Hello all,
I'm working on a high current application and wanted to increase track
size but adding a track to both the top and the bottom of the board. My
starting point is a fuse and I wanted to add a copper area under the fuse
connections on both the top and bottom and connect the two layers with a
few Vias so then when added to the board I could simply connect a track to
top and bottom of the fuse output.
That don't seem to be possible in the library editor? Am I missing
something or is there another way to do this?
Web access to CadSoft support forums at www.eaglecentral.ca. Where the CadSoft EAGLE community meets.
