please bear with me, I am new to Eagle.
Let's say we have a 2 layer board. A via is supposed to consist of a
vertical plated hole and two horizontal outer annular rings on the top and
bottom layers. These rings connect the plated hole of a via to the wiring.
My PCB manufacturer requires all vias to have annular rings on both outer
layers otherwise they treat it as a non plated hole.
In layout editor when I place a via I can see a green rectangle and an inner
circle showing the hole.
Problem: when I display layer 1 and 16 (top and bottom, by switching of all
other layers including layer 18, vias) I can see NO annular rings around
vias, i.e. my PCB manufacturer will treat it as a non plated hole.
Thanks for any feedback!
Peter
