EAGLE User Support (English) Aligning D-Sub Pins
  • Replies 10 replies
  • Subscribers 178 subscribers
  • Views 1035 views
Aligning D-Sub Pins
Hello!
I am trying to precisely align a d-sub 25 connector on a PCB according to a
technical drawing provided by a company. In the drawing the part is aligned
based on the top left pin in the d-sub assembly.
My problem is that the coordinate locus for the dsub connector in EAGLE is
in the center of the part, with dimensions to the top left pin arbitrarily
defined. I am attempting to match/ move the entire pin assembly such that
the top left pin is the coordinate locus for the entire part.
Does anyone have any tips?
Please let me know if this needs to be clarified.
Alex
    On Thu, 31 Mar 2011, Alex wrote to us saying :
    Yes: get the "company" to provide a more useful drawing. The exact size
    of a D-sub connector is quite well defined, but nobody really cares
    where the corner pin is. The people designing the case need the outline,
    and the PCB designer needs all the pins. The standard way to specify the
    position is by the centre, just like Eagle does.
    Alternatively, get a data sheet of D-sub connectors and it will tell you
    what offsets you need to add to the supplied drawing to find the centre.
    Then locate the standard library part on your PCB at that location.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    On 03/31/2011 04:44 PM, Alex wrote:
    Hello!
    Alex,
    Try this:
    Open the library from which you added the connector to the schematic and
    examine the package.  Show the properties of pin 1 and note the
    coordinates.  These are relative to the center of the part.
    On the PCB, add or subtract these coordinates to those that are provided
    by the company, and do a precise move.  By "precise", I mean type
    something like this in the command line text box:
        move J3 (newXCoord newYCoord)
    Of course, replace J3 with whatever name your connector has.
    Enjoy,
        - Chuck
    On 3/31/2011 4:44 PM, Alex wrote:
    Hello!
    Alex
    I think you need to use the library editor to examine the
    package/footprint for the D-sub connector.   By using the info command
    you can get the exact coordinates for the top left pad/hole in question
    relative to the part origin.    Once you know the coordinates of the top
    left pin relative to the package/part origin a little math will tell you
    where you need to place the part on the board to get the top left pin in
    the right spot.
    Jim
    Alex wrote:
    Hello!
    according to a technical drawing provided by a company. In the
    drawing the part is aligned based on the top left pin in the d-sub
    assembly.
    EAGLE is in the center of the part, with dimensions to the top left
    pin arbitrarily defined. I am attempting to match/ move the entire
    pin assembly such that the top left pin is the coordinate locus for
    the entire part.
    A couple of hints.
    The responders have all suggested using the current library part, finding
    the offset of pin1 relative to the part's origin and offsetting the part by
    this much so the part ends up with the pin1 in the correct place.
    Verify the placement using MARK. You can measure back to the point the
    company provided as the reference point.
    Alternatively you make a device variant that has the origin on pin1
    Create a copy of the library package. GROUP and move all the package content
    so pin1 ends up at the origin point. This a new package which you use to
    create a variant within the device.
    HTH
    Warren
    Former Member over 14 years ago in reply to Former Member
    Warren, this is exactly what I want to do. How can I group and move the
    entire pinset such that the top left pin is at exactly the origin?
    For being a precision tool, EAGLE sure makes it difficult to decide exactly
    how to place that origin...
    I would:
       grid finest
       show all layers
       group all elements of drawing
         click move button
         right click the new origin pin
         type (0 0) into command line and hit enter.
    fix layers
    grid last
    This almost worked, it was off by about 1.5mils from the origin of the
    part. You have to be sure right click at the exact center of the new
    origin pin, by zooming, to get it better.
    the entire pinset such that the top left pin is at exactly the origin?
    exactly how to place that origin...
    The origin of the part is established when the library part is created. It
    cannot be done/changed in the board editor.
    You can only move the origin if you modify the library part.
    Normally for this use you would not modify the existing part package but
    create another package, initially copied from the current package, and use
    that to create a device variant, the package of which has the origin on pad
    1.
    If you are struggling with the process to perform what I have said I
    susupect  you have not spent the time to read the manual and worked through
    the tutorials for creating library parts. If you are to be successful with
    Eagle, part/library creation is a 'must have' skill.
    If you wish to avoid doing this then use the method proposed by others to
    get the package/pad located as desired and then confirm it is placed
    corrrectly relative to your reference point. You will need to use similar
    techniques to do it this way  as you need when doing it the library way.
    If you want a very easy  'eye-ball' method I would do it as follows:
    Place a MARK, using the command line, at the position you want the pad. If
    you have done it correctly this willl be the exact position you need to move
    the pad (the whole DB9) to.
    Then set the ALT grid to finest.
    Next grab the DB9 and with the ALT key depressed, so the Alt grid is active,
    move the DB9 until the pad is over the MARK cross. You should continue to
    increase the magnification as you get closer and closer which you do with
    the scroll of the mouse.
    HTH
    Warren
    "Alex" <omegacore@gmail.com> wrote in message
    news:ing4vv$9rk$1@cheetah.cadsoft.de...
    exactly
    Its not hard. You just need to learn the basics.
    Here is a general way for any kind of grid:
    -Find the coord of the new origin (x y)
    -Make sure all layers are visible
    -Type the command "group all"
    -Type the command "move (>cx y) (0 0)" where x and y is the coord of the new
    origin you want.
    You're done!
    The '>' simulates a right mouse button click, and the 'c' simulates ctrl
    button. This is more convenient to do with a command than the mouse, cause
    the mouse resolution isn't good enough, and the mouse pointer coordinates
    may be affected by the grid.
    On Wed, 6 Apr 2011, Morten Leikvoll wrote to us saying :
    And because point-and-click type interfaces are fundamentally the wrong
    tool for high precision. That's why we need grids in the first place. If
    you want to be very precise about where to put things, you need to be
    precise in what you instruct the tool to do. For that you need a command
    line.
    this message are    |
    Don't believe a     |
    word.               |
    >origin you want.
    the 'c' in 'move (>cx y) ...' is not neccessary - but won't hurt
    either
    Lorenz
