EAGLE User Support (English) Calculating copper trace lengths for controlled impedance
  • Subscribers 186 subscribers
  • Views 709 views
It would be really nice if there was a way to simply click on a copper trace
(wire) and have it's signal name and length immediately displayed (for use
when routing impedance controlled wires).  Could you possible create a
button/tool that appears in the menu?  Or could you possibly add the length
information to the "info" dialog?  Or could a .ulp be written that does
this?  I cannot find a way to extract the current mouse X/Y coordinates when
the mouse is clicked.
Length.ulp does this, but it produces a lengthy text file that lists the
signal names and lengths for all wires on the board - which you then have to
manually open, find the signal name, then obtain the length for each wire
that you work with.
Many thanks!
Arley Jackson
Softronics LTD
100 35th St., Suite A
Marion, IA
319-721-6778
  • Richard_H
    Richard_H over 16 years ago
    Am 13.10.2010 17:02, schrieb Arley Jackson:
    that you work with.
    Many thanks!
    You can use length.ulp with for example two signal names.
    RUN length.ulp name1 name2
    will give a list of two signals only.
    Richard Hammerl
