EAGLE User Support (English) Newbie struggling with making edge connector
  • Replies 27 replies
  • Subscribers 190 subscribers
  • Views 6098 views
oldtech1000
oldtech1000 over 10 years ago
I am having trouble trying to make an edge connector in eagle.
I wish to make a PCB that plugs into a 20 pin edge connector, to make an extender board.
The board consists of only 20 tracks with a spacing of 0.1 inches. No components, just the tracks.
Have not been able to find anything in libraries,tried to modify other connectors but all appear to want me
to connect to other components (other than the tracks).
I am sure this is very easy for experience Eagle users but not obvious to a very New Newbie like me.
Thanks for your help
Regards
George
  • oldtech1000
    oldtech1000 over 10 years ago in reply to COMPACT
    Hi Compact,
    Sorry for the slow reply.
    I am trying to copy an existing  Tektronix extender board.
    Fingers are at both ends of the board. One end becomes the male and on the other end uses the same style fingers as pads to solder
    to the edge connectors .
    The fingers are 1.87mm (0.73 inches) wide and 10mm long and joined by thinner tracks going to the other end of the board.
    Fingers are rectangular in shape (i.e. DO NOT have a semicircle shape)
    The boards will not be gold plated (making them I)
    Not worried about chamfering at this stage.
    The sockets are a specials made for Tektronix (striped from old Tek scope), double sided, Connections are similar to wire wrap
    but wider, design to solder to the fingers.
    .Thanks for your help
    Regards
    George
  • COMPACT
    COMPACT over 10 years ago in reply to oldtech1000
    George,
    Can you please give me some more information about the edge connector fingers?
    You've provided the spacing (100mil) but not the dimensions of the fingers.
    Are the fingers to be gold plated and do they have a semi circle fill on one end (or both) to look like a giant D (or elongated oval) shape?
    Does the board edge need to be chamfered as not to damage the host socket?.
    Since it is an extender board do you have information about the complementary socket?
    Is it a wire wrap socket that has its legs bent to shape or something else?
    FYI - S100 boards use 125mil spacing and use gold plated D connectors.
  • oldtech1000
    oldtech1000 over 10 years ago in reply to autodeskguest
    Hi Warren,
    Excellent attachment exactly what I needed...Thank You very much for your kind help.
    I have tried to read as much as I can about Eagle but did not know you could go straight to the
    board editor and use the line command.This also lets you get around the eagle lite size restriction as you explained
    (and it's so easy to modify the length of tracks etc). Can you make some kind of pad for wire connections
    to the PCB ?. I have used very short lengths of "thick" wires instead of pads which should look o/k but wondered if there is a more
    elegant way ?
    I will also take your advice and go to Eagle Central
    Cheers
    George
  • oldtech1000
    Hi Compact,
    Very Interested in the walkthrough....Please post details
    Regards
    George
  • oldtech1000
    Hi Compact,
    Regards
    George
  • oldtech1000
    Hi Compact,
    Regards
    George
  • oldtech1000
    Hi Compact,
    Regards
    George
  • COMPACT
    Hi George!
    Would you like to view a helpful walkthrough?
    Very Compact
    autodeskguest over 10 years ago in reply to oldtech1000
    On 24/01/2016 11:38 p.m., George LIVANES wrote:
    Thank You Very Much for your help....greatly appreciated.
    Only problem is I cannot see your attachment  on my side.
    Hi George
    You are yet another victim of Element14's badly implemented web portal
    into the Cadsoft Forums....and you thought it was a E14 forum image
    Try Eagle Central, its a much better web interface that works properly.
    You will find the attachment is there on your thread.
    http://www.eaglecentral.ca/index.php/t/52170/1a48f5bf2f7bdad27de93cd6681c1c93/
    Warren
    Hi George
    Warren
