    • Avnet Boards Community
EAGLE User Support (English) Can a generic symbol (sup) be created?
  • Replies 14 replies
  • Subscribers 174 subscribers
  • Views 2023 views
alank2
alank2 over 15 years ago
I noticed in the supply libraries that there is a symbol for each type, 5v, 3.3v, etc.  It looks like the SUP type is what makes this work.  I tried to create a symbol with this type with the idea that I could use it for many nets.  For example, add it.  Use the name to assign a name.  Then add another.  Assign the same name.  Items with the same name would be linked.  I have discovered that that links them is the PIN name in the symbol itself, which there is no way to change when adding to a schematic.  Must you create a seperate symbol for each symbol type?
Alan
  • alank2
    alank2 over 15 years ago in reply to alank2
    Nevermind, I found it does let me edit the font and size, not sure why I missed that before.
    Alan
    Former Member over 15 years ago in reply to alank2
    Am 08.09.2010 02:20, schrieb alank2:
    While the xrefs do work, I think they look terrible on the schematic.  It may seem like a
    > lot of work, but I'm just going to create a library item for each
    type that I want.  It is
    > the difference between this:
    http://home.earthlink.net/~alank2/avr/nettype.gif
    PD6 is an xref
    and
    PD5 is a library component using the SUP type named PD5.
    Is there a way to adjust the xref size?  If I could make it smaller I'd probably just use xref's.
    Alan
    CHANGE Size ...
    Alfred Zaffran
    ___________________________________________________
                                 Web:   <www.cadsoft.de>
    Geschäftsführer: Dipl.-Ing. Klaus Schmidinger,
    Dipl.-Ing. (FH) Rudolf Hofer, Bodo Badnowitz
    Former Member over 15 years ago in reply to Former Member
    >> Thanks,
    >> Alan
    CHANGE Size ...
    The problem with this is you have to change the size to like 0.05" if you
    want the xrefs lined up on a 0.1" grid. I find that 0.05" is way to small to
    read for my fried vision...
    I want just a simple arrow style XREF's similar to Orcad with  the ->> or
    <<- types. This flag business and the surrounding border is ugly and makes
    the net names hard to read, especially if they have a net name with an
    overstrike (eg !RESET!). My only recourse at this point is to create the
    port visual elements as a lib part and then place the xref with the %f
    option disabled.
    You'll also notice the XREF on the left hand side of the connector the xref
    name text is goofy because the row/col info follows the net names rather
    than preceeds. XREF's need to take into consideration the orientation and
    either preceed or append the row/col etc data with the net name. For
    example, the net name D_SDA should appear as "[5.C5] D_SDA" rather than
    "D_SDA ".
    Bob
    MB5!.1PT&@H````-24A$4@```68```#!" (```!SHVC````"7!(67,``"XD
    M```N) $JX9D)````!&=!34$``+&.?/M1DP```"!C2%)-``!Z)0``@(,``/G_
    M``" Z0``=3 ``.I@```ZF ``%V27\5&``!--TE$051XVMR2RZN!413%[>M
    MI)2!&66@D($H1>0M)OY4!IC)JSPB0R&%@8$\8B3O7YTZJ7NGMV[W#$[?_LY>
    MZZRUSU)>K]?7_UK/Y[-:K9[/9V&-7:52A<-AN]TN&FZWVW<4/6JU6I:SV6PT
    M&A61:/1*&GY;+/YW,ZG;)M,IDL%HM\/@^\4JF<3B<Y3]A"H9##X1#E=KMM
    MM5J7RT51%'IL-ELL%M-JM7]_GJ@ME4J12,1BL3P>#WP=#H=ZO1X,!C]'P>*4
    M@> T'H]3XI2]T^GL]_MT.JW7ZP$V&@V_W_\);+?;_"\4"AJ-9CJ=KM?K5"IU
    MO5[%1<UFTVPV)Q()9K79;(;#82:3,1@,`@N;U6KU>KV?0#'\?K]_/!YSN1RT
    M6$#&;K<36$%K,IF2R>2/3\ I9GEK8K!<A$O:0>#`7:@%<!>KX>J;#8+=>A
    M1Z?346+V?K^3C=5JA2HF0S_?A"0:C2)8WD6H""<N1#9HF\_G`D50R96XB&C5
    M:C6/Q-VN[$S'H_1%@@$7"X7I]UN%QGD4,;U]]9;`.[*6 5"& ;#Q&D@Z H
    MZ":(DYN3OH&@@[ZHH*\C.O@"@KC?AX$@/6X\."Y#H;5_FJ;)I_7X.R/+O)FQ
    MJ)5!YT_3=)XGV_0K!4%]%$6A*VF:)DE"M=W=MFU[QPK&@V59)JXXU.#O71Z&
    M(0#2#0:A?MP(E4ZP+I.[D"[*VD &V\@SH\ "HV<@2-,TR)D&04!O;-NF0N%%
    M7=?B63H$.2TG!W5=QWL=Q^%Y7AS'ON_#`FC+UWF>]WV'9>]"K*HJ2,>?`R%R
    MV[;AA>,X$D;?]^,XTH?$8UQV619"0O[)[3 ,(H0FW(6J$(2QPA/3R<""_=P(
    M>/S,H%O%$6$S0]#S]4R4 ZJ2@^51.67R11>NZZ[KJL@HRQT@)3H(;Z^9*]
    M!."VWG$8"&$HBA99!%M@!^R_@)(UY2B6+!3F4T0I$G<(6Z.Q>??Y#Y&Q`F(/
    MXZU8D0Z[#'4LH;=U:F[ C(M(O;V_?C<<K;M/X))$'\08@R#Y9!Q9-&?&
    MBTPX;)K(85$L@O!A\YIS\O^SKBK)0GO*Z@>A7N:Q5X&%18;#7SPA5S%W:,"C
    M5:F']WN/_J!ES2/XQN&,&G?/86NN]6S=BQ?M>/ 5@OVQ.``9A,#J!$V0
    M]XRN&,(0=Q QB#0BD6@AYZ*?4DXD\PO)]WT2&TWA#3E_MF585F[[ZK?6
    M) I):3!.=)[1Z4[O'B>Q8;8/6!12J'D8AV8J8VU%HI&&,,/&,(89J LZ"B
    M``(_F'L\6P% &1%!8IA9C'%]H:KFG"$L?@KTP"S\T81+5!@2YNV\'P*(:33I
    MCP(R`##+D=1H`G9/@)UM8(,"6"?#JW>@"02;*F_>O 'V(M&Z>-^_?P?V.&1D
