EAGLE User Support (English) Special Clearance Around Hole
  • Replies 9 replies
  • Subscribers 178 subscribers
  • Views 617 views
Former Member over 15 years ago
Got an issue I haven't been able to resolve.  I've got an internal layer
that is carrying AC mains voltage (120VAC here).  I have pin through
hole parts that have pins that do not connect to this layer.  I need
to have 35mils (0.035") of clearance between the plated hole and the
interior layer carrying this AC mains voltage, but this amount of
clearance is undesirable on other plated holes on the board.  How do I
treat the plated holes on these parts which pierce this high voltage
plane differently that my default holes?
Michael
    that is carrying AC mains voltage (120VAC here). I have pin through hole
    parts that have pins that do not connect to this layer. I need to have
    35mils (0.035") of clearance between the plated hole and the interior
    layer carrying this AC mains voltage, but this amount of clearance is
    undesirable on other plated holes on the board. How do I treat the
    plated holes on these parts which pierce this high voltage plane
    Michael
    first of all, it's very strange to have a 120VAC plane but I guess you
    have a good reason to do it.
    if your plane is really a polygon, you can just draw it around the area
    to avoid or place copper of a diferent name around the area to force it
    to isolate. In v4, I don't know of a restrict layer for internal
    polygons, but maybe v5 has such. you may also be able to define the
    "penetrating" pins net names with a higher clearance value to keep the
    polygon off of them in the class list, this might even work if it's a
    true $plane.
    Former Member over 15 years ago in reply to Former Member
    That's also my first thought - I'd really try to avoid this.
    Both versions don't have restriction layers for inner layers.
    true $plane.
    Using different classes and their distance matrix surely seems to be the
    best way.
    Tilmann
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:i0nchl$6nj$1@cheetah.cadsoft.de...
    >> true $plane.
    best way.
    I would do the dirty way: draw a circle with 0 width  around that pin, on
    the inner layer.
    >> Thanks,
    >> Michael
    true $plane.
    In fact, it is not a plane it is a polygon.  I've got a portion of the
    board (4 layer) that is free of internal planes and I have U.L. spacing
    requirements that basically force some 120VAC tracks to the internal
    layers (can't meet creepage requirements on the outer layers).  However,
    due to relatively high current requirements I need as much
    cross-sectional copper area as possible, so I really don't want to hand
    draw the polygon around these holes as I probably won't do as good a job
    as the auto-clearance.  So, adjusting the clearance would be ideal.
    I'll look at the constraint matrix.
    As an aside, it would be nice to just have the ability to click on a
    part and set a manual clearance that would override the default.
    Michael
    >> best way.
    the inner layer.
    That's really dirty: it produces invalid gerber output.
    Tilmann
    It'll surely do what you need.
    For the whole part? I think using classes and their distances is much
    more versatile (provided the 8 possible classes are enough for your design).
    Tilmann
    news:i0npcs$n43$1@cheetah.cadsoft.de...
    >>> best way.
    >> the inner layer.
    Tilmann
    Yes, I've forgot that a circle with 0 width mean a filled circle in Eagle.
    So do-it with minimum allowable width (0.1 . 0.2mm)
    And remember: best solutions come from lazy people.
    >>> the inner layer.
    Not always (though this is a nice statement image ).
    Particular in cases like this, I would strongly recommend to do it the
    "correct" way.
    (I am lazy enough to have thought about this method, too - but then
    refused to provide that as hint for the OP... image )
    Using classes and their clearances also is much less work, as soon as
    more than one alien pad/via is concerned.
    Tilmann
    news:i0nvnr$f0g$1@cheetah.cadsoft.de...
    but you must first learn to use this feature (netclasses), and this take
    time.... for 1 pad I will not learn anything. all that matters is a working
    PCB
