EAGLE User Support (English) Added Generic Commands to CAM Processor
  • Replies 8 replies
  • Subscribers 190 subscribers
  • Views 681 views
One final improvement to the CAM processor.  It would be great to have a
"command" device where you could specify an EAGLE command to run, like
running a ULP.  If this was strictly a "ULP" command that would be OK too.
Doing this would allow for auto-generation of BOM and x-y data when the CAM
file is processed.  This would help ensure those files match the PCB gerber
files since they are all created at the same point in time.
With all these changes the CAM processor would really become "Export
Manager" or something like that.
Cheers,
James.
Specializing in CadSoft EAGLE
  • Electronic Design Services
  • EAGLE Enterprise Toolkit
  • dukepro
    dukepro over 13 years ago in reply to e14 Contributor
    On 11/12/2010 08:28 AM, James Morrison wrote:
    James Morrison wrote on Thu, 11 November 2010 11:10
    One other use of this is would be to run a script to delete those really
    annoying .gpi files that are created for the gerbers.  They confuse board
    houses when you send them and they have no use that I've ever seen.  So I
    always just delete them.  But it's an unnecessary step that I should be
    able to get EAGLE to do somehow.   A cleanup script to run as the last
    section of a CAM job would be a good place to do it.
    James.
    James,
    This is an excellent suggestion.  Two additional sections could be added
    to the cam file - one for PRE-CAM actions, and one for POST-CAM actions.
        Description="..."
        Section=camprep
        Section=TopScreen
        Section=Drill
        Section=campost
        ULP="drillcfg.ulp"
        ULP="genxydata.ulp"
        ULP="cam-wrapup.ulp"
        ULP="/usr/local/lib/my-cam-stuff.ulp"
    We're all familiar with drillcfg.ulp, but it could be modified to
    automatically save without mods in inches.  "cam-wrapup.ulp" can launch
    a shell to run a shell script.  It could also produce the x-y data,
    clean up the .gpi files, and zip everything together to send to the fab
    house.
    The CAM processor would recognize the exit status of the ULP.  If
    non-zero, stop the job.
    The capabilities are interesting with an added feature like this.
    7457.att1.html.zip
    Or script it in TCL and it'll run on all platforms.
    On 11/12/2010 08:25 AM, James Morrison wrote:
    The problem with the shell script approach, is that isn't OS
    independent. I use EAGLE on all three platforms so it would require 2 or
    3 different scripts to be maintained. I don't want that. The CAM processor,
    > with a few extensions, would fit the bill nicely. But again, I don't
    > care how it gets done.
    You could write a single Bourne shell script, and use Cygwin to run it
    on Windows.  It should run natively on Linux and Mac, as long as you
    keep to the basics.
    -Dave
    e14 Contributor over 15 years ago in reply to kcadsoft
    Your last three suggestions sound like you're trying to cram things
    into the CAM Processor that could be easily (and much more powerful)
    be done with a simple shell script (or "batch file", in Windows-speak ;-).
    Klaus Schmidinger
    I support James' suggestion.
    James.
    Morten Leikvoll wrote on Fri, 12 November 2010 04:21
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de[/email]> wrote in
    message
    news:ibitlj$oev$1@cheetah.cadsoft.de...[/email]
    things
    powerful)
    Windows-speak image.
    I guess you could use the same logic to leave out the cam gui all
    together.
    Maybe the solution is a "script tree" in the control panel, with a gui
    helping you make the script/batchfile. Or you could rename the "cam
    jobs" to
    "batch jobs" (and rethink the intention of it) and listen to James'
    suggestion (which I have suggested before and support fully).
    Thanks Morten.
    Like Morten, I don't really care what you call it or how exactly it gets
    implemented.  Let me restate it in slightly more generic terms.
    It would nice to be able to configure EAGLE to generate ALL output files
    required with one user command (be that a script, a button, ...).  The
    output required in my cases would be gerbers, drill files, mechanical
    drawings in PDF (DWG would be better), schematics in PDF, bom and x-y data
    in .csv.
    All of these files are required to support the manufacturing of the
    product.  It is absolutely imperative that they all are generated from
    exactly the same design file.  So give the user an atomic operation (i.e.
    once the user starts it will carry out to completion) to create all the
    required documents.
    The problem with the shell script approach, is that isn't OS independent.
    I use EAGLE on all three platforms so it would require 2 or 3 different
    scripts to be maintained.  I don't want that.  The CAM processor, with a
    few extensions, would fit the bill nicely.  But again, I don't care how it
    gets done.
    James.
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    be done with a simple shell script (or "batch file", in Windows-speak image.
    I guess you could use the same logic to leave out the cam gui all together.
    helping you make the script/batchfile. Or you could rename the "cam jobs" to
  • kcadsoft
    kcadsoft over 15 years ago
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
