EAGLE User Support (English) Inner layer keepout and DXF import/export support
  • Replies 7 replies
  • Views 1714 views
Former Member over 15 years ago
Two things I would really like to see:
1) Inner layer keepout regions, without usign the hack of placing wires to
   force a keepout region.
2) DXF support.  The dxf.ulp to generate DXFs is very poor.  And the
   dxf2scr import utility really needs work as well.  Interoperability
   with mechanical CAD packages (SolidWorks) for the mechanical aspects
   of a PCB is very important to me.  DXF support should be integral to
   Eagle, and maintained by CadSoft, and not pushed out to a ulp to be
   maintained by the public.
-Chris
Christopher Cole, Cole Design and Development, LLC          cole@coledd.com
Embedded Software Development and Electronic Design       http://coledd.com
Stow, Ohio, USA                                                800-518-2154
  • kcadsoft
    kcadsoft over 15 years ago
    Please post unrelated topics in separate messages.
    What we are planning to do is to give signal polygons a new property
    that makes them "inverted". This means that an "inverted" polygon is
    by itself "invisible" when calculated, but gets subtracted from all
    other polygons.
    Would that be what you need?
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
  • kcadsoft
    What exactly is "poor" about it?
    Klaus Schmidinger
    Former Member over 15 years ago in reply to kcadsoft
    Klaus Schmidinger
    I would love to see a dxf to Eagle ULP.  Have I missed it
    somewhere ?
    It is not easy converting BMP files and having to
    calculate the proper size and then not be able
    to re-size the picture once it is in Eagle  (PCB, mainly)
    boB
    Klaus Schmidinger
    Please see the attached example, with accompanying DXF which was created
    using the dxf.ulp.  I am using v5.10.  Using various DXF viewers, the holes
    are rendered in erroneous positions.
    I have also had problems with arcs being drawn the wrong direction.  It
    almost looks like all arcs are assumed to be drawn in the CW direction.
    In the past, I have exported DXFs from Eagle that contained 90 degree arcs
    at each of the four corners of a PCB.  When importing the DXF into other
    CAD software, some of the 90 degree arcs turn into 270 degree arcs.
    -Chris
    begin 644 led_board.zip
    M4$L#!`H``````!.<8CT````````````````*`!P`;&5D7V)O87)D+U54"0`#
    ME9_03).?T$QU>`L``03H`P``!&4```!02P,$%`````@`U)IB/69#??69"```
    M0A4``!<`'`!L961?8F]A<F0O;&5D7V)O87)D+F)R9%54"0`#/YW03#^=T$QU
    M>`L``03H`P``!&4```"EF&UL',49QV?NQ2_GE_,KL>/$'IL$$N.7N[.=.)5E
    M8VQC2&UCG8.C"&P=SNVE][M7G;W8M(BY515O$@50BV"!412.1#U4^M*%)I
    M52%%J@(ACH&`3;"J2*W:?D!J/D5I4GJ=9W=G9\^V"G$G6L_.;Y_]S_,
    ^SN
    M7*IRA]$O$$+!4&``_?X<7CJWO?%DT](-7IQ->_O##^TI6JH#A%J-H[\)S6
    M()S'3.?-L]!^-V3W9X=J41A7X0!RVB$M8Y_4H@J?SX\YCVM9D\9L[O?[`P6\
    MQ:!0*#0OM?FP6"@T+[/YD5%)87VVQ>7%Q2:_?YB4EOD[?IN7EOH*[0_8
    M/!0JK2/1BQ>5E9<:!^-6KR\/C./F;QBHK@.OL>BU=6%JVS[[5X.%RTSKX/
    M>$L5QJ[](YII:FGSW!U-?9Q/BW)AI/_<$V-X.*Y/+:6ES$^9.J#C/(P.OJ
    M<)CS425-54/15,;K[\/%G)O3*2E)+9V6^^H%3P@>WM8@=,PG=&5>40VP;]@F
    M>$P<.-VC_Z4E*:&K;^]T:,O>AIA\=5DIEX0*SW]'DL1<\O/9QG3+M"
    MF7WSSB)AWBXA02$_8A.)3O/:0E*.P%#[>V^=U\FH\JJF(L6/9MK44N3P@>
    MOG71WGXLMC[[@X=T/>.(]1`W3L7]@MR=>P<,/[BESZ\?\/J49ML)@
    MO?!,K=$H'][:'A'V<Z>ATF3V[7M#PE[P\$,/A=RZ.NGA'1W"GU%=2:6<
    M]>KL%/PQ64M(_"NNSG?)9J\Q;N[A?TDE8RL3JTZB40\EHRRRK4\C\:
    M%3Q.YZA.U21E/!837'YNSCYAO?7DT\0<O+9V/)I"51X^YVB*FOPYJCQV
    MS/,\9@W#J4_?4T]YGD>H<<?^''QGIPYE4YH*:L*Y]^6LS+RQSX,
    (SLL9
    MN"0)_K@ZIW']1$(\U^-917;JIT)&GGQF#9/J=AXN71+K&XM$$NF,S3_\4/@?
