EAGLE User Support (English) A few suggests for next major Eagle version
  • Replies 69 replies
  • Subscribers 185 subscribers
  • Views 3837 views
Former Member over 15 years ago
1. Tabbbed interface, with detachable tabs (for people that use more than 1
screen). See GUI that mikroe
(http://www.mikroe.com/eng/categories/view/2/compilers/) uses for their
compillers. It will suit very well to Eagle,
2. XML documents structure;
3. "Project" should be a folder to contain:
a)  sch,
b)  brd,
c) - lbr with all components added in sch or brd; this will become THE
library that holds all components, any change should be made only in this
library,
d)  macros - group of components locked together ; ymbols only, or symbols +
routed tracks in brd (this should solve the "duplicate part of the routed
schematic"),
e)  a subfolder for fabrication files (gerber),
f)  a subfolder with documentation files (doc, pdf, txt, images, etc).
Either Eagle should be able to open all that files, either it will pass the
name to the OS to manage opening that files,
g)  a subfolder with archived versions of the project (you right click on
the project name, choose "Save version XX", and the associated archive will
be created)
4. Should be possible to edit any component from project, without modifying
the others (if there are 4 0805 resistors in the schematic, to be able to
right click on one of them - edit - and only that component to be changed) -
very easy to implement with the proposed 3.c)
5. Cut/copy behaviour shoud be as the one that any other software in this
world uses.
6. Color palette to be saved in the active file (sch, brd or lbr file).
Colors should be changed directly from the "Layer selection" window, to any
possible combination
7. A quick "DRC check" button should be placed somwhere handy. It will just
run DRC without displayng settings window
8. DRC behaviour should be improved - there are many to discuss here
9. Panelized printing should easy the work for people that makes boards at
home
10. Bundled text editor should know syntax highlighting and word
completition
11. Editable GUI of the main program. Either by customizable menus and
toolbars, either by making-it open source, as ULP.
This is a lot of work, but all my suggestions are based on what missed me
while I was using Eagle.
    eSilviu wrote on Fri, 13 August 2010 02:52
    than 1 screen). See GUI that mikroe
    I'd rather see real features that help with the electronics and designing
    boards.
    boards.
    What the data structure of the internal files are is irrelvant as long as
    they hold the data.  It would be nice if they were documented better, but
    at least they are accessible via ULPs.  XML can be more of a hassle than a
    well thought out binary file.  XML doesn't automatically mean good, and
    non-XML bad.  XML is also very verbose.
    boards.
    Hierarchical schematic elements would be useful, although I don't think
    that's what you're talking about.  It would be nice to be able to can parts
    of a design, then use it as a element in other schematics.  The schematic
    would then be a tree structure, with the devices and symbols we have now
    being the leaf nodes.
    Quote:
    e)a subfolder for fabrication files (gerber),
    the
    on
    will
    be created)
    boards.
    You can do most of this now yourself.
    So go do it and don't bother CadSoft about it.  See HELP ASSIGN.
    Yes, but this is now lost in your flood of suggestions.
    at home
    boards.
    Get real.  How many people that use Eagle at home actually pay for it?
    completition
    boards.
    There are plenty of text editors out there.  Let's not have CadSoft waste
    time on reinventing this wheel, or chosing one at the expense of all the
    others.  There is no need for Eagle to have a text editor at all.  I edit
    ULPs and scripts routinely, but never with Eagle's editor.  Eagle would
    have to support exactly the text editor enviroment I use for it to be of
    any use.
    boards.
    If you want to suggest changes, you should pick the one or maybe two that
    you really care about.  You've dumped so much stuff here, with enough of it
    silly fluff, that I'd probably dismiss all of it if I were CadSoft.
    Keep in mind that everything is a tradeoff.  If they work on one
    enhancement, there will be other enhancements that won't get done.
    Am 13.08.2010 08:53, schrieb eSilviu:
    a)  sch,
    b)  brd,
    library,
    schematic"),
    be created)
    world uses.
    home
    completition
    I hate long letters, so I shall not go into the  details. IMHO most of
    these suggestions can be done by other ways and programs, and certainly
    I don't want eagle to be my next "operation System" image
    Hierarchical sheet structure is imo more important than customizable
    gui's. But we shall see...
    Gruß / regards
    Joern
    "Olin Lathrop" <eagle@embedinc.com> wrote in message
    news:i43alv$liv$1@cheetah.cadsoft.de...
    boards.
    boards.
    As well as you can draw boards in Paint or on paper by yor self!
    Eagle is a tool, and everyone is free to say what it likes or dislike at
    that tool. And to propose improvements too.
    what tis has to do with any of my suggestions?! you're out of subject!!!
    Eagle text editor has one feature that none of other editors don't have: It
    know at what line the error is.
    So...
    I'd rather see you proposing something constructive than just towing stones
    on any new proposal....
    "Joern Paschedag" <jpaschedag@t-online.de> wrote in message
    news:i43f4c$9ct$1@cheetah.cadsoft.de...
    So:
    12. I have forget about hyerarchical structure. It should be there, and it's
    just a step away of proposed "project library" and "macro components"
    IMHO most of these suggestions can be done by other ways and programs, and
    certainly I don't want eagle to be my next "operation System" image
    When you go to work... would you prefere to use only one pair of shues? or 3
    pairs and change them according to the terrain: one for gras, one in
    buildings and one on the street?
    When I start a project, I would like that all the work for that project to
    be in one and only one place. Maybe for you that "place" is called
    "computer". But for me "computer" means 1000 places (ordered, but still
    1000).
    Former Member over 15 years ago in reply to Former Member
    eSilviu wrote on Fri, 13 August 2010 09:43
    to be in one and only one place.
    So go ahead.  You don't need special help from Eagle for that.
    I keep all my Eagle projects in a tree structure with each individual board
    having its own directory.  I don't need Eagle to do anything special for
    that, and don't want it to.  That's what the operating system, text editor,
    scripts, and other things are for.
    eSilviu wrote on Fri, 13 August 2010 09:34
    stones on any new proposal....
    It's important for CadSoft to hear when people think suggestions are bad
    ideas too.
    The reason some suggestions are actually bad even if the new feature could
    be ignored, is because implementing that feature takes resources from
    implementing something more useful.  Everything is a tradeoff.  A long wish
    list is just a distraction without prioritization.
    news:i43j7r$u1e$1@cheetah.cadsoft.de...
    board
    editor,
    I still don't believe you understand what a "feature" means: It means that a
    software CAN do something, but it will not force you to do that way.
    I don't see why you couldn't use you OS and text editors further, after (or
    if) my suggestions are implemented. In fact I don't see how any of my
    suggestions would affect you in any way.
    news:i43jkd$vks$1@cheetah.cadsoft.de...
    wish
    I see here only big words, spoked in the name of others.
    Please, a "I disagree with X,Y and Z" it would be enough from a possible
    user.
    eSilviu wrote on Fri, 13 August 2010 10:10
    In fact I don't see how any of my suggestions would affect you in any
    way.
    They would take resources from implementing other features that I can't get
    from the operating system, text editor, shell scripts, etc.
    Am 13.08.2010 15:43, schrieb eSilviu:
    "Joern Paschedag"<jpaschedag@t-online.de>  wrote in message
    So:
    1000).
      I can hardly follow you. We are talking about the eagle layout program.
    If you want eagle to do all the work nessesary for a project, are you
    willing to pay for that?
    Gruß / regards
    Joern
