EAGLE User Support (English) Pad on Pad confusion...
  • Subscribers 178 subscribers
  • Views 287 views
mprowe@peritonlane.net
mprowe@peritonlane.net over 9 years ago
While learning how to create a custom library for myself, I tried placing
two pads at the same X,Y coordinates.
This was roundly prevented by the Library Editor. With the message ...
"Can't place pad  on pad P$1!"
However, if I place two pad at different coordinates and then subsequently
move one over the top of the other it accepts that without a complaint?
Does this highlight a flaw in the Editor validation routines? Or is there
something subtly different in the process of creating pads and editing
pads?
Best regards, Martin
  • clem57
    clem57 over 9 years ago
    I can see one application where you have two pins for gnd next to each other with overlap to connect the electrical.
    Clem
