EAGLE User Support (English) Terminating Eagle - unknown reason
  • Subscribers 189 subscribers
  • Views 612 views
Hi!
I tried to install the EAGLE-win64-7.5.0 on my PC (where is WIN10 PRO 64b, build 1511, language mutation: czech.) The program EAGLE accepts only trial key and after information box is terminated for an unknown reason.
Help me please.
  • clem57
    clem57 over 10 years ago in reply to e14 Contributor
    Follow these steps to install the free EAGLE Light Edition on your system:
    Go to the Download area and get the file that contains the EAGLE program installation data for your operating system (Linux, Windows or Mac).
    Install the file you have downloaded onto your system.
    When you first start EAGLE, you will be asked whether you have a personalized license disk, or whether you want to run EAGLE as Freeware. To use the Freeware license select the “Run as freeware” button.
    Limitations
    The following limitations apply to the EAGLE Light Edition in general:
        The useable board area is limited to 100 x 80 mm (4 x 3.2 inches).
        Only two signal layers can be used (Top and Bottom).
        The schematic editor can only create two sheets.
    Apart from these three limitations the EAGLE Light Edition can do anything the Professional Edition can do. You can even load, view and print drawings that exceed these limits!
    The Freeware version of EAGLE Light adds these limitations:
        Support is only available via email or through our forum (no fax or phone support).
        Use is limited to non-profit applications or evaluation purposes.
    Freeware | Get the EAGLE Light Edition free | CadSoft EAGLE
    Clem
    e14 Contributor over 10 years ago in reply to clem57
    The trial key I get direct from email:  info@cadsoft.de. Here is copy of email part:
    A Free Trial license code for the EAGLE Layout Editor has been requested from
      http://www.element-14.com/eagle-freemium
    Your EAGLE Free Trial license code is
      GURJ-KQOF-GGYP
  • clem57
    Where  trial key come from?
