EAGLE User Support (English) Adding parts to schematic not on the boar d
  • Replies 11 replies
  • Subscribers 187 subscribers
  • Views 1017 views
The board I'm working on drives a transistor (and other stuff)that is not
on the circuit board but I need to show it in the schematic so I know what
it is and so I have complete documentation of the circuit. I have the
outputs from the board going to through holes and I want the board to end
there. I want to add the other stuff to the schematic but not have it show
up on the board.
How do I do this? I presume there is another schematic layer to put this
stuff on so it doesn't show on the board?
Sage
    As has been discussed here the solution is to add the schematics-only
    components as drawing on the schematics. I asked this question a couple
    of days go in eagle.support.eng and this is my the conclusion.
    Sorry I didn't see it in the original message. I have it now and I'll give
    it a try.
    Sage
    Am 18.03.2011 07:50, schrieb Dave:
      I'd still be interested in the ULP that converts schematic entities to
    "graphics". If you can give me the name of it I'd appreciate it. I searched
    the ULP library and could not locate it.
    That's because it is NOT in the ULP library, but only in the ZIP file
    attached to my former post. Please find a copy attached to this e-mail.
    Usage:
      1. Unzip BOTH files into your ULP folder.
      2. Open the project of your choice.
      3. In the schematics (with board open and f/b-annotation intact), add
         all parts, nets, etc. that you need as usual and just ignore the
         stuff that appears on board.
      4. Create a group of everything that you wish to convert to
         pure graphics (without any mechanical or electrical function).
      5. Type 'run explode', select some options and afterwards 'OK'.
      6. All previously grouped things are converted to lines, circles,
         text etc., and their board counterparts are deleted.
    I hope this works properly with you. Of course, the other posts telling
    you to 'create a library symbol without package' also work, but they
    need a separately drawn library part for everything that you decide to
    connect via wires, while my ULP works with just about EVERY library part
    that has already been created (hopefully).
    Andreas Weidner
    Andreas:
    Sage
    On 3/17/2011 1:13 PM, Dave wrote:
    Ok. So far I've only made a few parts myself so I'm not really familiar
    with making parts with chosen net names (I don't think).  So I guess what
    your saying is you create a part like a transistor that has no outline -
    just pads? SO when it gets placed on the board all you see is pads not an
    outline. Normally when you place a part you see it's ouline on the board
    and need to allow space for it. Without an outline I guess I would just see
    pads and I could place this right in the middle of a board if I wanted? -
    no space required other than for the pads?
    I might need and example to study.
    I'll have to think about this a bit but I think I see what your getting
    at.
    It may also be beneficial to have the other suggested method of converting
    sections of the schematic to a picture (so to speak) so I can put larger
    connection diagrams etc. More than what I'd want to put create into a
    "part".
    Sage
    Yes, you've got it, the footprint is not the package footprint, just a
    set of holes for wires. This works pretty good if you have a single
    offboard component, except you can't rearrange the holes on the board
    and you need to make a "custom package". It gets a little more awkward
    when the offboard components connect to each other on the panel. A lot
    of this could go away if hierarchical drawings were part of EAGLE, but...
    I support the addition of an EAGLE native method to deal with off board
    components, such as a special layer or null package.
    at.
    "part".
    Sage
    On 03/17/2011 02:57 PM, Dave wrote:
    Maybe I'm not understanding what your getting at but I don't see how your
    suggestion solves the problem of NOT having the parts show up on the board
    (I just want them in the schematic).
    Let me give you the example:
      I have an ignition system circuit and circuit board. Off the board is the
    power driver IGBT, the coil and some connections to the battery and
    sparkplug. I want to include that stuff in the schematic because it has the
    part number for the transistor, winding info for the coil and the
    connections of them to the circuit, the battery and spark plug. This
    information is important for documentation purposes but is not part of the
    circuit board layout to be created.
      I like to have all the circuit documentation in one place not have to
    piece it together from a bunch of sheets.
    Andreas' solution seems to be the way to go.
    Sage
    Your off board part is an on board part connected by wires to your board.
    Make a off board IGBT part. It has 3 pad for the layout. The IGBT and
    info shows on the sch. On the layout only three plated holes which can
    be assigned net names so they connect to the correct place in the circuit.
    When you place your IGBT on the sch and connect it to the next you will
    have 3 pads that have the correct net names/
    The IGBT symbol you make or modify would have a dashed line around it to
    signify off board.
    Off topic.
    Years ago I developed a high power CDI ignition.  1 uf at 600V with a
    1/2 cycle sent via a scr to the standard spark coil.
    It made engines run very good at very lean mixtures but we had issues
    with the spark plugs breaking down at 0.075" or larger plug gap.
    Paul R.
    Sage
    On 03/17/2011 02:09 PM, Dave wrote:
    I managed to find the message thread but unfortunatly I can't read German
    so I can't pick out the ULP name. As much as I'd like to read the dialog
    about it, perhaps you can just give me the name of the ULP and I'll search
    for it in the ULP library.
    Did I miss something here?
      BTW, thanks for creating it. I'm surprised Eagle can't do this by putting
    the parts on a special layer or something. This makes it difficult to
    properly document a circuit which has parts off the board.
    Perhaps something to add in future releases.
    Sage
    If you are connecting the off board parts by wires why not make a device
    which has the schematic symbol you need and has the pads for the wires
    with correct silkscreen info. One problem with this is if you use random
    locations to place your wire pads you would have to modify the pad
    locations in the lib.
    Paul R.
    Sage
