EAGLE User Support (English) viewmate and excellon output
  • Subscribers 178 subscribers
  • Views 863 views
Former Member over 15 years ago
I try to generate gerber for a board, and everything went ok until excellon
file for drill and holes. Viewmate show excellon layer about 10-20 times
bigger than any other layer (in gerber format), and with many phantom
drills. I have tryed the http://www.gerber-viewer.com/ with the same
results.
Only "gerbv" show the real size of excellon file.
It is a problem of Eagle output, or a viewmate problem?
    results.
    It's most probably a problem of viewmate. All those gerber viewers need
    to "guess" the exact number format (number of digits, number of
    decimals) and the unit (inch/mm) of the drill data. A wrong guess
    results in a badly scaled display.
    Normally, you can select those parameters when loading the drill file,
    eventually you can also change them later to correct the view.
    Besides that, I have heard of some more problems with viewmate. I am
    using GCprevue which works pretty well (and guesses correctly most of
    the time image ).
    Tilmann
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:i2mc49$fgp$1@cheetah.cadsoft.de...
    >> excellon
    >> results.
    the time image ).
    Tilmann
    In my case GCprevue show the same wrong result.
    Former Member over 15 years ago in reply to Former Member
    >> the time image ).
    That's why I wrote "most of the time".
    However, with GCprevue you get a file format selection window after you
    selected the files for import, and before they are actually loaded.
    There, you can see the format guesses and also adjust the parameters
    according to the format you generated. I always use SM1000 format for
    drill files, with "2.4" decimal notation, metric. If the format
    selection window shows anything different, I fix it there - and then the
    display is correct right from the start.
    Tilmann
    Former Member over 14 years ago in reply to Former Member
    I used File/Import/Guess to import the *.drd file.
    The defaults seemed to work:
    Decimal Placement 1.4
    English Data Units
    Omit leading zeros
    Absolute Position Coordinates
    cheers,
    Mike
    >>> the time image ).
    Tilmann
