PLZ help me to use teardrop, i tried to do but failed.
Messenger: "No teardrops generated with current parameters"
Thanhks.
Thanhks.
You must not be having any vias on your board. So, if you have checked the vias option in the ULP GUI window which pops up upon running the ULP, then it gives the message you're getting it.
I ran the ULP on a 4 layer board and it worked fine.
Try checking the "pads option", you might get the desired results.
Jaya
"Jonquil.VN" <truongvt44@gmail.com> wrote in message
news:i0hcqj$t7e$1@cheetah.cadsoft.de...
Thanhks.
One possibility, I found if you are using fairly thick traces compared to
the size of your pads, no teardrops are generated.
Try experimenting with a thin trace.
