EAGLE User Support (English) What are these layers for?
  • Views 1112 views
I have not found any documentation describing the use of these layers:
31 tCream
32 bCream
33 tFinish
34 bFinish
35 tGlue
36 bGlue
37 tTest
38 bTest
47 Measures
48 Document
49 Reference
51 tDocu
52 bDocu
97 Info
98 Guide
I believe that Eagle does not really use them.  Are they for whatever
purpose we want?
Robert
    Jorge
    Thanks for the info.  My question has finally been answered.
    Thanks again,
    Robert
    On 5/4/2011 8:04 AM, Robert A. Rioja wrote:
    On 5/3/2011 5:52 PM, Olin Lathrop wrote:
    >> rrioja wrote on Tue, 03 May 2011 15:37
    >> Then you didn't try very hard, including the obvious HELP LAYER.
    Thank you all for your replies. However, my question is still
    unanswered. It is obvious that the Cream layers are for cream, and Glue
    layers are for glue. But what are cream and glue used for? What are the
    Finish layers for? Are they for components made in Finland? The layer
    names Document, Reference, Docu and Info seem redundant. What are they
    for and how are they different? How about the Guide layer? Will it guide
    me through the layer names better than Help Layer did?
    Thank you,
    Robert
    Hi Robert,
    Maybe this will help, the cream layers are used to make a stencil which
    allows solder paste to be squeegied on to your board. EAGLE creates
    features on this layer for SMD components only.
    EAGLE doesn't place anything on the finish layers by default. In certain
    cases (Medical applications come to mind) you'll want all or part of
    your board finished in Gold or some other material. That is what this
    layer is for.
    EAGLE doesn't place anything on the glue layers by default. This layer
    is used to define spots on the board where glue need to be placed to
    hold down a component while it goes through the manufacturing process.
    The test layers are not used by default, and they could be used for any
    special testing features you might want to include on your board.
    The remaining layers are for documentation purposes and you can pretty
    much use them as you like.
    hth,
    Jorge Garcia
    rrioja wrote on Wed, 04 May 2011 08:04
    This is not a Eagle problem, but rather that you don't seem to understand
    how PC boards are made.  There are probably descriptions of the process on
    the net somewhere.  Once you underestand that, the layers will make more
    sense.  Also keep in mind that some of these layers are very rarely used.
    They are for historical or special purposes.
    Quote:
    What are the Finish layers for?  Are they for components made in
    Finland?
    Of course not.  That would be Finnish, not Finish.
    the Finish layers for?  Are they for components made in Finland?  The
    layer names Document, Reference, Docu and Info seem redundant.  What are
    they for and how are they different?  How about the Guide layer?  Will
    it guide me through the layer names better than Help Layer did?
    Thank you,
    Robert
    "Robert A. Rioja" <Robert@Unison-Travel.com> wrote in message
    news:ipplh9$48e$1@cheetah.cadsoft.de...
    31 tCream
    32 bCream
    33 tFinish
    34 bFinish
    35 tGlue
    36 bGlue
    37 tTest
    38 bTest
    47 Measures
    48 Document
    49 Reference
    51 tDocu
    52 bDocu
    97 Info
    98 Guide
    purpose we want?
    Robert
    Hi Robert,
    They do have purposes.
    Tcream is the top paste layer, Glue is the glue layer etc.
    The help file can give more complete descriptions.
    There are user defined layers also.
