EAGLE User Support (English) Eagle 6 layer PCB design
  • Subscribers 178 subscribers
  • Views 1295 views
Hello everyone!
I am designing a 6 layer PCB in eagle. I am finished with the routing
already. I have few queries and I would highly appreciate if someone could
clarify it.
1. I have used a polygon for ground plane and named it as $GND. I have also
named all the ground nets as GND. However after creating a polygon and
clicking on ratsnest tool, all the ground nets are still not connected to
ground plane? Why?
2.After checking for DRC errors, I'm getting 1700 errors!!! Most of them
are clearance issues. I can't manually fix all of them. Should I change DRC
clearance setting?
3. I routed critical parts manually first and then I tried to use
autorouter however it routed all the airwires again and autorouter did not
take my manual routing into consideration. What I thought was it would
route only the airwires which I din't route manually. Any clue on this???
I have few more questions but I would wait for someone to reply first.
P.S. I have .sch and .brd file for my design. If someone would like to have
a look and give me suggestions then I would be more than happy to upload it
here.
    Le 22/01/2011 23:43, Sandeep a écrit :
    Hello everyone!
    clarify it.
    ground plane? Why?
    $GND and GND are not identical name, rename your polygon GND and it will
    be OK I think image
    clearance setting?
    You can change the DRC settings but you must respect the clearance/wire
    size / pad size / via size /drill size your pcb manufacturer can reach.
    First thing to do, ask your pcb manufacturer all minimum size/clearance
    your pcb can have, and after you can modify your DRC with these value.
    I don't no I never used autorouter !
    Regards
    Cyril HAENEL
    here.
    On 01/22/2011 05:43 PM, Sandeep wrote:
    Hello everyone!
    clarify it.
    ground plane? Why?
    You either use a polygon name gnd or set the layer to power plane and
    and it's name should be gnd. I think it appends the $. I don't use power
    planes.
    clearance setting?
    A lot could be related to the $gnd polygon.
    Did you use wire or route?
    here.
    I would suggest you start with a very simple a few resistors and one IC
      project with your 6 layer setup and get that to work. Then go and fix
    your real project.
    Don't use power plains just cover the required layers with a polygon's
    for your power and ground.
    Paul R.
    On 1/22/2011 5:43 PM, Sandeep wrote:
    Hello everyone!
    clarify it.
    ground plane? Why?
    clearance setting?
    here.
    Hi Sandeep,
    1. If you are using a polygon the polygon should be named GND not $GND.
    EAGLE will automatically append the dollar sign to a layer name when
    said layer is setup as a supply plane. If you're layer name has a $ in
    it, then it has been defined as a supply plane in which case you
    shouldn't use the polygon.
    It's one or the other do not use a polygon with a $ layer.
    2. Talk to your board manufacturer and ask what are their requirements
    then adjust your DRC to that. Whatever errors are still present after
    you have updated the DRC you must correct manually.
    3. It sound like you used the wire command. In EAGLE the ROUTE command
    is used to lay down traces not wire. Wire is only intended for artistic
    purposes. I know the naming convention is funny but it's still used to
    maintain compatability between EAGLE versions.
    hth,
    Jorge Garcia
    Cadsoft Computer
