EAGLE User Support (English) How to Import(?) .stp f iles
  • Views 1105 views
mprowe@peritonlane.net
mprowe@peritonlane.net over 10 years ago
When ordering components from Farnell.com, many are listed with related
support.
One of the support files is described as: "CAD Multiple Formats (????.??KB)
EN".
Checking with their on-line support folk, they tell me that they are
definitely Eagle library files.
Unpacking, the downloaded file it seems to be a text file with a .stp
extension.
Can anyone tell me how to process these file to produce a .lbr that I can
use?
Best regards, Martin
  • mprowe@peritonlane.net
    mprowe@peritonlane.net over 10 years ago in reply to autodeskguest
    Jorge Garcia wrote on Mon, 01 February 2016 17:16
    On 2/1/2016 10:25 AM, Martin Rowe wrote:
    Hi Martin,
    This is actually a 3D model and EAGLE can't use that. It seems the
    on-line support folk have been mistaken. The EAGLE library file from
    farnell is usually derlivered as a .scr file when you unzip it.
    If you have a .scr file, all you have to do is open the library you
    want
    the file to be in and then click on the Script icon. Browse to the .scr
    file and double click. BAM!! The part is in your library.
    Best Regards,
    Jorge Garcia
    Thanks Jorge,
    Understood.
    Regards, Martin
    Paul Romanyszyn wrote on Mon, 01 February 2016 16:25
    that I can use?
    The general rule on lib's has been never trust anything you get from
    any
    source. You should check with the data sheet. This usually takes as
    long
    or longer then just making the components and verify them your self.
    Verify with 1:1 test printout and placing the real part on it as
    sometimes the package suffix info is hard to match up with the package
    documentation.
    You also need to customize the pad sizes to your soldering process.
    Paul
    Thank you Paul,
    Yes, I understand the caveats, but the question was ...
    "How to convert an .stp (3d design file) into an Eagle PCB .lbr file".
    I guess I will need a 3rd party product?
    Best regards Martin
    support.
    EN".
    extension.
    Hi Martin,
    If you have a .scr file, all you have to do is open the library you want
    Best Regards,
    Jorge Garcia
    support.
    EN".
    extension.
    use?
    The general rule on lib's has been never trust anything you get from any
    source. You should check with the data sheet. This usually takes as long
    documentation.
    Paul