    MBT1=_M%'8KUBD9C+U\6<<4B/2[_^&,<%S7Y5>N"#]CD3Z7+RT)/V.1?2Z_
    M>A67"[?Y<ON%3P?I=_\@D."7[`Y9]^BLM<'A7Q?O89+A=<Q'OM&JX07,3[
    M^>>X4G`1[Q=?B/=;"KB75G!58*>%=7<;7@(MXOO\0U@HMXKU_'M8*>_Z
    M"M<)N)=6\/UH^Y\5;<N2/6<90:25W)P'-4<?=NF9N'F<E1]F%09=2$`NB-
    M_!OYQP-'?,T(]@$(032-.80@R[R"9$6S"JX9E:(^97\4;273ST-?]MS&,E
    M3R<OV6G:9CS<U';TN$C\*<MUU/_M;.\T._Y.I__D:0U]W*Y[V<CZ%?9:GR
    M<ACSX!'<[CQTKE\OC)T%(#871P:GAR#'@3<#@</CL
    >08GW>]#N3!V]**
    MD41.?LH]6'O,,4P-;T9E:&J_.7\3=2W(3O'BC(3Y3SS)\*\A.S+MZS_ZC^
    M8<G6AVO<_[8<KO_@O*W?GQ1Q@3VW>_VW^3RL$>=\'/M[/@]KRCD?S4@Y7G
    MXV</(N2UYV/OO)"W@"=OI\^
    $JI55=^M,+J:J];5U$W;[Q=KQ%YX_F!>;]C
    M?MR''+#?CYN%EM^UO$Q]`TW<0&',30OYV/>@'>AH,7;T-LV(KPFSM%ON[<
    MJ%/]L:X,NO>TYM#C:B]&UU[C_=NO+H2;@$T<*3"+B^N_WP;\]'N0N4WX
    M1>#@STOO="-GV*66>8/VTO?_E<)\R?N-.[/X)$`W_VS/O0]Y[VKUO`]O!:"R\8_[JU\K
    M;<OY,-34](P/+8P$$/2W`F%6#W[,Q]"#C<TQYF-^V-S6X0?7&<PA%AE&ZQOP
    MP"9\!UO5-?Q7M,_WMG5Q:E?4M?<AWP9[X'@3#OZ\V^JSZ@?J"-8-WH&@_QOV
    MCWT[+?W9D1&/SN9^C?AD`>[L__T:Y3T*^M.=LXP:XG-56E2?;B1--3K8>G
    M]T<CO3/C(VAT;&:DM6=RDO3MZY:)./QL;$I=.B)B=:W1TDVMU+#H/]R*/Q
    MSEC?P4<Z62W'$7KXS3OQJ@`B8?:"D>F<E$V9I!T-I"1U/BO-4R+3P8'$X-CP
    M^,0881]&95XE\2S;KPYT)P9#`YG!TA"R8PIJ;DRYVV1:=E00Q%E8FAD7FZ
    M>/&=A939063)`$S)W,4_Z"0DL[,T99\`JI)A=9&J<E:=9^<99D;5+C*CI5(F
    M)<J"3@G[64J*B6A!#4T568;6G;G*:S,_NF!2E!U0YBZG1NC@UGF#;H4]TV
    M2BG)!:J&QMC>TZ2IE'./0G62!2\S%*[KJG6/-TYVF6T.28BRR=-$I5EV&VQ(
    M52(EN@:Z"_D#JCZ4D[M`!WV-DNF&U!.DE)@C)Y@YK$U$A2.TGUD$06V=Z5
    MZ&P"2K0Y(F4R""6$4TUNL@1:NSI.FFDLRF))TI@V(H+9VR]61ESOH%8!*=
    MGL@J.H5?"48'K$TFQ7Y,L%60?D")N4!#KZH84CZ2+)S[)]L65))$@1*)V"
    MF9*,:VGEAU0.V3,1W<D4RS.16)(6B<I2Y$T/RPC[!CTWVUOS#[;?_+8#/@[P
    MV*TZ>[N;Q>A@(W&\C:$!E[@#\Z-(;M?ON?>NWGQ]C"?M[_M^SSGN9X.,3]
    M`YO;[E[R?[4;0Z`%'WIW`P4AP2L9XPI9/LY&_\]QYGL(K;%?&\O%]]Z?>7_M
    M/Q,5YWVF[T:!I#[:K#\;AVA+WZ7#]
    JO7KYU)OT.Z%B;.[P%@53I5>0
    M^8@L'/EA!#P;T'@E?K7L2L0V(`T/F?"X'@%@0BSQ\3`D5;$#@1C`N!XBT(
    MQ/]R`<%_;\+XOU!+`P04````"`#FFF(]U$C<\/(2```AM0``%P`<`&QE9%]B
    M;V%R9"]L961?8F]A<F0N9'AF550)``-@G=!,8)W03'5X"P`!!.@#```$90``
    M`.V=2W,<-Y+'[_P4.NQ5#KP?1YKB[#"6)C4BY;#ONX>)F)CY_K>MJ@:R,KLK
    M@<SR2'9,V!>K2?Q_A4XD\@%6=7_X8.[>'A_>GUY?[CY\<'=_?;S_]/AE^6>]
    M^Z_[A_M//V\O[-W]@S6F7G[^EZ?GYY]>/SW>?<CFSEQ^]OC+^T]/"\*:NX_F