    M9$AU]K=OWX"9%ICQ@ Q@B8/<\H>T>H 6:6IJXC$!V"5!<P\90%]?']A_N7GS
    M)O%:@-T08),*.?0(EM$T`@`!N#%[% 9"( K7'L/&QMH3"![;WLX+B"!VGL N
    M'PR(F"PDV29DMT5?V?FO3=_R#) `!YCSKFZ^4QYO"/*P=MK8D:Q^1Y:.!&
    M\$"0`5@#)=9X,CUJUEK7U!T2J:Y>6B4B,\YOE]X^Q*4%7HHZP\=Z_6$(
    M[QAC"('V[O',PVT<@V$B.6>I%_(%4@`:HRSV[,-.&-![_Y0P0BL$V\D.@/:J
    M8F)C#&8F'>]L.]'NN1*GIL`OG.9' >VE526C_KWRO#9YQSJUMK+:5\0?UN
    MVD,`[NS@!$(8B (H>$T!20KP: UIV:-@`=YC0_L@(!(7U]/"[DV4S(SF__E_
    MXAV#*#D6@E1VWN$=\T#F_$3H]:!GS@N2!0TL0$4,9QM+;6&D)(*1W:Z XK
    MR,JVIXC4;+:=HV/@)6FG2("B/,#]K9;12=DT34<W;#[YO8D=!I]T75?O>W7[
    M.6?C-]Y>9Q,I]GVWO)3";Y\I@>TZ>(QQ6181'LXF79&FFWF>S\>?V[;9Y?L_
    M#B#!XU""&XIU/3FOA[-`CPD?7@_B0L'_>%\[*7`-R9L0J#,!"&%U_!V<$7
    M$!=Q$6>1OJCBPXB. @A4QXB;R"$0C]Z$(5MDN'UBEH3"Z7N_^__/E#R!"W
    M$E5557GOV1((9)[G81B44J_U9*(ASW/RWUJKM:8_&,%NR4Y 05#3-$T0)K-L
    MVR8W<%<!#OJNI:[L7W?"7KR)!;>^ 7:I/_/2:&4\9?4GIATS3BV-OCB24Z
    M$J-M6Q'V3QW(VW5=QW$,"BB?\%A1%2S -0P/I88L2!F$%NTR[+<EF6ON\O
    MG4DR4\5(2@,-``U&!D1@HKC>85B8__E($MMSD3Q)PO*/XPCF,28385Z:IF]=
    M2JBP=N?<)\%@C$;)YKPAI6!<94Q%!=UWT[$NX"<&OO*!("411 -V @F!N(
    ML3MPV1H;FD$8U?@!OK A4)LNR<;AC$0!]5UN?=3Y7_=OLSE!)9@9&,];9M
    M/\JV<E 2[(_9CQ@'5"&R[(PR0N?X%LRY\7MT9%"KM.JG4)B<1;9]\=Z5^[
    M@."GH:OK6L(@?/V283R%2(5&GE"3%X%6X!XSBNZSI-4TX0Q)01:YI&(=20
    M5WE[' ?-4D[0^[[G34#P, PQ+,5!9'<0#,71N%=5I9ZNZQ)@:MJVS5ODC%30
    MP".W/_[%4WHG2=YOE9+A*9:G[KOWF>N(<42LRM-J"I[S=W]AZ6MM >BZ<C
    M'K,=$RPS-986:/Z%$U;72P#NS*@W01B(XZ4%-G$@BGO23K<]S ?WAC[QX?BV
    MZNMP1ER4_9HFC" /2Y;XL(80PEVOU_;?NN=RO/\_4R@%$K6< I!1DVZ? ;
    M(>PW`.6JW.(GCN7V`32!/C%JEF5UR9U!.3_-G!PVI?YCXPN^\74<(39>:TVO
    M&2K_AZU9Z?C)-.9PAU]C1SA',J3[P7;XOY\[S)H*>ZNE10E52B$AT,6DLA
    M,<&F:BA5! .XD%3N%&AKK;[%A -&DF!1#.7IMK'+%14A'\J!)/BO5VO_
    MSK=R,!#4>6QM&H02[YUAD@UE0Q'L>=B0*HUJ?ZX8^KG1_QZ\+M^7=J&V
    MFZVG/$!R_CJC3#R,&8[9`8FZ.U$/I%$R:B506FRT( CT1.^+O9U=[[Z7IJE=
    MBL/GH?@HL#[PW `/WP)HQ$VR4@Z S5=@:0*L!X ,(OL7-V_>!)8RP/0!++F
    M76A@27'OWKW[]_[_M#%A?A`E]??GW?#;(]+*TK_^_$(>W$4O-33DX>7U
    MIY^?<,GB40`,SX\_/KRLHKPBR K@,L"!6549="TL_&RB?.`S4R<S&KZZNC
    M-X[_(:[&6B.K)HLO(!&-D=:11K35=".%0K")\(5BFXL4!783560D%"BDD*
    MWEH!.I%FT645Q3--"DE6##"ED0JS)04<+#K&6LA3QX#%'#Q,ZD8:B!9@CM
    M`$ `C189) -@4Q/8S 8F#OCZ`H(`V,8&=EPAY0NPV7GCQ@U@]0CLJ^-O\MQ_
    M?[_]2/NOO[^ %<MHL("00(``FBTR" -`'O()T>!+9R@9W&RY<O`\L"()N@
    MA$P@%<XMV[=`FH$]IPZQ+G$>]T[00VIP=#WP2M`X4\%H,V78*\T@E3%E,!
    MQ'SDI?18QQ2P&H@LCFS(** =``B@D5)DO'SY$EB]4YZDEVZ].O7RLK*V"_
    M\=FS9\#NAI24%-;NR9LW;[Y__T[),"<7*Q<0#8KAH7__D8?H@'UI9C9F!E@9
    M\N_//3>$Q,S$Q A!O/H 0[4"\3"[@_CEJ(,()D$.HA7,0>/S;$OA6X=6C.
    M`#H2S=A10 L`$(!]*]9A$ 2BKOX%(Y,F#NP8!W\9)Q$3$KJZLN"&@]'-S9=>
    M2DS:H4N'-KV)A7=P<,#=.W[SR,#VBC%.TT0_+]$.(515]4XU5]K$S]X^CJ/W
    MOFD:RC-)*9527=>U;8NK#TJ792&EV3WW"9"7Q1= _J[[T-W</,\IC#J.HRQ+
    MXDW7==5:9P]N&W//\[RN:SUMFW&&(39R>'1ES$FACB6VN!AI?7ON_#,! Y
    MFKAMM&%S8@KPRNO['FL*@R,\+(J"<T[#<,Y=:=2_?$A.`=BW0AR&0A@ZA<%@
    M. $!3<(!P'%E! ? XK@!V'#O9_F-V29F?ABRU DE!*:]J6%OM$#(0TG+7W
    M_KC(VP<'@Q$@![^5=5:AQ"X`V\_E#2DE-Z6+41S_!9CPH#(
    MIV*,+^1W7,$8L]8B%CG3PUMKM=:<,P2DE%CB4D((,<9 QK?K)S(K@0AL"'G8
    M!V)S3D /J:6N#8@!H+WWSKGS0?$X"#ZLM4HI["VE,%WU/VX:3P'8-Y<4@$$8
    MB/8PWA\E=PE(UMZC#P)VH&NNFBIQ'%/B,,O/-Y]\9"FIK[7>FMGE.I
    MP>VGSNZ9R1KIG!HX_%^N(;W(O,[BS(SD*%2G<'%ASIWCN5=*/K#L/62UTF
    M*0D+3\?Z(N;W@P`T(L88,%<;6VNE%/T#`AE,1Q@9)Z A,#IDZO&7)\HJ@$8W
    MOS,PT&OS.S'.&RH`S^9W^!D3F%+ `N#AP_ `@")6;S.UK<(2\>!VH'-O'@
    M2S8A6X%$1$3V[MT5(:\6444!$`!-#HYO=10'[K@R3UP"; FS=OO+V]X04$
    M\9O?X7$'9Q\]>A18IB;FP,;<AJ@+U%8,<$>='M* N``B@T0G_(0/_?Y]
    M==6J1T>.8)5]?>W:A04+?A"]5(14`&R7`?/A3S `,DC=`07?_(Y<0!!Y3@\F
    M`)87KU^_1MMCZMP&074!0`!1(]6!C!2@3U>R#@6/VHJ:D14[T`4P9DH3<\
    M@4)$='1T@ U@8,6%9JRJJBJ1F]R?/'D"F<D'F@-L=P#-1]N]#N^P8)WU`$K=
    MNG4+J!ZR1QY8N6$]O@&858!U*7SA.7QS/:26!NHB?C_KR2E3KJY<R<;-';QB
    M!3?JKJ<WUZ_OJZY?_?NST?S//RJ-XN`Y*'#AV"1P%D6L3:VII($X"AFQ
    M1]L!`0PW8%2BK8S&[Q(@`/9'(.4%,.(P6SK(N]%&`2T`0 #1J<BX<.$",'=!
    ML@UD8_C+ER\='!P(5C(O7KPX??HTL'R!IU>(B(:&!K#$N7CQXH\?/Y"-A>R;
    M)%@!`G/RR9,G>7AXX=I`+4@;YF'5ZW L@EKK@9JAQPA`=0.3B0)V7@I1NP
    M7PV455%1@1@+;$4#;8&4E9!37H@L,H[W]=W8N)&%@T/<P( #-8\!RXN]554_
    M/G[D`F_HU$'!-B#@,R8P =NB&P@`,N+7;MV&1L;8VYAYPT!0P-8/@0660<
    M.W8,Z 9@>8&K8@`J`IM=""#=@`@@.@WE@&L:<W,S'[__@VI**Y=NR8L(QK
    M6S%RPP%MLA,B@FDLL,Z!9&-@TC0R,B0'V-B`N9V/S\_BXN8(D&S,^0]BUD
    MRSQ<&?"`F1PY\X=H$52DK C 34"RP:=N_>#2P=(B,CX>L"((+ \@(H`C<$
    M<@HQD M,]YLV;2*R_7QBPH0;&S8P,C%)&1L[-C<S(Q5J[^[<V5-5]?/C1R86
    M%IN*"@6DF0OJ`N3C@@G6$/"=K_?OP<&"["\@&]1P; !.#L[ R,-5E966+:
    MAL#H`!;B`0$!\&(=[9 >>(=E.!VS.M@`0 #1+V0AE1(DLH'9\O'CQU09HT(V
    M%EAVH.TW)^!YUWM# 9$$A_![N`&M2!B938!:RL" M!?$Q,1<75V1N_?
