EAGLE User Support (English) Gerber output vias and pads are filled
  • Subscribers 181 subscribers
  • Views 1655 views
Former Member over 15 years ago
After creating top layer gerber data, I viewed the result with a gerber
viewer program. I notice that the pads haso no drills, they are fully
filled. Is it the way pcbs are produced?. The Holes of the vias are
drilled after photoengraving by drill bit, SO the holes of the vias are
not photoengraved?
The check: pads filled is always check, by the cam processor.
Which method is better, photoengraving the copper and then drilling it,
or the copper of the hole is not etched and the via/pad is produced only
by drilling.
tstbeyaz.
    not photoengraved?
    by drilling.
    tstbeyaz.
    Take a look messages with drill-aid.ulp mentioned in the body.
    Paul R.
  • WestfW
    WestfW over 15 years ago
    This is the way that gerbers work.  The drilling machine is completely separate from the photoplotter (and drillings usually happens first, so that the holes can be plated through.)  drill-aid.ulp will provide "pilot holes" in printed output (suitable for toner transfer or home photoplotting), and there's a change to eagle-def to provide similar capability for Postscript and EPS output from the CAM processor (by me!), but as far as I know, the very idea of "holes" in an output object is entirely foreign to the gerber format...
    Former Member over 15 years ago in reply to WestfW
    The PCB will be produced by a pcb manufactorer, But sometimes there are
    cheap alternative suppliers for prototypes who IMHO dont have cnc drill
    machine but drill by hand. If I ensure that they also use my excellon
    file (have a drill machine) the gerber data in this filled (no holes)
    should be ok.
    How is this change to Eagle-def if I need the pilot holes in the gerber
    file?
    thanks.
    tstbeyaz.
    Former Member over 15 years ago in reply to Former Member
    On Tue, 18 Jan 2011, tstbeyaz wrote to us saying :
    To be honest, I would avoid any such "cheap alternative suppliers".
    There are places out there that will do properly manufactured PCBs
    complete with solder mask and silk screen off professional grade tooling
    for the same price as the so-called cheap alternatives. And definitely
    avoid any place that can't cope with the Gerbers generated by Eagle's
    CAM processor (or even anywhere that queries them).
    But YMMV.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    "tstbeyaz" <ferhatincal@gmail.com> wrote in message
    news:ih1shn$fb1$1@cheetah.cadsoft.de...
    not photoengraved?
    Which method is better, photoengraving the copper and then drilling it, or
    the copper of the hole is not etched and the via/pad is produced only by
    drilling.
    tstbeyaz.
    Tstbeyaz,
    There are software packages that will leave the pads (drill holes) open
    where the holes will be drilled.  This is old technology and created for the
    days when hand drilling was the standard practice.  This is long since gone
    and it is preferred to have filled (solid) pads in order to ensure plated
    through holes.
    Terri
  • Richard_H
    Richard_H over 15 years ago in reply to Former Member
    Am 18.01.2011 08:09, schrieb tstbeyaz:
    should be ok.
    file?
    thanks.
    tstbeyaz.
    There is a possibility to use Postscript output with the CAM Processor
    and have the drill holes visible, and you can use drill-aid.ulp before.
    This device definition was posted some time ago in this newsgroup.
    I just add it here:
    EPS-Drillaid]
    @EPS
    Long     = "Postscript with max hole size in pads/etc, ala drill-aid.ulp"
    Header3  = "%% redefine our /h function with a fixed diameter\n"\
               "/h {  %% draw a hole\n"\
               "   /d  exch def\n  %% Still need to pop diam off stack\n"\
               "   d 5000 gt {\n"\
               "      /d  5000 def\n  %% But override it to 0.5mm\n"\
               "   } if\n"\
               "   /y  exch def\n"\
               "   /x  exch def\n"\
               "   d 0 gt {\n"\
               "     newpath\n"\
               "     x EU y EU d 2 div EU 0 360 arc\n"\
               "     currentgray dup\n"\
               "     1 exch sub setgray\n"\
               "     fill\n"\
               "     setgray\n"\
               "     } if\n"\
               "   } def\n"\
               "%% The drawing\n"
    @PS
    Long     = "Postscript (printable) with max hold size ala Drill-aid.ulp"
    Header2  = "%% redefine our /h function with a fixed diameter\n"\
               "   d 5000 gt {\n"\
               "   } if\n"\
               "   /y  exch def\n"\
               "   /x  exch def\n"\
               "   d 0 gt {\n"\
               "     newpath\n"\
               "     fill\n"\
               "     setgray\n"\
               "     } if\n"\
               "   } def\n"\
               "%% Remainder of Header2 copied from define for PS device\n"\
               "%% the real drawing size:\n"\
               "\n"\
               "/MinDrawX %6d EU def\n"\
               "/MinDrawY %6d EU def\n"\
               "/MaxDrawX %6d EU def\n"\
               "/MaxDrawY %6d EU def\n"\
               "\n"\
               "%% the usable page size:\n"\
               "\n"\
               "/LeftMargin 0.25 inch def  %% change these if drawing gets
    clipped!\n"\
               "/BotMargin  0.25 inch def\n"\
               "/PageWidth  %7.4f inch def\n"\
               "/PageHeight %7.4f inch def\n"\
               "\n"\
               "%% are we going to rotate?:\n"\
               "\n"\
               "/RotateDrawing %d 0 ne def\n"\
               "\n"
               ;(x1, y1, x2, y2, Width, Height, DoRotate)
    Richard Hammerl
