EAGLE User Support (English) Trace Clearance
  • Subscribers 179 subscribers
  • Views 1110 views
Trace Clearance
Former Member over 15 years ago
I'm looking for how to increase the amount of black space around each trace.  I am getting freedfm errors because of this and have never experienced this problem before.  I have a circular trace on the bottom layer (that will be cut out later but I don't want my ground plane inside there) and I get insufficient spacing errors on that trace.  Does anyone know how to increase the spacing around each individual trace?
Thanks much,
Connie
    Element 14 User wrote on Fri, 21 January 2011 11:53
    trace.
    Eagle doesn't know nor care what color the space is around your traces.
    This is something you arrange with a board house.  Often you have to pay
    extra for anything other than green.
    trace?
    This is set by the net class definitions.  See HELP CLASS.  There is also a
    global override in the DRC settings.  Use the DRC settings to specify what
    overall design rules you want, then the net class for restrictions specific
    to individual nets.
  • WestfW
    WestfW over 14 years ago
    http://www.instructables.com/id/Make-hobbyist-PCBs-with-professional-CAD-tools-by-/
    this covers all sorts of modifications to the "design rules" to make PCBs more easily manufactured.  It's aimed at hobbyists doing "toner transfer" and etching boards in their sink, but it's useful as a general overview of DRC concepts even for professionally made boards.
    On 1/21/2011 8:53 AM, Connie Ciarleglio wrote:
    Thanks much,
    Connie
    you can draw into the restrict layers to keep polygons ( your ground
    plane i suppose ) out of an area. this is often superior to drawing a
    trace there.