    MAMGSQ[(!DI@PP?9?(@5Q)_%]/KJU;N[=C&QLDH:&3DV-K*B[E8$=E6^OWW
    MQLMK552D")YKI 7 L_D=Z$=@@Q%YUSFP60'L@$".U7SZ]"FPWX&UO( `8,-(
    M1$1DV[9M:,?G(N^"1VZ5'#APX,R9,\!(@;CG[MV[D.H!6$X=/GP8,O]"_(*]
    M44 &``B@@2F,(6LEB:QC@8D#F&0A#0'(D0I4,19K"0+,ZNO6K?OPX0,PV7W]
    M^A68XC&/U8)G%>1L+P8&R.4%L-"QM[<'IOLG3YY LAP9#@,-4M34_ %VOC@Y
    MK8JT<H8&_E_JX]3/\9-;R\%8D[5H^\L0Q]/7U<JRK%Q<355=7___L/V0L#
    M9(B+BJMKJ$,"34I2BI/P)EWEI:6MV[<O/[#W*1`326BQ-]L3RP_>CDX'3O
    MWCTF!B8&1E Q86EN2LO"Y3Z^N6K`^ N9GY:'E!:P`00(.]_0897 2VX9%+
    M$%SCIL"\2O:V#LBPV?/GSZ6EI:VLK"0D)("]8D@W!T\>X+F[-__\N7+T!'
    M`OM?D&(.6 SIZ.@@']Q(9'D!ZG1\^L3,QF997,PC(8%67MS>L/$7)[. AJ9"
    M=/"7O]_^T6QF$<_F=V9N9G4#G+O.V?G9.00X\&_*1M[>#A?$W 4/%>=C1=X`
    M#M]LSL3)I&ZH3K<-X",9``30$.CR019?`3,>9*@2V,Y_]>H5O%<"WTO"`-[6
    M@;;:AZ2&CYZ>'K Y#9_X`'9SR.L]Z>KJ0H9L(+M.($?UD'K2)]"S!YN;?W[\
    MR,S*:HG1Z;B];=OUY:L^R7!N5WDF[:"
    WC]7V 6'9U9' 6T!P`!--B+#,@D
    MJ+:V-GQ^#L@%M@7@10:PYPQ?S /9UB$K*TM>P81V]".DFP,?TH/WU;'.%" O
    M,$<V!WQ'[ 0(?7$)%#99VIZ8_UZ)E;61X</R]G8(/=*A%15N:4E_GW]&')
    MSMS95]W#[^>O3PPTFUBD9/,[5M,HV?Q.C"&C@'8`(( &IL@`UKT_?OR@_/S+
    M7[]^J:NK0V9,H U7<M=B`S/\A@T;^/CXX(,7R-T<8/_YY,F3D.+ T- 0,BGP
    M\N5+145%B'9@'3!@P<!`0%4/$S-LK 0F/]N;-SX\/#AW]^.38WPTL-8555
    MY_;VO555OSY^OCIAA@`'OYR#/>WBBY+-[UA-HV3S.TY#1C>_TP4`!!"=B@S(
    MN#JD!P%,!\3W(# WH2.0$YJ)Z.D`!H"N3@HA&RE$M<7/SJU:M ,X%]$V!_
    M!'GW.E QL/@`V@4IF\3$Q(!%`V1+%;#Y`RQ<;MVZI:"@@/6P5F3WPY=R`4W&
    M=2X>2JE15 0D@:7&L[-G]]?6(I<:(IJ:SFUMD!49!]M:;?[]I=V,"=F;W]$`
    M,%2!:0`8AFC#.L1O?H<`8%IZ\N0)\AC3Z.9WN@& `)3D0',8!\^? #&]16
    M%A9@90[)C? V/^;@`C!K`56B)3YD$;)WD0-UL;&Q`7L-0-LA:T:!(M;6UD!+
    M@0T8,9F0-V]#F1#EE= L@TP<0,3,3!Q0\H^8)I64E("L9L5 ,U`LL1> V)
    MO)0+;AI52HTC'1U $5J4&I1L?D<VY!H8`*,,;=4,\9O?(>#5JU<[=NR M^\@
    M8'3S.]T`0 #1J?N'9S<Z,-<!QFT<@&84(#U&#!M00H4YR%$V+G*T<@IY
    M:SRR.'SW.M:Q#.2%R<2,<6":3[SC(:L_@89(&AN[='0@K^:"K_YD9&:VJZFA
    MFHNJFQ/WD"!I`&Q<R,K(G<Q2-K\S@!>K 5LB0!3"S#;&UMT=PYNOF=
    M#@`@@.C4RL!3G8J(B!@8&#E'&"^D@#/6)N0D<6(7OD`NO>=E+%B6G@H&G$
    M93Y1;0U&QJLK5[Z\<.''AP_(>TS@;8WW=^^O'B1=@M T5I/Q&]!U8)7[Y\
    M"0@(0--"ZN;W<?.O7W[UMO;\&#!\".$F;G=W3S.QT`0 `-_(R)*!B,Q@1!
    M8)Z;ZNSBTNSHT17,!2P[6G!UA>*FZTLT]19/@>7%A0L7@&W&RY<O`QL@
    MP%P-'VX@=?,[4*>GA[:Q:Z8R6ET\SM-`4 `C6Y'P5$`?(VO]^]>Q=8+@"[
    M1P<', B!MA&@*R)=A4P0J 90V10U>CF]]I!P`":+!O?H?O4H<;)28F!A\W
    MQ31V.&]GSP9S9W2,?DTY,G@VKS^?OX6%A9'/--J?_I4ZZ`8 `&@;W['JI;JQ#.;WW$7V61O?@<":ROKFS=N`@.3F0DT
    MTV%E824CAS+H0_SF]Z]?OK(P@:YWEQ"7D)*4`FH!6@JYL'9T\SO=`$ `#;'V
    M&S#C`3,DP8U/9 ;C6YQPK(WOS.0,K-[P0WOTLI24DS2F/V@T WOW,RCVY^
    MIP\`""A<5[&U:M7@1D/6L#RXO;MV\#F[NXCI:FI.$SNOE]%(P"@@`@@(9
    MP.R$!C.5E%1@2Q/IFY#8W3S.W['T.WF=X[VHF_^1WK=OC17?,4`H `&NR;
    MWR'K)N!3&PQX]V50<BK7Z.9W?+% P>9W-%F0=F9&M!A$WOR.?VL\`RDWOZ-I
    M)$G9, %``)H"&Q^!P(C EF28%L ,IIW-;GXG"9"]1U-E@$\:*DI(0V
    M"P[?_ Y4?_KT:0<'!^1E?J=.G0(V8&R#AO?@=&`3!@T4:=@.6XFIH:1",$
    MO'KU"JC,Q,0$61G01J";@2W!T>* & `00$-O\SL>8XD_E6MT\SM)'4.R-[\C
    MRT("!Q+@R.8C;WX7$! `A@FP'PHL"^"9'%@K`%MV#*@WOP-=!8SWW;MW`QG
    MIA^P/GX\2.RL9 U&LA#SD#M.W;L0%MN!PHT146@@R&#4,E`D$`$$!#;_,[
    MD<;B!Z.;WTDJ,LC>_(XL"PDN>% @EQ?(FUF!=0"P7'!U=05J!ZK?M&D3L!T!