    M!VMB<?GN@R.O_#Z![/]MXON?]E$=AV5?-DTYH=D8O;N6FN'E\^+;/=_HEG
    M_7[_X_/CV_;C[9_;#Y_??_U\F:/=?M->+[]Y>'UY?WKY^OKU;?MU"LM/_=W;
    MO_[Q]__]\(___/_EIZNQ27__GU_87N]RNON"OW/_ZVJCA>-BO%SH\I/E
    M=Q;XR=VYY?U\2.3B='#"HVV.D^$9#R\S>%&-KGAT]./1RXJAT7DRF-IDRG:Z
    MX5XSE:`9''432;KA63>\Z(97U7!O=,-U^IU^J]QA5]4(W6K:G7K:G7K:G7
    MK:FOFM@2C"JV!%7@"DX']YI0%(*$&WI('&W-5,P^&Z)0VZ)0VZ;1IUVS3J
    MMFE4!EZC\S!GK,8G'&JA7&:SS8&>IE=OINHR;../,!N;SZ;OECC:U/3$
    MSV9SL61APVPT658[&TU6-<U&TS6=C59E=WL5-Z8S3\KQ63F^*,=7W7AG!.-1
    MO<L4WC\^OS[\SV7P]L_E7V4KEMW=EV487,/B.M[A%[3"]TVV7N;U^>E3YUW:
    MBK@#T"M"6/P/C;-DG,7C'`$ZI/(.C_.8AU]X?].:_/B\&#6()?'D_88U,M
    MM(>GP];Q]'M(=&OG0M,6#'UX?W_]??E\8J*?GI!>:;TAH+
    M-.&%WC5H)=;VMWQU]&WK'$4&MNFLZI4B?L8QVV\U1X7G=NHJ=-0R;*[;BY
    M:0;*M\>_3Z)''JH6]_WK_Y?&,@X+R/S&X?'G]OIC%6Z\N%F/N7EZ_/
    M7]_.S'67?K?9OO_U\<M/]\]G9KMU]2@F';(#Z7U,^[0N3<#899/,Q2][BB
    M[P,O@:(A;N$PS.(93>EHZA_YN7\DD_\HGOU',OV/_/P_DC?`SU:]7XG_5^
    M_C/K_9GUOGG6..@H/R/S7IGK-*%WSOKG9GK+OW>6>_,;'?IGUGOCY7UF!;
    M1G+
    M_#;ZT\O;4EML_/7<$5W!V'N:!$NY6.TH:;EA<,O/-H7T?SAKKO^J?T=2N^
    M;E5=UYOO>%V4Q$.07VQ[86->_ZPT7ZWX.WG)][CND9>(K_MO]I)O=MTC+Q%<
    M[,I]D@5NZ<%MS-L6;],_A!E.W#UA<V7E[P<?"8WF6W]!3-^C<4;W)O3L
    M4JE`KRE5$;W#)9-Z-7XY/3TIM8IB/TC+"5973RV7DA5XN;2H2_1+-:JF
    M@VP\=TJ7PR9.LST9:\WA$DI.>C5365]4AL=Q@VI^/=-*`3CW1M>71S!]F$
    M[F??DSW,G_W,Y_)A_[N>7_[&(MO<MF=+R;Y);!'CE8U3[LXC.S*,;0V2A6
    M8S8GZ%VFHHO]G=*%EI'28[`YF.FJ1FO-@=QI<`3$.W%R_6TKOLENZ2KT$=
    M"4`VC@31!Y.RGMYE$WI?'J5ERKREL%TN;\3.N_OQ#(C\26X?U]RTWZ[`&R
    M&1UYI-PRR7B[WE@U\7<8MJVJR7Z]_T][[);NBTAZ2,!R,:62=X7:_5S[[)
    MW`F=B3,')T.N_=;A%]<G0Y,N;<YH74NYO'#XQ6_H#K_'=8Z0EU4T+7[2]^
    M0W?XS:Y[U!TG;I#BOON\NFVQE\K;^XM7'`FR<<P@=/FN)G/G=_52W._U
    MK()>6X,PH:=3M0G()O2NQ1Q!B9S'ZPJH8OK64IGWU;3]55()OX3$85IX*>
    M4<4YH.-5E5O&)6/-O$N!8;H\0^ELGG$YAJ#W=Y"-/=)5DVO4S[W+)G,G='F.
    M--0.,]5<\:WR9'?X[I'.5)ZW7]WCOQFUSWD837-DEIULY',G&UEVLI'/
    MG6QDV<E&/G>RD<GI+V\9>AHF[3@R/0WC>C%B&7F\(Y;AXQU9504=K^J`GDEM
    M(K8,/85D4-.\L0=-O5WML->,BFJ">5TV6E8B0#B_V=G/ZR_E[PZ:]\54$V
    MGCNAR=>?#!Y7OG`,.7<,7TP]Z4*OJ3#9!-Z"GDI(\$(!O[.Z'+HQBA\U&,
    M6$:QJM@RPE555#ZY_?9RAU5[,;]OI29[#K3K=X&/N>X>Z((**G_&='2`S6'9+=X@O>EKISM$YV(2?FGF1S3?FGH1SEZSJI":NTR66
    MWU5@RQ_ORD?UN/C*@CL"L?5>3?\,I'-;G@<I>:7'SOR_F=_GRH?WO_QN
    MWO(-KWQX#XS:6V[O"4CXI-`5]OS?H3[%.^G]#(0.LEMZ0)V$@AY0)S&@XU-.
