHANGE DRILL on the group (right mouse button)
    - use CHANGE DIAMETER on the group
    Note that you can enter the desired sizes directly at the command line,
    you don't need to pick a value from the offered list.
    Next time, you'll surely set these sizes /before/ placing the vias. image
    If the vias are fine, but DRC comlains though: check your DRC settings
    and adjust them accordingly.
    Tilmann
    Thanks for the tip.
    Thank you - this is the answer!
    tool successfully!
    Poop!
    Tilmann Reh wrote on Wed, 30 June 2010 02:19
    He didn't attach anything - the forum software just made believe him
    he
    had attached a file, instead it put it into the message body.
    I was able to upload and upack the ZIP file just fine.
    Quote:
    You might also try direct newsgroup access instead of the
    web interface ("forum").
    Yes Tilmann, we all know you don't like the forums and want everyone to use
    the NNTP interface instead.  Give it a rest already.  Both are here for
    people to use, and now even a third interface via the Element14 forums.
    "Jack Edin" <eagle@logicunlimited.com> wrote in message
    news:i0dqbs$tjt$1@cheetah.cadsoft.de...
    before
    First, the file IS there (at nntp servers)
    It appears that James Morrison is right, you have been drawing wires instead
    of routing. This makes the nets have the wrong names. You can rename your
    tracks to the wanted name, like the "5" net wich should be "5v" , but it
    seems like you have wrong routed tracks too.
    Remember to click the "route" button instead of "wire" when routing. Wire is
    for drawing only, but can be turned into a signal by renaming it to an
    existing signal name.
    What happens when you route and click on a pad, the route will follow the
    airwire (yellow thin one) until completed.
    Am 30.06.2010 08:19, schrieb Tilmann Reh:
    JayaB schrieb:
    >> I'm unable to download the zipped file you have attached.
    He didn't attach anything - the forum software just made believe him he
    had attached a file, instead it put it into the message body. One of
    those boring bugs...
    To the OP: if you want to provide files, put it on some webspace and
    post a link. You might also try direct newsgroup access instead of the
    Tilmann
    Well, as Tilman and others pointed out, the file is not readable in the
    newsgroup, so i got it from ec,ca.
    I messed around a little and include them here.
    I made the pins visible in the sch, so you can see that the connection
    is allways at the little green circle (if visible).
    Your terminals should be with or without pinlength, as i pointed out at
    top left with 12v/gnd otherwise you get overlapping of pins.
    For supplies you should provide a supply symbol which automatically
    names the net.
    Wih LABEL you can make the netnames visible.
    Your "SP-device" crosshair was not on grid, so you didn't get a
    connection there. You shouldn't mess around with grid in sch, stay at
    100 mil.
    In brd you must connect to the center of the terminal, not just on the
    rim (pin 6 on K1 and K2).
    Make the grid suitable for you and stay on it. If for any reason a
    device terminal is off grid then route from that point to the nearest
    grid and continue from there.
    Hope it helps.
    Gruß / regards
    Joern
    "Jack Edin" <eagle@logicunlimited.com> a écrit dans le message de news:
    a substantial list!
    Thanks, in advance.
    Jack
    Jack, the best thing you have to do:
    group, ripup and as James said: use the ROUTE command.
    MB5!.1PT*&@H````-24A$4@``! 0```+)" (```"LHV;H```@`$E$051XG.S=
    M?ZA<:7[G]Z>T\HZN)AMK&ME7U$;Y0]WWCV46&K=5T.#I1?^TV/6<2V[TEUT!
    MTYN>! PA,&XE<;85FH$KDMU46Q!"YH]TV\Y"GS8$C((*QZA9:'9FV"'57C,X
    M=OZH;@72<7'EB/8ER>C*\7@Z?QS=HZ/SJY[SG.?W\WYQZ9:NJI[SHTY5/9_S
    M?9YSQ)=??BF$X\E_R7_[?_DO_^6__)?_IO;?2?DG`````$F9D 0```"
    M-%$9`````!)%90````!(%)4!````(%%4!@```(!$41D`````$D5E`````$@4
    ME0$````@450&````@$1-A!#?_.8W91ZZ6JUFLYF6I?K9E-[66$XFM;&BOF
    ML"F]K?G9E-[66$XFM;&BOFL"F]K?G9E-[66#%)5 8```" 1#%G`````$@4
    ME0$````@450&````@$11&0`````2164`````2!25`0```"!15 8```" 1%$9
    M`````!)%90````!(%)4!````(%%4!@```(!$41D`````$D5E`````$@4E0$`
    M```@43HK`UF>]_SK<C[7LA29Q6E?5MR+XX5C<2.797EQH>])RXOCA6-Q(Y=E
    M>7&A[TGB^.%8W'CEZ6G,M!_-86:6UQNG9EQ(OCA6-Q&I=E>7$A[DG+B^.%
    M8W$:EV5Y7! K:7EQK"2,_<LRXL8B4M+XZ59''FGF5Y<4&LI.7%L9(L3ONSJ P`
    M````B7I:&1##DX=R,+*_.(7G1KPX7C@69WI9EA?G9ZTO#A>.!9G>EF6%?Y
    MGK2\.%XX%F?B\50&````@$0]JPP`````2,J RD"69;J6NEHL/&Q*:-U&C4V)
    M-/88V^BP-0Y7ATUQ5#AL2OCZ4J:PC7I;TWNXLL<&26$;1=1O\ &5@>5R.7)A
    MI=G-FQXV);1NH\:F1!I[C&UTV!J'J\.F."H<-B5\?2E3V$:]K>D]7-EC@Z2P
    MC2J-_BSRL#0FQJ,O"^:S<4I/#?BQ?'"L3C3R[\.,_WI.7%\<Q.-/LKPX
    MS_>DY<7QPK$X$X]GS@````"0J*>5`;6\HIQR;"XNB)6TO#A6DL69>Y;EQ06Q
    MDI87QTJR.'//LKRX(%;2\N)821:G_5EG)Y.)Y:NCBQR>;LL%A?HLEA<N(N
    M>-/B7ES$F\;B`ET6BPMT62Q."SU)0/[N!EJV2G)QNO9@Q(OCA6-Q&I=E>7$A
    M[DGB^.%8W$:EV5Y<2'N2<NXX5C<;J6-1%"Z*H,]"]/>[CI69R)(!7QXGCA
    M6-S(95E>7.A[TO+B>.%8W,AE65Y<Z'O2\N)XX5C<^&79'B,$````P!,Z*P,`
    M`````D)E`````$@4E0$````@450&````@$11&0`````2164`````2!25`0``
    M`"!15 8`(![R-R4%`$!0&0" .! #```*J P`0/!(`@``-6<FDXGK=0````#@
    M`)4!``@;90$`@#(J`P```$"BSE 9`````-)$90````!(%)4!````(%%4!@``
    M`(!$#:@,9%FF:ZE-J6W-58LCJ;TML:.6Q;VM-B6$6"T6'C:EM[445BR%
    M;=3;&BL61U-Z6V/%)'$'8@`(&Y<6!0`H8\X`````D*BSDPGW'0. ^"WG<]>K
    M``!ID:S<NOU\IC(`````)(JK"0$```")HC(`````)(K`````) H@,```!
    MHJ@,`````(FB,@`````DBLH`````D"@J`P```$"BJ P`````B3I+90```, '
    M69Z-;V0Y7XYO!.F@,@```.">EB2@L1TD@CD#````CNGMP9,'((_*````@$LF
    MN=C.U##<<8`3#7\]RS,_[$5E8%AR.XPC6,,`-)A^O.9
    MSW]LQ9R!`8QF=T,M(RP<8P"0#CN?S'SHQ5`5ED=YC&,08`Z;#YF<SG/WHP
    M9T"*M>S.V+YD<8P!0#KL]\ZS/%MV';]]X]RVL"WYR=3";D@7Z6LSM]M01Q
    MC % .FQYK_S[B?/EOO6U>6'DWKO?W?/) X*@-;N,GN]-52PC$&`.FPG 2^
    M\];5ZESMZ[6/_WOW2,/)&[ G($LTW;XME4L[4Q[]C58J6^&HWEAK+'XFM*
    M;VO-ICPYQ@+:8YZTYF=30HC58J&KJ11VOM[6_&Q*;VNLV,BFE#_SE_/E_:29!(J_%NOP;,6*)"_K[9B(IR=[Z2UY7S>_&7S@SKXST,?'I(_:P]_'EE_5D3
    M`(B50A)06$KQK&H2N'7[![=N_Z#K\:'D`4$D,(S*0)UO?2/?U@?C?::K8^
    M`! 3.TE [;D!Y0&80V7@.7[VBOQ<ZCQ\]7T<ZT`(#5CIW+M[\_^ZCX8T]-
    M(% 4!PRA,O",S_VA9NVO__L!Z$)XQ@#`+B@ZZ(.R_FR>GL!H!5@:?\[PFM
    M?O'2LRL!W[LW\D)@L,__8\S_-02 6&E(`F4G87__[Y^Y/'Z5/$1QP 3N0"R$
    M]WV@(M]_YZVK0GRYK-X9A!N%=/O\[EW7J_"<-QX<"B%V+EURO2);<#\R``A;
    MT3&@TPQIW($X@"107A:@Y=Z!0_* 6O_X\L&!PK-<\2T#%(HD((0X.7HZE-/G
    M5$ >``#M'WJ5KH$Y]_B?G!D)%Z94![$FA]/RLOI98$RGL'?O?\M\K'7#PZ
    M$K/9H[??5EO$5F7WVO-4X&<,$)4D4%6D`K5(H/<8:T4>`( @,5@`PR5=&=#8
    M?^KO.97_K_$RM"@IW\M_EQT(M\0A[][Y980XN+MVX_>?OOB[=NJSY T=OV
    M,!)X&P-$1Q(H#8H$VHQ?N0!``!2D&YE0%>?:5"'J7CPUD4W[R+G;>NEB-,
    M"F
    .%Q.#%7$.CB6R0(-PF43HZ.O. B6-,!GD``"PP\4F[LUJ=S&:,%((,
    MKB8TRIA[!'9I)H'?_/?K5H2$$+<?O\STF@Y$D7W)/5&*_Y^I9,'&,````%
    M[C.@SL0]`EN30/-AM]__[.TW7U1>NA;..+.5T"OUCQ@\SZ4`("P5:\YOK_
    MLUHY71L$@\J HO$]K:TM^)P$"I%UQWUCX1@#`(0EEQD%RF7',025`14:[Q%8
    M_6OMVD&>)P&WHLPAU>* H6,,`!"SYR\XOK-:';[]2V[7"/ZC,C"8WMY5:VNU
    MP4(E#Y- E)URYRP<8P" .%4'"PDAA#A\^Y?UKFON%H="_=JPGYI@P`K=<.
