EAGLE User Support (English) How to tell what drill precision is being used?
  • Subscribers 181 subscribers
  • Views 785 views
Former Member over 15 years ago
Hi there,
I'm pretty much going nuts here trying to generate the Gerbers for
Olimex.  I've followed their guide for generating the required files
which you can find under "Eagle" at this link:
http://www.olimex.com/pcb/index.html.  But whatever I do I get garbage
when I try to load the resulting Gerbers into Viewplot.  They suggest
modifying the "bin/eagle.def" file with the EXCELLON entry that follows.
I can generate a bunch of Gerbers fine if I use an old modified
Sparkfun CAM job but am having no luck with the Olimex flow.
How can you tell what drill precision has been used to generate a drill
file?  The other layers look fine if I deselect 'mirror' from the
bottom layers but the drill file never matches.
Thanks, Shareef.
Type = DrillStation
Long = "Excellon drill station"
Init = "%%\n"
Reset = "M30\n"
ResX = 100000000100000000
ResY = 100000000100000000
;Rack = ""
Select = "%s\n" ; (Drill code)
Drill = "X%6.0fY%6.0f\n" ; (x, y)
Info = "Drill File Info:\n"\
"\n"\
" Data Mode : Absolute\n"\
" Units : 1/1000 Inch\n"\
" End Of Block : CR/LF\n"\
"\n"
    "Shareef Jalloq" <shareef@jalloq.co.uk> wrote in message
    news:il6em7$53c$1@cheetah.cadsoft.de...
    Hi there,
    I'm pretty much going nuts here trying to generate the Gerbers for Olimex.
    I've followed their guide for generating the required files which you can
    find under "Eagle" at this link:  http://www.olimex.com/pcb/index.html.
    But whatever I do I get garbage when I try to load the resulting Gerbers
    into Viewplot.  They suggest modifying the "bin/eagle.def" file with the
    I can generate a bunch of Gerbers fine if I use an old modified Sparkfun
    file?  The other layers look fine if I deselect 'mirror' from the bottom
    Thanks, Shareef.
    Type = DrillStation
    Init = "%%\n"
    Reset = "M30\n"
    ;Rack = ""
    "\n"\
    "\n"
    You may look for this setting on your gerber viewer import and leave the cam
    job alone. It is probably fine.
    Doug
    Former Member over 15 years ago in reply to Former Member
    the cam job alone. It is probably fine.
    Doug
    I'm using Viewplot which allows me to specify the drill precision when
    I read in all the Gerbers.  With my normal flow I select 2.4 and
    everything just works.  I've tried 2.3, 2.4, 2.5, 3.4, 3.5 and none of
    them look correct.
    The flow I'm using is:
    1.  Run drillcfg.ulp
    2.  Run excellon.cam using the supplied edits to eagle.def
    3.  Run gerb24x.cam
    I've tried running step 1. with both mm and inch as the unit specifier.
    Same result.
    Thanks.
  • Richard_H
    Richard_H over 15 years ago in reply to Former Member
    Am 09.03.2011 10:39, schrieb Shareef Jalloq:
    >> Doug
    I'm using Viewplot which allows me to specify the drill precision when I
    them look correct.
    1.  Run drillcfg.ulp
    3.  Run gerb24x.cam
    Same result.
    Thanks.
    please try the following definition which contains more information
    about the data format used:
    Type     = DrillStation
    Init     = "M48\n*INCH,LZ,00.0000\n"
    Reset    = "M30\n"
    ResX     = 10000
    ResY     = 10000
    ;Rack     = ""
    DrillSize  = "%sC%0.4f\n"        ; (Tool code, tool size)
    AutoDrill  = "T%02d"             ; (Tool number)
    FirstDrill = 1
    BeginData  = "%%\nM72\nG90\n"
    Units    = Inch
    Drill    = "X%1.0fY%1.0f\n"      ; (x, y)
               "\n"\
               " Units             : 1/10000 Inch\n"\
               "\n"
    Richard Hammerl
    Former Member over 15 years ago in reply to Richard_H
    On 2011-03-09 10:20:49 +0000, Richard Hammerl said:
    Sorry, I'm confused.  Doesn't this define how the tool outputs the
    drill data for the board?  So by modifying it to what you suggested I'd
    be diverging from what my board house have requested?
    Shareef.
  • Richard_H
    Am 09.03.2011 21:52, schrieb Shareef Jalloq:
    >> Hi,
    Sorry, I'm confused.  Doesn't this define how the tool outputs the drill
    data for the board?  So by modifying it to what you suggested I'd be
    Shareef.
    The modified EXCELLON device has some additional information in
    the header so that a software or the drilling machine gets better
    information about the data format, units, precision....
    The coordinates of the drill holes remain unchanged in this case.
    Richard Hammerl
