EAGLE User Support (English) Bitmap import into schematic
  • Replies 29 replies
  • Views 5105 views
This is not at all urgent but maybe someone has an idea. Yesterday I had
a situation that happens a lot. I received a schematic that was in need
of some minor redesign. Only in PDF, like usual. So this time I wanted
to see if Eagle can do the redlines by importing a black&white bitmap
snapshot out of the PDF file. Then I wanted to draw the extra stuff in red.
Long story short in a graphics program the bitmap looked crisp and
clear. After importing it into an Eagle schematics window it was all
blurry like I had ten beers and with a bright yellow background. Useless
for any redline work, so I did it as usual with a red pen and my
scanner. Why is that rendering so badly in Eagle?
Regards, Joerg
    Joerg wrote on Tue, 10 May 2011 15:14
    Tilmann Reh wrote:
    Wish I knew how. The other thing that happens is that rendering in
    Eagle
    becomes very slow after import.
    Hi Joerg,
    The reason EAGLE becomes slower is because the bitmap import is creating a
    small rectangle for every pixel (or number of pixels, depending on scale
    factor you selected).  The idea is that you then use that as a guide and
    draw bigger objects (like one rectangle for 100's of the little pixels) on
    the layers you want (like tplace typically).  Then delete all the objects
    on the importing layers used.
    It's not perfect and not real polished.  But it will work--I've done it for
    a bunch of different logos.
    Good luck.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Joerg wrote:
    Tilmann Reh wrote:
    >> Joerg schrieb:
    >>> AFAIK Eagle will only take a bitmap. The background was white but
    >>> after importing into Eagle it turned bright yellow. That would be
    >>> ok (sort of) but the resolution was greatly reduced and so bad that
    >>> I had to do this sketch job by hand again.
    >> I don't understand your problem. Of course, EAGLE can take only
    >> "binary" pixels, no color shades, and the color it displays is the
    >> color assigned to the particular layer. There also is no background
    >> color.
    Hmm, the import-bmp.ulp just asked me to reduce the number of colors
    to 32 or something like that, so I did.
    >> So it's pretty obvious you need a true b/w image and convert that by
    >> on of the available programs. The result are rectangles in the given
    >> layer, representing single pixels resp. pixel lines of your image.
    >> The pixel/rectangle size is provided to the converter as a
    >> parameter. It's a simple 1:1 conversion, and in EAGLE the result
    >> looks /exactly/ identical to the bitmap source.
    Ok, so now I took a graph from the BC857 datasheet (source: NXP) and
    reduced the grayscale to pure black and white. Looks less nice after
    that and won't work for all cases but ok, man's gotta do what man's
    gotta do. The result is attached. This time it turned green image
    I had cut cut out little pieces and reduce the JPEG because the
    Cadsoft server limits post sizes. But the green and the white stripes
    still show, also the poor quality of the graph. Result is in the next
    post (hopefully ...)
    >> BTDT.
    Eagle becomes very slow after import.
    Joerg
    I believe your expectations are different to the way the ULP presents its
    results.
    Here are some points to assist you. To get it clear in your mind, practice
    with a monochrome bit image.
    A monochrome image has one (1) colour, black. The other colour (white) is
    'background' so when you are asked to select colors, only select the black.
    The background colour will be that of the editor.
    For each colour imported the ULP creates a layer and assigns a colour to it.
    For a monochrome image with one colour selected you get one new layer. In
    your case you selected two, the second being the green/yellow you see.
    Import a six colour image and you will get six new layers. By default they
    are layers 200 and up.
    Image choice is important. Ensure there is no anti-aliasing, like your BC857
    example. This creates a number of greys which will all get their own layer.
    As mentioned by others. The pixels of your image are changed to rectangle
    objects. The foggy look is a mix of the rectangles, the layer's fill pattern
    and the resolution of your source image.
    Hope this helps
    Warren
    Result file
    Tilmann Reh wrote:
    Joerg schrieb:
    >> AFAIK Eagle will only take a bitmap. The background was white but after
    >> importing into Eagle it turned bright yellow. That would be ok (sort of)
    >> but the resolution was greatly reduced and so bad that I had to do this
    I don't understand your problem. Of course, EAGLE can take only "binary"
    pixels, no color shades, and the color it displays is the color assigned
    to the particular layer. There also is no background color.
    Hmm, the import-bmp.ulp just asked me to reduce the number of colors to
    So it's pretty obvious you need a true b/w image and convert that by on
    of the available programs. The result are rectangles in the given layer,
    representing single pixels resp. pixel lines of your image. The
    pixel/rectangle size is provided to the converter as a parameter. It's a
    simple 1:1 conversion, and in EAGLE the result looks /exactly/ identical
    I had cut cut out little pieces and reduce the JPEG because the Cadsoft
    server limits post sizes. But the green and the white stripes still
    show, also the poor quality of the graph. Result is in the next post
    (hopefully ...)
    BTDT.
    Wish I knew how. The other thing that happens is that rendering in Eagle
    Regards, Joerg
    So it's pretty obvious you need a true b/w image and convert that by one
    BTDT.
    Tilmann
    >>>> Useless
    >>> i know similar problems in other programs if they fail to render the
    >>> alpha channel in a Bitmap picture.
    >>> Perhaps you have better effort, with a different fileformat,
    >>> or after adding a white background layer and flatten the layers
    >>> to the visible.
    >>> Gimp can do that.
    >> Maybe I should buy a green ink pen as well in case another reviewer has
    >> used red already image
    I think the problem is that EAGLE can not handle the bitmap image
    directly, i believe when it is imported it will be converted to polygons
    and vectors. but the yellow background is very interesting...no
    explanation for that!
    Once the bitmap was in Eagle it didn't look like vector but an
    assortment of coarse fuzzy blocks. Similar to what you see on the screen
    of a digital TV set shortly before the signal pixelates out, plus the
    fuzz overlay.
    The yellow was full pigmentation, like a school bus image
    Regards, Joerg
    >> to the visible.
    >> Gimp can do that.
    to the visible.
    Gimp can do that.
    Regards, Joerg
    to the visible.
    Gimp can do that.
    hth, good luck,
    Jonas Stein <news@jonasstein.de>
