EAGLE User Support (English) How do I do a custom part list?
  • Subscribers 178 subscribers
  • Views 1455 views
Former Member over 15 years ago
I want to generate a part list that shows an attribute I have added to my
parts.
I'd like to store a part number with every part.  I don't necessarily want
that shown on the schematic or the place layers.  I used to use the "value"
field, but that gets shown and some parts don't let me enter a value, so I
started adding an attribute (i.e. "DIGIKEY") to all the parts in my
schematic.  Now it's time to do a parts list, and I'd like this attribute
displayed as a column in my parts list.
How do I do this easily?
If there's not an easy way to do this, is there a way to export the
schematic as text that I can postprocess outside of Eagle?
    AdamWozniak wrote on Sat, 17 July 2010 12:37
    my parts.
    want that shown on the schematic or the place layers.
    You can create your own attributes that can be shown or not on the
    schematic as you want.  Look up the ATTRIBUTE command.
    Former Member over 15 years ago in reply to Former Member
    Olin wrote on Sat, 17 July 2010 13:46
    Please read my entire post.  I know how to make attributes.  This would be
    obvious if you had read the post.  I want to know how to display those
    attributes in a column when I make my parts list.
    Am 17.07.2010 18:37, schrieb Adam Wozniak:
    parts.
    Try this ULP from the Cadsoft download area:
    ftp://ftp.cadsoft.de/eagle/userfiles/ulp/bom_with_attributes.zip
    parts.
    Have you tried "run bom".   When the BOM dialog appears click on the
    "New" button which calls up another dialog where you can enter a set of
    headers for the columns that you want in your custom BOM.   You can add
    pretty much anything (Manufacturer, Man. PN,  Vendor,  Vendor PN,  Unit
    Cost,  URL to datasheet for the part)...etc.    After defining these
    columns in your BOM you can then go through part by part and fill in the
    data.   When done save the database file so you can (re)load it later.
    You can print the generated BOM as text or html (the text is pretty easy
      also to import into spreadsheet).
    Jim
    Alexander Horst wrote on Sat, 17 July 2010 19:19
    That's exactly what I wanted.  Thank you so much.