    M:=%@WOP.6: !++G0-LL#2W.(L?!T!2Q3@,4<L-P'^@)MUSRD-73APH6O7[\"
    M[1V=IL4/``)HZ&U)Z. P-J$&=W\3@D@?O,[A 'L/ +[;L B'AC7\&M-L&Y
    M!S8T@%4%,,_[^/@`%0`+#KAZS%XG\G(8>($%[&@`HP;8S(%G_B]?O@#[1T"K
    M@0Z[?_\^IIN!M@#+."E0!OMZ1 0Q<`!&#?#I$``$$@BGH^[A])G,0W8Z%(
    M=T:"Q9$DR_ZP/_S3+T8?C?D7 ;305@AR4/)0[1K'OXG97 AB#"YC#YO=NL
    M8AR'5_PI<NE7V# BG)DY=*!'5?5_VEQ;`(TNQ1\%1 '(YG=(KPJ8.9\]>T9,
    M$P_8!%!45 0V)!44%" 97D]/['#AY B`T]315Q<'-A8,#8V)K*;`#0'LK/
    MV[=OF"4D;MC&$9WS1,!``)HL&]A_2!@6U:H';(LB[DS>_7KU')J"7 (.
    MF0?!M5T=&8QN?B=AN(N"S>_ 7@;:FE?D8@/YO>7U\J*2D!@PL8PL24&L!(
    M!!89P#X%,$BW;MT*-!G/K8ZXP%\P&"T4\ . `.R<00H`( @$/^?[]4L-+'2(
    M3.K40<]AD&NE,?T.OS-8V*LP\P5^)\EQA5SF)Z#L+)QC91XV_'Y;@#S#[T0_
    M:]]D\#OE`_)0+X-U9NI#23_"(#KC/R8F;L3B^V;=V:$)B)!KIM",#.&:,`
    M$,) \#6^(6!O%?"YOB(/L?0)-[ @%L?A776%J:V2;'9#6/]N?H?)>9E2@M-
    M'9V$)3-'/*IM<I(SK:,]#4SS8X=4CKF]U?QS?P.#B."+$WTKDQ:WX?8P#X
    M4@HC>=,EI"HD@PZ]ZZ_$/?>67-4LEEW="BE::VY^^9>H_NKSK=G#S')0![
    MYVX#, @#T34\`I);&@_AN:F8P,OD2=>@2)%(JA2XHD#&_,Y8^.#OY'?J,.N]
    M=WEF,V,QL5!6;2N=_-4=RB&_;\IG\CM!!V5V(X"^0WZGE3EG:TVX@/*(&&.
    MLPPUIQ)0&$P!A65/52EEXT:69^<S!40HF:FOOW$\]$I&[(6#>Z.*NP'[L&
    M]?6P(T]R":#!OOD=F F!%36PIH*LLX+T_X'IC"9A,;KY'4>A0/;F=V 0V=G:
    M$;_Y_<OGR)"(LC#$,!0U=30_/OGP,;Z.9W=U=WY)O?K2VM(3>_8VZ6AVRZ
    MAQC[_=OWO[__,OYG!"J3E)"$[)K_SP"-D<\?/P-=I:"D,%H<$ ,``FBPSYA
    MJ@M@%0',>) B0TI*"I@5R3M%#G^/?73S.RY G\WOT#WL!NJ_?J/8):LJ"]_5
    MCNOF=\S-\BC&<C!K&&I@;3W]^OE+6@4TG#2Z:YY(`!! 0V#S.[ 6`N9;2$\!
    MLOD=F%"<G)RH.Q\VNOE]%(P"8@! ``WV(N,?&"!W,H&5-K __./'#^K>OCFZ
    M1V_8ZAR\SNN;>98;W['M8D>_9Z7+:/[GFG%@`(H,&^^1V8Y2!;&R';PV@'
    M1C>_XVOR4.GF=US;S-%N?@>R@ :B[9&'VX)_<STNVT?WO%,``308-_\BPL
    M#%1Y\.!!;6UM=G;V5Z]>P4_E0JOT2*HQ1C>_DP2H=?/[J5.G@+HPUVZAW?P.
    M#&J@H)2$GP4";[G'1B8P$ &5B&0HOG#AP] <63;@;0BZ"1S1_=\TY%`!"
    MO;-7<1"(HG"QW0H$0,K86-G)5I'''M]A_.S#-8V$C\Q2!!(,)/O!A9 U
    M11((J78*BW'FGNO<>XXS,H,?69:]87'!&YALZ/N>X$$P8J^4DE/JW(6?IYLB
    M<T[#,&!RV[;T170PXCC.Z)@Y]"OTC1-V[8?=(E4PR")R!4:NZX'_!G&(:F
    M:0#"3R"B)+=6;2GDC8X`PKY.O*ODQ/;M<L=,04<Q/A6UW79"JX# )9CI&[
    MNOFS6!RVVW51[+IN4Q1SI2[[,CZGT\@6"V7Q_UI?77;#;Y^S_TUTPQSF=\
    MCN/8]WW$&F[C-B2';XPYD45!DB21G50\*8^&VD+XT9)!:TV]YWDC/J.\# C4
    ME44?RHO-, RQ)D(@9]YI0"7HB%2>YTB#95E55:$O:9I>T(DFNG-+G*)V18
    MOL:5[],@_A]Q>JK\"J#!OOD=4SO6T012KX ?W?Q.4I%!E9O?@>4"4 K8!$"^
    MEPCKS>] ZX"%-5P[YIYWH(U?OW[%W/,.<2W0=J![@,49`RF>&#Y`@QG"I2
    M.("LX +V--&&L48!'@`00(-]\SM![40J0 .CF]\I;9V2?O.[CX_/]NW;D;MI
    M1-[\CMF'E4"=;T93#"^@X3?%/P0#3,6@A1[N[KMW[P::CUP@C@(\`"" 1C>_
    M#QE@GI,#['KP2DEAW?SNU-KZ]-0IC8 `NKF'F/8IL( `MB^ 31)@I^;RY<O
    M3@20E).3@W3WBSYG8S9=(C;BDI7EA8>/2F>)(`0 "-;GX?,@!8=VN'A>$L
    M>;6T1&FYWIF\S>?/W\&9DAK:VN(7K3,3K-[[A*)6 !`3]&$-C7`/99( U
    M(J?A*;DN:P0"@ `:+3)&`>$<Q4#NYG=@:Q]Y[2RPH-'5U87/F%!^\SO024 3
    M-F_>#&E60"[Z-C0T).D:Y]^_?U/W3ISA#0`":+3(& 5$-?*I=?,[,B#RYG<\
    M>]Z!C1<I2E'1T?X:2Q$'L,/)X"],CH0 ;Q`"" F$:#8!00`R";W]EA`$]Y
    M@;SY'3^ ;'Z_=NT:_B4JD#WOR"*0N6IH"@8OTH4[#.A.XGL9KU^_?O7JE:NK
    M]F'R(Y `!! HZV,44!4TYV\S>\$S4';_ Y90??ITZ=+ERXI"A 1DF1][P#
    MK7OW[MWW[]_UP8<)8;T@'@[@-\4#BP;(GG=@8P1HG92$@/XX\]>_:8F)A0
    M=?!L <``32ZS'X4$ 9W;M1E9/%NJ#SXX>/#^X_@*<BR"EGZAKJ[!SLV,V1
    ME463`FJY=>.6G+P<)Q?GY\^?[]RZP\;.]O/'3V$187D%Z!;8#\@/:\@^>G
    M@:4&T'P.3M!"V_?OW@.U`/5B=?;=.W>!S@--:X-N2F+Z\QLT! LT5D%1`>28
    M6W> 3_6I ,BICK4R#>8DT!S+Z
    M`!F#A%QV!>_@P%L0:',K</,AZUQP-330EH>@&0OIC& N,AP%^ % `(UV3 8O
    MN/_?ON1]E]_?S$QC@XYC8!`@`":25,7C!M]_??O[]"3GM:H!3"34VO/9
    M;(Y_\SO"]RQKJ;%;.,0N=4=[0YZN*1/84_-/#;. QVW ,$T&B1,0H(`RR;
    MWUEP;WYG(G;[.7(I@V7S.Q,C_/8&/!>X`]7#%< 3,]!Y:+D:C^VXE(&V.__Y
    MB^DI9'',T,#J5=,9@!0 "-=DQ&`6% ^>;W%R]>/'WZ%->1B/@WOY\Z=4I
    M0 #Y0%#X/>\0]9#Q$6!5#QD'`;)=7%QX>'C@ZK%N?L<$;]Z\N7OW+OR(>:"]
    MD D7H,E TMG9&7XP;ESY[?OP\)#<CB,1T='<RCAD<.,'-S0V_CQH(@X%
    M^M36UI:*AZK0'P`$8.\,3@`&82@Z08].DPW<V$&$#""(6_2U'X+@P4-/!7-3
    M/)C@_XJ:_$,9QW8;[P?E]X!B44::O-RN]@";0S&-Q&^>76&M!5D7'UA,X[
    MXU4=P]U[[U"5IC'GK2CY?15\7ZW6&NFS8!O7<L[ZZ %]J%XY3=C3S%)*1(/#
    M!T2 O
    [T41J!&&,H7O68(WK-28CM<>?KH=;`/;.& 6"$(:BV^X1+#R$I1[
    MRML*ME:67D&\@Q?8QWX(4RQ,O3 I4OB#DQ'R^2,)\]RK/79OU(.U<N$I9OTG
    M\7696U4G%6A"1ERSC%%T'M'0?R\=#A=_$GEHBDJTL_OTUZ]U2/D)!U(.
