EAGLE User Support (English) Board DRC - Supposed to Generate Errors/Warnings on Unrouted Nets?
  • Replies 18 replies
  • Subscribers 189 subscribers
  • Views 3289 views
I just noticed that I have two unrouted nets on my board layout (i.e.
the ratsnets lines are visible but no copper tracks connect) and the DRC
isn't generating any errors/warning.  Is this correct?  What am I doing
wrong, I've never seen a DRC that wouldn't flag unrouted signals.
Michael
    e14 Contributor over 16 years ago in reply to e14 Contributor
    "Gary Gofstein" <nospam@use.forum.net> wrote in message
    news:i6onrq$sor$1@cheetah.cadsoft.de...
    I would vote for real time flagging of clearance and width issues rather
    than running DRC on small areas.
    That would be very nice.
    And to not lose sight of my main point, DRC report, when there are no
    errors found, should at least mention that RATS has not been run since the
    last change and that some layers were not checked.
    Amen! Good summary.
  • kcadsoft
    kcadsoft over 16 years ago in reply to e14 Contributor
    On 09/14/10 16:24, Michael Sansom wrote:
    If you run a DRC without doing a RATSNEST first, do you run the risk of
    missing spacing violations because the polygons are old and haven't been
    updated?
    No. The polygons are always calculated according to the same parameters
    as used by the DRC. So it doesn't matter whether they are calculated or
    not when the DRC is executed.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    On 9/13/2010 5:19 PM, James Morrison wrote:
    Klaus Schmidinger wrote on Mon, 13 September 2010 03:38
    >> > (i.e.
    >> > the DRC
    >> > doing
    >> If the DRC were to warn about unrouted signals, it would ave to
    >> run a complete RATSNEST (including processing all polygons) every
    >> time the DRC is run. Clearly this is not desirable.
    I'm not sure it's so clear.
    I think that there are actually two usage cases for the DRC:
    a quick test at design test to make sure that the just placed features
    don't create design rule issues
    a complete test a design review time to ensure that the board that is
    manufactured meets the intended design criteria
    There may be more usage cases.
    What I would like to see is the ability to configure the DRC engine to turn
    on and off a bunch of different checks. So for the first case above I
    would care about things like clearances and trace widths, etc but not
    things like off-angle, text and mask clearances, ... And because I do that
    so often it would save me a huge amount of time.
    However, for the second case I definitely want to know if there is a signal
    not routed--that board isn't going to be manufactured to the intention of
    the schematic. And if this takes 3 minutes I don't really care--thorough
    is good in this case. And it should also run the ERC as well since this is
    pertinent information. Think of a board design review--any information
    that you'd want to see there should be in the report.
    Maybe you could pass a DRC configuration name to the command and it would
    run with those settings. Then we could have numerous different levels of
    DRC checking. And there should be a switch to run on all layers no matter
    what is displayed.
    Altium has a similar feature where they have a configuration window where
    you can turn off individual checks in both their online DRC and the batch
    DRC. That's sort of the idea but why not make it more generic so that the
    user can just create a configuration and run it--no need to limit to 2.
    The other big shortcoming of the DRC is that there is no reporting facility
    other than on-screen display. A typical design review process would be to
    attach the DRC report from the CAD tool for a record of any issues that the
    CAD tool had flagged (preferably none). It should show the name of the
    design, the timestamp of when the test was run, and a list of all the
    errors and warnings (approved or otherwise).
    It would be good for the CAM processor to create its own report as well
    since that is as much of the design process as anything else--any error or
    warning there could mean the board won't work too.
    Cheers,
    James.
    the last change and that some layers were not checked.
    e14 Contributor over 16 years ago in reply to kcadsoft
    On 9/14/2010 2:46 AM, Klaus Schmidinger wrote:
    On 09/13/10 22:27, Gary Gofstein wrote:
    >> And why does it need to run RATS anyway, don't you have a running tally
    >> of unrouted nets in the status line? If this<>0 then you have unrouted
    >> signals.
    If the drawing has been modified since the last RATSNEST, airwires
    might have become obsolete or new airwires might be necessary, due
    to modifications to signal polygons.
    Klaus Schmidinger
    updated?
  • kcadsoft
    of unrouted nets in the status line? If this <>0 then you have unrouted
    signals.
    Klaus Schmidinger
    (i.e.
    the DRC
    doing
    what is displayed.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Klaus Schmidinger
    I think it does not need to process the RATS, just warn that changes
    were made and RATS has not been run yet, or that not all layers were
    included in the DRC.
    As discussed before, if there are DRC errors, it doesn't matter, it can
    be skipped. It's just that misleading "No Errors" that is the problem.
    Just one line of output.
    signals.
    Let me add one final thing.
    Clearly you could add a check box to the DRC options that says "Check
    for unrouted nets".  You've got several options for the DRC
    configuration as it stands now and this one would fit nicely under the
    "Misc" tab.  That way your user could decide if checking for unrouted
    nets was something that he wanted to do in the DRC or not.  If a
    customer thought that checking for unrouted nets was slowing down his
    DRC too much, he could uncheck this option and it would work as it does
    now.  However if the customer was accustomed to having the DRC check for
    unrouted nets, this would give him the option to continue to do so in
    Eagle as well.
    -Michael
    Klaus Schmidinger
    You say that Clearly this is not desirable, but I think you are somewhat
    hasty with that declaration.  Clearly other PCB layout packages do check
    for unconnected nets during the DRC.  Also, your engine is pretty fast
    at processing polygons, so I suspect that Eagle doing a RATSNEST during
    a DRC is still probably going to be faster than your competition (I know
    you would be faster than Allegro).
    In the end, I'm fine with doing a RATNEST outside of the DRC, though it
    is not what new Eagle users moving over from other tools are going to
    expect.
    That said, if I were you I'd really think about adding a feature that
    lets you quickly locate unconnected nets on the layout after you run the
    RATNEST command.  I know now that there is a ULP that helps with this,
    but in my opinion this functionality is generally expected to be
    integrated in the software as it ships.  Before I was told that a ULP
    existed for this function I was reduced to turning off all layers except
    the Unrouted layer and turning off grid dots just to see these small
    no connects.
    I like it the way it is.
    It is good to run a RATSNEST to verify that you are done.
    It is also good to be sure that any hidden airwires are accounted for too.
    If this does get added to DRC I would want to be able to skip this check.
    I run DRC periodically while routing and there would be unrouted airwires.
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:i6kmn1$nsi$1@cheetah.cadsoft.de...
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:i6kke9$d83$1@cheetah.cadsoft.de...
    It should say "warning: Ratsnest has not been done. There might be
    airwires."
    This also touches a similar subject (Topic "ERC/DRC rerun?").  I suggested
    some indicator to show that ratsnest is needed.
    So if Eagle knows there has been changes after last ratsnest, it should
    warn in the DRC window. If there are no changes, it should report if there
    are airwires or not.