    M[Z1WJ8#,8-F$;F:U_C'=<)T$L8RKLS.E0\N`;+RJ"CH^NQ[0L67`M>9T?/[K
    M+7="FPJZ!T;A,P7=83/P&4P_.??!;LGRW-Z/EQ5Q])SR1I-4[IB;4,\9D@
    M[6UIG`FLOQ.?D=.)W?FY$[O++8-/]<5T:8]U16?C##YW=T[\MVEB&<?UAU=T
    M\5F.19TS3X=A.LM0.FN9[-#]#/)5!=EX5;-'O:V"[E%O.Z`'U)<K+!-07SZP
    M#*&?8;2^54EEI'[#$,&\7HJLKI9%5Y.O%(N66$_JY:U=Y$UI3W$!G:BULX
    M#-MXWM4Z"I&'<%#=P/MO='!0*>#P!E5PH5G$\&+6;AW2DB_K9[@='?:T8=N"
    M+B_6@V$=]6MM]08JM/"0:6!]S>H@[-FR:6FZ@'NJAW5CP#OH-5!W"__RG8
    M?LN2S81J`Q6W<S,@6(73XG_$64!FL.H!;OR?3Y9]Q%%QV>%,9KJ%IQ3V
    MF;N2DFA!N\I@U0'<00V=TM?(IIY5QFLNH7'ZO;ZR"YUGLCF766PZ@"9!5P
    M16N\$;EB5QFL.H`GFRS:H:+8`BJ#58<[-#LUO*L4<-MVM0X.JK%9Y'!LEA$<
    M:AM(4.WH*`:NZ)M(4/GBJ`:;R;0H9N$X%JO/UM"QFZ[0^J<>"R3:,+7*`:
    MAUS;WJTNY()JG"QL6R==L@#5.,W9YF&Z-`>J<8*V;6_H$C2H)O"VJY7PKAH7
    M16(X8JD<E9)PU2VF17K>@H!HO:&DY2N>H!J[8FG95;>)0#7>1*75!;KM
    M#ZKQ]B^MHM$%E"-`U=IM9@NY()J'')JR)UR0)4XV116OVK2W.@&J>YTBIW
    M78(&U3A!E]9S.%=I8"BR("YXLB8A8Y')ME!$<BY$R8+RA2AQ17$)35R1
    MZ'))A(7_V03\<4_V?[BMH5L?[YM(8%W'"1P,4W7"3DBEM%$G+Y5I$D"W&3
    M2Y(%W^22-"=NSTF:X]MS>B0B/5APIMJXSSPR)T6VFA+VWC_*CJ%`-8%G7\/N
    M+:6`A>H#%;=PI,U!@72R9*TARH#%;=PK>[AR!P74PYAW<57H`)O)M2!P?5
    MV"S=E#JS@&J\H%VC6U!0C5VQOUN=*X+J!@[;004GFV@`;WZD,PNHQF9Q/MC=
    M+*F:.OKD,(!WE<&J&WCP:?M-]_-0)'!0&:RZA2]30,>MV47)]@>5P:I;>"QQ
    MW_YB>%=-X#DX5%KX[6\,<WA7&:RZA9>U+X#`%;.H)P5P:I;>'4Y@%F:>?P
    MKC)8-8$W4RKA734Q2S.ETBQ=-5G0IE$N:%=-7+&]6Z4K=M5D$XGA9!/Q\.9'
    M2K-TU<0L;NFN\9T=0=(J@LI@U6U4M#6YO6ZQ8I";E<9K!HG"W%1%&6;)[:
    M1%&VB>*I311EFVA9=;?W1,4M>5T"[RJ#5;?PX/:9^VI<%MF\JPQ6'<%WF_LJ
    MC(J@,E@UA@<C75`,!]4MW,%#4ZZH!XM*ANX0Y%Q>"%VQ]4!JMNX09%Q1"$
    M@0M4!JL.,A&BF(XJ";PC*BV"R@&ILE)+_?L2!>4%"-%S3$2T6C5P:H#/\_H%I18MX\_$?AY
    M1G?^=-41?>Y/%D89/-!LB!P::U(X7R:LQ[?$25<4%"-J]Q(ZA9I?1Y)W<6
    MY_%4VQ)E;4L\U;9$6=L23[4M4=:VQ%-M2Y2U?%4V[D^YW9&&8>`[#E'1
    M%5$'3>%==0,O-5M;M'!0:>#]#>K@K%E*3;E:/;RI9G"S1'[(H76[55``;RJ#
    M5;?P$GR$!?59YN>@,EAU"
    E!<BA/LA.YT!EL.H`[D/<2PMKLNC\O*L,5MW"
    M4ZD6;.Z6YD9T"MU5!JL.X''OB=:`(6JX0&6PZ@".BO]@XV9*`1P5_Z`Z@!L7
    M`6YJ]";=Y7!JEOX$KE0Q>6WKVF<P[O8-4,?HE'6GA3'<66_>A/#N\J!=RW
    M>2#@VIL%CD<FT4,OP0[+;RIQJ[H6[#3N2HQIO(MV"GVT2@&F]_WX*=;ON#
    M:ARX?`MVNL`%JG'(]4VC"[F@&B<W]ZMEF`:ISF?%LG79H#U3A!^^9AN@0-
    MJG%IX=O>T)46H!H710HXHJD\!:/E/"N&A>B8C@I15PJ5DHG#5+;3E*"V^J
