EAGLE User Support (English) Definitive guide to Eagle.scr Eaglerc.usr Eagle,epf
  • Replies 8 replies
  • Views 1536 views
I suggest that a definitive guide is created that explains the interaction
of the files Eagle.scr Eaglerc.usr Eagle.epf
Less uniformed discussion and support requests will result if this
information is publicised in an easy to understand essay.
Spread throughout the HELP and manual is some of the information but it has
not been brought together into one place.
Much of the information needed is implied but not explained.
Needed, in one place:
Explanations of precedence,  the order in which these files influence the
editors and each other.
The impact of these interactions e.g changes in Eagle.scr not being
effective because of settings remaining in Eaglerc.usr
Discussion on multiple Eagle.scr and guidance for determining which
Eagle.scr is in use
Locations of the respective files including the effect of environment
variables.
Situations where the hard coded defaults are used.
It should include discussion in the context of:
-Project
-Non project
-User (or one of many)
The guide should address issues that may arise from networked environments
and multiple users
The guide should be initially created as a separate downloadable document.
Released via "announce" and  feedback given via "Beta" forums.
After a few iterations it can be included in the manual.
Warren
    Silviu Epure wrote on Thu, 03 February 2011 11:11
    "Olin Lathrop" <<private_email>> wrote in message
    news:iic10c$kcs$<private_email>...
    Morten Leikvoll wrote on Wed, 02 February 2011 05:03
    >> Imho, all relevant settings should be under gui control,
    Nooooo!
    Have a GUI wrapper if you want, but the underlying settings must
    always be
    available in something like the eagle.scr file that can be
    automatically
    copied, edited, archived, manipulated from scripts, etc.
    I propose that all settings (1 or more files) to be accessible from one
    ULP.
    This way a GUI could be designed and easy changed if new settings are
    to be
    added in the configuration.
    I agree.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    "Olin Lathrop" <eagle@embedinc.com> wrote in message
    news:iic10c$kcs$1@cheetah.cadsoft.de...
    Nooooo!
    Have a GUI wrapper if you want, but the underlying settings must always be
    available in something like the eagle.scr file that can be automatically
    I propose that all settings (1 or more files) to be accessible from one ULP.
    This way a GUI could be designed and easy changed if new settings are to be
    Silviu Epure
    "Dunarea de Jos" University of Galati, Romania
    http://www.etc.ugal.ro/sepure
    interaction of the files Eagle.scr Eaglerc.usr Eagle.epf
    Great to see my suggestion triggered a number of replies. Alas they all
    promoted ideas for v6.
    I gather from these forums that v6 will not release for another year. We
    believe (hope) it will be significantly different so the time to a stable
    version could well be longer.
    My suggestion is to support the current version.5.
    Nooooo!
    Yea I agree that all config files should be human readable for the skilled
    computerist, but GUi controlled.
    Am 02.02.2011 17:33, schrieb Olin Lathrop:
    Nooooo!
    I agree wholeheartedly. We have MANY users here that stay for a few
    months and then are replaced by other users with new PCs, so as
    administrator I have to install or reinstall EAGLE quite often. At the
    moment this is just done by copying all files to the new PC and that's
    it (or even by not copying anything, but just starting the thing from
    the server). VERY efficient, very quick. If files like EAGLE.SCR or the
    like would not be available any more, the whole installation would need
    LOTS of steps with the GUI to get it to work properly. So please keep
    the WONDERFUL text files that are SO useful for administration.
    Andreas Weidner
    Nooooo!
    "Warren Brayshaw" <warrenbrayshaw@paradise.net.nz> wrote in message
    news:ii9o80$13f$1@cheetah.cadsoft.de...
    Hopefully, v6 won't have any of these files. Imho, all
    relevant settings should be under gui control, and hopefully everything is
    stored either:
    -default global options (first time use, could be included in the binaries,
    but would be better to allow company preferred options like network paths)
    -user spesific global options (copied from default at first use, then
    modified to users preference)
    -project specific parameters together with brd and sch (in one file).
    I guess as you move down one level, you should be able to override the
    levels above, but not overwrite. And maybe the above levels should be able
    to lock parameters so lower won't be able to change them.
    Brief example1, brd grid:
    -default global:1mm,visible,dot style
    -user spesific:(as default)
    -projct specific:0.1inch (size overridden, but using 'visible' and 'dot'
    from levels above)
    Brief example2, paths:
    -default
    global:projectpath=
    mynetwork\projects\%activeproject%\proj,libpath="
    mynetwork\common\Eagle\libs";"
    mynetwork\projects\%activeproject%\libs"
    -user spesific:projectpath=c:\temp\Eagle\proj (libpath taken from above
    level)
    -project specific:libpath=%eaglerootdir%\lib (keeping projectpath from user
    spesific level)
    And for the next version, Cadsoft might want to revisit which entries
    are project specific, user specific and company specific.
    And implement cascading settings (already suggested).
    Oliver
