In the default eagle.scr file there is some (what I believe to be)
commented out commands. An example is under the SCH:
#Menu Add Bus Change Copy Delete Display Gateswap Grid Group Invoke
Junction \
Label Move Name Net Pinswap Quit Script Show Split Value Window ';'
Wire Write Edit;
This or something similar seems to be put into this file in each section
(BRD, SCH, LBR etc etc) and I'm wondering if this is just there for future
use by someone or is it actually something that isn't commented out as I've
assumed. I find it odd it is all over the file in different sections. I
actually uncommented one part and all it does is add some menu functions
across the top horizontally...what's the big deal with this? I'm curious.
jom
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