    M&?R2776N"JQ]96%^@V$:C&FZBVBD:W_4$UWOZUU6*ZP`6J<>"JK8K4A5Q0
    MC4-N;?6OEF`:IPLJD?G>(T!ZIQFJNMY]`E:%"-$W1MW9*NM`#5N2X@@N
    MHBLX5Q35UJ$JX5VE@(L40G"U%B%CD<FT4,%Q;_5W"N^">N*&Y;B"OR;0O9
    M1.&BVPBON$BVU_<I+MS[>*)'")FUP2N/@FEX1<<7M.0B[?GI-D(3Y8(,F"
    M/U@@:4Y\)$+2''\D0AT#"')&C,(>4%N)C%):2(_I'#ZE&7['*D#.'D
    MM`_3P=E/,*PV><C'<.3#)Y.P=GO&Z/PV7>E'<.#%Y.P:L,7L_`K1'!89@.
    M;F5P>PKN9'!W"LYLQZ%S[ZW[Q@NVZ'VU`ZULAUJ3U0R^Y0F]/V+'N[ZT\(
    M7_L4;Z;P7&S<G_B3PNG#2BR</D\DA1=;EFIE"J<V/Q6X+!NX;`HUP&V<TL#E
    M?$F0H'EX3AD]VR%4YNS<&IS;QXAYZRE,5S,9S:G(WGBR.BY^:D\=P5;',6
    MOI0S97_Z3`JG-F?AU.92>/'5[I]KTMS8CBU.9OF[%M[O="2].<)W[.PM?G
    M@KW5PJ\>A)397`I?'_E!ST'+;'XJQ]N'>W^0Z'85.;8S_GX5</MDO-0I_A
    M$IE%#=F8>N6S17W3RH0PD.UH<I/"[=4BQ:>)3!-S^/6CC]N`\63A_YD<(W
    M/X]3.%W04[6B8VO%9PWX*C^MCC%XCSXFBRLU<I@K)PNJ!2
    M.$D6/)PNZGZG/_FZZTHVA_$R]HKL5,X7'I)JS3PJ,,OE5<20NG"\K"Z8)*
    MX5O%-9\Y7=!3/9%C>ZULX`C$2?MB1:;[-^-QL.CR24;+3SX&O;4M4SO_J$
    M)=F"2N%;VSW.5W04WWHX3<O;W"7[-XJ3K\]'BTH?J!@L#X!E3Y@DK@U"RG
    M.FC'MHK>8K-(6\7-S^?PQ2P)O@-0#(\R.#7+J2;7L=V<)]XB[>:V>!ZF\&B"
    MA)?#(\R.#7+J3[4L0U7(-XB;;C6N@6KXJ'+YZ]?QR?&!YE<&J64ZVB8WNB
    M]0\.>SR7]D1;?6[F\(HWD10><TQ[E2OKYL1P8A9O^)DC/X=A\YF[BVH,)S,7
    MPG,V>(_5.2*7MX3%0F<SOQ49'9*G=QQ-U;O+CX3\A;>#B=^:D2VK/E7"C8
    M6\15;L>(JL5Q7`Z<[9N6>(;\A9Q.1>!$YG?JHHXK]>)&3L+>*Z)6)OD=4M
    M8CB=.9O]0\;>(BXM(O86_G"^NOW3>,5P>GL;7[>0.]"D\/7;%MU\YM3FIXHB
    MSY86(:&#!2N6T*1P,L2]B&'BN'4YGQ11&PNA2_E?X<]`!.;'ZJXO)\Q950
    M[^_%15'`.Y0_G$\!W=TJ/IPG-N<K+F)S*;SZ&/U\YM3FI\HYSU=<$;7G7EQQ
    M!1Q;^,/Y9()Q6OC5K;,RFTOAU==8YS.G-C]5_)?`7;U3[O(1<^&DX,IS;GZW-B<RE\"[EU#B<V/U7\
    M![[X7TN4%(L<U1[\#M](B:.'4YGQG06PNA6^EA9O#B<U/M2UAT:@4XL@
    M;ELL.K7@X6L)O8=<\4'QU3.Y(IM+X6L);=P<3FQ^JN'BOW&1PD_U1$%6_`=Y
    M3W3YW?2(VR"X$<[7\(G?SWOEA@><3^^?'I[?C
    _4O=_\/4$L#!!0````(
    M`-2:8CW1G<%MF`X``#PJ```7`!P`;&5D7V)O87)D+VQE9%]B;V%R9"YS8VA5
    M5`D``S=T$P_G=!,=7@+``$$Z`,```1E````[5I[<%35&3]W'WE#-H%!"19
    M`B&\N;N;A*@4"4D(T"1D-KPZ(GDNDIJ7R4:QMNYV$9*B"<IM)"&4TY,DGX/KM'0]F_[Z]]Y^(XLDJYY-!<QKO7=/>(FB[@=
    M#J>&>B[/Q(."-SI=HL>%#@I?+JE\L<#?[QH7"#PA(<FJ7RKPQ,0DJ_Y2
    M@2<E.:SZ90)/3G98]6\5>$I*HE7?KW,\-371JN_W<SPMS6W3#W!\TB2W33_(
    M\<F3$VSZQ1Q/3T^PZ9<`GN_1-%-_97<DTMW)[4S/R-`<B-<WM_49_D_/S)3X
    MQO9F$\_TA(0W]#5"SVT`9Z=K:4C7MG>&>[J:^_N8KAWBI:(>2^H[DUS'GR