    M%H:]E4RQIAS>N]O^[O66F2B*?B]-P142D$FL#-/B3$"B0L'/"@O%H(X3HI
    M"]U LO!"SAEVJ[6B1"1).!SG7&M-*_]H'P$T6F2,`C(+$6(VOT,Z#L >!#"_
    M84YG$KGY'725@975AP\?;MZ\29(C(9O?@?D6V,3 ?W,BY(HF8$L*US)0H'>
    M70]<'0KD2Z& Y@!-\_/S`WH*<BXDL#T"]"E<,;#T01,96@`@@$8[)J. _ X+
    M037 )H"WMS>PX8 UMQ.Y^1UH$3!#6EA8`)L,)%V;2,SF=P@X<." AH8&Y%0>
    M(%!04 "Z#=@Z4%)2`I8U0.TB(B**Q)UX]O3I4P$!`6 ?!](D`=H..0(268VT
    MM/3]_>':+P#!-!H*V/(@'_?U]=M>K1D2-895]?NW9AP8(?'S[0R';(YO>?
    M8 !D(%\-AP<`VT\.9SXS>^@59O"PL#>??NW0Q$GZ !++"(X `HEHK`W)A
    M!_(I_L0<; D'+U^!&J')"#D>'A5[3#C87?_(Z<GH#1"2S:L=Z]CA70[N9W
    MH(' &A67.13=_#YE"IZ;W_=55[>?GIT#ZN9W`H4@B9O?@4WZM6O7`J.)
    MR)M6B4RW6'>F07HB<"ZPW4'DX5U 3P%+'V"K!'F4Y,&#!\AJ_H#!$"TR``*(
    M:D7&BQ<O('>I,\!FGH IS,G)B9AL#-2[9
    >R'IAM'OA@0PT8^$WO\-+<6 M
    MO7Y';VW!S1N#-[W@`D9O?D0$P50`+
    MV"@4>NZO./'CZNJJFN3$.[L)Z*AW=]^O3I_/GS!"\P'[0`( !Y9W,", A#
    MX;L'EW %]Q <6 *(SB';M /!!$L]H?V4)J3".80D_<2Q.0QR,"0@AC3/MN
    M2A[[V.,UMIUL0I7AQ! <9RR$1H0@$V!<ZTU.WU$.VM"O:N%:O!FZMN<LUJ
    ME.*<`TW.H,;;D]_)::'$6<_?)KO97?R^$1@@V"&;L'WY:4DI1R[A5<:\4)
    MN=P12A9X<2EK@#.@J/%%]ENR"4#>'9PP#,-0`%TC'L)7C^"5O46F\0!]\,&$
    M&IH>VD/I)01#%$FVOF390A].?^:LRTLIA0NEG=NE8WGYI+6VW#MC@Q<K%Y6R
    MI9 ]CJ/6>IYGR 8OV"&D$/.S6X!RC4%NA/]:Y_?0S$['( Y#Y]\ZOS,D$^1I
    M<,Z9\G/J6OT!WBE?_H[S!47Y+K7=49VHWU=_&ZC/?>=Z'@B ATC)'T)Z&$
    MA]C+K@0_' 8!5U;5UF-=OMAUA4)R(O%P5&'E_&Y.[2& :#AC0F33$1@3P# ]
    M=>H4I)4!N2$=SX4T\%OC@1'V^/%C8.D`[%1#QK2!)@!#6!2((P"Q!*_Y
    M';(&$<T<H)-PF4-@S&6(W_P.O7*=@5%27))1DA%RY3K:+CODF]^!!<&?7W\,
    M] U_O@)OR]23U</;783Z![XN@X,]!N?@>"KU^^LC"Q,/QC0+[P'6[[MR_?
    M@!9A]1?0R\!$!705L)AC9F(&N@1T'SW,4T#W``LUQO^,$"\#8]S,Q$Q>41[N
    M6N2%IPS@`['96$%5"S E\'Q&KL;#^D3?0`":. G68&--&"A#FQJE^^'%+*
    M0%;.$.Q?0-;MO'__'I@Y(>4]9#$/&3F3@7HWOT.J5J"K@.8`?0%L;0%[RYUP]7!E0-N!!O[Z^0M1S6#<\XXI`@122E+2
    MC-X;)=6D<:\AA[95;)J O X?/8QJ; Y0%JX2FL>X641Y14&^8V=6-U1'
    MDQUR`"" !L6Z#&#^!#;L(3,FD.L7@?T+%Q<7@D.#P.:)H* @L$T!:14#]0(S
    M.7D;[:AU\SNDB02L9^ M'5-34V#SF%1S1F]^'P6#$P`$T, 7&9 +Q,3!`%JG
    M24MOW;H56((04V0`NP,Z.CIPHV[>O$E>D4&CF]_1S"')/</FYG=D[03WB5-]
    M\SM!VW&Y!-?F=_S&XM_>/@PVOP,$$V#&"X`/OSN(Y.0 8W;MPX>?*DL[,S
    M,3,=Q!M+J#BS>_ CAPE>'DY 0QY\V;-W!S2 +#YN9W^&YQ-(W("O#<_$[.
    MYG<V9N3<CM]VK,8RH&U)]I3"^4'P:;WP$"D'?&-@"#,!!LL@K[3T!-Y9*.
    M"9C 94YZR7:A"(T"242CT 8WLBO/UZ\(^#>Y 6J?IMSCC%*8_EO60EL DR
    M$?@\,49HR1<* :PO7?!$L;A_)X-G_/SLG*;;'5!X=]J+4R5F5F@?-/Y_?6
    M&IR1'G>/@9=_F6WB=SHE$M/LG+$;^]5%\;M@>21B45G\;F:<A%S*%>T;XO=3
    M`.[.X 9 $(:B.S #6W#APH&PF#-QXB#[,((O^4ECU!@2]:('8XA\*_R62EK[
    MFLE@MAA67 ;32>R%%<Z]_,.BG'SG7$JI]XZ:V?8G2[UT3+#VN<'9>Z^BP5PK
    MH7"/>6ZYD198Q8\A*BTA!$3"H8 ZVDR-,<KWX5KQ)E(;R TI(:NL&Y+ ;ZM'
    MQS(=\;9AW)-5MR8M!KKLM#RA=5XF/RN`LZE%*:&CJTU=33\[Y?N8W'L0#D
    MG)F^,08KDRWM]T,OD=:<&!GP9;:V64%"J"'3F4F+?C'\GOFP#4G<T)P" ,
    M1KN):WCOU6E%,H8S]5$AA!A:#U!3ZV@6(A??I2SS(KQS2W:3].@)@?UV'3
    M3L=V7T2QNVK"#'Q?1,#_37Y_G2<<]= V);CFTAD*45W.YN-KU!6PKY7428
    MDU>]HCX#W^<>6JT5*==2UW%?>\="SNA &E<QEHHQD&/VWA$(-8Q1E4<+$"F6
    MEU*R_\[!-Q!MX7AX;JWEG,,H0\4(==M7-2X!1,W5G[B6)P'%(7N?D8?0T.YV
    M)_4J=K2LCD>$)-=2Z9W\KQ#H*TQ!&]!T8ZL$4&+PZ.'3L&S)GP-CQ)F]^!
    M.0U8/)&Z:!)Y!/WDR9/ DD5#0P-3&63S.["!@W_S.YRM@U"! R(C4I2V!!