    M$MU)P,YU1;T2<09>F4A```&Z3K#6/S^V0DC%X.3KA3L@>H# QCXB1KM<VA
    M-8'B/@/:5VF0B+OF3I@Q@``7M%_].GQ8']_2S/^I. YN4B3%0&/%*[LUC)
    MYR0```"\<^>$.*=7VPO-9,$4)7T'8C]4;O?<%57$KC]_F>/;O.\37S3_2%
    MB,_OWO7GGFX``*_,Y\L\S9R]=YR''MK]6KE8@/][N>CD10&1C W%B+V726
    M_6K+J]"3!-Y^
    7?-;0VP]%_U>5WK]PRU/)ROM1?B08`Z&#BCN_E9_YS7?_G
    M__"=MZXNYUR$-'54!KQ3CA'J3P)V5PH``(2-H4&NK#:+_@?,IC?MK$DK*@.>
    M(@E$XN//Y5_\/T'A]>-%0<``-[26QR@%.Q<1*L-INM#UYM%EF>%W^V?\V/
    M`5<3RC)M!Y:?30DA5@MM]YY95=V8<VN;5[/'_ZU/6W^OX(W#PY$M&&I-
    MXTOIU3;Z?F7RI
    ZOS9_K5V[=?W"8YYG,SX!C;!N-1[[P^ WNYXKI_A#;
    M<OY)7@H[7V]K?C:EMS56S&A36WOPDJW)) &-'_MZ=_Z-]5I74ZZ.BBS/E"
    MX]_;,S3E5>LRT0(D69E0"$T#\IJ\O-[BC!0KLMVS0K D4X\N+PPXOZR0
    MM3D#`4T@?N/!X!11O*:&=J;I8QZNE.>3^BWG<]-K`J!IZ&?OU@_>_@Z&]L49
    MI7"?@9V5SK-7>K7N?)G*@!!B-ITV?VGGU>$^`WYYY]U/!HT.XNJB``#X;&A_
    M;LP(G["20$P&G<[_Y2=]E0'E9I6=F4PFII>1H %E@8H0[S@&[;@N$P!$QDX>
    M( FX8KJ_;KI]@,#F'HQ[MU;_>EH4G@]ON?D03BHS"R2!*3R0# (84\(/^Y
    MK7#F"2@BYVO5Z-X6I"OAB:!RZSP```.BG<+7\O&M?7?E#B))0 O)_3^;
    M3K=.&VB=,-"Z.!.O'?<9\,[.I4O%K0:XNFB"=BZUWSH>`! !Y?L_5I^UMUGE
    M(\X3DP2T&/0Z]N<!F2107:[V5Y Y`\.8*-.TMDD22):U8PP`8-_XGMQZ.MO;
    M%Y1AR2@A<W:E>/?U 24%YZ/^8,Z* #$\<8`, ?]OOE) %=
    MUY5E_/E<KY\>/-?/[SYKU_\EKQA7UM:A"Y4!%;I>@V8[91HG23FZJ1
    MJ[WBYHXQ`( /;/;.20*ZJ-V^LW__JT4"C=_O5 84C7\-:BT4Q0'N,Y"FU@%"
    MVH\Q`(!7[/3120Z%R_57[GT0"7=_R5 ;4F;Y'8-%!Y#X#T>N9F#S/I0`
    M`/M,]]1)`DXHC_]1?N(85 9&:?:W9&8/=_72JC,'"LPDCMO.I4M;)PW;N0\E
    M`, 5<YT_DH!&\ELXW>[? M:ON[3O< \K5^:P;=`V+K$JN#A8H_[ A1W':@
    M]/2.8U=NJ:XR/G=*[>Z[B@\Z,)!>H\Q>7RP#XM!W!2AVY2>RSBC=75)ZFU
    MJ;=!R-"UVTT<$ETF0HAD\X P< )U+D2S,C!T*45]H#9_H'HGLEH2\&'RP.6#
    M`SL^OSN73LTJ6:![1</%3O?2@'05^RO)<YF'^=STFHQ$E!TJJ3V6PL;*
    M;/>9K6>SGH>X.TVUIS,K:BU<Y\1X+8TB^-)'J7VR7=RD!!>_!:
    MC;LO8%:&2A_N7/ITCOO?O;U 3,TQML_H4X".Y2H:%\BR FVM\FT1_&2>VQ
    M1#965Y_$SZV+GHG=;J<^<'8RF9 '@AA@762#?W%ZJ)4GR'TH"Z!?*,=8@6\1
    MV&?HQML1'\Q)[;&D-E9^K<;?X122_/\&'WD\IUX9*.CJJVTMVPU2SB<N)Q)4
    M7^FG9Z_W]\5J=7E;4\$-K8E/*'G SV]'Q,W<6\/;#M](2>VQI#86X3(Z"]QT
    M_X&K"3WEYR?"=]ZZ6D:"EC7<WQ?W[CE8+2CQ\QBK\G\-$1_37W)!A/!image @;X\QX?>Z(59VNF(Q=?B2
    MVF-);2R"%OK-(J@,/,?/_M#3M;IW3]R[]S02D 2"Y?4Q!EADLQ,61X<OJ3V6
    MU,;"9Z$<'F/6D\I G6]HOKZ%)& )! RWX\QP#S[WZA?*-W26J/);6Q")V=
    M[U"C2Z$RT$)MC^N=/3QF3> _?UY9?]8$Z7#5\0JWPY?4'DMJ8P$?4!EHYT,/
    MR8=U@#DO+XK -2X[;%6*'ZD]EM3&`I[@/@.=W%X+DEY:"CC&D!KE`U[C
    MC;?#NJ!D4GLLJ8T%_#&@,I!EVGHM?C;5;&W,)\)JH7Z[[.9R-6[F&X>'NIK2
    MVYJWVVCT</7D&#/Z/OD;VM=F4$&*U6.AJ2OO.5B<>?XJ?65,^_2JU,
    M94W\?"FICS<8^;>DB,WMO7357EC_3PJ];F9U-"B!OKM:ZF='^ZJG_GUBST
    M-25TK-A$"$%EH)_D)Y2N.0,FSDE8N.G8TYN@F1?3MI0LUP<X[Q69+,]E'K:<
    MSTVO28^A!_G(KZA1=B4U!Y:F-UB>,.Q">SP1VGG97.GO166X\/K3:;ZE\EYZ@(W=-4.#S@)SM7
    MH#)ZT)XE"0QBXD.$7AJJ.,:0)KU':0H=/@M[K!8#AI)#<U%S;3YL,X/.!*
    M$?+F/<(E8'!FKL[S[/YS8=.5@91HN\.PV1,6#\HELC`> GT\4!TVF$.0,`
    M`,=,?(_&':JCWV/5-!+]Q@)N<34A``#PC,.R0)4GJP'(,'?RWL(@)2H#``#
    M10!,#_.M+(-:0R``!PR=P7K?]?X6J,[C'?^M\<'@B%B5/X=N8N4QD8*X[[
    M@0,`X"'Y*YD"YDA&1[U]=\G6QL=:KB8$`$#J\M-NQR\_^:SK,7]P[D5;JP,I
    M\_F2,YT75E(9O7,4^`P" 8-#U&2J7ZU4>_7;BU=,KDZGKA!R8;/(AQ0'
    M.#Q@B/P-!\;G`?DDH"5X4!D```2@Z-32U1LJE#W657:836_>T7HG8\""HC>O
    MT%-W<H,S@,``-]1$+!F-IWZ-H<8\,30NQ$/B@0,4#7)'BN)C0*WT\`8!J?
    MM"E;4A: 3]1.]O=W]<^0->:=$R``!PJ6=\[<BA04X[A;HFJ'8VKPK#A@
    M>F.!H8;6!PIZCS>];PKF# ``?$1!P"%/\L!L.G6]"D#\N,\``, O>9Z1!)QS
    MWA%WO@) %[=WK-.^=.8,```<JQ;0BQ@P/@G$/0C$SKU.9].IJQYY=;GAWM@5
    M$7.5!TPLESD#ZCAQ!0!Z\;GJH5H>D)_1JW;S8 H""$71[<6,W%#^8,``#<
    M^_9B=S:=Z4H"9SWU3NSUL0>DXD-DH'!_XUUA9L0.Z<VGUAA>8:9\X``,"Q
    MO<UJ/9VIG$9N$U-7KY^N0UBCR6UL0BZ2%#IML?,&<@R[2]?_QL2F]KWJ[8
    M&X>'NIK2VYJWVYC"4<&Q=&4$&U6.AJ2O>K5I_O[=9%4G@Z4(E.FK]S:T
    MJ?G2]FUNUH6:G>/R:8C*%[K&=5)9N2W%B-F\F'V% WUFM=3=G<^<OY4K[+
    MG^ R30[?C,9(Z0NH,<YW?OFE[$Y8,#TXLHQ+0M@!:2`RT<WKRIJP=6C0%5
    MRJ?!AB8!MY<$Z6%M0WS88TEMK D!]4::3F8MGP#]=E8Z$ZD)6JI/-@\_KB:D
    M*.CW'@#8U/JMUI4$A.I7:4Q=O:'K%O0>2VICD8)!50+M3U? U80``,95Y]CM
    M;59"BXD4"@>/F-J- []^K-W168M![+F-12*J1]'6@]#M(<?5A ``-A0=
    MOIZ"0%/Y#=KZ3:E<BP^EJZ=PE9)P]UA2&XO4>'Y041D``-B0Y]E<B%PZ"51I
    MO ,Y]_-<I70QQCR6UL8 _F#,``#"NO*^PV\Y6B%V]I/984AL>(+[#*A@
    M]C `R*M]9KKJ<H7;U4MJCR6UL8 /J P``$S)\ZSU[(G]CE?H7;VD]EA2&PLX
    M1V4``&!$.32H]5]M=K_BZ.HEM<>2VMB1YO-ESFV5,0*5`0" 9ET%@1H[G;#0
    MNWI52>VQI#86<(C*``! I_Z"0(WIKEA\7;VD]EA2&PNX0F5@,&8/`T 7A4](
    M<QVR6MZ2>VQI#86<(*``! `\FA0:U,=,OB[NHEM<>2VEC /NY #, 769Z[
    M7@4H&E\R5;[A5%=KNIKR5E)[+)V-5=O,O<VJ.H?8YPV$A[@#<;H._^6_U-C:
    MGS]K&U'G_WDT],\+:M@`1*+H@6@9/ZNKPI=,32FJ/I;"QN@)/EF<;R9\
    M<W8RF7SS@P]<KT9(]C:;/3SEQ8ZT `2I'T.%3V8H9:8W%OK,;2AR /8 CF
    M# RSMUFLIS==KP4`N,?5% !=]"8!<VTB2EQ-" "2H'%*QIBYP@!JS/7:R0.0
    M064``## H-L(`.AGNK].'L!65 8`(!4CBP,4! "]=/74U]/9WF9E>BF(%94!