    MIW@EWB+Q]*DYDB>RKK?][O:N/M#/F2KQ%HFGYTY3^.N:.\-]@G]:KL(O\?3I
    MMRCZ&YL[N$IG_=$5?XJDS\IQ2OR$B(C2+3,;D2#U)>[,][FD?D5ON%GX
    M.<N7[Y;Z$G?.+'":_HRL:N]J[]O.]0MF)IAXB\2=LV8K_-7,3-%OUNQ9"K_$
    M$POG.-='Z"'SJG$)EO!)/9J;:L9/Y)OA<`;81COW)4,WY:))XZ;WZ*
    MU`\QGM[VU@C3GS\O1>I/'7!@A0SKNZ3N'/A0FE/96][1X>8^>B11)?W=W!
    MIQ'&M7BQYD2\EJFW=]W-\25I'YMNFOOS?,XT37%?[NUGX6H6!_NM\O\5!X
    M6[@WW-4:9CR!@,3;=FP3-TP_6SX$X@$GE\<5/PI\?0[[Y3KJ"X<,=?1EBW
    M>NSOZS/BTWG77<IZA!@W]+=NE7FRX8'.ENX.'I_IC8VR7PQSP)N:)([A#'AS
    ML\37=&WK1OZ6%KFNJ_O;VXSXT=J(XL_ODBX5@?/BSG-Z#K+9T]`C]R1-H?
    MT/TF_N:;<KX">L#$WWICBN@!TW\Z%'-?%B$S]V3-H9T$M,?&!`VAG02TW\
    M'$M2>)+3?S$"2U9XF4F_O;;6HK$;S7QDR>U5!/WR_&\XZ6)G$YWE.GM$D2
    ME,]?5J;'$YWC-G9'X.5XSY[5/!*7XQT<U#(D+L?[[KM:IL3E>-][3\N2
    MN!SO^^]KV1*7X_W@`\UKX@%SO-KPL)S'RG!?:V][#ZPC[=JU5-,/#;65;&/H
    M:B/9,8U,8V%2R$!CEJ-)3N35\8JV:Y'ZNM\FJ7^O7BANH_N76`CP]>MJ
    M?"6%"WW)<630K.]"M6A18%2M:N7%2\5`\1@R>:QSB)<GECA$`TP,BFLD];
    M>S</ZD,A^C!R$5\;.3V?>P9*BIJF3_ES)<(Y8K&F1]+8ME9)(X%^@[K)!>
    MJ@?)]?07Q>2]@_54/=O/[W-BX.OQ=LY@E=1'8S^F!=I1Q4I"%C+]W;=2"O<[
    M2;G)"7C/G\2]DU28>$&,;"UK)00_<%UV21PN:`_OI11QN(?/]?3Q.U4?.51]
    ME)$/<;3?KH_\.`Z!![?6#U+JN5]A[BJ>@IR3/('`KZNVY7]<E6E*&5^I)G
    MU8>4/O/2>/V!'$(0]\>T1K`;QC"0XV-/+J\KKZTR\<UGQA#?6%ZSH2J7S<L4
    M/N?6<TCR607W44/D9\9WP3JX?_Y+*HDT48[X7A$RB%>(0UZ+Q@K
    M`MJY%RA]T&'%LR]3JN(H0PN4G&0\3G`V;AR<7YMXYV.\ZJ.%_NU\215'*2
    M'J`"7-F]#:VLOAR`3\7;3Y-Z1GFI/WS"8%VC(_480RM/,_I53@SB*4X3F)
    M:T4H(Q_@<V)DEO\*I8U#E!YGB>+I='-=>%.N4?KQ9#&OT!K]>D'.X)2!Y:
    MP,$/Q7C%&+QLFN?Q0`=[QIXMP/"V)$"_Q=S./'D\$;I!Z6/.`03Q8\(/(8
    MY$W,69WM?7PU0!YS$ID?$%\ZE]%UT)J(T1U541";./XX_#.8-5?//7DA
    M,7\;WTRBC2QPGJ)C9VCGI]>H-`.-669ZPCEF)9/+@A0PO/J3CR()YKLQ_M
    M`?`(;"C1MF'U7KM?9'N7O!/IF(_XN`?#]&4/!J:B!Q\[Q>K`>NF[=!/\D*
    M\87Z-?:%U0TEH3Z3BLTX3Y2*O8OJST;)[;';85T5JQ-J)]@A58W'5](OU$
    MZ27Z24WM0]"%66?QQDDC>P>.T![M+4<%[-HW0>=8FF9..X).\72XM=$^P[
    MUZF%'(XBC#FM_QNMR_4(9G5'V47V8+3M5'N6F=51_EZVSZCX(PO8#]\=
    M+-A'E/S3!#A\#-S<=QYB$L8NA/R\!%ZB,XGK:,W@-Y&,?Y'U9RG]A.7'
    M%<2`BWF892AO65(YF&4X3F):T4H(]-\G#"**6P5PP[Q)X1%3Q>D&%/@N^A
    M!1SR,.S3RSX>GX<!WWQJ?!Y>^)F8J_.IGTQBX<1#!?!31MEKX#Q4\L@T\KWA
    M`Z,[W6L=)/H@\P]?OFS_=9!7`]<X3ULN?XSS`%YS3*Q(`^<\8.=7B93"GCV0
