EAGLE User Support (English) 4 Layer Gerber Generation
  • Subscribers 178 subscribers
  • Views 658 views
  • board
  • layer
  • 4
  • gerber
  • layers
I'm working on a 4 layer mixed signal board. I'm  working on generating gerbers but it seems to not be working correctly. This could just be my ignorance, but I want to make sure I get this right.
My layers are stacked up as such right now:
Signals
Digital Ground
Supply
Signals
When I generate my gerbers, I run into no problems. When I go to view the gerbers of the internal layers, I'm expecting to see planes with isolation around vias that should not be connected to that layer. However, I'm only seeing filled in pads and vias. I'm always confused when interpreting gerbers, but that certainly doesn't seem right to me.
I'm confused with what I'm looking at, as it isn't what I am anticipating, so it may be correct, I just want some reassuarnce.
Thanks!
    On 03/23/2011 08:35 PM, rybarnes wrote:
    Signals
    Digital Ground
    Supply
    Signals
    Thanks!
    If you use a supply layer type then the output is negative. What yous
    see on the Digital Ground and Supply are missing copper.
    If you change the supply layer to a normal layer and then put down named
    polygon(s) covering the layer. Name the ploygon the net name you want
    the plane to be. The gerbers should then all be positive.
    Paul R.
    Former Member over 14 years ago in reply to Former Member
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
    news:imefgc$od7$1@cheetah.cadsoft.de...
    >> Hi,
    >> Signals
    >> Digital Ground
    >> Supply
    >> Signals
    >> Thanks!
    If you use a supply layer type then the output is negative. What yous see
    polygon(s) covering the layer. Name the ploygon the net name you want the
    Paul R.
    You should include a text file in your Gerbers with your contact information
    as well as a description of the layer files:
    xxxxx.001    Layer 1 Signal Layer
    xxxxx.002    Layer 2 Supply Layer
    xxxxx.003    Layer 3 Supply Layer
    xxxxx.004    Layer 4 Signal Layer
    'Supply Layer'  would be interpeted as a negative layer.
    If you change that to positve in eagle, you should note it the description
    file for the board house.
    eg:  xxxxx.003    Layer 3 Signal Layer
    The board house does not care about the function of the Layer.
    It helps to avoid confusion and you will get boards made the way you want
    them to be.
    Cheers
    "Martin" <martin_rid@verizon.net> wrote in message
    news:imgcgp$ti7$1@cheetah.cadsoft.de...
    information as well as a description of the layer files:
    them to be.
    Afaik, gerber has instructions to tell the layer is negative, but Eagle
    doesn't use them?
    Morten Leikvoll wrote on Fri, 25 March 2011 04:34
    doesn't use them?
    I don't know, but I have never had a board house misinterpret a gerber file
    from Eagle or even ask about positive/negative.  I know Eagle does
    sometimes produce negative gerber files, because I've seen that in the
    gerber viewer when I do a quick check of the files before sending them
    out.
