EAGLE User Support (English) Adding parts to schematic not on the boar d
  • Replies 11 replies
  • Subscribers 187 subscribers
  • Views 1027 views
The board I'm working on drives a transistor (and other stuff)that is not
on the circuit board but I need to show it in the schematic so I know what
it is and so I have complete documentation of the circuit. I have the
outputs from the board going to through holes and I want the board to end
there. I want to add the other stuff to the schematic but not have it show
up on the board.
How do I do this? I presume there is another schematic layer to put this
stuff on so it doesn't show on the board?
Sage
    Am 17.03.2011 14:05, schrieb Dave:
    up on the board.
    From scratch, EAGLE cannot do this. Using one of my ULPs, you can place
    whatever 'real' parts you want on the sheet (including their board
    counterparts) and afterwards convert these things into pure graphics on
    the sheet (which deletes their board counterparts again). See my post
    'Rein graphische Symbole im Schaltplan zeichnen' from 2010-10-22 in the
    newsgroup 'eagle.support.ger'. Depending on your EAGLE installation, the
    ULP dialog should display texts in German or English. Hopefully it works
    for you.
    Andreas Weidner