    M`,!V% 0`O6SVT<D#Z$%E8 !F#P,(PMYFH;=!"@* 7O9[Y^0!=*$R```1TI4'
    M&!H$:.>J7TX>0"LJ`P`0(2UE3(8&`=JY[9&3!]!T]LLOO]1XO3D`0 0TWE<8
    M0$FY+]YZ!S&UUK@?&6H&5 96"VV#4/UL2F]KWJ[8']Z]JZLIO:UYNXTI'!6L
    M6!Q-Z6JM* CH/4V49=K.1VIL2F]K?C:EMS56;$Q3"GWWY7Q9_+2N6.U?!ZQ5
    MGGF[\V^LU[J:"NH\&U"94!24'/'OZ[GWQB>A%_?O6JZ4448MH6P)">SZOE
    M?-[_7&8(`"8,30)#N_AYG@WMS/E0'SB9S88^96?5>1%5J&'.``! ".8*`\:8
    M3@)JSV``I<30@`P%QAP!0[24#MN>0!""H#`) X"@* /Y23P'R.;]^S#X
    M!V'A:D(`'-LZBAU=QG]Z$P,`?CJQR_G2T[Y0][9R63RS0\<+T:O@MZ]G#-
    MK7_P#TPT>_G@P$2S39?/V]Z$=:V!7"+) #X0\9??(`Y)UESH",/,_OA'SR
    MTD('&D! N(T``!P=C9D <`(!T4! #?F!CH3W$`DKB:$ #$9CV]N;=IN?O8
    MWF9!$@``5'$U(0!(0C'WB20``*BB,K =)](`A"ZFJR `D3%W,5 N,PH9S!D`
    M@)@5XX5(`@" 5EQ-" "B14$``-"/.0,`$">2``!@*8,`$!L&!H$)&@7^9<
    M2Q3#41G8@MG#`,)"00``((\Y`P`0"0H"`("AJ P`0 R*@@!)``B.N?L$<P=B
    MR* R``!AHR ``%#&?08`(&#,$ ``C,'5A/HP>QB ST@"0!Q,C.=AC! D41D`
    M@/ 4%Q D"0``1J(R``"!8J6U"V!F.@]D4]9`/H# ! ,(J"`#$`B%*69TL=
    M[VZ2``894!G(,FW'EI]-Z6W-VQ5[X_!05U-Z6_-V&U,XEBQ()J20BL%@L=
    M*R5$&CM?;VM^-J6W-5;,=%/]_7B9UB23P&JQDEVGK4O4NO-OK->ZFHKFJ##=
    MVD0(066@54RSAS_>]?T(BX?')A>1"&F;0'DM7XB97G>]?BNN<7+5SSF@'8
    M9NBI>N7Z0)9G>YO5>CHSO2!=3F:RJUK:66F+,2@XOL^ A8Z=LI.CHZ[5H[.(
    M@/C\+NO!NZS$T" @=,OYE 9`*#H_H/G[O3,
    MR#HUA@H"Z^G-KON.`?"$G3Q $D *@,`%-5Z[5LT/4P5#$T"$B9X5(:$9%?AL`6 'IR0P")4!`-"C_]NWYV)_?&<#
    M`%RA,@``8\G,%5;("3&%!(VW5C4AOMNU;MWA\6TR`#5G)I.)Y$.S3-M'N9]-
    M"2$6BY6NIO2NF,;6WC@\U-64WM:\W49O#U=6S&%KU::*@H!RQSW+GCZ]^5,,
    M.FK]+2V6BS45J-UQ70U)818Z?MTU=B4WM9\./*S/"MJK]LW<;61YI;,=.M
    ML6)Q-"6$N%>ZVHJA9VOI37&"#TGUC%VG]^]:WH1-J]?&=GF(&A./C3*/#:
    M;J_7T]O5OZMUG4?B.$6,[G1M>M"Y4!H[3LWM!W`JI"Z<<S&9#G[STGDZ
    M`((Y`U6AO',`,#A;03*A>9Y7OW]WJ9>%BATXP$B(;&E%4T120`4N-XSH"%
    M4[SR3HZ.)->'T\8(B%?O,GF>O\O\/'?051FHAH1J?O!P$S"(B7I+EF?D`2 I
    M5 8`8( 0[RM<#0EW*L.$4IBX'#%S(Z_(`T!2N)H0`,CRLR"@3.]-EV&-A0D8
    M#!D"TD%E``"D1)8$>A 2?&9S*C8E`B %5 :>NO_@\/J56Z[7`H"/0AP:9 (A
    MP3G[%V4B#P#1HS(``'W20@HDPD)>YMG5P-<3P=?3!#"W>59R0,AFY4PF<7
    M9% 9`(!V% 1&JNZZKF!014@``/NH# ! "TZJF=/5Z=\:$EK/3WM^.S-=U#93
    MUQZC. !$-K*P/T'A\4?F D`&!Q3)LXDL!Z>K/U)L3>Z@H)Y<50FY,3YO-E
    MV4F-.!4,W;3^CKO:'B,/`+&MC)0]E'5""Z@T'$?1K G.M7;L7WWF%HD%>V
    M]CZK\:#(#*O-2L0UXFA0EWU0?[UX<$_[[[S[2?6OJW<OS6H[]MX]^<4!\%.T
    ME8%2M:<B$PP`)"N.@D T9/JUS==KD269VE.2U [<[^<ZMYH!H`OO/6U>HC
    MWWGWD=Z__O["HL#X)MH*P.MNH(!`#71% <H"/AFS(B46NVJBLD>$N^+)$R
    MB%,``" `241!5#!CY4QH)8!"N\^\EWWKHJJH.%[MT3^_L4!V#$XD?/_GSS
    M97?KD83XP-=:L& .09 LI(J"&1Y[F2YJ\U&"#&;3F4>/'YL>E<>ZH,A'ZK
    M! U[[,-)]M;5ISW^AJ[?`T8L?O1<`@&`R$VFUTAQ'3ZT/)12RMRD"/07,,
    M`)1"PXDE02<DXD$NF:I]M0'FH*^GYJV/?;A)!N4!(JR`,4!Z%5`J)>&9BN
    M5N(T$M20$-2D6QDHU?HQS#$`A@HT#S TR)6>2*#W>C6#\D KMR%!9N7U[+%B
    M]/]>\O*0F_=_D'QA[I_%D(\</;7WOY_$M/_S*;/?LO///:XT]/[H3VTC23
    M0,/);":$)KXMUO:?&W6Y[@_2BCG97CX8M4!OIT!8,WQ8&+U0&@#04!C!%T
    M)>$YY23@RMG]:M<?L*08"S2RX][Z].='&?4]TI$BWCB,!%0&9%6#P7,7L_/V
    M(QZP*#B``4!3ZPVFUIQP,1E[,<7!P:Q'!T[;'3)' RF_V/0K1UG1">B^=?
    M>O3XTXME&<=G$@4!=8$D!(>1P'%EX/*!^U/L._E[0U=C7JD,$ S@.6OOLC?%
    M@?^GV_U?0T1)(238RS##1_S_Z/&GP?1Q400C":!I()P:<"@CE4!L:J?L03
    M# "?D01\TRP.I8G)+1>!=7H?1).&/H/^YPD@2[--;%>0#B9S>P7!U?,Z"W
    M<T P0.+F\Z6?'6Z&!OG/Q!BALF6;(X6T-YS=]7$\)L.BL?HWAL=UP(Z.7S
    M+_WH\:<J#0#>)4$6@4RQ&@D@.F$ P`3_B93Y*RMUG\W)//:K_\@W,O.EF9
    MH%4K`W<ZOF6JY(]\R@PS?\DT,5P0K!?'$B],F 'P0#I\HX0$%@/;WI>A6$
    M$&(]O;G:&J__.4GGPDAFS^O/AK5W=6I/T2AHZ)Z'G8 -X2:!+B'7$*@,
    MV$8P0/0\R0,K -Z%)6!<L[ G>X7J[5'RXLKH]Q+S6"<Y]FUS2<?G[;UT['
    M!85Q\1D$+;XDT&5K0O!C/YR93":2#\TR;6,N_6Q;VLR3<WGR_(GS[/RQ^B
    MO7%XN/U!EKS=ALY7!VVIMQ4:QP8<6,-B6$6"WJ)^!]:$H(<?S;]6%"8MNM
    MB$O5C\KY?)GG.I/ :J&M'._M49%E6>V1@@QGR^GT]G3O?KAY.YEXJ?1X\_
    M??3XT[_STQ_7?HJF;OX?/]:X8C?6:P^;TMM:"BLVK*EM2<#/;=39VLV7;_P[
    MY\7-EW4E@?$?%TF/$?VQ*'VBL'G=^^.;Z2?S:O$1K8YL7U_DIJ:%"6YZY7
    M059SF)!X/@R8FT L)&[E:W3I:HRN<_$VN?;N)Q_=77X43:KQ1H)/C,K_L,:FM6!J8,P"&$B$&3@8>9OPT93X147=>OHV7!_
    M_J'(?_5+D6?BV[O_[IV'/4_Y?TY[_X4KIUW,1QW7'?H#PH?I#,T$".YPQ8
    M.,7;X3H2&T%;)XV)AA@)(?O,N6WF!CDNJ(!"!9A(\LS0Z?G@KBLJ2<,>
    MNW=/[.7[YK/;WM^,.?#VFCJ]-/2/"!+S*^T:@`HIPI4?_GRB(X[(2$M)($0I%L9L'/"THZN8"#(!G#-:'&
    MH4$EO.YD^7S'4V,5(HUC%"!5TCA9[>AWA_?V>URO+LUNUG_?(R`[2F`HT(
    M"1$B"02"RD!L:AVCHK=T<G0DA(@F_" LAO(`!0% CR(/%'\00@AQ^/8O"2%N
    MW?Y!]5'55/#(XDT)" FA(@F$(]W0"WE(QB?/^@V=7WR<8(%P4!"FMS@0
    M>EE 9J20GCUVF@>JBSM\^Y?>>?>3[[QUM;E693%A\XN7/G[KJG#Q?KS<\?NN
    MFRXG^XGQ/1?G33:;W>GT_Q-6+X_IK]IU>SU$92 AU0! ,(!-&HL#% 2BIRL/
    MA)X$Y.G`ZM?O/2.$&7OOS4)""&>#2L28CJ=S>?W14+[OSMV;4"A 1K-IO=
    MZ;3O,K7P#96!1!$,8)F6/$ 22,3XWFTZ2:"@9X^]=54(\(`!8$TJ?5N8TH"0VG?8VT3!NJ]_Q[-
    M<D%8;V1&',DC"00MVLI YG0%=(J'I3V+L#L4,$`SA'02!Q13]5LH,;:PP8
    M=,,!HWM,N?@_R"B00@)-22!T$5;&5 FT]/M&6)8%=/[GV `085!R@(H%#V
    M65L[H[%F@*JA-R SL<>TS.H.;A#1('Z&A/E\:?2SE"00@;0J`[I(OJED,D.(
    M'XMP6 G?R_$;8%]DGF )("F%/K]7=1N2QKCVF_&9P(?Q"1/#]#@A8D@3BD
    M6!FP-NM1YOT<>I&AW).7#P[BJ/_"N2)AOOD;?9<T`1"-R 81R0L])) $HD%E
    MP+&8B@RM]5_AP8K!-SW%`:[T!711*PYH6:Z=!<4]B$A>$"&!)!"3%"L#(1I9
    M9#@Y>GI9:&O=+((!ABH*`B0!H(?]/& M"=2D,XA(GC\A@200&2H#\>AYVW]^
    M]V[Q!YEK)0G='3"`9IJQ0$`H DFWG 51H2G80D3R9D!K[W%;L2@YK@Q<
    M/G!PC<Z=_#TGR_6!9'])C.H==T(!O:9.]I'OI7>% ?%.$\SY@A`,@K^NA&
    M(X$/,:"&041#57-4UY=OZ^.[4!"(57*5`2Y1(D.FHU\+##OY>ZT/Z]G;! ,(
    MWI* *G,E`@^30 V#B,90&VY$$H@8<P:@J!88NLX02TY])A@DJ"P+N%X1(%0F
    M\H#_2:"040:]82$:]=6'W
    $R
    3>3R"DUQE`):-G/K,Y[O/E.]E4[VOL.D;
    MX@!QTSAD**P84,,@(G.N75M-IP_G\_KO>[Z[V?-AH3(`]R0#0_FY4UX<J8E)
    MJ/ZCZP]H5_;C%5)!T!F@%8.(-.H9'=2S5[VZ"BJV.B.?!+),6RW2SZ;TMN;M
    MBKUQ'5!(?NM]6]C,92H^GU*]?N57W']P>/_!8?9/WBC^T/JC=\5<-:6W
    M-6LKUIH$>@8+I;#']&[C:K'0U93N%5MYV)3>UGPXI;S9?%3_67K-K8^TMR
    MF6ZMM:GR6Z,XG50]J>1VQ2RWUOH9*].4Y#R!9E/5K^SJ3_6%Z'I1(MOYK6ZL
    MU[J:$CI6;"$2<RD.PIR?+2HN;8O$!3;7.J_7N%J<M=BY=2O-0&4K/54=
    M&C2F'51E>3[T<MFL1](29KE`H7/6)LSAN.N))S,9D.?LK/2><IC^8,('C5
    M`%#KZ+=F`YG </G@((B[/H=BZ_<0,P<`V,$@HJWLWTS G_NII8DY`XA*K:,_
    MM&A0-7J\Z!V(M9?$*@B#P"PB2L1M?J$J*$!#L<5P8L#%^I.CDZTK+$9.]9
    M%IRNHH&N><:Z`H-D4VJ,OLOZWU/E?84EUZ':&N\R`'9P):*25TF@!R%!+RH#
    M2(7I8-!ET)!Z+4UYHDP"\HHIX%P2"H K*0\B"B4)]" DJ$EHS@"=#)1<!8,>
    M0109)!6[5&UGD@<`""U0401)($>A(15 :0NM9@L)._Y^%G@5J1H?6V#.9Z
    MVW3E`<3$YB"BW<WN^$8>#N_3QYT$>A 2"@E5!H"MREYL[6I"8;W_:VO;.EY?
    MYOJJ0_OT8PH"M>7>?W#XIF#.``"_&!U$I"4)%.T,R@/))H$>J84$*@- N]:S
    M02+\]WQ!UPT9J@^F( `@$=H'$>E*`F5KDGF )#!(K"&!R@"P7=S!H(MD8"@S
    M0T]X4)A)S&5&`?A/RR BO4F@;.:!UJOW4P2T*4_)SV-/:[R>?\GX.@V1
    M2F6 TY;0)<U@T&_KFTNRR%!MA]L.``BVB B$TF@;FK/F#_MF)I*@Z DSOU
    M.Q _:L2#DI.<$&UE8- (!T!-XL% ?I* 9!2OOFUW\O=$6^TUD7T+(%SR@XC,
    M)8&R_68>H"#@7$^/O\@)W[/[W1=M9:!Y)]K6>$"Y`+HD& R*F;YZ&RS_7-QT
    MK%D<B.&# !BU3(R'02)=2S0,D`<\5.:'Y+69T6DTE8&FUGZ_QE'.0"G!
    M8&!(<[!03#=D`)".6KG@UJL?B7,7["SZ*T^\?JY[VNO7/YR3?^Z6D2X.,O
    M$;GD=;&9#4T^/OR@F$! Q",+ OV;L^`_#??[<W>P*<>&K3X[7_[86# X
    M?F%/"+':[/ZQ$--S#U\[_7U&'HB"EI"01&5 ;?9PUU/N/S@L1C,WT6] /X*!
