EAGLE User Support (English) Eagle 7.5.0 New and annoying popup
  • Views 399 views
The new popup which appears on every startup (freeware) is very annoying and cannot be turned off directly because the cross in the top corner isn't available until i have switched tabs (due to graphical bug?).
At least add the option to "do not show this on startup". Very few users (any?) like popups on startup so i don't understand why you have chosen to add it in the first place.
Secondary why does it cover the project description in the Control Panel? That's relevant information as well.
I don't see the point of this popup at all, the user gets reminded anyway when trying to do stuff that's limited to freeware version only.
// Regards Rikard
  • e5frog
    e5frog over 10 years ago
    It really is annoying, and I guess it's a planned annoyance so you'll have to buy (or hack) the program to get rid of it. It's sad to see this pop up in EagleCAD as well - I hate it too so I'll stay with 7.4.0 for now, I don't know if there are any direct benefits with 7.5.0.
    There's already limitations in the Light version so I don't see the meaning of the time delayed splash. If one need to make professional multilayer cards of "normal" size you have to register or use some other program, KiCAD, DipTrace or whatever.
    Perhaps some boss-person decided they need to sell more registrations, if it doesn't work maybe they'll let it pop up every ten minutes while working... or other worse things.
    It really sucks.