    M"?0[6@$W5 ! `-%CQ@28AJBRO'>$`_/<7!%U=6YQ<:PWO[OV] #+"R575[JY
    MA\C3=Y''N2$=D P[;:TWOR.;#NPM +:#C0$TEM$`R1M?J=\$J0WOP.$$"C
    MF]]'`5& O,WO</#JU2N@%F"#`C)N3;"I@@;(V_R.7%Z\?/D2V!?@Y.3$G+JB
    M[N9W,HJSH04``FBP;WZ'#!G<NG4F&0AB\3AF]^!;&"/&E@S$&\<N=SZ&U^
    MGSP9S^9W2,?DTY,G@VWS.]"SGSY]VK=OGYN;&]II-[3>_ Y9.@$YAA-87@`C
    M&K.\H/KF=V+ D-[\#A! @WWS.V1O.[!H@&PS1][\#I0Z=^X<L'-+1I$QNOF=
    MU X(>9O?(;O4@)G-T- 0WNR'`UIO?@=&RO'CQX%N!K9N<)4R9&Q^QW,3/3%>
    M&.J;WP$":!O?@?*0O:JVMC8`#,SY.K=O7OW1D5%`;F0'=GDN79T\SM)@S-
    M[\# `=8'P'P.'[;\"P;P?$C3S>] B[Y\^>+CXP,?_D"VG8&"S>_ )BIR"0BL
    M@>[=NT?D_M2AOOD=( #[9I "4 @"T2-Y_Z7G$._2@X&A913!YU/+$*&4=,CW
    M=?B=.!%O8:B4<A"-2"GAW_P]K:AM^I!!'!"TM[*(/NGO&\J_ [THFBE9ED
    MHZ=X7=XWX'?VY1:=A<"DV<$M-U!5_G/5Y"&6%D%X$''_#_A]"*#!OOD=TAU%
    MSF#PW2CXSXPFKP09W?R.U:=D;WX'50`6EC=OW 0&`C,3:"##RL)*1DX&;82"
    M1IO?@4T27Q_?V[=NPVTW-S674X#N2R!C\SND5@-69L&!P<!B`B(+--;"S )Y
    M\SNPD0?&@\VCH&)`914AL?F=X `&L*;WZG>8Q_=_(XD+WYG0&VMQTYG-&V
    M?M-N\SNDU2.GH>\WP2NANS-[Q!CD661S9%4E)1BE,LK V;S>\``32T-[]3
    M$8QN?A\%HX 8`!! 0V_S.T0]U9MVHYO?\3L&S^9W@ANZR=O\CFD=IC,8".V1
    M'P54!P`!--@WOP/3"K")^_+E2\A(&&0`Z<F3)P0G8D@%HYO?\<4FWLWO!#=T
    MD[KY'==F=K0KUZ&.@>^1'_K[RH<$``B@P;[Y'=CTX.3D/'3HD+:V-CL[.]#8
    M6[=N028R((/5P'P+M!2>H/$LOD)/Q.;WXD&>#:_`V,$(5_F(;4S>^X-K.?
    M/7L66"XC-S"!T0$LM8&VOW__'C"CFN8=A10"P`$T&#?_"XJ@IL@ `S)S![
    M0H9H+'PS>_ ?/OAPP=@<H&;>O7+ST]/8)%QNCF=Y(J`SR;W]^^?0O,YWAZ
    MG<!0OCQ(V3S.U Q7"-<#=KF=SR;V8&M2UM;6V#@0R8&9 64 D(" #U[MBQ
    MP\W-C9N;>S1CTPX`!-!@W_R.6>@;7['511Y-K1S>_XBPR2-K\C`V!A`6QL
    M`AMQ\,H?KA&YO,#<S(IU,SORIGA(X,,#%N).8$$#-!_8(,6Z77444 4`!-!@
    MW_R.M00A*$ZV:T<WOQ,)B-Q1!BQE\/19B-S\CEG<`_N/P)((4NO 2P?(2).(
    MB BP2R@E)059=C4*J X``FAT\_N0`>8Y.7S2TKQ24E@WOSNUMCX]=4HC((!N
    M[B&C?0KLJ5VZ=,G4U!3")7S.QQ !LN^?/D" Z )1&P`[)[]V[(XEJX&F!/
    MEEHW(8X"K `@@%A&@V"H`"965NVP,%RRHEI:HD@[+ZD.()O?(;TJ8/OBV;-G
    MI#;Q@!V0G3MWFIB8P <RB-_\#@' BN?3IT_ E@6\!0%D/WSX$'-7&^/H$A6:
    M`8 `&BTR1@&AX2XJW?P.;" 8&AHB3Y>0NOD=
    Q.S VUD)F[T04:M ,``31:
    M9(P"HCH@%-[\?OCP82$A(2W4=A"IF]\AT^KX6Q#'CAT#NFUT((-V`"" 1D_E
    M&@5$`<CF=W88(F\.'[\^->O7S'WF$,VOU^[=HV8)2I </KTZ:M7KZ-;B#/
    M0!T]>A2R.96\(Q%&`3$`((!&0W84$ ;$;WZ'`QT='<ARNR-'C@`+!3T]O<N7
    MT..J\!S\SM<.];-[(J*BOOW[__X\2.P6P1QS]V[=R'S]$"@ T9R/P+D4=O
    MC R`$ `,3<T-(R&PBC /Y8!;%.(BHIBK;HA5V=CH<'E@M ]9\^??KRY0LP
    MJ\,/T0-F=6YN;N3Q"VEIT(Y28%<"N<@`FLG#PX,VS '4*"DI";IU'7;-DJJJ
    MF0P%61A87%Z.I/6@. `!K=R3,*1L$H( $`!-#H6,8H& 6C@ 0`$$"C1<8H
    M& 6C@ 0`$$"CPYC@#" ;/9']&;!&J0C\ @9A4\'F7(LZ>0?6B0RR+0-JU"
    M1D.8F9F11U7@XA" +(OF;&@E"3.6F"G;48 )``)HM,@8!83!Z=.G*=G\S@"^
    M=^ITZ>XE)TX<0/S>\,L N9(=>@<'!P.#@X0$X#_?#A`U"<`>G>>: L9"\L
    MD'ONW#FTS?)__OR1EY<W,3$!LL^<.</)R0D_9784$ D``FBTR!@%! `EF]\A
    MX,V;-SMW[D3>\(X,"-[\#I3=M6N7@8&!FIH:T#' KYV[5J@>F I\_E2VYN
    M;J 6+WS)T>WU!Y>#;,X"G;/?LV0/4HD7+A?;##P`$T.A8QB@@
    M#(#Y"KZ4"T@",[.>GM[#AP\9B-B;^_KUZ_W[]P/S+59E\,WOD-X$D 0V$X J
    M@1;!U0/5`*W3U-2$=#HL+"Q<75TAZN%71D,6F $%K:RL@)T12"F&[&Q(,P3(
    MA3<Z1$5%W=W=+URX0-V;$X<]``B@T5;&*""S$"%F`2BDHP'L7P!;!\ Z'[,_
    M0LSF=] QJ*@7XDF@'K:.IACY$ T&V$6<MV_?AAR_A+P(54A("%AJ4/'FQ)$`
    M``)HM,@8!>1W6 BJX>3D]/;V!C8<;MZ\B2EY.9WLD<HD3?&QD9\?+R`DL'
    MR'V:<#7(-R>.`F(`0 "-%AFC@"A WN9W5C"@L*F"'P`;$<#""SZ6`>SF@"XZ
    M`AN+N5G>P,#@T:-':#MB1^=-2 (``31:9(P"!F(J><HWOV/-[21M?L>2?%E8
    M@"9LWKP9?B_!CQ\_# T-(64$YF9YK(44VC3M*, /``)HM,@8!41U0"C<_(X5
    M$+GY'<]-Z\"&CY24E.C(Z25P8!Z"#,QR].G#@!],CH0 ;Q`"" 1F=,1@%1
    M@)+-[[@`D9O?(;.\R")/GCPY??HT- 6#;Y:".PSH3G@9`51SY<H59(UH-[^_
    M?OWZU:M7KJZN0_J25#H#@ `:;66,`L* [,WOP%8`L$0`DF_>O/GRY0M0&; Y
    M@&?S.]:;WX&-D=V[=W_X\ %R+\2[=^^?_NKZ_/@&.//!P`30#VIQX^? BY
    MHIT!]>9WH+/W[-EC8F(RNOF5) `00*.;WT<!X;$,LC>_?_[\&7)I'B\OKY"0
    M$#"'X]_\#BQ6@-4^L\!;#L`<S+D_@$@`[[G':@2R#4U-046- PX]LC#`5!
