Is there a way to move the origin (0,0) in Eagle?
-Michael
-Michael
No, but you can work with relative coordinates after setting a MARK
somewhere.
It's also no problem to move your whole design to work with another
origin (DISPLAY ALL, GROUP everything, then MOVE).
Tilmann
That is not so easy if you have a number of locked parts.
"Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
news:i3g8v1$asc$1@cheetah.cadsoft.de...
somewhere.
Tilmann
Doug schrieb:
(Quoting order fixed)
It's always better to choose the correct origin etc. /before/ doing
placement and/or layout...
Tilmann
news:i3h8eq$nle$1@cheetah.cadsoft.de...
Tilmann
I agree.
But things change after one begins layout.
Tilmann
Absolutely agreed. I like to put the bottom left-hand corner of my
board at (0,0). However, late in the game I found that I had to add
break away tabs/rails on the left and right side of the PCB (I hadn't
planned on this). If I don't move the board or re-locate the origin
I've got gerber files with negative coordinates - which probably is just
fine, but as a matter of practice I avoid it. So, while I agree that it
is best to choose the right origin at project start, sometimes reality
intervenes.
That said, even if you have locked parts I don't think moving the origin
is a huge problem. All you are doing is mapping old coordinates -> new
coordinate by adding/subtracting some constant to the old X,Y numbers.
This works quite well if you specify that locked parts can't be moved
but they CAN have their coordinates remapped. If you think about it,
moving the origin is actually easier than the alternative if you have
locked parts. To do a move you've got to unlock the parts, move
everything, then re-lock parts. If you allow coordinate re-mapping (but
not moving) on locked parts you just specify the new origin and you're done.
I can tell you that several PCB layout systems do allow the origin to be
relocated and it is a handy feature.
>> Tilmann
Absolutely agreed. I like to put the bottom left-hand corner of my board
at (0,0). However, late in the game I found that I had to add break away
tabs/rails on the left and right side of the PCB (I hadn't planned on
this). If I don't move the board or re-locate the origin I've got gerber
files with negative coordinates - which probably is just fine, but as a
matter of practice I avoid it. So, while I agree that it is best to
choose the right origin at project start, sometimes reality intervenes.
done.
doesn't the Pos Coord checkbox in the CAM processor do what you are
looking for?
looking for?
Yes, so at least for /this/ reason there's no need to move neither board
nor origin.
So if that was the real question behind the OP, there simply is no problem.
Tilmann
>> Tilmann
I agree.
Agreed - but if such things change, these parts shouldn't be locked.
Locking parts is for mechanically really fixing something - normally due
to external constraints. It doesn't make any sense to place them /not/
at their final position... (resp. to lock them if they are not at their
final position)
Tilmann
intervenes.
That is not a problem at all (see other answers). Placement of origin
resp. board outlines is probably a matter of personal preferences... I
often try to achieve some symmetry related to the case where the board
shall fit in, or simply related to the board center. So, most of my
boards use negative coordinates. Using the appropriate CAM switch, the
Yes, it wouldn't be a problem at all - but currently, it simply is not
available in EAGLE. So we have to "avoid the need" to move the origin.
Fully agreed. (But I think other issues are much more urgent...)
Tilmann
>> looking for?
nor origin.
Tilmann
That was in fact the question and I'm glad that this feature is
available in the CAM processor. Thanks for reminding me.
That said, I think there is still value in being able to relocate the
origin in the Eagle layout tool. Reason being, if I spin this board in
the future I always need to remember to set the Pos Coord checkbox on
this design, whereas if I had the ability to relocate the origin I could
do it once and forget about it. Plus (and I accept that this many not
be a valid reason to many people), I just find it aesthetically more
pleasing to have the origin at the lower left hand boundary of the
board. It certainly facilitates placing components that have to be in
an absolute X,Y position relative to the corner of the PCB.
I've corrected the issue by doing a move so it is not a problem anymore.
I had just grow used to the ability to move the origin in other layout
packages and missed it.
Thanks for the help,
-Michael
>> looking for?
nor origin.
Tilmann
-Michael
