EAGLE User Support (English) Tying common nets togeth er?
  • Views 676 views
mprowe@peritonlane.net
mprowe@peritonlane.net over 10 years ago
How do I tie nets together without drawing lines all over the schematic?
Much like I would use a supply component, say +12v or GND. But one that I
could link to my nets.
Like so:
myNet----*       no line drawn but the "star" says that both myNets are
linked      *----myNet
Regards, Martin
  • mprowe@peritonlane.net
    mprowe@peritonlane.net over 10 years ago in reply to autodeskguest
    reece wrote on Fri, 05 February 2016 23:22
    ... or an inter-page label that has a box drawn around it.
    Ahhhhhhh....... Thank you. That was the clue I needed.
    From there I was able to Google and find the (Incy Wincy!) Xref switch.
    Many thanks for helping out a beginner, Martin
    autodeskguest over 10 years ago in reply to mprowe@peritonlane.net
    On 02/05/2016 04:56 PM, Martin Rowe wrote:
    reece wrote on Fri, 05 February 2016 21:25
    All nets that share a name in a schematic are connected, whether there
    is a line drawn or not. Use the "Name" command to set the name of a
    net.
    You can also use the "Label" command to display the name of a net on
    the
    schematic.
    Thank you. Yes, that is very helpful.
    But is there a bit more finesse that we can add to the schematic? For
    example if a line terminates (without warning) on one edge of the drawing.
    How does the reader know that this is deliberate and not just a mistake?
    Are there any dummy components (other than the label command) that flag the
    continuation of this net elsewhere within the diagram?
    That's entirely up to you; Eagle doesn't care. When viewing within Eagle
    if you select a net all of its pieces on the current page will
    highlight, but that's a bit tedious and doesn't help when looking at
    printed schematics.
    My preference is to place labels wherever a drawn net terminates. You
    can choose between a simple label or an inter-page label that has a box
    drawn around it. I also make a point of having a the net line end
    conspicuously, though I've seen plenty of schematics that don't bother
    with such niceties.
    net.
    the
    schematic.
    Regards, Martin
    On 02/05/2016 04:15 PM, Martin Rowe wrote:
    Like so:
    linked      *----myNet
    Regards, Martin
    is a line drawn or not. Use the "Name" command to set the name of a net.
    You can also use the "Label" command to display the name of a net on the
    schematic.
