EAGLE User Support (English) Text in a Polygon
  • Subscribers 178 subscribers
  • Views 894 views
Text in a Polygon
Former Member over 15 years ago
I'm using a polygon to provide a ground plane around my circuit.  I have
some text in the ground plane area, and I would like to etch the characters
into the copper, rather than etching a bubble around the letters.  Can I do
this?
Jeff
    "Jeff Kincaid" <jeff.kincaid@eeontheweb.com> wrote in message
    news:i2l9go$qq4$1@cheetah.cadsoft.de...
    characters
    do
    this?
    Jeff
    Jeff
    For text on the Top layer, write that text into the tRestrict layer, when
    you pour the polygon it won't pour where you have the text.
    The "isolate" setting for the polygon comes into play and ideally for your
    text needs you would set it to zero
    The width of the polygon wire also affects the exactness that the pour wraps
    to the text but small widths generate larger Gerber output so use as big a
    width size for the polygon as you can tolerate.
    Warren
    Former Member over 15 years ago in reply to Former Member
    Warren Brayshaw schrieb:
    >> I would like to etch the characters into the copper, rather than
    >> etching a bubble around the letters.  Can I do this?
    when you pour the polygon it won't pour where you have the text. The
    your text needs you would set it to zero The width of the polygon
    wire also affects the exactness that the pour wraps to the text but
    small widths generate larger Gerber output so use as big a width size
    Addendum: It makes sense to use a separate, smaller polygon (with lower
    rank) only for the area that contains the text. This way, you can easily
    use zero isolate and small width in the text area, without getting too
    large data for the complete board.
    Tilmann
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:i2lu9m$bkt$1@cheetah.cadsoft.de...
    Tilmann
    Thank you both for showing the way.  I had found the Restrict layers on my
    own but could not fathom how to obtain a decent-looking result.
    Jeff
