EAGLE User Support (English) Verify PCB trace connectivity?
  • Subscribers 178 subscribers
  • Views 484 views
Hello all,
I feel some what daft asking this as I'm sure it must be in there somewhere, how do you run a verify connectivity to check you have no unrouted traces left over? I have looked at ERC/DRC in the manual (and ran them and experimented with them) but can't see that either checks trace connectivity.
Daniel.
    Op Sat, 05 Feb 2011 15:26:04 +0100 schreef Daniel Wainwright
    <solder.splash@virgin.net>:
    Hello all,
    trace connectivity.
    Daniel.
    If you do a ratsnest, in the lower left corner it will tell you if, and
    how many, airwires are left. Although strictly speaking not every airwire
    means an unrouted trace (it could be a stub for some component slightly of
    grid), it's an indication you could check.
    Richard
    Former Member over 14 years ago in reply to Former Member
    Thank you Richard, I hadn't noticed the airwire stats in the bottom left. As you say, that will at least give me some idea that I need to go through and try to find unrouted traces. I also since realised that I can turn of all layers in display then just enable the 'Unrouted layer' to see it any bits have been missed! Easy when you realise... I just haven't been looking on the right places / thinking about it the right way. Far too used to clicking on DRC->Connectivity in _another_ CAD package.
    Thanks again,
    Daniel.
