EAGLE User Support (English) So close: Need help with Stop Mask errors !
  • Subscribers 178 subscribers
  • Views 1119 views
Former Member over 15 years ago
Hello gang,
Thanks in advance for your excellent help!
I am soooo close to submitting my first PCB to BatchPCB, and am in a hurry
to get them back & built...
Following a tutorial on how to make my Gerber files, I found a DRU file for
SparkFun/BatchPCB which I loaded. Now I have fixed all my errors except the
78 that remain - Stop Mask errors.
They're on layers 29 & 30, so I turned the rest (except 20) off and
captured an image.
Look here:
http://www.logicunlimited.com/EaglePCB/v3_7-StopMaskErrors(78).jpg
I see the marked areas, but I don't know if there is a reason to be
concerned, or if I can simply ignore them all...
Can anybody please advise?
Do you need a better image (more layers showing, etc) in order to help??
Thanks, and happy Independence Day!
Sincerely,
Jack
    "Jack Edin" <eagle@logicunlimited.com> wrote in message
    news:i0osui$m55$1@cheetah.cadsoft.de...
    Hello gang,
    for
    the
    captured an image.
    Look here:
    Sincerely,
    Jack
    When I get these errors it is usually the silkscreen overlapping the stop
    mask. If this is the case, I usually ignore them.
    Isn't  Independence Day a old movie about aliens?
    regards
    Former Member over 15 years ago in reply to Former Member
    Correct!
    Actually the silkscreen >Names & >Values caused this, and they were near
    by, not overlapping.
    I fixed them all, except 9...
    These are effected by the item's own footprint!
    The device is a 2-row header, at 90-degrees.
    Part Package is: 2X03/90.
    The Device is:   PINHD-2X3/90 (PINHD-2x3).
    The Library is:  PINHEAD.
    The trouble is on Layers tDOCU (3 of 'em) & tPLACE (6 of 'em).
    I believe I can ignore all except the tDOCU 3 as they actually cover the
    pads!
    I had a similar issue with my vertically mounted Diodes. To fix them I
    edited the offending portion manually into a separate library, deleted them
    from the schematic, then added 'em back in. This turned out to cause alot
    of pain because the wires were deleted off the board in the process. I not
    only had to reposition the footprints, but redraw the routes too!!
    No way I want this to happen again!
    Can I hope/assume that when I make my Gerbers the tDOCU layer can be
    ignored??
    Thanks, again...
    Jack
    news:i0qahr$368$1@cheetah.cadsoft.de...
    Correct!
    pads!
    them
    ignored??
    Thanks, again...
    Jack
    Yes, you would not normally include tDOCU in your gerbers.
    Also, the size of the stop masks vary depending on setting in your DRC, so
    if you change DRC you may get your errors back. I would turn tDOCU off
    before you do a DRC.
    New issue!
    I just uploaded my Gerber files to BatchPCB, and that right angle HD Header is causing a new problem, and expense...
    Because the part is shown hanging off the board, they are counting the silk screen layer's image of the header's pins as part of the board. And charging for them!
    So the board which is really 1" x 3" and should cost $7.50 (3 sq in times $2.50/sq in) is now $8.11 because it is 3.24 sq in.
    What a be-atch!!
    The header must protrude it's male pins to connect externallly for programming.
    I just thought that as they are outside the board's outline, they would not be counted and that BatchPCB would chop 'em off!
    Hmmm....
    The outline was included in the Top Copper layer. I have the option of making a seperate outline layer. Anybody think it would help?
    Help!
    Thanks.
    Sincerely,
    Jack
    Jack Edin:
    Never heard of anythig similar.
    Uh?
    On 7/4/2010 11:33 PM, Jack Edin wrote:
    New issue!
    What a be-atch!!
    Hmmm....
    Help!
    Thanks.
    Sincerely,
    Jack
    Hi Jack,
    What you should do is find out what layer the drawing of the header is
    on. If it's on one of the gerber layers then change it so that the
    drawing of the header isn't outputted with the Gebers.
    That way the batchPCB bot won't even see the header, just the pads at
    which point your board outline will dominate and you will be charged the
    appropriate amount of $7.50.
    hth,
    Jorge Garcia
    Cadsoft Computer
