EAGLE User Support (English) cadsoft eagle 5
  • Subscribers 186 subscribers
  • Views 401 views
cadsoft eagle 5
Former Member over 15 years ago
hi there i am new to eagle. although i am getting used to the library. and i can create a schematic. but thats when i get stuck. i place the components on the board. after that frustration sets in. how do i print a board out in black & white without all the components still there. i cant resize it. i dont know if it did work. how to make it single sided.
any advise is welcome please help. andy-------
    Hi ...
    Do you mean how to print the bottom trace as black and white ?
    Use the "Cam Job" , and select PS or PS-Inverted as device.
    Sincerely
    -bino-
    Where is your location, you can contact e絡盟 technical support team to help.
    Hong Kong : 852-9882 1241
    China : (86) 400 820 3793
    Taiwan : (886) 0800 868 880
    If you are located in other countries, you can also find their contact at element14.com
    By the way, do you know the latest Eagle edition has the design link function that you can find the electronic component after your product design?  You can also upgrade to the latest 5.11 version for free.
