EAGLE User Support (English) Missing components in the library...
  • Replies 37 replies
  • Views 4174 views
Still using the free version and still at newby silly question level.
I am creating (at least trying to) my first PCB board which is going to be a PMW. I started by ordering all the coponents from digikey (got an head acke with their web tool..)
My coponents are in my ordering list:
* SN74ACC14N: Found it sounds good
* EVU-F3lFL3B14 (potentiometer): even with the datacheet I do not find it
* 1N5817 (diode): can not find it... 9there is of course some close enough)
* BUL704 (NPN) was not able to find it directly but using the number of the datasheet TO-220 whihc was not in the database either I end up finding it using TO220...
* 1N914BTR (diode) was not able to find it... (same thing found stuff close enough after some time but my electronic level is limited)
And the list is going a like that on every conponent.
My frustration level in rising, I spent more time looking ofr the components that I will spend on creating the board (step that I have note reached yet...)
So simple questions:
1) I am doing something wrong?
2) If I am not doing anything wrong where can I find an extended library of components?
3) If netheir one or two are possible, how do you proceed on your side to order components? you try to see if they exist in Eagle then in DIgikey (for example) and then only order them?
Thank you for your help
    On 3/17/2011 10:09 PM, badbad2142 wrote:
    Thank you Joerg.
    Quoi comme frommage, un chevre par exemple? le boursin ne me dit rien pour l electronique...
    I have been able to create my two first items in my library (thanks to kd7vnn http://www.instructables.com/id/How-to-make-a-custom-library-part-in-Eagle-CAD-too/).
    I undertsand what you say about 50% of the job but when you are just doing it once in a while it is a bruden... but it is ok.
    Now that I here one more question: Why do I struggle so much to have a connection between my wire and my components? one time out of two it does not requognize each other... is there a parameter to make that more automatique?
    Hi Alex,
    I know making components in the library can be a pain. Have you tried
    out the make-device-package-symbol-bsdl.ulp included with EAGLE? It
    doesn't do everything but can speed up the process of creating ICs and such.
    Maybe it's worth a look.
    hth,
    Jorge Garcia
    On 18.03.11 4:09 AM, badbad2142 wrote:
    Thank you Joerg.
    Maybe your component is off the grid and you have to press "Alt" for the
    alternate grid. I had some unconnected components due to this when I
    first started using Eagle.
    Thank you Joerg.
    badbad2142 wrote:
    Thank you both for your answers.
    My mail adress is abessy@free.fr (mailto:abessy@free.fr) image
    I was hoping to spend more time to design the PCB and less on the components selection but I understand that all of them can not exists. It is just hard from the point of view that I am not doing PCB often (in fact it is the first) nor I am working in the electronic field so I am not fluent with the components equivalence (yet).
    Just a comment from a guy who does electronics design for >25 years:
    Packaging, component selection and the creation of library parts is
    boring but it is often 50% of the job. Especially on cost critical
    designs. So it is very important to learn the library editor of a new
    CAD system very soon. Eagle isn't particularly easy to learn in that
    respect but with persistence you'll get there.
    Afterwards, when you haven't used the program for a while it is normal
    to forget things.
    By the way, the Digikey search engine is hands down the best there is,
    there ever was. If you learn how to use that (easy) it becomes a
    wonderful tool to find electronic parts. And now they also let you sort
    by price.
    But I will get at it then...
    En peu du vin rouge, du fromage et la bonne musique ... and it will all
    come together nicely image
    Cordialement, Joerg
    My mail adress is abessy@free.fr ;-)
    Thank you again for your answers.
    Regards
    Alexandre Bessy
    Am 15.03.2011 21:51, schrieb badbad2142:
    I am creating (at least trying to) my first PCB board which is going to be a PMW. I started by order all the coponents for m digikey (got an head acke with their web tool..)
    My coponents are:
    • SN74ACC14N: Found it sounds good
    • EVU-F3lFL3B14 (potentiometer): even wiht the datacheet I do not find it
    Sorry, no email adress to send the extended lbr.
    • 1N5817 (diode): can not find it...
    Use diode.lbr -> device DIODE- with package variant DO41-10 and set the
    VALUE to 1N5817.
    • BUL704 (NPN) was not able to find it directly but using the number of the datasheet TO-220 whihc was not in the database either I end up finding it using TO220...
    Use transistor.lbr -> device *-NPN- with package variant TO220 and set
    the VALUE to BUL704.
    • 1N914BTR (diode) was not able to find it...
    Use diode.lbr -> device DIODE- with package variant DO35-10 and set the
    VALUE to 1N914BTR.
    And the list is going and going like that on every conponent.
    Plase read
    HELP USE (enter)
    HELP ADD (enter)
    Alfred Zaffran
    _____________________________________________________________
                                 Web:   <www.cadsoft.de>
    Geschäftsführer: Dipl.-Ing. Klaus Schmidinger, Bodo Badnowitz
    On Tue, 15 Mar 2011, badbad2142 wrote to us saying :
    >Hello,
    >My coponents are:
    >* EVU-F3lFL3B14 (potentiometer): even wiht the datacheet I do not find it
    Manufacturer part numbers for pots are often of little use. Most
    designers are more interested in form factor. That said, the standard
    Eagle libraries are short on pots (there's a good selection of presets
    but few of the shaft-and-knob types).
    Diodes are a classic example of generic parts, where the library
    component doesn't match the part number because 57 varieties of diode
    all share the same circuit symbol and package. Look in the diode library
    under D-fill and select the package that matches the 1N5817 (check sizes
    or package names on the data sheet). Then once you've placed it on the
    schematic, set its "value" to 1N5817 and you're done.
    Again, there are a LOT of TO220 NPN transistors out there, so the
    component is generic. There are also specific transistors in the
    library, partly because of the potential confusion of pin ordering (so
    it's worth checking that the library part you picked matches your data
    sheet, although TO220 is much more standardised than, say, TO92)
    Again, you can use a generic D-fill and pick the right package. Note
    that the 1N914 is practically identical to the 1N4148 too.
    >So simple question:
    Yes and no. You're expecting exact part numbers where generic
    descriptions are used.
    >2) If I am not doing something wrong where can I find an extended
    Cadsoft web site, in the downloads section.
    >3) If netheir one or two is possible, how do you proceed on your side
    Sometimes I check what Eagle already has and order that, but more often
    I either have a specific device in mind or already have a drawer-full.
    If none of the Eagle libraries includes the part then I create my own
    library part.
    If you look back through the archives of this group you will see this
    repeated time after time: Learn to create your own library parts! It's
    not hard, and you're going to have to do it sooner or later. It will
    release the power of the tool and enable you to design what you want,
    not what somebody else had left lying around. Don't look on the limits
    of the existing libraries as a drawback, look on the ease of adding new
    ones as the huge plus that it is.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
