EAGLE User Support (English) DRD file info dispalyed incorrectly in Gerber viewers
  • Subscribers 179 subscribers
  • Views 1146 views
Former Member over 15 years ago
I am using Eagle Pro 5.9 (I'm upgrading after I get this next board out).  I
have done three other boards and not had this problem.
When viewing the CAM Processor outputs for my current board on GCPrevue
18.2.2, all the Gerber files look fine, but when I import in the DRD file,
the displayed positions of the drill holes are around  (but not exactly) 10
times the correct places.  I see a little set of displayed Gerbers in the
lower left corner and a big screen of drill holes.
I have reread the manual, checked this support mail site, redone several
things with the design files including starting over several times, and
double checked my CAM processor files.
As I said, I have done three other boards and have had no problems
displaying/verifying the CAM output files on GCPrevue.
Just in case, I tried another Gerber viewer that ran online, submitted the
Gerber and DRD files, and got the same results.
Finally, I looked at the DRD file, and the drill positions are correct with
respect to the placement on the board.  They should not be displayed with a
scale.  And I cannot find a scale factor anywhere.
I am a firm believer in cockpit error.  But this has got me perplexed as I
cannot see anything I have setup incorrectly.
Since the dimensions in the DRD file appears to agree with the hole
positions in the Gerbers, I am probably ok to send this out, but I don't see
why 2 different Geber viewer have a problem with displaying the DRD output
from this board but not the other 3 boards.
any ideas?
Thanks, Dave
    There are a couple of settings in GCprevue that can affect this.
    When loading or reloading the drill file there is a dialog box with a
    "Format" button.
    Verify that the inches/metric setting is correct and that the precision is
    set correct.
    "David Bailey" <baileymon@charter.net> wrote in message
    news:i1e91f$vbu$1@cheetah.cadsoft.de...
    >I have done three other boards and not had this problem.
    10 times the correct places.  I see a little set of displayed Gerbers in
    the lower left corner and a big screen of drill holes.
    with respect to the placement on the board.  They should not be displayed
    with a scale.  And I cannot find a scale factor anywhere.
    see why 2 different Geber viewer have a problem with displaying the DRD
    output from this board but not the other 3 boards.
    any ideas?
    Thanks, Dave
    out).  I have done three other boards and not had this problem.
    file, the displayed positions of the drill holes are around (but not
    exactly) 10 times the correct places. I see a little set of displayed
    Gerbers in the lower left corner and a big screen of drill holes.
    the Gerber and DRD files, and got the same results.
    I cannot see anything I have setup incorrectly.
    any ideas?
    Thanks, Dave
    Hi David,
    I've had this issue too. Here's what's going on EAGLE outputs the
    excellon DRD file in 2.4 leading zeros suppressed absolute:inches
    format. GC-Prevue tries to automatically determine the format your drill
    file is in, however it doesn't always make the right determination. When
    it messes up it usually selects 2.3 which is off by a decimal place
    which explains why your holes are off by a factor of 10.
    When you import your files, check the format and make sure it's 2.4
    leading zeros suppressed absolute: inches.
    hth,
    Jorge Garcia
    Cadsoft Computer, Inc.
    Former Member over 15 years ago in reply to Former Member
    Thanks to both Doug and Jorge
    I guess since the first 3 boards had no problems being brougt into a Gerber
    viewer, it made it hard to see problem,
    So I had a problem missing the obvious of the precision being bought in
    wrong as 3 instead of 4.  Changed it when re-importing the DRD file and all
    is well again.
    As I said, I believe in cockpit error first and foremost.
    Thanks again.  Dave
    "Doug" <doug@midnitesolar.com> wrote in message
    news:i1f8bi$v3e$1@cheetah.cadsoft.de...
    "Format" button.
    set correct.
    >> any ideas?
    >> Thanks, Dave
