EAGLE User Support (English) Configuration Files
  • Replies 15 replies
  • Subscribers 180 subscribers
  • Views 1491 views
Configuration Files
Former Member over 15 years ago
Hello
I'm a bit confused on how Eagle starts up and how it is configured between
universal, user and project.
I was playing around and decided to run the eagle.scr script just to see
what it does.  It seems that since I ran it the program doesn't seem to
store configuration for any particular window any more.  I'll open a
schematic for example and set the grid.  Later after I do some work with it
and save it....when I reopen the grid is NOT what it was before.  It is
really annoying having to set the grid again.  I KNOW this can't be
correct.  I must have done something when I ran the eagle.scr script.
So what do the files do and when are they saved? :
Eagle.scr
Eagle.usr
Eagle.epf
While we are at it, what gives with the part of the Help file right at the
beginning called "Command Line Options".  It implies a command called
"EAGLE" but there is no way to invoke it.  Is this supposed to be in
Windows Explorer or something.  I don't get it.
Thanks for any help you can give.
jom
  • Richard_H
    Richard_H over 15 years ago
    Am 22.12.2010 21:39, schrieb gbtjom:
    Hello
    Eagle.scr
    Eagle.usr
    Eagle.epf
    jom
    Please look at: http://www.cadsoftusa.com/faq.htm.en#06011304
    This should give all informatio nyou need.
    Richard Hammerl
    Former Member over 15 years ago in reply to Richard_H
    Richard Hammerl wrote on Wed, 22 December 2010 23:59
    Hello
    between
    to see
    seem to
    a
    with it
    It is
    be
    script.
    Eagle.scr
    Eagle.usr
    Eagle.epf
    at the
    called
    in
    jom
    This should give all information you need.
    Thanks for that...it was a great help.
    After reading through this I understand better.  However, I'm at a loss
    why, for example, the grid setting on a schematic is NOT saved (to the
    eagle.epf file) when I close it.  I'll set the grid to ON with style of
    "DOTS" but after I close and open it again the grid is off and set to
    "LINES".  Isn't this supposed to be saved?  Note that in the Control Panel
    under Options/Backup the "Automatically save project file" is CHECKED so it
    should have saved.  In fact I know the .epf file is changed due to the
    date/time after I close the project but it doesn't save the grid settings
    nor does remember the window size..for that matter.
    So what gives?  This is why I've been confused by this issue...
    jom
    Former Member over 15 years ago in reply to Former Member
    Op Thu, 23 Dec 2010 22:07:06 +0100 schreef gbtjom <gbtjom@cox.net>:
    >> > Hello
    >> > between
    >> > to see
    >> > seem to
    >> > a
    >> > with it
    >> > and save it....when I reopen the grid is NOT what it was before. > It
    >> is
    >> > be
    >> > script.
    >> > Eagle.scr
    >> > Eagle.usr
    >> > Eagle.epf
    >> > at the
    >> > called
    >> > in
    >> > > jom
    Panel
    it
    jom
    You don't make it clear wether you first make a project and then start a
    schematic or just create a new schematic. Project settings are only saved
    when you create a project first because there has to be a place to save
    the project file (There is a project file (.epf) for each project you
    create).
    HTH
    Richard
    Richard Herman wrote on Thu, 23 December 2010 13:48
    Op Thu, 23 Dec 2010 22:07:06 +0100 schreef gbtjom <<private_email>>:
    >> > Hello
    configured
    >> > between
    just
    >> > to see
    >> > seem to
    open
    >> > a
    work
    >> > with it
    It
    >> is
    >> > be
    >> > script.
    >> > Eagle.scr
    >> > Eagle.usr
    >> > Eagle.epf
    right
    >> > at the
    >> > called
    >> > in
    >> > > jom
    loss
    the
    style of
    to
    Control
    Panel
    CHECKED so
    it
    the
    settings
    jom
    a
    saved
    create).
    Thanks for your question.
    In my above post I made mention that the .epf does, in fact, save since the
    time/date characteristic of the .epf file changes after I close the
    schematic.  So it does exist and it saves.  It just doesn't save the
    environment I leave it in.
    I'll tell you exactly what I do.
    1) I open a schematic from a project that HAS a .epf file
    2) Open the editor window to max
    3) I go to the grid menu and choose Display "ON" and Style "DOTS".
    4) I save the schematic and close it.
    I then re-open the same schematic and not only is the grid setting back to
    Display "OFF" and Style "LINES" the window size is back to a small non-max
    size.  Isn't it supposed to come back in max size and have the same grid
    setting I left it in?
    I'm using the evaluation version of the program on both XP and Windows 7
    and both do the same thing.
    jom
    the
    jom
    Hi jom,
    I always open the project from the "control panel" by clicking on the green
    dot, rather than opening a schematic individually. Try that.
    regards
    Oooops... I should have said white dot. The green dot shows which project is
    open.
    Greg Erskine wrote on Fri, 24 December 2010 13:59
    since
    the
    the
    the
    back to
    non-max
    grid
    Windows 7
    jom
    Hi jom,
    green
    regards
    I do open the schematic by using the Control Panel...I double click the
    sch file.  I'm not sure of any other way other than using the menu
    pull-down.
    However, I tried where you click the white dot and the program asks we
    whether I want to open BOTH board and schematic.  I say yes, proceed to
    change the grid settings (like I mention above) then close both windows.
    When I try to open it up the same way it only turns on and off the green
    dot and won't open up as before.  That is another ODD thing...but I
    digress.
    Nonetheless, if I open up the schematic by clicking the .sch file listed in
    the Control Panel (like I normally do) it's the same problem.  The grid is
    "OFF" and the Style is set to "LINES".
    So the bottom line is regardless of which .sch I open it won't save any of
    the configuration....or so it seems.  This is NOT what I thought the
    program is supposed to do.  Weird.
    jom
    "gbtjom"  wrote".
    I believe the grid setting is saved in the BRD file for each board.
    If your grid setting has changed when you re-open the BRD then it is likely
    that that is being commanded from the eagle.scr file.
    eagle.scr runs each time a board is opened and after the settings of the
    board file have been applied.
    So check your eagle.scr for a GRID command or a script that is being run and
    contains a command to set the grid to lines.
    HTH
    Warren
    pull-down.
    digress.
    in
    Open and CLOSE the project by using the white and green dots, don't close
    windows any other way.
    On Fri, 24 Dec 2010, gbtjom wrote to us saying :
    >windows. When I try to open it up the same way it only turns on and off
    >the green
    >digress.
    No, that's not odd, that's entirely expected.
    When you click the white dot to make it green, you are opening the
    project and Eagle restores the project's settings. If the last thing
    you did was to close both editors then the project's settings are for
    both editors closed. So don't do that.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
