EAGLE User Support (English) #include "directory/file.ulp"
  • Subscribers 183 subscribers
  • Views 314 views
Former Member over 15 years ago
I've been working on a ULP that is a bit involved & spread across
multiple files and directories.  I am having trouble getting files
located in one directory to be able to reliably include files from
another directory.  The documentation I've found is very thin & doesn't
really cover how to do this indepth.
From what I have determined, the include path is affected by the location
where the eagle binary was invoked.  How can I work around this?  I would
expect that since eagle has the 'default ulp directory list', the file
path should somehow be relative to that location, but it doesn't appear
to be.
Any thoughts?
Wes
    I may not have been very clear, so I'll try a simple example.
    File list:
    a.ulp
    b/b.ulp
    c/c.ulp
    a.ulp can include b/b.ulp or c/c.ulp using:
    #include "b/b.ulp" /* or c/c.ulp */
    How can I enable c/c.ulp to be able to include b/b.ulp?
    #include "b/b.ulp" /* Fails */
    #include "../b/b.ulp" /* Fails */
    #include "/b/b.ulp" /* Fails */
    Why would I do this?  To try to make the directories as clean as possible
    (given I've got around 20 files and still growing).  The worst case
    scenario is to dump them all in 1 directory & rename everything (sigh).
    unit-test.ulp
    program.ulp
    calc/calc_a.ulp
    calc/calc_b.ulp
    unit-tests/test_calc_a.ulp
    unit-tests/test_calc_b.ulp
    unit-test-framework/framework.ulp
    Did that help?  Any ideas?  Should I stop trying?
    Wes
