EAGLE User Support (English) Net Classes
  • Subscribers 178 subscribers
  • Views 330 views
Net Classes
I use "Net Classes" in my schematic a lot, I miss the possibility to assign
a "Class" to one "Wire" and not the totally "Net". Is there a smart way to
do that.
-If making a power board there can be some wire there must be more heavy
than others in a single net, how to handle that?
Normally I just fix it before or after i use my external auto router.
    Hi Flemming,
    Unfortunately, it's not possible to assign a netclass to just a segment
    of a net in EAGLE. What you could do is treat the width you define in
    the netclass as the minimum for that class. Then you can go in manually
    and thicken up the parts that require it.
    Best Regards,
    Jorge Garcia
  • lbrer
    lbrer over 9 years ago
    Hallo
    ..for this case  i create a part in my menu like this
    ' Rout { class-conform ON : set Option.AutoSetRouteWidthAndDrill 1 ;| \
    class-conform OFF: set Option.AutoSetRouteWidthAndDrill 0 ; \
    may be you can append the "change width" command to define this
    or even several Class-conform OFF and change width options
    best regards
    Hans
