EAGLE User Support (English) Way of making point A to point B measurements within a layout
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 1312 views
It would be handy to have a tool, by using two mouse clicks, to measure and display the distance between two points within a layout.  The points could snap to the snap grid.  Protel has this tool under the "reports" menu drop down.  I miss it now that I use EAGLE.
    e14 Contributor over 15 years ago in reply to kcadsoft
    >> many requests for this seemingly obvious tool.
    >> The EAGLE way to do this is to use the mark command to set the origin at
    >> one point and then just move the mouse to the other point and read off
    >> the value.
    And in what way does this not do what John wants?
    Klaus Schmidinger
    It does what he needs, never said it doesn't...and as for what he
    wants, that should be clear from his question.
    It is different from most user's expectations of how the tool should
    work. That's why they sometimes can't figure it out. In my opinion, it
    is also clumsy to use for checking dimensions, for the reasons others
    have said.
    When there's lots of mechanical specs, and these days that's very
    common, it's not so much fun. The best solution in these cases, with
    EAGLE, is often entering coordinates directly, but did they get snapped
    to the grid? I wouldn't know, you, the designers, would know EAGLE's
    behaviour in this case, but not me.
    And, you need to do a lot checking and rechecking of dimensions because
    it's amazing how things get moved in a layout without your awareness.
    And this is when the mark method can get clumsy. Maybe I just don't know
    how to use it, but how easy is it to forget to turn off the grid and
    make a measurement that seems correct but isn't, or seems incorrect yet
    is? I think very easy.
    And in my opinion, any ruler tool snapping to the grid is probably not
    something good here, snapping to edges and centers would be better.
    So, Mark works fine for this. But is it the best way?
    James Morrison wrote:
    >Yes, Bert nailed it.  The difference is that EAGLE's mark tool is only as
    >accurate as the grid setting.
    which is not bad per se. if there was a measurement tool, I would like
    to choose which grid to use.
    Currently I do "gr fin ma" click, move to other point, read value, "gr
    la" if I want a measurement with resolution below the current grid,
    but I also use "mark" with a grid.
    Other CAD tools will automatically snap the measurement to some object.
    this would be a nice option and improvement over current
    possibilities.
    Oliver
    "James Morrison" <james@eaglecentral.ca> wrote in message
    news:ia961t$ldu$1@cheetah.cadsoft.de...
    As a minimum such a tool should be able to snap to the center or edge of
    any object on any layer.  This would include, but not limited to,
    wires, circles, rectangles, polygons, ...
    So the only thing in your way is the grid? Its very easy to draw a wire
    between two points and right click its properties to find the length,
    followed by an undo.
    But it WOULD be nice to be able to see the properties of sub-library items,
    such as pads, smd's, holes in a component... And even pins on schematic
    level.
    Question is if Cadsoft wants to direct all users to use the same work
    method, or if they want to open for more personal tastes. I guess both ways
    have their advantages and disadvantages.
    at
    >> the value.
    accurate as the grid setting.  Other CAD tools will automatically snap the
    measurement to some object.  Usually the object is the center of something
    or the edge of something.
    Think like you are trying to match your PCB to some auto-cad drawing since
    this will most likely come up when you are trying to make sure that your
    PCB matches some drawing of an enclosure or some other physical feature of
    the system.  Mechanical engineers use the strangest points of reference
    sometimes to indicate how far something is from something else.  Usually
    they are concerned with edges, not with the center of mass for a component.
    So EAGLE should have a tool to help the designer ensure that the physical
    distances are all correct.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:ia8ktq$2nn$1@cheetah.cadsoft.de...
    >> the value.
    Klaus Schmidinger
    Klaus, are you still arguing this one?  Yes, the "Mark" tool can be used to
    measure distances, but it is just not very convenient.
    For example, what's the drill size in that pad there?
    Using Mark:
    Zoom in.  Of course the boundaries of the hole are not on grid.  Change the
    grid to 5 mil.  Nope, not fine enough.  Change it to 1 mil.  OK, that allows
    me to get pretty close to the edges.  Now click the Mark tool, and click on
    a grid point near the edge.  Now move the cursor to the opposite edge, and
    read the distance, being careful not to move the mouse while I look up.
    If we had a "measurement" tool such as seems to be found in just about any
    other CAD tool, this might work like this:
    Zoom in.  Click Measure.  Click at one edge (anywhere -- doesn't have to be
    on grid).  Click on the opposite edge.  Read the distance.
    Please, please, please, just give us one of those cute little ruler icons!
    Bert Menkveld
    P.Eng.
    Greentronics
    bert@greentronics.com
  • kcadsoft
    kcadsoft over 15 years ago in reply to e14 Contributor
    the value.
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
    the value.