    M`G,SB2DR`"O'!U4#0!E,-"8"HH8((2X\,7Z]RX\^L;1V0?//X \$%!(2'U
    MRH""ZU=N%:.9FT_T"QL(A@$@2(#`(VZY@F4&4!+BABP(4OUL<O[!5)X%>.
    M+WY5')?S!\H80!Y(3;J5`6N&%FMZGH*D$ SZ7945U%!I^W$<!(,C.&FZE
    M"/'@RE_)MU8$@/(/11(X?O+D;__TI\=/GGSEP<]>./>_S3[^N/P\VKUV;?;Q
    MQX,VQ+E?.YZ%2)'9<"&GB]XB@FH(1BT\C\/;,6H)"!E0Z\=].-S%\JK`7>
    MN#\U]:6RR3P#X_#2&>E+__R:6O'Q_]/2&6_YF]O''[_S0);G@DA@$I4!
    MQR@FH ?!(#5#1R7M;39=CUE/;^I9)P"C#4T"M9L#]-_.K'APL8@B`QR_L/>'
    M/_U7/_W9+__AT=^IMO.32U\_>_2G0HB/7OWUUW_XW>H_>9X'!)' I(D0(NX\
    M$/K9Q":%8LG=^\:6YVGNN91F!#9YBCP*AC8?(O%]W8>J?AV;6W6;3^?C:=
    M5O_*_@1,&YD$6K5"QN=HO9`G_XTW]5# VJ/N4GE[XW:SXLSY\C=%'BAB
    M@/]AH!!B&#B9U>] O-7.:F5B3;I0&0B/0C'AM?/?,K8Z<*"K8B#HV^%45V7@
    MSO-?I<QD`(PRD01$Q[? ;/[PHR??Z$H"14V@ZJ-7?[V8/R!"&"Q4R/(\Q#S@
    M.>8,Q*/G"_O]W[K:GONF1"!GAOTQM>'BV#F@&8^@SX0S()U!3OODR(S6;U
    MOXOU-YZ<%>>>>T!K$BA/[O[L<J*(BY4!I+0<\$H4!YZ*?9D >L(ISX %
    M:DF@:BFRZ?3A`R$N?_HS/W_ZR\UTUI4$6G_O/XH#VE$92)K"#9C[GP6O1!\,
    MX ]NR ",,3X)_&=/OC$];>3E_5_.C57Q>G\P2*7U9G"X2;!&#"&?DDD&52
    M)WZ\:FKH&40_MU%O:V\<=O;RJZY?N=7U<__!8?F3_9,WBC](GA?L87\;)<5Q
    M5,SGR_(GS[/RQ_F*315;(NUM3XV9008K5HGS>LP,1143T.NWZJQV?KSRNO
    M[((6M>*;3:[__3<]VN_+'K\?W'F?/'S\S]]
    M7/W]3[[U6-=::?S8T=N:MT?%C?5:5U-"QXI-A! ??/#-XB_QG8]A.$'!SN5W
    MK%T.E:L):32^8N#J7<:[6_1>3:A-.5UB@P(@LP$XI%E@<UF=SI]6V7<);G
    MJVO7CI_\O>:#:S6!\@*CJVO7A!#^3R NA/4Y%MC5A!A(@#&XMUJ(&$J$0#'U
    M&1"G2:#VR*Z0!]6G]PUB@\NJB9M81OGMNS@#=`K&_/_@I]X96(_8<&^U
    M((3U"<!,8FS%U&=$;+/9%4*426 I1';ZWX?3:?.P[D\"1E<5GNN\FE!KMT#[
    MIZ'I\1XG1T?]B[AX^W;UKX_>?KOVK[7?%"Z___[3#* 0'E!!,<$"M7=9]=X4
    MU4O3-J>/;WV7J4EGI!;<8NHSW%(;(]1:$!"G>:#P@_6TPC%B0!])*ZFE#S
    M/M@BA$]P\.>ZY[4\2 1VW=7C[F]L#N6*TT]Q823HZ/6?(R1X94=VSU
    M,E/.=SC%`5A#D0'Z$H"HI($EO-Y.:>(PR@W[#[#(0UBF KM23PZ.VW+YM?
    M-W29SY==YZ&[H?JO,\:D]9@T!^\C2(/P!\4&6!!3Q)HU9,$NHH"NKW&; S
    MCLB0HD^OE@1$9=S%Q:.C1V9&.C%&0@'W5K.LV'M%$O"J8@#XC*G/4-:?!);/
    M#Q-:SN=?>?+?G=W\2?.1) %4Z;D#<4#CB,:,#FK]O2$6KIZ9#H5[J[TI"&/#
    M.!Q*1'$`\6%4$IID:@)%'BC_<.&+M3AW3@AQ_.1)^1B2`&HTWX'8\W)!V:'W
    M/ G FJZNI<Y&L-^," /($&,2DJ_.B@XK4L2@3E/0XNG#M7_.'XA;V+IPE!
    M5"[8GPDQ<W3]?H7[I4 O/96!5F[!<U!S-J30.U*1(A)]5HZ-=5ZU0Q-J:5
    MMY./@4109(C T'D"78Y?V+OP1<N];[-*20$)TEP9:.7#M&,32: 8:Z1]5>$Y
    M9B8H,QH,* X`RB@R.+2[V>V_NJA:$E@\94GWQ O[!5_O?#%NC\)(&4&P.M
    M:L&@N$:DZ:Z2H22@?3T1-(69":&'A#$7$:)B``2'J<_VC:D)5+OQR_LE?M
    MRBK_1;)L5 :ZE->(--H5( G N2B+"1HO)]H:#';R]X;V&"@.`,XQ*DDC7:.#
    MQ//!H&HYU=(\PF:[,M#PCE"D@`\%&XQP=R-!<IF+Q\<(PJ) _T<S([$*AA
    M5%+-UI%":FWJ;1 1<UD9:-4:#)2['2/O)R#Y>T [GXL)UFXQYL-T(P"N)%YD
    MT%@6`/IY41GH4G8XQI02 (B?-B@JN;#<L'`XH#0#JB34B@,CDP!E`0SB
    M766@U9AQ1"0!),)",<%5$JCI"@;E/Y$'`%0%,?6YS ,D`5CF=66@U?AQ1-QG
    M`$G154SH2@+7K]QR&!)JW\V28P8`H,:'44F[F]T_%H(D`,O"J QTZ1]'U-J)
    MYSX#0&EH,<&3RD"/I89<-M.P#%44EWQ.S6JQ\U'_/C:O_R]"X]^X?BB
    M<A08F@2TSUI&H,*K#3J&D=4P_P!0$:MQU_-`#WOP^YO0\Z@#35/F3F;=WT
    MKSXYKOWF_4L_>?/H[%?%\94'7SG\X>NM3?4@"4"9X\K Y8,#[6V^*0Z$$'F>
    M_>5//_G>X_>*7[YV_ELD`4!!K1K0K P4UP`MWVM-KCK?U9D#254,`/CFX?1A
    MK;->JPS\WH5'OW)\49Q[M=O7UL5SY(9F%0\>.CZ#'T*(A9)9:#5=#J;S\5
    M?_[\ZU_+WWQ1/#@4S_=F2 ) #_EQ03V]ZIXO,]-]\=:9Q 0#`/8U\T#I:1)H
    MV-WLBFM/G]OKT*(MB)#4S5[D 10$_:<`5G[+V[UP__5LYSF'X:2KQY__
    MZI?7VWY??3S!`'&33 +%?<1[*.0$:_UR@@$`:UKS0%<2J.H?`M0Z_:"F# R'
    M/WP]%\Y.T,!/,5<&A!!B?[_X?W6F[UQ,BC
    >ORI>/L?/WW 9>JS[O_F%$P,J`UF69=ZC@!3=V[5_[QT;:3E_F#0R'$?_/>I__QMUXZO53B
    MJ*8VLR3<E?%CBFD\*H>^4Y:JS4U,@F,?RG++YMF4V.*
    M"?(KMC48^/EY(18+1:SFS>U-5WQ;S=8WZN6 K;J+>U@%:LS ,*2>#XUXXO
    M_//M=8!6M=%!K=NH=GW5Q6)U\^9,H:E67R(W5BO?W]O3TM30L>13M&*,^S
    M8>3\J\G1T?RSWWT-/B#[5R0?UA\58&%)B8"]YEZ[@4C*&0!+[W^#WGYXKZ
    MBPFZ[D'F5<5 X=*BR_G<Q)H`&&IWLVNM"!<S!.0S)$_U%V,JLGI:UV5H,G
    MA8\1^YR!T^+ SFD/4G)F<-$?RA\<7G__L_MOOB@:%U&Y>/LV<P80);<W$5.V
    M=69"\YM)H3?/4"(`6ORQ$+\0;Q(00XH,>YM-SV/64SU5`O2(?<[ \X9>(VC^
    MX>31Z<SCZN75RYG'Y(&"S;(`+ @T#W0IOI.:Q8&1,Q,(!@#4;#:[T^G#AU9N
    M&.SSM8-./YS[@-[FT7SE\VG\,$[1M25@7OWQ/Y^61P8>171ZHV-\U_]LKA
    M:3D7&8A,D0=$]UV@],<+3Q,D<$`P"2BB10_GG>J-:^)P$)56!NXTA@DQ
    M]7D,QY4!<X._3XZ./K][]+1T:,AHX-*U]__[-'MWEZ?'G5T4>/_W%9,8BF
    MS^2_RP<'3!NPH#BD94H$Q=M-[])-E)O4KBQ4)5-,(!@`Z%)-`@5S>2"")"!/
    M;>JS<E.1B;HR<$JA)I"_>+6PP((2Z>?ZF\Z%!U'%%2P8 Q0G&+;,C02&.*
    M"00#(''-)% PD0>22@2)#]X$RPRQ#]G0'%T45GW__X4K6W1+D`,8DI#VB\
    MLE"SY=;?MWZO$ R H3YT[K]EN[>;EU)H W#Y $QM!59 CHLSWRRL"CM]^N
    MWB:L-'^P%9EMRGZ<H&KL@`CA2R*0]89N<R1Q$+O0MH7Y1[3,M&%>TXV;3^
    M)%#0E0=(`A8,"@ROG5ZPOE7_5>SMB\R4.2!:E=>5Q)HC1DUE L0C6CR@GB
    M@,:U'[3%0]ZGAWT+N ]D6YQW1M5-F:Y4V320(%O$Q*3N3^[TW6?@45M4
    M-[SQ[SI3_[(*P.%:A[0F 2ZR@Y=XBL7N)TM0'' OF@N,>1/'JC9.OFXLOJ
    MQ;FCO!1WZ%U ^Z+<8WHWJFS3VJ;))P&DJ;4R('\A[ZG#!)_9:!;Q)07HW6
    M<H$(K8/%O.$TR5]B""-)!(-G5]INO11W(="<$'H7T+XH]YB)C2I;MK!I) %H
    M8?I:24E4!D3WY %A/0G4!#J.R),D0'' E0B&#'E;'&C5&@SV-INRH]_3XZ_F
    MA&I\'G;0\"VA?E'C.W467[1C>-) ";QEPK:'0.LP(;7[#!A:PR#&$7D2
    M`TKD`5?(`ZY4P.U@D!K)C^LGJG'F]G)H3>!;0ORCUF>J/*I41V, #]DJX,
    MM!I_GP%#_!Q'Y%L,*)$'7 DZ"<2AUONO9H.MHX,TWH!9([J 0T6YQ^QL5+DL
    M$YM&60`!2:@R4B.%U^S\"S;O'[[YOK(A<=7.?CB+S-`%7%2A(),%2@Q8$N
    MU0`P!C4C+D!\Q@1= $MBW/V=RH
    M)OBZ6X8U$K(H$K$0P9BD]K,,CS?,PGAM%B0@1=0,NBW&/V-ZI<KJY-(PD@
    M.,E5!DIE)! =TPEG4E@?]_LG;;>IF1E)4ABE0`&9$5!UJ5P>#.?&[H$V-D
    M,2&"J!E4>XQ5QM5GW\II$$$(4P-5U4@@GL\&Y6\ZD\"]>P[S0*DU&,3=
    MLY$4Q `G"PA%6Z60!TJ63R7(%!-6F]5>Y??K:=\->K0+,0]$T&EN;5;MB:TK
    MH];:R$TC"2!0Z58&JIJ#A:X__NSB^><2PG/>?U\(EY6!JUW)DJDBP-@*YM5UU.J.<&?+J!E$72:M:Q&_PJ4_SJT9>5-(PD@7!,AA,,\
    M8.Z<Y<@1S/U/#N4,6"Q-FI#&B?,V#_719<<2"KW#1 TK)R:=$>UH+!T([:
    MWF8U:ZL;-%=2>?2$:VR^$>&[IHA>6:7@1)8 QS'V6>.)D-KG;NK#K/B9A
    M92!^E L`&4D-%NIGIV*@L7_6G)E0]!16FY7\H"/_ZP-&>[3LE S9'W&[S$
    M2:!XEKE-(PD@=(XK`T:-5Z/OD] ,(!><;QEPMH*Z?3-'YNV.D""B&^O=CM
    M^J?6G.!M'K"VQZPMR/R#"V.)# >E8$F@.P@6G'0!/%@7ZZ*@8VNX!W;C[L
    M6ESKY(1O+W;OW/2N;V=SCQD]B3[&*4,W;2M2 *(0I7$X)@'!& X:Q-/C;7
    M!>P:063ZWFJF>=AI'D]7WM"X:20!1&- 92#LN52TVPAYO2VUJ(*Z;P[>[G
    M'@MQY[MMC14K218'O-W&U6(QNSGL?L-=Y%=,YJ-#;3/;X SO*F>N!JL9K=
    M?"X5*-];S8>CPMP>6VTV0HCCW_[LPK__8KW]X<,\"A\=?J_96F$VG5979FM3
    M\MLHDP>:1T6-?!)(X=,U@@\QRZW=6*]_?V]O^^/DC%\QY@SH?VY\&$>$K2)[
    MRP2Q.?X/M.T,!G*G9K4//C&W7-/%!+=[K(@!/693Q:[;ZO3>V-TM3X671P)E
    M`8W\_R@;B3D#B 'CB `HZ*H8Q$>YF."YK3' P@HH)XT>(P<+D000&>8,8 "W
    MMR@"K&$FL7;5G;FJ7.&G:"B3FI3H;"=QU%VHL))O;8;'ISZ\G[U) $$!\J
    M`U#$]8@`JD&@.HE?>3O"1"!0<6$8B]9WC_,P&TR_+<DV$A) %$B<H`-& <
    M$>)#<<".KF"0LN915WRT]NR?6'.4B3%"!84R$4D`L7)<&?C\[EUSC9\<'2FW
    MW__<RP<'JBL5.<H%'CZBN->;NU\N%=1AZPK.S1N=0V<6/+QHIKR>'O^\
    M8]R1\JXKRP>C!1R7AP@"2!B5 9@"N4"`,J8H32(M9D):2()(&[,&8!Q?DC
    M7!0'?,!GB#*URQSE>;97N8[0SSWYK/J /SC7?F<`+7[Y^65=J!0E<HDY#"8.