    M75T=<N$>Q)' 'A!\1=G3IT]E964QQSM&`7X`$$"CF]]'P2@8!20`@ `:'<L8
    M!:-@%) ```)HM,@8!:-@%) ```)H=/AS%! &%&Y^AVM'TXBL@!:;W_'8PC"Z
    M^9U<`!! HT7&" ,-S\?N+$"?PWO]-H\SL:.'/FC(J*BI"0$)P[NOF=# `0
    M0-%QB@@`"C<_'[DR!&@&LC-[T"-P!R._^9WFY1RN5KERY@EQ:C6Y)P\`
    M!-#H6,8H( S(WOQ]Y=8#/$T],36!9 9FI%1$2 K1*T\H)&F]\A`%C,`<N+
    MUZ]?`]L7R%V8T<WOY & `!HM,D8!F84(,0M @;D7V-V =NS8O7OWX+T&
    M2C:_XSJP!VWS.["!LWGS9F#IX.OK"[0%;4D!9//[Q8L7/W[\.!JG1 * `!HM
    M,D8!1T6@FJ0!Q=OW+@!Z8# UVL?_[<VMJ:%IO?(6X#=ENV;-GR\^?/KU^_
    MGCMW[L>/'\"R8,'#Y!5CFY)Q4`!-#H6,8H( I0>/,[L'L"U )L4 !;&?#>
    M`>TVOT.Z+VP[,U9#MY\ <KJ:F
    MIJ2DAR2=IO?,9TU 5O4(QN?B</``30Z.;W43 *1@$)`"" 1L<R1L$H& 4D
    M`( `&BTR1L$H& 4D`( `&AW^' 6$`?[-[UC7-2#/7.#:_([_9O9?OWY!>LU
    M$;CY:,9"5F&-;F.G)P`(H-$B8Q00!G@VO[]___[@P8,,&,NZ75Q<N+FY(6Q<
    MF]_/GCW[\.%#M$,Q%!45C8V-(;O@__SY`S06* C9-@(L08#&\O#PP+6KJ*@(
    M"@H"&<K*RICK/D8!+0! `(T6&:. `,"_^?W%BQ? /.SL[ Q?3 5O#D 8R)O?
    M@8S=NW<#!2&EQI,G3SL["#'"".W,AC N"!9@M`MJ^8\<."PLR 7NR!M2
    M@,409 T8G#$*Z ```FBTR!@%A %
    SMDWA2^^1U89"!O/\?4>.?.G3=OWOCX
    M, U`IL)7[Y\@28%A9D8U'2)9(@T I,9<"F!U <LO,%PB!X.-@HH H`"*#1
    M(F,4D%F(D>C3!P,*0=TFT!%CW'CAT#%A/?OW\'=HZ #0TC(Z/1J*$U``B@
    MT2)C%)#?88&4'<#N!GSU)V31)UP-,!N_?/ER\^;-BHJ*0 7 QHBFIB;R:LLK
    M5ZX`^R! H[2UM3DX.(BT&JC%S<UMY\Z=D [+UJU;D4_Q&@4T!0`!--J0&[S@
    M];5K%Q8L/'A`Z;4O]_KZY:]>C($;HY!MCR!_8%("2P#LV3-<I*B`4M
    M2S4U-4@_`EBX[-FS!VW4@YRCH4%:-KHL0!`0`!-'A;&<"NZ<V;-Y&3%[!"
    M`R8@B>R`%,24"-\IQ.0"]$(J?W09"$`6 $"6\O2TM(0]JU;M#W:XF*BLK(
    MR.#2R ">0#6G,#^_+5KUX"N!7(AJ1D(D(T%<H$! 0$@-RK5Z]"&/A]<:BE
    MY>W-FZ^N7'%L:F(%GXX+!W=W[S[<UL8E(F);5:7HY$33B(!O?@?Z$>A!R)&\
    MP,"$;'X'<H'U//S60BR5$A,3L 4!Y^[?O__4J5,V-C80+K!50L;F=WC'Y,B1
    M(Y".R8$#!T8[)O0!``'8.7\5!F$@#K]"Z>@24;)F<T\>S,G%)W+(TJ6#@R#Q
    M&:3N@FW?N4@.$FAM'2HTR5R9\#[??E'\KO(0#,AA&W;9!..XKJNC'MM<>S
    M:'2.(VDDCF0\]C1-SCEJ)&Q\&[M08XQHN&U;),W@F:\(.'!42N$X#,.R+'MF
    M"8TUD0#"0Q&2P]O6$11(1&7W?YWE.$2/+LF-D/&O*XIY'&]==RE+5U5[
    M:IRU/J7I?9ZO=4WQH]2(A]]!@VQYR&&SU]&_7Y5,DH1_\6:3Y%9A[SWS$5K5
    M- T&</_K^0O/0P`-]K$,+2TM,S,S8"8$9B%@9@96U/CK-'BM"*SY@<D(J!&8
    M=5_?KUW[][UZ]?[_M#VAIP6>3*$$@"VQ? \@)87P&K06 I`-0(S"% O9&1
    MD9 >N(:&!K"EC;8`"=)$]_7UA=2Z&S=NE)65A2A#SBW L@92V,$9!)KTA87
    M_'ICX\9G9\^BE1K"JJHN[>U[JZI^?/Q(AU(#XF:@7R!'[ +#!!@:Q&SH>O?N
    MW9DS9X#%#7R<`A@^E)]G`YD]`48T9"8%PAB=J$/``B@P5YD0(6I$4`S.2/
    M'S\F<K,S) %!- )[!\!:\?3IT_#>+[(L6@\%F/A,3$P@30DQ,3$W-[>G3Y\B
    M3_AAU0@O." T)0!<'#QX`LPJ0<?GR90@#6#8!FR?XUF6145 $FNI(:*I
    MZ=S61I]2`WGS.[#(AMP;`!115U?'O_D=V.D`%A8[=NP`-DPP-[\#C06&!C<W
    M-]QPH!I@J:2HJ(C=JSB>/;FCP*J`X `&DH%,^0P%?6!0.'N1:"%1`9,:
    M6D*']": %2-DPA]R0#:P40/,_! MN#3B!\ "`MBI`>I]__X]G 'L'^$_DQ)>
    M:FCXX/64X%+C=_?OL&E(*4&!S__WS_C[9W/-U]D$9C&>:&YMQ#E8T.=-@,IXN'DP'087QZ5@%- "``302)ED!=:$P$P.
