EAGLE User Support (English) layer setup and settings
  • Replies 9 replies
  • Subscribers 178 subscribers
  • Views 2206 views
Former Member over 15 years ago
Hi all,
I am sorry to be a noob in this, anyone can help me in writing layer setup
properly (and in some other issues)
1. Schematic has 2 classes: default and power. I would like to router 4
layer board, with top and bottom to be signal layers, and 2nd and 15th to be
power levels (GND and +5v respectively). What should I write in DRC layers
setup?
2. How to make power and gnd layers to span through whole PCB layer (and not
to just connect vias, pins and pads).
3. Board has holes for mounting in the chassis, and those holes should
connect to gnd layer. How to do that - I can not define holes with their
pads in schematics, but if I define them on the board view pads disappear
when I perform "ripup".
Thank you for helping me.
    On 10/27/2010 6:58 AM, E wrote:
    Hi all,
    setup?
    Hi E,
    I hope you are doing well. See answers below:
    1.You don't write anything in the DRC settings to define your inner
    layers as power layers. There are two ways to do this.
    First, you can simply use a polygon that encompasses all of the board
    area, give the polygon the same name as the net you want connected to
    it(GND for example).
    The second method is to turn the internal layers into supply layers. To
    do this use the display command to view your layers. Select one of the
    internal layers, then click the change button at the bottom of the
    window. This will open up the properties of the layer, you'll see a
    check box that says supply layer make sure it's checked. Say ok until
    you return to the display window. You'll now notice that a $ sign has
    been appended to the layer name this is how EAGLE distinguishes a supply
    layer.
    A few tips about supply layers, only use them if you want a clean plane
    with only vias connecting to it, if you need to route traces then use
    the polygon method. The reason for this is that supply layers are
    reverse layers, what this means is that anything you draw on a supply
    layer is considered removed copper so if you draw traces, then when your
    board is made the traces will be removed which is not what you
    wanted.The autorouter works better with supply layers than it does with
    polygons so that may be something to consider.
    2. See Answer 1
    3. Use parts from the holes.lbr these are already setup for this purpose.
    hth,
    Jorge Garcia
    Former Member over 15 years ago in reply to Former Member
    Jorge, thank you so much.
    Can you please tell me how to make polygons solid filled with layer color? I
    am routing power and would like to use poly's for drawing tracks of various
    wide (between the lines of other signals). But poly shows dotted contour...
    "Jorge Garcia" <jorge@cadsoftusa.com> wrote in message
    news:ia9p9o$qbg$1@cheetah.cadsoft.de...
    >> Hi all,
    >> setup
    >> be
    >> layers
    >> setup?
    >> not
    Hi E,
    1.You don't write anything in the DRC settings to define your inner layers
    The second method is to turn the internal layers into supply layers. To do
    internal layers, then click the change button at the bottom of the window.
    This will open up the properties of the layer, you'll see a check box that
    says supply layer make sure it's checked. Say ok until you return to the
    display window. You'll now notice that a $ sign has been appended to the
    layer name this is how EAGLE distinguishes a supply layer.
    with only vias connecting to it, if you need to route traces then use the
    polygon method. The reason for this is that supply layers are reverse
    layers, what this means is that anything you draw on a supply layer is
    considered removed copper so if you draw traces, then when your board is
    made the traces will be removed which is not what you wanted.The
    autorouter works better with supply layers than it does with polygons so
    2. See Answer 1
    hth,
    Jorge Garcia
    Help Ratsnest
    r
    That doesn't help.
    Let me say again: I want to draw areas of copper manually which will be
    automatically filled with specific color of the layer and assign these areas
    respective signals (gnd, vcc etc)
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> wrote in message
    news:iab9ai$t5f$1@cheetah.cadsoft.de...
    Help Ratsnest
    r
    "E" <msx.fan@mail.ru> wrote in message
    news:iaboh6$jsr$1@cheetah.cadsoft.de...
    That doesn't help.
    areas respective signals (gnd, vcc etc)
    What he means is that you have to run ratsnest before they get filled. It
    does not happen automatically.
    Also, there must be a signal to connect to within the poly. Try placing a
    via in it, and rename the polygon and via to the same name, then press
    ratsnest.
    Morten, thank you. That helped, now I can continue my work image
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:iabon4$l70$1@cheetah.cadsoft.de...
    >> That doesn't help.
    ratsnest.
    Another issue which I can not sort out.
    I created a series of polygons on the layer 1 touching each other and having
    name "gnd". All well and ratsnest seem to accept it. But when I run DRC
    check it displays error "width" for layer 1 for one of the sides of each
    polygon (seems the initial ones I was starting drawing them from). I tried
    thin line width, I tried thick one with same error. What's wrong? I use
    default DRC rettings.
    news:iabqt5$vfj$1@cheetah.cadsoft.de...
    >>> That doesn't help.
    >> ratsnest.
    I found out a problem - it was in net class setup.
    Well, issues did not end here.
    I have 2 polygons, and want to have thermals for specific elements (e.g.
    capacitors) but no thermals for passthrough vias (connecting top and bottom
    layers' polygons). So far I did not find a way to achieve it - polygon
    either has thermals or not, I can not define it at the specific via level,
    right?
    news:iabvmr$4oh$1@cheetah.cadsoft.de...
    having name "gnd". All well and ratsnest seem to accept it. But when I run
    DRC check it displays error "width" for layer 1 for one of the sides of
    each polygon (seems the initial ones I was starting drawing them from). I
    tried thin line width, I tried thick one with same error. What's wrong? I
    use default DRC rettings.
    >>>> That doesn't help.
    >>> It does not happen automatically.
    >>> a via in it, and rename the polygon and via to the same name, then press
    >>> ratsnest.
    news:iac2mm$kmr$1@cheetah.cadsoft.de...
    bottom layers' polygons). So far I did not find a way to achieve it -
    polygon either has thermals or not, I can not define it at the specific
    via level, right?
    There is a DRC settings for thermal on via. See the supply tab.