    M8[43\/'[)O'N'7"2G@RVS[-V2YF#7'$*_Z",'\3;_"-T]\4Q"M]#J^HC#GPJ
    M#C)PJ#CP?B&,_=GW5GKDLWMH2G>3TQJ)9=K743VF??&*4J/\CX01SN
    M05_%@7_OE1&:M'6,VOB#/4M&Z"ZV.1SZ_C!O#9X@RM#N8/6.BH.\:\&(!=]]
    MPDE`7O&0FZ@XRM"J_"CO..4T<1;G"\Y/9W:/T9S/F'F"TR&N#G"AQ<!GQH
    MC</$0=]S8)3Z/ASESXDX5.NEE_Y?+Q%KO03L=?/&TG<ME8I/JYX`9GX8
    MU,30BGJ8>%&&,8$-B,,XP6;$4<9_'JHPP^4_51'C2.ZXBCC/;>3!V>QQ+:
    M:7J$SB;XH-O^YP?<BG8!D6VJCA!Y2AA;&H.,CPG(JCC'R8GQ>SF(+/99?5
    M3L`@1QNXD?<<1?/_0>E%ME&=88=X:-&W(,;>:_L5^M"&5X3N*D"&7D`QSB
    M)<K,8]]"7T)&``GS=<8!&_L\E55>7C/PNX6TGB?Z!YW]6_O`\_B>JW'S
    M?1N43'9\W_D&C<_`_X^/SO#`Y=%OEJQ9JK2AYS!E&&5N8E@8.<].6P!?<D
    MBWQUZ$`"47&4H57Y33E-S6\.]@#.0OXH,7X1!Q:R%DJ#CH2]SA1=G*HWE1
    MAC;VO-/D1QGX5!QE[-_>]^XXC%'I`YGX*CK-K)\/Q80I[B4]W$]@>$Z(
    M$;)]_2C=O(CQ;R#F!?B>%QPD'@[ZT\R_\31M.0QPZR//8O$F$!^SGD>2B?
    M>?Q`7A+Q8UU'@-OC9TYL:-;4$9&W/W6J>5OW>JZ(?#64J.8E/\<A_P".>0G6
    M!:Q1>'8PZ_491,G#!PL$IXGSNE$ONN/E/Y)B$_O(T0:(=%OT4H0UOY$:4J
    M#C(\I(H(]PX1\/
    ]0G/<D6,_;\SS6S6J>__KO,8AW1;/UO(!Q"^^.X,(Z
    M'>,]1[_M9@WQ%$&'\/<(8XRS(FJC_WV9%'U4=9[1?/Q7#&8RYC.<_'S^GV
    M<W$T1>#B7*R__1S?\9[_YGMX\_2;PKWCFWJGSCMR;2MYUS@WKYINJ)]&WG
    MW.+@#?1MYUQ_Z0WT;>?<@%Z[IF8B?=LYM_A&K;W!M'I$_ASHG,Q,&ZU?4
    M71%D-M<C7N)D[_?Z)>ONWAY'[=`OR;EHN>AOTK/)[BF`EN"S\UUO7"\9
    MS[)?C7V&)F'_!5V_J'$<Y`Y>-X#?N!0>$QP.`L9=_A[Y%YTG&CO_%2=D
    M7.D?R`-0:]KK)<!7_ME:PG_%#_+$##79HPXQ[;?YV>(?Y3VVR7^!S>_M
    M!'[BFX%_@6Q-K.#"\E0$3I,WF?`/M!UR\][?RGZ=[&7\.\FW\P]F005L
    MY1?GB/'
    (EK7R%F/RX7]C]`[@]/J<UL7V)#M/D
    MY6_,P5_98$67G7<1R*":1O@/58'%)3XXCC;F3U?,B)?V83"G\9DZ:1D4NE
    M>7[2=.Z05D9',VR_7`7U\'_Q?O)XV`@[[`Q87Z<U_/,O#JH8'RGC>9CW
    MNP'VX^AOQ#K58\1\#\O[Q;&?=S,/L6<TPG]HUZJ<US?[N)VKEZ:?1=&AG]
    M0D]#>P!7[2DQ[(D\DQ'7SJ,[/`8./_%)?-^D#,MXR\X[B$O8OQ;L\0>XVY@]
    M&K?_Y>],,>S7R.71Y`3HUW-['JEY<8JE7Y4'-OSJNDJB\FS_A2<NC^L#CX4G
    M_["T"@[4L38/W;5&7G8M]I)OJ&,R_Y%I@_HLUC?U$^)-8\"U.'C!_N"=
    MX.?71C.YOYN*LOE[K_S#;DN_&RLJC'Y=I#G_%>\EWT-3XO%KU^%?\:J7\X/_
    M@!_T7=?1?ZU-%G5M]N#_A3V_-QSR1>Q;&3HAO9`_Z'=K`GP[3'/8$]J`\M
    MZ&=E/I'[`/RO*JP;DEAP+"BL)0,MZ(M1"LK?65E);5U?JJ0U55=:2FJKRR
    MJI(L:UD>JFI8T[!76C9DI;E9%6(K>]&?EFOVZYM^N5ARI8Y-9WWQ_N]86,
    MMZ>$GW3LI[E*97M\-<L+8M]H09?17=G3W<7_(W)_X2AHKRO&(-4K1V=W6%
    M6]ESREW=NE!M>0W1%P<VLT_CFKJX6O[Z1;P@8S>-O-*"&UY"P0VOC43%TUA?