    MJ8N %3NP`W+GSAW($ ;RB2_ QC:P,P*L_X$M"\@HIH2$A(.#`Z0%`=0(U'7O
    MWCW(((6IJ2F1M@.-!79VUJQ9`ZQL@?VL5:M6R<O+`QM-1&H']E!8V-EO;M[\
    M[,R9?;6UAT=S#V"[#4`/90#K>VO7GUI'E1KMJ_<%X)B7_4/B^;C97M]Q64
    MFIR%&=0=^/7J%PLS"]:IDX-7#D+/XV0`[RMA8H344/]>__O]_#?<6/0*@)GA
    MW[M_OU_]1K?]*I9V!%P<EX)10 L`$$##L\B C%]<N7(%6$P`TNK5Z _0(C
    M(R/(31:007XY.3E@SL=`K/#]6+C%_T:=%__S]`VF /WW]^\O? VNPS_
    M,;7C,I8D97!Q(LT9!50!``$T;(L,8%\`V/@'YG;(G(NSL[.LK"RD9P'I, .;
    M"9@:_X&!IJ8F7 38(;]Y\^;W[]^YN+@@1096C?@!L.@!]O8A-PP"'08YC0[H
    M/&#I0TR1\>;Z=6#CXO?7KXQ,3+:5E=RH4P/'^_IN[MDA]I<M0S72)J>1D9M]
    M-%F/`MH!@ `:2D4&L.$`S/_$C+<#6P' O@"PY0_,Y,>/'P=V0XBT`JCRU*E3
    M]O;VD%,GJ054556!!F[<N!%81@!=M7KU:LB4"C%MZ7?QI[/S]BTS.[M-
    M>3G:&.?M;=NNK5WPL8F;F)DT5S'R$63\@_YG<T!9B'CY-Z\SLP6"!L>/@@
    M[WF'[[7':AJN"().@.7L:-;5] `0 `-ZB(#,AH/Z5\`4PP)8]YUQZN) Z)
    M<F"ZL;&Q`>K=LV>/@8&!GIX>9 P5V%6!& M1#U]S!6Q$`!4</'@0,N /+*2
    M'1,%!05.3DY(.H;W=Y ="5G*A6P[6ED`285HYSLP$'</V,DI4SX]>0)4:554
    MA%9>OYV[?S\^<RLK"*:FDXM2PT._86S^9W"(!L;P=F;,@5)TY.3LC+QDF]
    M?W/GS_ ``2&$B3/(]YAU\!#XPFH&G "-70T$ >L3I\^#!0%2">+0KX(&
    M>/3H$<09P/A%OKT9<K\TY'Y9HRNKBZDI?GQXT>@V^SL[$:/%(8#@ #DG;$
    M@S 0AOL$OH-[1QT%'400W'V7/I6#./D`C@Y%F<==>O83WX(DM!NA4S&9,S
    MQ/_Y/3N\M.4@2VP[SL;>+M\95DF#RC9%WX7P5HGMK*)$E0N6F:P %(0BQ0
    M&,?QNBN1*Q<&2Y[GH':>9R5H",,P35/IN=]1KES.)PGGZ7[]NP9^P>@P37,2
    M910Y?'%:X_'\SB@C'M=?X\O/@>_WR[A[5J<T3&;,9Q)8S9-!O\?NVHXIS\
    M+CTWQJSK"O7(_5>_HITCX %&W_=(4^0[VTD(/8YC(608AK9MJZK2J^'NMFUE
    M60(`Y+ J,M2% 62(1KD(!;:8L",EDMY# =!`%5U74=F_[CS\M`/.WH9!
    M&(C"!#%%2J] FR%8!HDM&(6",BMX@%A8EA=(0Y<NGW+Z623,ED4*&S.7[L
    M>^P'_BG?Q=<ST%J9))QT DLATCT#L,`(:CTC*_#(4>NFU>TX%:OY!XJ5W8
    M[P!WS;K!S?N[[%JLI?9/%4J\F.?;LIS:]MSWA?KSOFW7<7SL>]MUEVGZMOIS
    M75<@PZX/!02@80T@0>&`A J,.%1TSK..1J"\(LQPN?TGJ@Q8MZ)6>2.Q(3
    MP-H:>;,#':S\G!,!9Z!,2DDN0WN(/1!?& HY^R]IU05931E"$%V1'<5[=8
    MR$<@#_$#?N&*N["#7'^[/070H&YEX!D:%!$1`58RD.&+7 ? BIO3$U0MJ<
    M!(W%KX#(I@$N[7!Q8H8\077[Z=._OWY5`:L,/:8OM]^\.#!UPB(K0N+_ ,
    M,$,"'^UN=P;4327 4@9Y#ANS/T+,S>_(_3NT;BG:N GR.!=0,=P9P )"2$@(
    M>:<L4"-<%K.CA&8IL0`-C!?5N@[:/WJ@$$T%"=,1$%@'<_&-DMNI>7KJ
    ME$9 `%IY`03KJZ_OGSAE92@WOHC 7X,*%P%V)1X_?@S,P\ R44-#`[D@
    M`&9:8$4-%>/'D"[ /"U=O9V1%97N ?@$V:H"]DK5KURHH* "!J!U:*M(
    MB5\!"&SUG#]_'FV'&["*&KT@'@(``FCTO(Q!7"QJ:8DB#=&A-)I86;7#PNCI
    M&&)N?O_\^3,D9UZY7AZY+/CZ]2M0.S W`DV S'8S4.GF=S@P-S<'%AS
    M/@BDBWKRY$F@F_&W(+"6%SMV[( ,EV 66,G$@,!0 "-%AFC@BZG9B;W^'9
    M#%B@H WZ`-OSD'K[X,&#P/X(9/,[Y3>_XVE[`LLL8%="4E(2<@L\2>6%%K:2
    M>O2"> @`"#1(F,4$-4!P77S.\'A<[1U#1(2$O#-[T3>_([F$B(M0NM8.I%
    MN\H`?WEQ[-BQT0OB(0`@`'M7; (`#,+.\VC!U5L<Q-6Q`4&D4.@!9BMM(8N1
    M@&UV1F7QA5?R.R)N\?D&IBJDH4=8A6GYF].Q?R:3\FX(N#;*T4$,\/
    MS,.M%V .)I,&.*@JF-<2UT4$UN:E%V9&1!L0#QP!V#MW&X!!&(BFI&$)QO&V
    M%-Z EB4H$4/D1=<@$9$!@DN$N*,Y?R3;)\HX]FV;[G+M)7!W3??$SX\Q0@@Q
    M/GVN^^;W:]G\/BO6FN<5\"#Z\IWP$(Q)RSRI_$#L@!,J>LA$-"&U!22J+1
    M6B-G$.PS1012GUBIT6'$9E%(/SSUQ'J/[1;`/:N( 6 $ 3PC?T_]$
    M(-V[I73>@0%9BF4_X!RUIBXC!8/6&.?"/WKO4-V79FC$V'OS7W#T!'YG(441
    M`=6]G1:)#$+P[GZL9-S,>-#=7&/..<;(:[36DI/N810%SE[#`R<'T*MJ1- O
    MDP6+)6.MA2QXRL>5> 30:)$Q"D;!" !``30Z%C&!@%HX $`!! HT7&*!@%
    MHX $`!! H\.?HX PP+_Y'7-[..9F=I0TAVUW//&;W['J8AC=I4XO`!! HT7&
    M*" ,\&Q^?_7J%5 *;2/)F3-G5%55!04%/W[\>/CP8<@%[G"]D-,,D=43O_D=
    MJRT,X%G24Z=.C>Y2IP,`"*#1(F,4$ #X-[??L6F,1M#Q]A2R$I2;F]O9
    MV1E>^0,;"S=NW'CY\B6R8N(WOR.#X\>/7[MV#7Y8AH" `%#OCAT[W-S0DS[@-[\SH&X11NYZP!G :A^``QRN!'RAF#XYG>(
    M($0]Y#9YH*60"^4A&N%:(">MO7GS!EB$P5>%`178V-@`2Q!@J0$L;D:CC'8`
    M((!&BXQ10&8A0L:.,F !\>'#!WBOA-3-[PS@=1F;-V\6%Q>'G)V#/$H"60\"
    M[)M<N' !L$S"J@%``)HM&,R"LCOL#!@W/P.`3]_,!L>@`K?V#3P-O;&UY
    MD+KY'=BC`38B.#@XOGSY<N[<N9\_?UZY<D5.3@[YH%914='17>HT!0`!-%ID
    MC *B`#&;W_$`8'\$J 6M04%J4^7CQX_ #A'R,DU<8'27.NT`0 "-%AFC@(&8
    M[(=K\SO6F]^!I0/R/G%@XV?OGUN;F[(YV(QD[Y'>T,"Z!>'1T=R(P)<ML'
    MUWF+HX J`"" 1HN,44!4!P37YG>"`%A>[-JUR]C86$A("$V*U,WOQ(!CQXX!
    MW4;\&1FC@%0`$$"CPYC@"B :_,[?@`Y!!Q87F ]'8O4S>\$P=&C1U_?@UL
    MSA!Y2NLH( ,`!-!HD3$*" ,\F]!G0O,L4:XJ=/GP+['7A.TX-O?D<;GL"Z
    M^1V/JX#..'CP(+"
    /3T'-VE3E,`$$"CA?$H(#R6H:.C@VM5I9B8&!?&:<;:
    MVMH0]? S? `"PN+Z]>O`_,_\GBJJ@HVL ')D!VU>?/GWEX>$Q-34?+"UH#
    M@ `:W?P^"D;!*" !``30:,=D%(R"44 "``B@T2)C%(R"44 "``@P`)UHP?A(
    /\?_>`````$E%3D2N0F""
    end
    >"D_SDA ".
    options-settings-misc-Xref part format
    Lorenz
