EAGLE User Support (English) The GROUP TOOL Needs to work different.
  • Views 556 views
HI,
I think that the GROUP TOOL ( And selections)  Needs to work differently!
Nearly all "drawing" type apps have a MOUSE SELECTION of objects on a
screen by just simply clicking down and dragging around the objects you
want to SELECT. I see no reason why Eaglecad can't work this way. It would
be more intuitive.
The idea is that by clicking on any blank area of the schematic or layout
windows a "selection rectangle" also called "marquee" will appear WITHOUT
the need to select the GROUP Tool first
We should also be able to ADD or REMOVE items from the "Current" selection
by using the COMMAND/CONTROL Key ( for Add )  or SHIFT+Command/CONTROL (
Remove ) or even SHIFT CLICK for MULTIPLE selections!
The selection rectangle COULD stay visible until its done. and the objects
should stay highlighted until done.
Then once we have a selection we can Right Click and a Contextual menu will
appear ( or just choose a tool button) for all the possible actions that
can be used, ( I.e Duplicate, Delete, Cut, Copy, Rotate, Lock/Unlock etc)
And especially a new feature that allows this selection to be GROUPED
TOGETHER by giving the selection a NAME. (e.g "Power Supply"), and this
NAME can be seen in the BOM or elsewhere.(i.e the properties window for a
part.)
This way is we say group items together they can stay grouped ( if a name
is given) and then work with all the standard functions but worked on as a
group,This would be great for repeating parts a of a circuit including the
BOARD LAYOUT!
If a group of items is selected, then some new features like
ALIGN/DISTRIBUTE would also come in handy especially for the BOARD LAYOUT.
Pressing ESC cancels the selection.
Parts could be tagged with a small icon that shows its locked.
What do you think?
Dave M
    Am 22.06.2011 03:50, schrieb James Morrison:
    eSilviu wrote on Sun, 19 June 2011 05:08
    >> "davem" group comand).
    Altium has that with "snippets" I think they call it.  That would be a
    great feature for circuits like RS232 transceivers and connectors that tend
    to be there for diag purposes in the corner of the board where things
    aren't too dense.  You lay it out once and then paste the schematic and
    board layout into your design.  If the layout bit just got stuck off to the
    side and you had to move it as a group to where you wanted that would be
    fine.
    So yes, I think that would be useful.  Seems very close to design reuse and
    maybe even hierarchy if implemented right.
    James.
    If eagle would have a hierarchy design that should be possible. Right
    now in a new design with eagle the first thing i do is to throw in the
    RS-232 and/or the USB interface.
    Joern Paschedag
    "davem" <<private_email>> wrote in message
    news:itjb1q$se5$<private_email>...
    Another idea is that why couldn't we treat a Group of parts as ONE
    PART,
    and keep this in the library!, This would be so useful!
    You start to sound like my proposal, where a local library should be
    created
    for the curent project, that should contain used components with only
    used
    footprints, and  any "macro" component defined in project (obvious with
    group comand).
    fine.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    "davem" <imix@bigpond.net.au> wrote in message
    news:itjb1q$se5$1@cheetah.cadsoft.de...
    Another idea is that why couldn't we treat a Group of parts as ONE PART,
    You start to sound like my proposal, where a local library should be created
    for the curent project, that should contain used components with only used
    group comand).
    Hi Olin & James,
    I just tested out the multiple selection ( Group) method and I got it to
    work, you have to select GROUP Again.
    Ok, That parts ok, but I still don't see why we need to select GROUP at
    all. I remember when I first used EagleCad this drove me nuts!
    Secondly, The main point is to be able to" REALLY" GROUP OBJECT as James
    has suggested especially for the use of SUB-CIRCUITS being grouped.
    It would be great to select part of a layout and DUPLICATE That , I would
    want the SCHEMATIC to AUTOMATICALLY create the grouped symbol as well. We
    could have it so that
    a) Groups are RELATED to the First Instance, so that to make a change to a
    part of the group you need to do this in the FIRST InStance, and all the
    other "Related" groups change.
    b) Grouped are NOT RELATED, so changes to any part of any of these groups
    do not automatically update. This would just be a simple time saver for
    duplicating repeating parts of a circuit.
    Dave M
    davem wrote on Sat, 18 June 2011 03:00
    differently!
    It does.
    After EDIT > GROUP left click instead of the usual right click rectangle
    drag.  You can specify a polygon with successive left clicks, then close
    the polygon and end the group definition with a right click.
    HI,
    differently!
    would be more intuitive.
    layout windows a "selection rectangle" also called "marquee" will appear
    WITHOUT the need to select the GROUP Tool first
    selection by using the COMMAND/CONTROL Key ( for Add )  or
    SHIFT+Command/CONTROL ( Remove ) or even SHIFT CLICK for MULTIPLE
    selections!
    objects should stay highlighted until done.
    will appear ( or just choose a tool button) for all the possible actions
    that can be used, ( I.e Duplicate, Delete, Cut, Copy, Rotate, Lock/Unlock
    etc)
    part.)
    name is given) and then work with all the standard functions but worked
    on as a group,This would be great for repeating parts a of a circuit
    including the BOARD LAYOUT!
    LAYOUT.
    What do you think?
    Hello Dave,
    I don't buy the idea that just because everyone else does it one way that
    EAGLE should necessarily change.  And the functionality that is there now
    works quite well for the intended purpose.  However, I think there is some
    value to looking for ways to further optimise things.
    I group things a lot so any improvements will have a big impact.
    I think there is value in having some default behaviour when no function is
    selected.  I think the CadSoft software guys are smart enough to be able to
    allow for mouse activation of the move and group commands based on mouse
    clicks and drags like you suggest.  If you start a click and drag away from
    any selectable object then you automatically start a group.  If you click
    and drag on an object then automatically start moving that part.  I don't
    think that breaks anything that is already in place and it would be a great
    help to newbies who are used to that functionality--I don't see a down
    side.
    Most don't know this, but you can build up a group through multiple
    selections.  You have to select group function then select components in
    group by drawing rectangle or multi-click polygon (the multi-click polygon
    selection is priceless--I don't know why other tools don't allow for it.
    This is one thing EAGLE does better than ANY other tool).  If you want to
    add more to the group then you have to select group again, hold down the
    shift key and then select more objects to add to group.
    This would be a lot better if the group command was sticky.  In other
    words, once I select the group command any selections I continue to make
    with the shift key down should be added to the uber-group I'm defining.
    There should be no need to continue to select the group command in this
    case.
    Additionally, if I have group active and I have the shift key down then
    individual objects I click on should be added to the group too.  Again, I
    don't see any way this breaks what is already done but only adds
    functionality that most people expect.  So no down side.
    Finally, I'd like to see the ability to glue a group together, like
    autocad.  Once I get my RS232 transceiver circuit placed and routed I could
    group it all and then glue it together so it moved as one unit.  We already
    have the smash command which could break it back out into its regular
    components.  That would be very handy.  It would be good to be able to give
    names to the groups as well so that you could access them from the command
    line with the move command (or via scripts).
    I would think this concept of a glued group would be very helpful in design
    heirarchy or design reuse.  Imagine you layout one channel of a design,
    glue it together, and then select a command for EAGLE to simply duplicate
    other channels just like the glued group.  That would be very useful and
    save lots of work.  The components of the second channel could be placed in
    the exact same manner (with an user-defined offset) and then routed
    identically.
    So, yes I agree there is more that can be done.  The current implementation
    of group could be enhanced in many ways.
    James.