    M"9(`HD=E`%8QC@C!(0]XA<^0\?HO\]KSKT9C0.LBJG,&[K@8)D020 JH#, 9
    MQA$!&(./"S4RZUZ&KZ<,U [;5_ZO[2LEG](`D@$E0&XQQ@`>([B`%*SG,;
    MEQ;MJ@S,NV<8KS5=#LCNI'TE?65XHX 25`?B%,0``$):>'O]>1TZ0
    M# FKS<0U47[RKUP9^E(0``( !)1$%4SU[]Z#_]X>O+*R:6#'@GYLK ]2NW
    M[C\XO'[EENL5@2&$04D^K<;Q0&;LCPS<3]=L:T&"X3>ZPH#HR\KFA7I[\(
    M"3_7-NZH67_PY(YC0*RBK0S$W2])#>.(/'3_P6'UKRF\W<@#@"Y%2&A-&K69
    M":^O)C 8.VM5Y0%["P\$',E0%$B7%$;I49H-;[+WY?30@IQ ,@;J?%@F<UAPG52@<]
    MSPT(Q0%K3(Q[B76,4,'<'IM-IT((RY&@6&B5VCT3!BV4)( T41E #!A'9$Y7
    M6"KYN/CB ?D`:2IV3LO8_I;UZPJ.-A6W+.H!LPKS:K/2'6TUGM]R0!)"O.
    MR@!2QC@B+90S0(]8XP$,T7NJ.^ZR0"'B/::V:<U/_BS/Q'0FA-C;K*J__P]N
    M'/_WOW]A3ZR:(0&('I4!Q(QQ1 KZAP/IU1,/=OWBC]X^'I1'!&5^_6JWZM
    M41'OL?&;5MVH:J?_:4U@L3S(:%66. MCUA%6!E@P@":!=L9:(4H*!<^N6#
    M@^(/S4(_+UQ2]'8!4Q#0'EO.EX.6-6;3NA94&QU4AH3F@C3.8 :\0F4`R:%<
    M4.5)!NC1?&E\B <4!\;PH0O8Q=#]#4:*>(_9V33))%!=J^8O+<Q@!IR(L#(`
    M2$I\VK'-X4!Z>1(/R -CN.T"=O$S"10BWF,*FR:_:(6KB&J9G%"@F( @3(00
    M,>6!VG>S\E<UW_$IBWL<D;FM\^I=8R<>N-UDR2NQ5/EV)U>%X2CCNX C6W8K
    MXCVF/#:I=36VMJ8Q":BAF%"X.LW\EL\*STG=5J^X/TH3(`U$4YCBCNA--D
    MIWI <6"DH:>$1:63I]8%[%D3M2=:%O$>4]BT@L*SG"<!03$!/F'.`- ICG%$
    MQ9J'M<XF&(H'Y(&1;'8!>]9!5U,61+S'E#=M$!20 ]F)L",_))(,NTO47]
    M;$IO:ZQ8'$V5K<WGR_(GS[/BQX<5ZU*N9+'._JR8JZ::K55?T]HKN_4E]G8;
    M5XN%KJ:L'15#.V&KA=8"N 1"IVL'14.]]AJL=)Y*X/&9BHW/G(;:\OU\PT
    MGR_S7.J#29+RL]M%&%B UU8[W6U930L6)1S1EHGI]CS@",\K!<X' X4)3O
    M&LGJ@9-MCVR@K9,+@'IR,EA-Q'O,W*:UE@6"/@SZ!5%,B.RCK(DY`T#,O!I'
    MQ' @$SRY<E$[ P1J2W1YNTBWB/&=JTU)* 8&8"Y#!G`-##U7W-4IL9[%Q7
    M/'">!B-@LW<;1Q<PXCVF?=,23 (]F)F JG@J`ZUE>N;VP0D+UR,B`_BC^G(7
    M?Z9ZH,Q.[S:F+F#$>TSCII$$Y%%,2!"5`< @$^4"A@/YC\%%8YCNW<;7!8QX
    MCVG9-)* %A03(N:X,O#YW;NZFCHY.FIMK>OW:JT5+A\<#&T0&%DN4,X2&M]E
    M_=3>:UU"?)?UE"*)!X.8Z]W&V@6,>(^-W#22@ 44$T(7267@_H/#ZU=NN5X+
    M0,J@:<<,!XH5\:"?B=YMW%W B/>8\J8%EP2TO(^;*!D,6%OLRG_O)[>-M.
    M:!//G $@1#WCB!@.%(Q\Y1DXD'KPVEMW?K3P_)G(CWF,*FI9D$BG9\WLS"
    M\]]]SRXMNK?IO,D`.<&<2"H#0 3#!P.S/X0^-U"_J+1>7IM(B_(W7U;OWO
    M&D2\1X;M$J;S>YTE?*961S.]59T@\D"KGDS:DZHYH=TSH^80V4`\$7
    M<*" EAY_<HM!NQ94)E
    O3KL'DN
    :9X$&B?QB'VV&:S.YT^=+T6`YB8[Q%N
    M'NA2_5B[4[GI&#,3QHNA,D#_`T'K'P[DZO8%&,/R18V;7?^XXP'0@R10;3FR
    M/-"*RQR-1V4`<$.A9V_A]@70Q>U-3KKB`;5UP"NF[Q&12![HPF6.),50&0`"
    MHN7L_J#K$0'B-![TU]8Y?A"ZL,H"=NX>G7@>:$4QH2;XR@!CA! *0U<'8AR1
    MMSR_`SK7-D5D2 (]RR(/2$JSF$!E`##+9@>]=1S1:^>_97JYB /Q`.$B"6Q=
    M(GE@CB"<%7!@`_N3U)7UWH[]UM?@#-33[/"\.;$4\0!!(`I++)08L+68
    M\-KC3VO_=/'\2V;7:2 J`X!FOMTLK,P`]Q\<-G\)TT+/`S7$`_B&)#!HZ>0!
    M:\I/PI,[L]H_/6K$@X*KD!!V98 )`_"'_^/UJV\6@@%T(1[ H4220&L/7JTU
    M\H /NCK]94CXGMU/42H#P"C^9X!6K<& 5&!(9,6!K8@'L"/Z)-#?:R__=6C+
    MY %OE2%!YE.T-/[C-.S@ SNB@I#?!L.I(QQ1!:DE@=JB ?0+NXD,BS7CQX
    MT"+(`\$Q.H,YX,H`77PX$6@I0 ;CB& -\0!CD 1:GT4>2-/XRZ'&7QD`M(@X
    M`[1B')%VB1<'MB(>0!))H.>YY &4Y(L)CBL#EP\.E)[D[\G73Y1XYY"F(5
    MG"@\4?RF)I"UOO=LP;!QH1#] 45A(8:GS7?&@>0)JH# !24BL%R&B]V[%@
    M%TFC.# 2\0`1TW62GCR H<Y,)A/)AV:9MF-K?%/E%ZK&M=+;&BL6:%-YGA4_
    M\_FR/%DQ8RVIM!4N7#F[QX\.V6E-N:EB=VEIJM5JL=#55! [OWH<UH[&
    MVF%I><7\:4IO:VY7K*<LX.T>6RU6,@^33 2R;3FN2R>!#;@;Z[6NIH2.
    M%0MU]O"@LVL*I(X>Y>@T(<#8!R@0Q='R]9G@]]RG(^'[_<X% ]B$.@`X0D
    M3])K'[OO:KDHO\H.YG5;SJVU<Y6U23$?#5A `M& ZD5[D;V;%=&"QD&8.+
    M(A!H$I!DHD?.8"'("W+.`-^C&(^NJFG-5"#8VZ?(`VY)WM"'%\@3<2<!P#DJ
    M`T@.PX$L8]HQ_-=Z-%) \ %)`# MR,H`H(!2@ ]:@T&:KPC%`?\QOLBY%)*
    MN5'[C!2")"H#B%SB/4Z?,8X(P2$>V)1"$@!\X+@R\/G=NT.?<O_!X?4KMP8]
    M\>3H:.B"I_";96"P'"@@L*[3)G">TT(\=KY;Y5_?OWKA9_V+ET*?K7CN)
    M!(@'AI $`&NH#" VE (<NG[E5A'7Q[10_.'RP4$*+R5Y(#[$@_%(`H!-S!E
    M)%+H.:&<42(`_%@$)(`8%E@E8&1)QT1)88#12_NZQ%1'$@0\: 20"PXG
    MP/BA"_ 0I8 T<3TB1(EX($@"@".!50;L(#GXC/X?2M&,(Z(X@";B02*R/#-T
    M=5&NPI)(54&Z.GC R 'A&,(R(/8NXXP%E`< 5@/P'5,", CCB)".:.(!
    M20!P*3P""4$4)'-\Y__K_+PAI'1'$`XX48#T@")D8*,48(\J@,P"]D@%#X
    MGP2J0BD7D >@G>?Q@"0`.!=,96!HSX,K" 6'X4"P(ZQR`:"=/_& )%#26QR@
    M(!!J S ,9]/TZ)'$G;SVG'% =@GY-X0!HT94'2 (8IC*@ **`SXC`X0K
    MRK=5..(`#M,QP.20OQ>8 D``5A5 :B['PDB% \)SS<404! AC?$@J22P
    MG"\'==#'Y(&A2<#0_0T0G)@K`X+B@$\XVQJ'I-Y0#L<1D0?@/[5XD%02*-C)
    M`R0!* NC,H!PD0%BDE02J&$<$;#5UGAP[=HJM2104,@#0KJ_KC TB"2 JL@K
    M`^*T..!Z5$<"#$RLXX(HH#B$#U`"YJ`LWJ@4CCFV)H'A"57GYKWUUY>@!)
