EAGLE User Support (English) DRC Errors
  • Subscribers 178 subscribers
  • Views 298 views
DRC Errors
Hello everyone,
I did a design rule check and I am getting some errors as shown hereunder.
higher quality
http://i53.tinypic.com/313q5go.png
http://i53.tinypic.com/5o7c06.png
I Have 794 Errors image
Errors are
(Angle)
(Off Grid)
Can anyone help me so I can fix them, as I am still learning how to use
Eagle.
    Matthew wrote:
    Hello everyone,
    hereunder.
    higher quality
    Errors are
    (Angle)
    (Off Grid)
    For the Angle errors:
    DRC/Misc/Check Angle
    Warren
    On Sat, 2 Apr 2011, Matthew wrote to us saying :
    >Errors are
    >(Angle)
    >(Off Grid)
    The angle errors are mostly tracks within pads, which result from
    off-grid pads if you route to the pad but not if you route from the pad.
    However, it looks like you've set the grid to 2mm when using traditional
    0.1" through-hole components. This is a bad idea. You should set the
    grid to 0.05" for this sort of board.
    When routing to components with pad-spacing that doesn't match the grid,
    always try to start from that pad and lay a track to somewhere on-grid
    before routing further. Also, if you're going to run with the
    angle-check enabled, be careful to never use the direct-line routing but
    keep the route settings on one of the right-angle or 45-degree modes.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    Former Member over 14 years ago in reply to Former Member
    >> hereunder.
    >> Errors are
    >> (Angle)
    >> (Off Grid)
    I would go down to .025, it's usually good to set the routing grid to
    1/4 or 1/5 the smallest pitch. And keep it in the same measurement
    system as the most common components to minimize the procedure that
    Robert talked about with routing from, rather than to, pads.
    "Angle" just checks if you have tracks at other than 90, 45 or 0 degree
    orientations, they aren't really problems other than esthetic and show
    that you didn't use the routing grid, which you already know.