    M7BEJ&7ZGT*K>(5\^>K&AT$5\R]@DM86W-?=WB`)@9D7X$?)?7I\?>^$'E_=T
    M/@L
    ,=Y?/:_D%'\G%B$CAN@F#&V7LE@?,F"![S/JZ9!*Z;(CCJ1])`O=-
    M$.C?W2()$FZ"X%YW2!(DW@1!Z*_/$?@3Y#_`U!`0(>`PH``````!.<8CT`
    M```````````````*`!@`````````$`#X00````!L961?8F]A<F0O550%``.5
    MG]!,=7@+``$$Z`,```1E````4$L!`AX#%`````@`U)IB/69#??69"```0A4`
    M`!<`&````````````+"!1````&QE9%]B;V%R9"]L961?8F]A<F0N8G)D550%
    M``,_G=!,=7@+``$$Z`,```1E````4$L!`AX#%`````@`YIIB/=1(W/#R$@``
    M(;4``!<`&````````0```"!@D``&QE9%]B;V%R9"]L961?8F]A<F0N9'AF
    M550%``-@G=!,=7@+``$$Z`,```1E````4$L!`AX#%`````@`U)IB/=&=P6V8
    M#@``/"H``!<`&````````````+"!<1P``&QE9%]B;V%R9"]L961?8F]A<F0N
    M<V-H550%``,_G=!,=7@+``$$Z`,```1E````4$L%!@`````$``0`9P$``%HK
    end
    Former Member over 15 years ago in reply to Former Member
    >> Klaus Schmidinger
    somewhere ?
    boB
    Look for dxf2scr in the miscellaneous files section at Cadsoft.  It works
    well for some DXFs.  Rounding errors from imperial-to-metric conversions
    cause some problems where some line segments don't quite match up properly.
    For this reason, I typically import a DXF into a reference layer, and then
    I re-draw the artwork into another layer.
    It is a really painful process that takes several iterations to get right
    (scaling, unit conversions, etc).  It would be really nice if Eagle could
    import and export DXFs natively.
    -Chris
  • CSWalt
    CSWalt over 15 years ago in reply to Former Member
    Hello Chris,
    I examined your example.
    I used the viewer 'dxfviewer' on Linux to check the dxf file and attached it as screenshot.
    I don't see what's wrong here.
    Did you use the original ULP version from 5.10 ? I cannot reproduce it exactly.
    I your file there's a white border around it in my case not.
    But that's not relevant anyway.
    2nd problem (concerning arcs):
    I drawed a wire with 90° arcs, exported it and looked at the output with dxfviewer.
    I don't see any errors. Probably this gets imported wrong into the other CAD system.
    If you can you tell more specific what's wrong it would be helpful.
    I'm not saying that the ULP is completely error free image
    Walter Spermann
    >> Klaus Schmidinger
    -Chris
    Walter Spermann                         Phone: +49-8635-6989-10
    Pleidolfweg 15                          Email:   wsp@cadsoft.de
    Putting in my 5 cents... I agree with Chris that a certain level of compatibility with mechanical CAD packages is a must. I have been using Eagle for 15 years and I must say it's a wonderful piece of software but that's one of the features I really miss.
    When I have to import a board or package outline in most cases I just end up drawing everything once again manually in Eagle, which is a time consuming task, especially with more complicated outlines. Any other method I have tried when importing dxf to Eagle, from different ULPs to even some executables that can be found, has left me utterly frustrated. It either does not work, or requires that much of repairing (of soure dxf or imported results) it doesn't make much sense. I really think such an important feature should be an integral part of Eagle. I would like to be able to do something like File-->Import DXF / Select Layer / OK - at least in board and library (package) editor.