    M`#6.*P.7#PZV/B;/LS=_XY,Q2]G)WY-<5OEX0>CAI.FOM%U,$N$Y-Z^Y@>
    M1T0>0'Q:CV>O;GU@CD(>*&B<%DP20%/\E0%Q^H7J>BTB1P:(&UW2K1A'!/3H
    MGRK@SZT/3%/.`[J6[FK1\-F9R60B= LTW;XMF4WM;26;$\SXJ>8O'CPXJE
    ML_,];$IO:X&N6/EV*-X=Q8]R4X/.9:P6"_D']PMTYSMLS<^F]+:FUE17$NAI
    MK7P3M;Z;FNI@/;8F![Y:K%2?FYMN<Z/BB[Q?8CMK.JOVHWU>O3J/#-,WV?
    M/:SK?.2@\>N<!)7!N<]T#'I'\/;IHOR6Z=JE69X/78?E?#[T*<!(YBX?%'3U
    MP')]P.>:0 H?92>SV:#'-_.#4:E<38B10KJ0`5)#YUX7Y6G'S!Q N(Q>2#3H
    MP44VQPOYG 3@@R3F#)3X0AV#JP,!6BA,.R8/($3V;RD05CRPDP=(`M@JE<H`
    ME%$2!D=4-.8=HQ8>7)S,<_C@>D\0! #*\K`]H[(IQ=DT>_!&IO%MYEROK'
    M$;%C$1!/DD KW*!N3Q $@C7R6QF<]H`E0'4,1P(@IJ 4SWCB'A=X#?DT K
    MY_' 1!X@"4">X\K YW?O]OSKR=%1_P,&5J3:7/K8Z\IQ*E@%BIO8G&O/NT
    MO'.C?)<I: 8#\@!\%EP2:&4_'NC-`R0!#.)O9>#^@\/K5VYI;_;ZE5N&6@X4
    M&0!-O$?\5+Q)RRNL[VTV0HCU]*;CU0).Q9$$6EF(![KR`$D`0WD]9P!&,1P(
    MK4@"_CM-!;D08F_S[ 8]! ,X%'$2:&4B'M"/AQ/^5@;,2;PX0"D`"%IMYD U
    M`)3!@%0`RU)`JV<SST`U% 92 49`#)2SLD!.;V8OT>G&4&H%P`^(!X@"!X
    M6ADPW2-)JCC <"!(2N=-$3W*!;")LH \X@$\1&4@6I0"@(C-Y\O5XA69_GVU
    M7%!,,Q!\+$ ?DL!(Q ,XYVEEP()8BP-D`*B)\NV JO7TYIWYTY%%K?<U`X8B
    M"9A /(!E/E8&Z)2H83@0E/&F"]%Z>G-OLU ;_--Z7S-KGQZ&[K>J2WQ7=-G=
    M[/8_X%2AYXD8 WQ`$:E6QD0L10' 4`R1J3!TKE1P?E@LALS0#-1\JG`I*
    M6\0#:.1C90`RR #0)8)(#"U:RP6"#YG0R&> GN?VIP2@(=DXD'KPP#O@/F
    M^B6M=8 0BP,,!X)&P1W_J-%2'&AR.XX(:L;$@-:F6B,!22 4K6]8"@AHHC(0
    M#Z/`;0RE =C",@L8D4&VSE@=(`J%C?!&:O*L,V.=Y<8 ,`'-\/OA(<81
    M><M$$BA;O,`22!*Q -0&? 7PX%@%$D@)J:`TV,(_*$N1A06\0?"T$22 3Q
    M(#5509<]4Z\*@[PM0H@(PC<L5"$BC\WH5'OW!\D2B0.)!W*@,((,`)O\
    M2;_0Q7YQH(EQ1#992P5):K=D0#Q(1[$Q'%EX/!0?6O._E[M=_HU=-^]9],
    MKT8-PX%@5/-@SO/LS=_XQ-P2+;^#4/(A#Y081V24S23P>Q<>_<KQQ7*YY &T
    M(AZ$ZXQ\$L@R;?>,;&TJSS.%HT376LWGRSS/3&]C59YGQ<]\OMRZX397S%5K
    M?C:EM[5$5FRQ6.EJ*H4]IG<;_Z??_DQ74QI7;#Y?YOG3C]D\S_8VJ[V-^D&R
    MTG> Z6W-VZ/B->.E9];30(CFVKR=HQ8EJ:*KHWU9RYU/-)^U6BQ,KYCS
    MUFZLU[J:$CI6;"*$\&2DD%H8T+B(\E^-K@EGR."6\S<:=,GRO/7W/<6!Y7QN
    M<HUD97DFA"CSP'HZ4VADV7:,96U]"RTM>T6M+-!Z1K^_J5H2Z&\*4)#GV6JS
    MJ?Y&IK;IR4>9O)/9X$^YG97.LQ[]F#/P3)%93<<`.DEPB&YZ"KP:+-2CS #5
    M*L'68-#?4R__54LJ\-/0)-#?<2__M=EL5Q(0#!:"/O/Y,G_^O,;>IEX9\/_3
    M+'1^74TH2I0"D!K3N1J1J0: GF PZ(1]\>#X(L&@)#"HOUX\N&R_)PD<O[ G
    MA/C*DV\?N[[U=_SAH<6S:Y_,QX($5AEP'.5 8\Z3H4G1@M39$!X!M/WF6P
    M()3B0%-K,%A/9VI#=Y;S97QY0)+:F?N'TX>[F]UF$B@"0.'"%^OB-]67)-&]
    M#"N:'V5,3=:+RH!^# >"AT@""$X9#.8C3J_$E ?DRP)CQO#\L1"_T$@"10"H
    M_697/!LLM!0BHS@`6[ARD5Z^5 ;\H5P<H!0`P!_A%@=J:C4!A=L7Q)0'9(Q)
    M`IO-[G3Z\.%I\"@`JU)8.1`GH1#\;PHC(0]#E+,@#\%_1;#,HBR /-T4%J
    MMR]()P^,3P)E.T4>D$P"2>Q<!(5X((_0+NMG2<R`$)!$D"@MLX3 ]LF7)!
    MZ'E 9HR0KB10F$T?KIY?Z/$>VS)]4;#7SEP<^^_L/OKJY=FWW\L1!B]_0/
    M@%%=%U;>IC[M>+5XI?8;0V=/_LLOOACZE/]<<1M5>%$9" M3`@"$HE8<4/T&
    MU6RUV<RF4XT-MI8!!_4TII)H)@`4(T"CRZ\>';S)\WGK@@`");,E8N"JY*
    M2JLR('_%P8C*04@1)0%X.=@H>(V0SV10/G.7SV?VZ$7!_J9N/!_,5CH,F3
    MGUSZMFC/VTX">7OCZ[['VY0*NI!D/W%<&/.LD $0+L_?7,#62#!2<QS1
    MWF:E=L-CM]1N.2RIJRQ0ZDD"9X_^]-7?_WU'W[7W.H!;J40#]J# Q%7PKA
    MXNA%R<_B@$W55%"]?8&[-?)%,PG4/KP8D\2,9>@+_D;HL64D)P7QGP37$"
    MJ>A(Z;H!&0"@2W,*@?(8H:VJ(X5Z[G8<'+4Q0JU)H%H6R(3X1W?_HX]>_?7:
    M8T@"0%5KO[^:$'[F;ST40OSUWQ@L\8WAN#@S\GZG"@<JWDYQ@`7N&X10W%
    M@:;6NQVG8VM-H#@QUOQ]5Q(H9A(SGQ@H5#]O__IO_@MQ&@FJ/(D'5 :X.A!B
    M0Q)(7%>GW<\H/WZ0D-5@T$*4\5DDL"R[>X!_4E V_K%J'4D"?KY7FEK-GU
    M]R0>I#MG((6/>P`)\KG3/XC\0$V]'^.#;E\0(LDDT%0F@9__Z>/J[__LU<OS
    MTWWU9T\NT^MM%<%;$MKUQ(/R?63AR$FQ,C"H%,!((82%PQ6B.P\XSPG%U]O/
    M/?FL4\7-G]>_MF3@FVLMR_H3P)B6Q(00OS%F?/5W_CNY^7!]6/S[U(KQ=0
    M5L:#\GUDX>)%+BL#EGLME (0/9) 4I;S><]-Q/SLD!5KM6H[<UP=)G3'O\,X
    M\=O.]%]=U/[Z`.FP<&W3"L#M4]MA0L$41P`$ WGQ8$(1#.J%0$3I(`X!7M
    M\2#:.0,)GKE!XHBL">HO#G3Q, _49@]G>6;HZJ)Z[T#LSSBBW<VNKCL0+Y^?
    M,_ 'RW\DF :<2 $R/C@;/@+F.BXG!IA0'X#F.3\"M,<194)<//[LN/%[
    M:@* YP;%@W@J`]%\^ * O.5\+H086A_PJCC@]J*B)F@?1_1PG!W8"@5%
    M19="-)=:2P*O__"[Q1]6UZ[96#D`2GKB0?!S!JQE`(H#\!9')A1XD@>ZDH")
    MD4)ZQPC)L%DNT#A22)SF@2!7#AW3@AQ_.2)D+CCFX5`&":X\J EKZ+)]>>
    M`]PB"4"HU@><BZ\FT"/T:<<7SIT[?F'O[.9/FO_$5 $@: ,J`UF6+9=Z/K86
    MB]5\KOC<VLD5C6NUM;5!Q0&;^:J;VM^=F4WM;263'E-WBSJ>CWF,:FEO-Y
    MEF5">N_W%P=6B\7LIK:Z0:TUF1C051Q0VV-=98'58C6[.6O]I\&+D%LQF6G'
    MS:9D1@IU%0?4]MAJLWO\PIX0XL(7:R'$\0M[%[Y8'_^'3R[
    PO5M<JNB(="
    M%$===II)?GY/M;6@HKEL(VCFSMY,Z=ZE]OK->_O[?7_Q3YM]+XS0QF]K#&
    M`NO6I?<\@.P\(K/!Z3/ZX:2DY=IT' =8.%["]1P=:O.<EI`UH&"U6758T$
    M-;/IPW)=NY;#.!D-OB,P\YJ96)-6@4P9\"KX4#,'( _.!0QGO?:>,G#]B?
    MJ!&USBB\9,':JGCPA?KXQ?VBD@@JG@^(4]?X\;`-(<S!F0_.+AZD `8$'<
    M>2"4)%#5-8[HX5SVFD)C\D#K(JIE@3(5O'[N^^'M7 `-WE4&_,\`_G]Q(@4<
    MA$B*6AX(,0G4U(!5U\]%D\^-R%[F<\I98'9,)&&0R6"4W_!F+FT7T&O!H.
    M!/B,) "]@CC'4?3L)2-!!#&@:3Y?SH78W>Q]<FSX#U!(.B9R\9"8;>QT#C
    M94P!N&6[,M#\OO&_% ``T0LB#XA*+0D,Q9H":VF6%M@:#\L&MW7>U>YF1
    M!("8.*L,!)T!0OG61)0X]@"11K^_2S4/5 - &0SZ4\'XI6MI!X G',P98#@0
    MH(PD`',XS1&Z,@-(CB,"`&&S,A!T*:");TT`@"O]]R"3Q<H'=\(P"\8KPR
    M4,T`])Z!,7@'P30J ,B<T]BH;5<0!(`HF2P,A#]<""-6$3!QOLX),M())Y
    MH-!:+A#2P8 D`,1*?V4@LN% ``!XJ^BC#YT</&@<$3$`B)NVRL#6#!#EJ29.
    MH<$.#C/8Q"=;< :5"&KZQQ&1!(#H::@,1#\<"'";AGL(P\$9TP>*#3!8<_
    M?#T7' 9 Y-0K`PP'O"5"0#P@=J0H58/KOR5$$)<$8O>R!V@RL#?"@`-A$U
    MX0IG.@)5#NQ12 6M@X+8R"OW.B-`P.(QH#P)CA0'%_H_"5"4,XK@`HDT\%
    MDA,#JA]'! ,@&MLK`_&5`NB[`X ,0Y^62SY^[3(Q";@U&/#%"H2HLS+ >WL0
    M`@:TXXB"#_APPU:,(P"UE(9T'YU(+Y(@%XUP`(#N.(@! ]JPQ0"AB)\V?0
    MA0,)7N'##0H81P2$XNQD,OG@@V\*WJ(``, `QA$!/M-V!V(`6G *%AZB. `M
    M*!<`'M)P!)27U_\'V)D6(Z?G@[1(87%'I1+@`\064````XP[3C4E;9?&5<
    MNA=#G9E,)I(/S3(-QZC/36EIK3AYIJ6IJHCWF.=-Z6VMOZFAIUW98PY;\[,I
    MO:TUFRH_W[2TIBR@/>9#4WI;,[UB\_FR_,GSK/CQ8<4L-"63!%:+E99V1%!'
