EAGLE User Support (English) Move polygon
  • Subscribers 189 subscribers
  • Views 1799 views
Move polygon
I often have use for moving a polygon. Why not put it in context menu?
  • bradleyb
    bradleyb over 10 years ago
    I just learned how to do this myself. Just use the group tool, then ctrl-left click on one segment of the polygon. Now you can move or manipulate as with any other group.
    Morten Leikvoll wrote on Fri, 10 June 2011 05:10
    Sorry, I obviously suggested that before with same topic :d
    "Morten Leikvoll" <<private_email>pam> wrote in message
    news:issmuo$25p$<private_email>...
    menu?
    It's a good idea.  I'd like a way to move a polygon as it is without having
    to select every vertice.  So in other words, with some combination of
    modifier keys I could select any point on the polygon and the whole polygon
    would move as if I had selected it with group and moved the group.
    My polygons tend to be very complex and it is very time consuming to have
    to select the polygon and not the dense routing around it.
    As a side idea, it would be nice to be able to turn the display of
    different types of objects on and off.  Sort of like layers dialog but
    filtering on object type.  So show me all the polygons on the GND layer--no
    problem.  Show me all the traces, but not polygons, on the top layer--no
    problem.  Might be an alternate way to get the same result--at least it
    would be easy to select a polygon if all the traces were out of the way.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    Sorry, I obviously suggested that before with same topic image
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:issmuo$25p$1@cheetah.cadsoft.de...
