EAGLE User Support (English) External text editor - again
  • Subscribers 191 subscribers
  • Views 1324 views
Had a crash on my machine last week. All the important stuff was backed up
so just an annoyance... Lost a few configuration files.
Went to re-install Eagle 5.11 and set Notpad++ as my external editor. Was
making me absolutely crazy as I would enter the path and next time the
program opened, path was corrupted.
This is what finally worked (copied from eaglerc but entered from control
panel - Options - User interface). note that the eaglerc entry has an extra
set of quote marks bounding the entire string.
Interface.ExternalTextEditor = ""c:\Program Files\Notepad+\Notepad+.exe"
"%F""
Every time opened Eagle, the editor string was showing \ otepad++...
Finally realized that Case was *important*
I had originally entered the string as "c:\program
files\notepad+\notepad+.exe" "%F"
Was able to duplicate this by putting the errant string into the external
text editor box.
Another one of life's little mysteries solved - Oppie
  • pacav69
    pacav69 over 9 years ago in reply to barrattk
    Using Sublime text editor as an external editor in eaglecad use the following including quotes and "%F" for file opening.
    for macs
    "/Applications/Sublime Text.app" "%F"
    for windows
    "C:\Program Files\Sublime Text 3\sublime_text.exe" "%F"
  • barrattk
    barrattk over 13 years ago
    I'm using Eagle 6.3.0 and I've just had a similar problem but the solution given by the OP did not work for me when accessing the setting via the 'Control Panel window -> Options -> User Interface ->External Text editor' setting
    I ran into problems with the %F quotes.
    In the end I used:
    "C:\Program Files (x86)\Notepad++\notepad++.exe" %F
    with no extra quotes
    Cheers,
    Keith
    "Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
    news:ijinj4$rnn$1@cheetah.cadsoft.de...
    Klaus Schmidinger schrieb:
    I see you are both old timers in the business also. Brought a smile to my
    face. Escape characters, CP/M and Teletypes... Think I'll read my intel
    i8008 programming/design manual again for old time's sake.
      Cheers
    e14 Contributor over 15 years ago in reply to kcadsoft
    Well, (ab)using the backslash ('\', which originally is an "escape" character)
    as the directory delimiter is one of Microsoft's "original sins" image
    The others are using "\r\n" (two separate bytes, 0x0D/0x0A) instead of
    a single '\n' (0x0A) as the line delimiter, and using the forward slash
    as the "option" marker instead of the dash ('-').
    I think these other two have much longer histories than Microsoft
    itself, and every OS had its own separators those days. (For example, in
    CP/M the options started with square brackets.) The CRLF pair as line
    delimiter is really old and has its cause (teletypes would only feed a
    line, but won't start at its beginning, if given just the LF).
    In fact you feel the "right" way of doing something is the way you are
    used to, and your background obviously are *ix systems and their
    conventions.
    However, I agree that using the backslash as directory delimiter
    really is a sin - as is using case sensitivity in *ix systems and the
    C programming language. These "broken by design" details, however, will
    persist - it's far too late to change them now. :-\
    Tilmann
  • kcadsoft
    kcadsoft over 15 years ago
    "%F""
    text editor box.
    Oh well...
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