    MA0]-Z6WMQGJMJRFA8\42'2/4OV(C5]O;K8;/HCQLHMPH\++"LA3*!5IJ`E74
    M![QR,IL-?<K.:GOPT\7XG($$,;(6``!=HA]'I#T)%&V2!R").0. >Z1'!(3S
    M'7 HONL1F4@"9<OD`<B@,F $7Y:0QZ$"``HBN!Z1N210MD\>P%8&*P-T<0`@
    M2ISO@%<"'4=D.@F42R$/H!5`5/XLH0,#A($BH\X"F4<41VDD"Y+/(`>C!G
    M`'"&OA0`F./M."*;2:!<(GD`74Q5!CSOY=@YI\69,P`1XR,.H?"J7& _"93+
    M)0@%94!P UZ48@`>0#!<5LN<)4$RJ63!]#$G &S9$XX*`'#+_K1CY230
    MVH-7:XT\@"8CE0$Z.@"0"$YY( (6QA$I]-W[>^WEOPYMF3R &BH#QO%-B1J.
    M!P#PEHEQ1$/[ZX,ZZ\6#!RV"/( JY@P`5I$$$!].>2!*NL81&4T"U6>1!Z"&
    MR@``8"SR`.*F/(E0&#YKXFD2!PP``0F?N>D3CN9#\P`@
    MJ P`UI $$#?.>B U>J]'I.LD/7D`0S%GP!*^)@%$CP\Z)&OD]8CT#M<A#V 0
    MS94!O@: 5KPU`" 1U7%$>YM5\>?U=.9NC8 ^9Z@,6%.<,W.]%G" )(!T\$$'
    ME.;SY7HZW[V-JOBI_DP$[-XF1D,><P9````,NL#%3S`.4"^(#*@%6<,TM0
    MRF4!#O@T\;H#/<I:05DNR/.,MPP<TED92G3`[3B38$T,9,8D&>SI:-"Y7J
    M>N,PC1B2N)J0;7Q'`@" &G.WP#ZI3MG@$XY3.,`0\KXC 74ZU]`;#5@#D#
    M6=97;!KTH=_?U" :F]+;6D]3"@-J$]]C#IM2;JWU'>'#BIEN2F]K*:Q8"MNH
    MM[445BR%;=3;FK<KMEJT7#Y(WGR^+'_R/'OEE5U/5JSVYWO[8K=6]U-25T
    MK-A$"&E,A#B&:"N=;:P2'NLCC]2VQQ'`8#$;1VU;_0:H&Z7CM);/!E
    MHW96VM+:5EQ-R VNM@$@!7S6`8#GSDPF$]?K`$2%4Z$``" 4>BH#]'X4<,(L
    M2KP7@!HZX >YJ[R75%(8G``# /(``'B.0. -I0%``! 6#14!N@`>-L
    M64QX(P`]@#NI@8S\,8(<BC,@`````DBCD#CG&V Z4!8"M+@#NN@]D4]9
    M`(-0&0#&(@D`DL@#0!==/7B2`(8:6QF@&S0>WXX``&!\/YXD``54!H!1R,/
    M()S0%6`[\@QO3FASYWZ+HA5LP9\ +?CH$B"0`,1#4NSD`9(`E(VJ#- 3
    M`@``Z*>0!0[]X,>K+8B!N5`5]PJBPXA&% &9]X2(U"_[OHY7=U]/O_5>^:
    M(&YG4YXS4'P;T9^#`HX<`, @R_G2SA"@_G70U12BH5X9H#.D':?`2#3SPD
    MR&U?G"2 5EQ-"!B,) QH01Y @ESUR$D"Z,*<`;_PU>@_DL @'-(`4&._7TX2
    M0 \J`P``9XB2)/-WCE)`/T4*P.<'#6'KT:?<>0#VO&AAS39Z:.3! 5E0%
    M%DD``"1Z9XZ20`RF#,``'",X@"29:Z_3A ))7*`.='3>-[T4,<]@``$TST
    MVDD"D'=V,IDP4@CH1Q(`3.,ND.BAY:Y;/O>/E>]'UM6:KJ:0@@&5@2S3=ICZ
    MV93>UD8V52L.^+-BYEKSLRF]K;%B#IO2VYJ?3>EMS?Z219%4]AC6RC?&LR
    MO>358J6EG:>/=+''9'KP,ILIF01"/RHL-Z6WM1OKM:ZFA(X5FP@AAE8&8CIY
    MT[HMGFR@)ZL!7HB1V(&0Q]&"&HWGRPN<-8=])[/9T*?LK+8'/UW.IIP$/$?1
    MW >\!(!-S<^]Z,>':!?3'M.>!(HV/=DZP!-<30@`X"E=?4$3?4H_Q;3'S*V#
    M#UL'^(/[#'B-RPJY15D`L*_\W-/;8TNA_Q?3'C.]]!2.!T#2L,H`?2.D@Z,=
    M<&47WY[L:N]V;C[?X9&U&AOTY_EQGT\`/)U]'N$```87DE$0512KPSX?K=
    M_S6,$DD`5M
    M:5T?M=9"/QX`9<P9`)XA<0%.,#YDJ)CVF$*;R_FR^%'X5[UK`D1 =LX`G23G
    MF#E@&@<YX$1_#\S<S &9I?LIIA$U0UL;U,M7B 0A'@_ 2&<GDPDCA0``3LCT
    MO5H'"R4[/B2F$3424!A<OY<M""PCH>@/&8,P`(05D`<$%M?(C,OPYM.93^
    M7TQ[S$X2*)]'@"Z,&<@)(P4,H0D8!3'5H-ZIRMI[/YD.Y@E.-#4AY1,[YK
    M3N<>Z"(U9X"N$@! (X5K4*J]+EW.Y2U$36#'F]GCGJQY,'@%94!@+#25;M
    MR+J 99;'APQZO)]Y(.4]IK<'3QX`FK@#,9)&$@`\5^V]J9T-2:W_QX@:`(-L
    MOYH0O27?< ,R`(G0.#[$SU/^VMG98ZO-IOK7+,\5%E%K1 @QFTZ;JZ'0<K]T
    M#@9 $I4!I(M,!?BLM2.H/%0RA;/=%D;4K#:;9B=>%Z.-`^C"G($@,7-@/)(`
    M$"@^`)VPUE,G$@"6;:D,T&$"`-AG:'R(]C;]$=\>,[?TN(\$8"@J`Z&>9 IT
    MM3U!R@6"Q@>@9?9/U5,<`QAS@"20Q(`(D >```M!E0&LDS;QZZ?3>EMS<*
    MJ7T7IK#'4MA&O:VQ8G$TI;<UARO6/XICS(HU6UXM5LJMU3C<^4;W6/4D_?%O
    M?Z;<5%-_:_T7*<KSK/KSRBN[&E?,SZ-";VM-J6W-6]7[,9ZK:LIH6/%JXK
    MFLX)U-J6!K3A`:VJ)]AC3K#;4;7UPH[R0[H5#BV-2[?&[3KO+E[I?\!L>E.A
    MV=5FT?5/O_SD,R'$A7,O-B\V6AKYD1B88!PG<QF0Y^RL]*62?:?I\!^(Q[
    M#@S"O@(`267EN>B:M_J#<R.7U"S_:+9V?3FG?E\?/L`ITE"0```L4)$062
    MXTOO?KM;96!D;0D"@#*.BL#?R&@N]"2>PE($J\KX<*98^M-@LAC%0&N ,Q
    M4,75A) $D@``J.D9N!_E<H'4<)\!````(%%4!F+ ];;[418`PF)N%$>LXT-,
    M[S'[)^F+)9K8KEB/`4!9>V6 SA.BP<$,`&%A@!!@$Y6!2% <``"8,YM.[?31
    M:TO1>R*?L@#0Q)P!Q(RR`! HQH<,96>/&8T$78WKVK2X#P! 6<M]!N@_!8IK
    MC-:P-P# A%J7?:ET:[ LSX<\.!MY2V"2`-"%RD =/<@X\#H"H6-\R%!A[;&A
    MG?LQZS/TN2.#!Q 6Y@Q$A9D#\!-')M0P/F2HL/:8G3Q $@#Z41D0@IY*="@+
    M`-$8WRM-)PD4PMIC"GE ?O4&/5AM?8 (U"L#]*)"1[#A& 8\Q_B0H>+>8PHM
    M%W\KE7M_U>]:P)$X.QD,F&D$ # IN5\.:BOIC9_-(XD4(A[CPW=NI&(H;/
    MKSY@%',&(I1R<8"R`! *QH<,%?<><[O__7_U`7.>JPS0D4+0.("!L"B<#RX?
    MW]I[4SY/'$I?,.X]IEP?&+]<^PL%_-%RGP%$@'L.``@"XT.&BGN/V<\#8;WZ
    M@ E<30B1(/P`@6)\R%!Q[S&;6Q?BJP]HQYP!Q( D``3-59\LW+Y@W'LLIJ4`
    M_GM6&: [%9F4IQ$#"([]GEGH?<&X]UA,]0? <\P90/#(L4 <;(X7CZ,O&/<>
    M,[=U<;SZ",CKBQ_U/^"CFR_;69-6S!F(60K%`9(`$!/&APP5]QXS=,TB[6T"
    M3;N;W?)GZX-?7_RH_+&P;C5/*P/TJ ``/C!]MCNOF#<>TSOUGGZFO94L^W
    M,04RO?_"?_WW__H_^5]_IO;+(@]\7_-]1E0&<@R;>]&/YO2VYHG]8L#GBR
    M8EJ:Z@JQ,6VCG=98L3B:TMN:PQ7K[\VL%BOEU6BV[.<>&]J4M3WFYB0Z=W
    M;*-\+]G)2RF3!&0V4S)1'GDZVW-_HI)U@'[#=_HJLIR17K-Z$R4"CW0'R[
    M(KXML2Z7;'B]<)0VL]V1W_&E#T6+EZ[T/5WW/?6?]GZ^];0&&]][7RSP^G
    M#\>LVU9G)I,)7])Q2V'F`(#XZ.W-I- W8H\%RL0H+R?W<D[6UE/XU9Z]C-KC
    MY<<=J>$`P@2"19(@:[:#K]6O98<,SUVLD#=ICNJ5M8RD0(\<$'WZ1?)4[[
    ME['V,F/:KIBV)1V\:@!08Z&_3JXS9V@'O398J&N,4'\9P<20(2H#````MMDY
    M<T]]P!!#IJW#B@RL=PSD\F$TW4IB&;F`">8`0"AL]E')P]HI]8C7]]K;^O
    M+SFU0'L>H#* D) $``"AL]\[)P_XHS42;,T)1G$'XH1$4QP``"!0KOKE_W][
    M=PPCR5$%8+CFM $V"8'A3BL0DO%&E@@.KQ.$G#FY.UU5/=0#4OPNS#\Z?=3^[[T7OOCN_[[UW@M?O/?"%QYE
    M@.SB`"L#* ;+`@" HN7-RD'PGEDX3;[#WF 5$^&GQ6*^J!Y2CW=DF%=AN-
    M<L<>`(CPSL6/WA'(K[7U=LW]A;S-S;]GI?CVP;.>XOKANLC-A4ZH! ```*+R
    MR-W'L_;F7>V3#V0@'>.[E$2A./,``K %64`0GFYNN[S<X]7Y_U8_P,Q)
    MT,.OUKNW(%(V<&9@<8H[1DPE```HET<EX/$LU -..;QA\/UTZF#!$(]FL;
    M````0!1I*@&_[Z4><.=X`5XV@W=L+7QQ@)6!)2IH<8!E`0# 0H1OY><P0$8Q
    MKN6G61]@90!Z40D``!9"HG'A"7#BOA\ >LCP4/H7!Z@$```+(9O!4P^D
    M%\2?H+%`3YG`("8\1VH9X>]2PFZJ&E,9,_NHB(&`)"UN$I@9.H].P_.#VW
    M_Q]OI)JI=[M=;R7:$0^(YF4!LK<ADY%Q>7-95<:G3_#TWD(B!A3'Y6T>Z?V;
    M\:DK,[D)Q/B_>3=A!TH7%MM5HMYSBYU"NM)F[PUZD'=F 5%\)"+:CAPK
    MJB\^?40,`/33?V# "NGGY9F!)4PDDZ_1+@M(M:;?>KN>]9(G6Q-I1S.RMR$Q
    M7DM-\>DC8@!0AP3+`G[/XNZKNPG5/9$P]7:H#8C:90&U$<LNWJNH(SY]1 Q
    M(]Y&';8`P=&5NPG5.I$P]7:TNRVX.&""`[*H2B!VRVG$[G_I\>DC8@``5;J?
