EAGLE User Support (English) Add PDF Output Option to CAM Processor
  • Subscribers 178 subscribers
  • Views 959 views
Former Member over 15 years ago
I often need to provide PDF drawings to customers.  It would be very
helpful to include a PDF device so that these could be generated whenever
the other output files are created.
Cheers,
James.
Specializing in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
    Am 11.11.2010 17:06, schrieb James Morrison:
    RUN cam2print (enter) --> card |Help|
    use a CAM-Job to switch on/off the layer like a CAM-Jop and start
    print.
    Alfred Zaffran
    _____________________________________________________________
                                 Web:   <www.cadsoft.de>
    Geschäftsführer: Dipl.-Ing. Klaus Schmidinger, Bodo Badnowitz
    Former Member over 15 years ago in reply to Former Member
    A. Zaffran wrote on Fri, 12 November 2010 02:59
    very
    whenever
    print.
    Close.
    From what I can tell, this script uses the last selected printer from the
    Print dialog.  So if I want to print PDF I have to go to the print dialog,
    select PDF output.  In the print dialog the "cancel" button will actually
    keep the change to the printer though it shouldn't--so that isn't clear
    either.  Then I have to run this script, load my cam job, and hit the go
    button.
    So with this I can make it work to get what I need for mechanical drawings.
    I'd argue it's easier to simply change the layers to what you want and
    then print to PDF.  But whatever, it's an option.
    It doesn't help the problem that I want to ensure that all my manufacturing
    and documentation output files are generated with an atomic function so
    they are all guaranteed to be in sync.  I could write a script that
    includes this, but I'd still have to hit that OK button so the script won't
    complete without me doing that (or editing the ULP).
    It also highlights another problem:  How is it possible that I've created >
    500 boards in EAGLE and I didn't know about this?  While the ULP's are very
    powerful and flexible (I've created many myself to increase my own
    productivity).  That strength is also the greatest weakness.  It's very
    difficult to keep track of all that functionality that exists.  Most tools
    use the menu system to make that little used functionality in the user's
    mind.  Then when they need it they can find it by browsing through the menu
    items.  ULP's suffer from out of sight, out of mind.
    What might be useful is a menu item for ULP's that would go out on startup,
    parse through the ULP directories, and then populate a menu with cascading
    menus (based on folder structure) with a list of the ULP's available.  You
    could even have a special tag in the file that would be pulled out as the
    decsription to put in the menu list.
    That would help users find these type of useful, but hard to find, ULP's.
    Maybe the same thing for scripts.
    James.
    Cheers,
    James.
    very
    whenever
    print.
    Wow, something else I learned today:  The CAM processor works when called
    from the Schematic editor!  I never even thought to try that.  So this
    solution is a bit closer to what I had in mind.
    I can't get my PDF print out to include all of an 11x17" sheet (frame).
    It's actually 1.5 times larger than 11x17", maybe that is part of the
    problem.  I have a .cam job that is just for schematic and creates an EPS
    file.  Then I call that from cam2print to create a PDF.  The output PDF is
    not scaled correctly.
    Still not a totally scriptable solution since you have to set the print
    parameters in the print dialog (from what I can tell).  And the cam2print
    dialog always comes up--it really shouldn't if you give it the name of the
    cam file you want to use.
    James.