    M,U#?1,4VT% YB)B0]TO-SX]!$Q`( V1SYG8&@B6:_%)IAD3<V=%/_T\<
    M?3CV+(*O4;"U]7:]?]!=!PA9'.BW9GQSD9LWKTLM"T@.L&,1\S;4E%_$\KXE
    M1_HL'C&Q<]LJ(R88+B,:,9V_Q&2;DFU-9U.RK=&QN63?X#H[IC;XLAU[_(I/
    MBGC4*W)-&8F.K8PQM]ZYU?^'"K::>4R'-B=VO/MAA_Z(3=Y65?;I9@5$YP:A
    MQ%=8]0^AAE]D`H=90?'IRWUONB(`768?.]'?9_F??8Z1+VGIY>#'X"<>D+
    MS>G[KSQBX]V3/3G@\HSZ,82&Y.IG?'I(V(``+6Z9P;:RIU(F'H[E =$X;
    M\HAEE>'^N/31\0``)JMBXNQF>+XI:00B:_D&U"#6T1<PQ(C)U"UGA J 3Z
    MM VAAG=D["OJ_P#6RN"[&M<0L2 RO )Q5;PC:AP3,#;06-E?!DQ1C3Y"L5
    M3+VS7D*['DB6BV@K!LC>AGB\ELZK&/I9A[>L4[S756O$@/I0#)3.Y9-]$]0#
    M4;LQO3)@%3%<1)(5TRH&!%O.8FZWSP[[M^XXC22I@%10"2PD>YO;?X\?M\A3
    MZ)'@Y506,:!*% ,5T+ X$4/8V<&VK)OG)CD,2ZOP=F/=BO/(\`O6G4=;
    MM\2"4CIE4#U0ZB1)NDL-SY]1 R .S[AOG0NETUMS]X-Z$^S0.+J3?PJ:L/
    MR"0B)M6'D=>XV>S&J\T2X].7\H)]'1$#`&3DNC)@Z9Q(F'H#G[3]HB;3M9'O
    M=='T3=6R`$-(2OB*\]+6K(N(V'J['?HO]E,#"R'[J[ZLB:,.\2[>QUX6,,:<M.)X9J(;(U%M3Q+($1%4E,!=#:(A45EIK?/HT1"PPH;??OMML0AH!8(Q9;]GCQ)DY"$"#RU<6ZU6R[D4)SCUBK23W=$7,G=Q8B=C&$ALB^
    MHOKBTYW(_Z\%_8&9<P$/(]W;T'D(PY.5JN5^]U%L1QV<4#V
    M*G[[$XX!1)5^3:!CO=URL!AH>!ST;QY?_2?<U\=F\QZ9>I:3RB=4`DB#2J!6
    M\>:56F\KM)R(<:\AH,W['2KXOJ82"#'WMDS2@/,D#JDX^OG!FH=8A$G7HC
    MM1R58[>YK5"#(82R9%\6:&/7$-#(SN?&2><W\7\41_\@%2/1G"R@!28%D`
    M6#AV#0%6KA4\*@$I?A\[(+O_1[ 2,)P9P#B1DP-4`H"WN:MS9X>],>:;GW\^
    M](!_A_;('[N&`"M]/4 E@!&KBXN]F2S/S'O%<7U:7M
    *(T9 YA
    O\ZSR
    M:7)R/M+/&_WE ?G T1&]DF='YZ)]ZSNZ,D`)5`PI_3U8@XV<2RRXF/[*
    MP.15J+?T#2G9/L^]$*XP8E)=LNW,71;H/'M_6:#Z(61\0P<L![N&@#3K`U0"
    MD?AM%A)Y7O$V.3. XT3N%35&>CV#4$Q*X'J 2BLGEY
    MLI(@1AE@\0G$Z-INU^*?,+!,F\W.'KJ(]''.2L2;R53=)5,0$6OC1D-8..Y6
    M5[IX.7JR9[G67ADH<2)QP=3;,=)M6P9X5P+MEFM:%@CY08^7!(4.(>AW?GJ:
    MNPNNN/<H%HY/N"]=['H@=OO75JN5XV7+_8.)0Y;NUFNQ!$BP*=G6!,-EDG3,
    M;T%@J&,>E8#:42'RH[0EP<V;UP57"=1&; GO(YU-F:L1"ZP']@\>!'=G1FON
    M)8':X:JS*=G6Z%BDIAQS=\=?B2ZM$7S9UAZ=/G)/V1^_\MCQD2[-AK_,R]/#
    M-D%Q^36LL-9TN;;JWNU9";'L4TOQZ)74OB#[U..50/5#:%[('.(=3FN'8A
    MWLE<SQM.6\0ZAP?\[B;4WMD?RHIPBP6")KQ0I_*RZ-R"F"-+N/K,N["6TV
    MN_5V??;E#1:KV=W16&_7N9(5G9J "!YR+3H@DP2'4'.\>'_8FK>:]#&K@,
    MG">>FWS;Q\<K"3A8C,4BCZ]#X,'BE&6 =>5N0DT-8*N"^DH"M$6ZUTU-1P6B
    ML@<)J@F7;+U==V%I)8Y8LV5(*LG>;391EP@H"0`4K9W33Q8&Z0N MLN["74F
    MD@].SS\X/3\[[,^F/HRI(++I1>G)RMEAOQ6M!%PV")4NQA"JZ8TF%9_2WUSN
    M2H_8;K.)G:QSL!A !>S6_Y'_\G;OVL7%Q=!$TBX)2%9BM).%_6G:E)V S!4C
    M8C75WN'Q6<Y8LBJ(6()Z@)(``.*9_IP!FZF0K BVD)$M`]H7[P4#4O>R0"/2
    M$%[IN[E24D/G._5?V@5&C"4"`"C7:F1EH&^WV>G\4%7!&7'\OCI*IMY)
    M_7Z.GP/Q[N?<2D!G]F82_F1=GJC]PU(2L03Q*>7-Y6BQ$>->0P!0EI4QYM8[
    MMUP>VIY(FGNEZZD*I.;%D6) Y]0[9.[G?P7F(I&>(B5MV=O987]^>E[N6\PX
    MARA>RWDM-F()KN)3$@" %->5@9'4V:@I"40FR/%@/I=TASNUCWW3M^N4@%
    ME8"E,'LK_2UF'8V2;&LZ3EB!$`0!&<5@8F)Q(]^4KX9-DN!LJ:>ONVV[7W
    M;.R>BU13"5@ZL[<*WF)2"AI+UL(C1DD``,I-KPS,^NQ>HR!?"9QZPT_!:DA6
    MYG[&;8C)B&D(R"QJLS>I#XH.E#$Q8TE:$1HQX``,TF5@8\)A(-QPE"IM[
    M8D##U-M/&>/E(O55`I;:[V.DMM/H6/)(F4! "@T]C*0.!$DC=KF3OUOO[F
    M8/7_
    7
    ^]@W[YS=>?6Y6(]FGWI&8Q\A%:JT$K%D1:\9/WZQ1Y!@Q#25!
    MXNRVZ%D$3$.%@. 0H,K`U(32<:LQ7'JM6F<S=A>?_/][<L738;_J=)V:?>
    MR3TDXKG(>#&0/2#A7"6&3_]T=4"9,#:6[$LI<$R;+;"L:21<0,2P0`H,SQ
    ME0'QB237WJ'QJ;>3Z]M,KI_@NI0$>:=>]Z10,!>IOA*P1B)V=/P<?=@;KSXW
    M]\-[XB5M03GH9JQ9!$QBY(``)0XLC(0=2))G[@,3;V=YSY:R?';;X^DLQE
    MKP1FQ5,D%UE()6"Y#'Q2F#\,48B8OJ7X/Q4-I8L(F:Q:P@`-.BN#292!(G
    MIVIMWEWV9I__WD$V/,LY]]/<GGS'&/''CQE#!T)9QZO4.8W@N,E(,%)2
    MN.M'[&B6;X=0X]?O_*LS8&(/H5PE0:3LMLJQ9!&Q!DL$`)#7E96!Q!-)RL2E
    M/?7V4_Q?_>3;S5;8N#V_X[/O/7'CQM WFMR50$CH(MUPJ<1<Q-'0$&I7
    MDFUV_!ACVD/(]$91C(AE0G$L]NQY)%Q!HL$0! 1E^M#.2:2)(=)[ OLY.*
    MO7;_+S9C:]ABH,GDK":?:W][WHB%A\LO%UEF)6 U$6MO'FM7DHWQ\=-\>^PM
    M>>76`]6/)8N(M;%$``!97*X,:)A($ES.7&_7G6NZ_4SNV<\^W/QQU:D0;#+7
    MSN2R1$P\1!ZYR% QH&$()= >0I-K`FWM76?)AI">(SJS+&0L642L@Y(``!);
    M75Q<Y.[#%7'3E]NWUR]?OMZA:[J__=W??OF+\__VLW_$HAT
    MH7=6KP2L#:_!&4Q,Z5@+VZ_?N_M#.?$0RGX'4F 6=@T!0$HK8XRV>L#$
    MVSMT]WF#_]\#S[T_=O[]]^>%IU_K?_V)_?Y(.TDH2>;2;SO1R/[H
    MOQP`G2'TU/W[G]Z]V_\F^_7OO/12MYV$E(PBP!%+! "0QHG"2L"T4I8H&<QP
    M)?#IW;OFHWO'O_[PX95DA52<'6\*@'[^"Q#R*CB)(`I;#)>KR2P+9,20``
    M)ZN5NIU";9(9S-5KNAV3F5QZJO(V:IO%#)^CJ(D0%EVFTW4)0)`@!070ET
    MA.X=NGV[_;?;F_KT
    ?.K)9X[TY5[1$;>XZ$J5;5F<Q:Q62S,N!>"5RN
    M#-BAF':;4!\E`0K"KB$`B&3&F8'U>KW;R>0-@4VUDQCOIOK;A(PQ/[UW[P^O
    M=0\,-&;M\?#NV-$46_P1XH!/:,B4E/=UEHEY5 ].>''W^\>_[YR[\$%P,B
    M]..M^W6Q(J8FJ9D6]/9E&QKVCK6U /[!P_.[]R1Z%2WM<"2H.@QVA*MC4Z
    M5D=3LJW1,4<EK0QT!%[7/%H,C$NPX5OA-7B%75)"YQ#RPT\9I6")``!D*;V;
    MD#OODD!;)J=SSP8YX@AM0RB0SA$('$5)``!2E-Y-R%W[0*0I-I4AYT9VG"U&
    M03A8# !2BE\9Z'!/991<UM6<>U&BC%,RA&+0/"R!-I8(`"!0P6<&1KBD,AHR
    M.<W9MN:^:%A"$5%28!24!(`@+?:5@;:QO<.Y<WDE=95 (NJB\&+.5C%;"H
    M!P# 3_%G!D;$_1CC`3: AG"5 $/K$8`/S4O#0T<EFLES62*CHE9QM)"5
    M@;8B!C 6O82@:$D`%"7.L\,C&CV#OWHR9_/_=Z03*Z4(I*P-T"BP&00]
    MV#4$`(Y.5JMEU0$O/V;YXSQKSX].#G#0LB>4)IM=*<4M%HM=0P#@:%F5
    M0)N]K/OGC^X9YY+ X[)N63D31<LLBUT9:)0UO%,[!H"@'$.C/0T<[D'$N"
    MN9E<6;EU6;W5@&+ HB2 ?NP:`H A-=]-R)TM`VQ)8"3V#I$>83FXW1#TXQ.+
    M`6 (P-'#"T4.%[6+?$2>XE]SHZ5@3Y`BC'$@$`="S]S,"(?DDPF<D5F@E1
    E"?BA&!A2Z!L!RT%)``"-_P-F=8I>KI_@0 ````!)14Y$KD)@@@``
    end
    Tilmann
